root/radiance/ray/src/rt/rview.c
Revision: 2.16
Committed: Wed Feb 14 15:18:09 1996 UTC (29 years, 4 months ago) by greg
Changes since 2.15: +1 -0 lines
1 /* Copyright (c) 1995 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rview.c - routines and variables for interactive view generation.
9 *
10 * 3/24/87
11 */
12
13 #include "ray.h"
14
15 #include "rpaint.h"
16
17 #include <signal.h>
18
19 #include <ctype.h>
20
21 VIEW ourview = STDVIEW; /* viewing parameters */
22 int hresolu, vresolu; /* image resolution */
23
24 int dimlist[MAXDIM]; /* sampling dimensions */
25 int ndims = 0; /* number of sampling dimensions */
26 int samplendx = 0; /* index for this sample */
27
28 int psample = 8; /* pixel sample size */
29 double maxdiff = .15; /* max. sample difference */
30
31 double exposure = 1.0; /* exposure for scene */
32
33 double dstrsrc = 0.0; /* square source distribution */
34 double shadthresh = .1; /* shadow threshold */
35 double shadcert = .25; /* shadow certainty */
36 int directrelay = 0; /* number of source relays */
37 int vspretest = 128; /* virtual source pretest density */
38 int directvis = 1; /* sources visible? */
39 double srcsizerat = 0.; /* maximum ratio source size/dist. */
40
41 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
42 double salbedo = 0.; /* global scattering albedo */
43 double seccg = 0.; /* global scattering eccentricity */
44 double ssampdist = 0.; /* scatter sampling distance */
45
46 double specthresh = .3; /* specular sampling threshold */
47 double specjitter = 1.; /* specular sampling jitter */
48
49 int backvis = 1; /* back face visibility */
50
51 int maxdepth = 4; /* maximum recursion depth */
52 double minweight = 1e-2; /* minimum ray weight */
53
54 COLOR ambval = BLKCOLOR; /* ambient value */
55 int ambvwt = 0; /* initial weight for ambient value */
56 double ambacc = 0.2; /* ambient accuracy */
57 int ambres = 8; /* ambient resolution */
58 int ambdiv = 32; /* ambient divisions */
59 int ambssamp = 0; /* ambient super-samples */
60 int ambounce = 0; /* ambient bounces */
61 char *amblist[128]; /* ambient include/exclude list */
62 int ambincl = -1; /* include == 1, exclude == 0 */
63
64 int greyscale = 0; /* map colors to brightness? */
65 char *devname = dev_default; /* output device name */
66
67 struct driver *dev = NULL; /* driver functions */
68
69 char rifname[128]; /* rad input file name */
70
71 VIEW oldview; /* previous view parameters */
72
73 PNODE ptrunk; /* the base of our image */
74 RECT pframe; /* current frame boundaries */
75 int pdepth; /* image depth in current frame */
76
77 static char *reserve_mem = NULL; /* pre-allocated reserve memory */
78
79 #define RESERVE_AMT 32768 /* amount of memory to reserve */
80
81 #define CTRL(c) ((c)-'@')
82
83
84 quit(code) /* quit program */
85 int code;
86 {
87 #ifdef MSTATS
88 if (code == 2 && errno == ENOMEM)
89 printmemstats(stderr);
90 #endif
91 devclose();
92 exit(code);
93 }
94
95
96 devopen(dname) /* open device driver */
97 char *dname;
98 {
99 extern char *progname, *octname;
100 char *id;
101 register int i;
102
103 id = octname!=NULL ? octname : progname;
104 /* check device table */
105 for (i = 0; devtable[i].name; i++)
106 if (!strcmp(dname, devtable[i].name))
107 if ((dev = (*devtable[i].init)(dname, id)) == NULL) {
108 sprintf(errmsg, "cannot initialize %s", dname);
109 error(USER, errmsg);
110 } else
111 return;
112 #ifndef NIX
113 /* not there, try exec */
114 if ((dev = comm_init(dname, id)) == NULL) {
115 sprintf(errmsg, "cannot start device \"%s\"", dname);
116 error(USER, errmsg);
117 }
118 #endif
119 }
120
121
122 devclose() /* close our device */
123 {
124 if (dev != NULL)
125 (*dev->close)();
126 dev = NULL;
127 }
128
129
130 printdevices() /* print list of output devices */
131 {
132 register int i;
133
134 for (i = 0; devtable[i].name; i++)
135 printf("%-16s # %s\n", devtable[i].name, devtable[i].descrip);
136 }
137
138
139 rview() /* do a view */
140 {
141 char buf[32];
142
143 devopen(devname); /* open device */
144 newimage(); /* start image (calls fillreserves) */
145
146 for ( ; ; ) { /* quit in command() */
147 while (hresolu <= 1<<pdepth && vresolu <= 1<<pdepth)
148 command("done: ");
149 while (reserve_mem == NULL)
150 command("out of memory: ");
151 errno = 0;
152 if (hresolu <= psample<<pdepth && vresolu <= psample<<pdepth) {
153 sprintf(buf, "%d sampling...\n", 1<<pdepth);
154 (*dev->comout)(buf);
155 rsample();
156 } else {
157 sprintf(buf, "%d refining...\n", 1<<pdepth);
158 (*dev->comout)(buf);
159 refine(&ptrunk, 0, 0, hresolu, vresolu, pdepth+1);
160 }
161 if (errno == ENOMEM) /* ran out of memory */
162 freereserves();
163 else if (dev->inpready) /* noticed some input */
164 command(": ");
165 else /* finished this depth */
166 pdepth++;
167 }
168 }
169
170
171 fillreserves() /* fill memory reserves */
172 {
173 if (reserve_mem != NULL)
174 return;
175 reserve_mem = malloc(RESERVE_AMT);
176 }
177
178
179 freereserves() /* free memory reserves */
180 {
181 if (reserve_mem == NULL)
182 return;
183 free(reserve_mem);
184 reserve_mem = NULL;
185 }
186
187
188 command(prompt) /* get/execute command */
189 char *prompt;
190 {
191 #define badcom(s) strncmp(s, inpbuf, args-inpbuf-1)
192 char inpbuf[256];
193 char *args;
194 again:
195 (*dev->comin)(inpbuf, prompt); /* get command + arguments */
196 for (args = inpbuf; *args && *args != ' '; args++)
197 ;
198 if (*args) *args++ = '\0';
199 else *++args = '\0';
200
201 switch (inpbuf[0]) {
202 case 'f': /* new frame (or free mem.) */
203 if (badcom("frame")) {
204 if (badcom("free"))
205 goto commerr;
206 free_objmem();
207 break;
208 }
209 getframe(args);
210 break;
211 case 'v': /* view */
212 if (badcom("view"))
213 goto commerr;
214 getview(args);
215 break;
216 case 'l': /* last view */
217 if (badcom("last"))
218 goto commerr;
219 lastview(args);
220 break;
221 case 'V': /* save view */
222 if (badcom("V"))
223 goto commerr;
224 saveview(args);
225 break;
226 case 'L': /* load view */
227 if (badcom("L"))
228 goto commerr;
229 loadview(args);
230 break;
231 case 'e': /* exposure */
232 if (badcom("exposure"))
233 goto commerr;
234 getexposure(args);
235 break;
236 case 's': /* set a parameter */
237 if (badcom("set")) {
238 #ifdef SIGTSTP
239 if (!badcom("stop"))
240 goto dostop;
241 #endif
242 goto commerr;
243 }
244 setparam(args);
245 break;
246 case 'n': /* new picture */
247 if (badcom("new"))
248 goto commerr;
249 newimage();
250 break;
251 case 't': /* trace a ray */
252 if (badcom("trace"))
253 goto commerr;
254 traceray(args);
255 break;
256 case 'a': /* aim camera */
257 if (badcom("aim"))
258 goto commerr;
259 getaim(args);
260 break;
261 case 'm': /* move camera (or memstats) */
262 if (badcom("move"))
263 #ifdef MSTATS
264 {
265 if (badcom("memory"))
266 goto commerr;
267 printmemstats(stderr);
268 break;
269 }
270 #else
271 goto commerr;
272 #endif
273 getmove(args);
274 break;
275 case 'r': /* rotate/repaint */
276 if (badcom("rotate")) {
277 if (badcom("repaint")) {
278 if (badcom("redraw"))
279 goto commerr;
280 redraw();
281 break;
282 }
283 getrepaint(args);
284 break;
285 }
286 getrotate(args);
287 break;
288 case 'p': /* pivot view */
289 if (badcom("pivot")) {
290 if (badcom("pause"))
291 goto commerr;
292 goto again;
293 }
294 getpivot(args);
295 break;
296 case CTRL('R'): /* redraw */
297 redraw();
298 break;
299 case 'w': /* write */
300 if (badcom("write"))
301 goto commerr;
302 writepict(args);
303 break;
304 case 'q': /* quit */
305 if (badcom("quit"))
306 goto commerr;
307 quit(0);
308 case CTRL('C'): /* interrupt */
309 goto again;
310 #ifdef SIGTSTP
311 case CTRL('Z'):; /* stop */
312 dostop:
313 devclose();
314 kill(0, SIGTSTP);
315 /* pc stops here */
316 devopen(devname);
317 redraw();
318 break;
319 #endif
320 case '\0': /* continue */
321 break;
322 default:;
323 commerr:
324 if (iscntrl(inpbuf[0]))
325 sprintf(errmsg, "^%c: unknown control",
326 inpbuf[0]|0100);
327 else
328 sprintf(errmsg, "%s: unknown command", inpbuf);
329 error(COMMAND, errmsg);
330 break;
331 }
332 #undef badcom
333 }
334
335
336 rsample() /* sample the image */
337 {
338 int xsiz, ysiz, y;
339 RECT r;
340 PNODE *p;
341 register RECT *rl;
342 register PNODE **pl;
343 register int x;
344 /*
345 * We initialize the bottom row in the image at our current
346 * resolution. During sampling, we check super-pixels to the
347 * right and above by calling bigdiff(). If there is a significant
348 * difference, we subsample the super-pixels. The testing process
349 * includes initialization of the next row.
350 */
351 xsiz = (((long)(pframe.r-pframe.l)<<pdepth)+hresolu-1) / hresolu;
352 ysiz = (((long)(pframe.u-pframe.d)<<pdepth)+vresolu-1) / vresolu;
353 rl = (RECT *)malloc(xsiz*sizeof(RECT));
354 if (rl == NULL)
355 return;
356 pl = (PNODE **)malloc(xsiz*sizeof(PNODE *));
357 if (pl == NULL) {
358 free((char *)rl);
359 return;
360 }
361 /*
362 * Initialize the bottom row.
363 */
364 rl[0].l = rl[0].d = 0;
365 rl[0].r = hresolu; rl[0].u = vresolu;
366 pl[0] = findrect(pframe.l, pframe.d, &ptrunk, rl, pdepth);
367 for (x = 1; x < xsiz; x++) {
368 rl[x].l = rl[x].d = 0;
369 rl[x].r = hresolu; rl[x].u = vresolu;
370 pl[x] = findrect(pframe.l+((x*hresolu)>>pdepth),
371 pframe.d, &ptrunk, rl+x, pdepth);
372 }
373 /* sample the image */
374 for (y = 0; /* y < ysiz */ ; y++) {
375 for (x = 0; x < xsiz-1; x++) {
376 if (dev->inpready || errno == ENOMEM)
377 goto escape;
378 /*
379 * Test super-pixel to the right.
380 */
381 if (pl[x] != pl[x+1] && bigdiff(pl[x]->v,
382 pl[x+1]->v, maxdiff)) {
383 refine(pl[x], rl[x].l, rl[x].d,
384 rl[x].r, rl[x].u, 1);
385 refine(pl[x+1], rl[x+1].l, rl[x+1].d,
386 rl[x+1].r, rl[x+1].u, 1);
387 }
388 }
389 if (y >= ysiz-1)
390 break;
391 for (x = 0; x < xsiz; x++) {
392 if (dev->inpready || errno == ENOMEM)
393 goto escape;
394 /*
395 * Find super-pixel at this position in next row.
396 */
397 r.l = r.d = 0;
398 r.r = hresolu; r.u = vresolu;
399 p = findrect(pframe.l+((x*hresolu)>>pdepth),
400 pframe.d+(((y+1)*vresolu)>>pdepth),
401 &ptrunk, &r, pdepth);
402 /*
403 * Test super-pixel in next row.
404 */
405 if (pl[x] != p && bigdiff(pl[x]->v, p->v, maxdiff)) {
406 refine(pl[x], rl[x].l, rl[x].d,
407 rl[x].r, rl[x].u, 1);
408 refine(p, r.l, r.d, r.r, r.u, 1);
409 }
410 /*
411 * Copy into super-pixel array.
412 */
413 rl[x].l = r.l; rl[x].d = r.d;
414 rl[x].r = r.r; rl[x].u = r.u;
415 pl[x] = p;
416 }
417 }
418 escape:
419 free((char *)rl);
420 free((char *)pl);
421 }
422
423
424 int
425 refine(p, xmin, ymin, xmax, ymax, pd) /* refine a node */
426 register PNODE *p;
427 int xmin, ymin, xmax, ymax;
428 int pd;
429 {
430 int growth;
431 int mx, my;
432 int i;
433
434 if (dev->inpready) /* quit for input */
435 return(0);
436
437 if (pd <= 0) /* depth limit */
438 return(0);
439
440 mx = (xmin + xmax) >> 1;
441 my = (ymin + ymax) >> 1;
442 growth = 0;
443
444 if (p->kid == NULL) { /* subdivide */
445
446 if ((p->kid = newptree()) == NULL)
447 return(0);
448 /*
449 * The following paint order can leave a black pixel
450 * if redraw() is called in (*dev->paintr)().
451 */
452 if (p->x >= mx && p->y >= my)
453 pcopy(p, p->kid+UR);
454 else
455 paint(p->kid+UR, mx, my, xmax, ymax);
456 if (p->x < mx && p->y >= my)
457 pcopy(p, p->kid+UL);
458 else
459 paint(p->kid+UL, xmin, my, mx, ymax);
460 if (p->x >= mx && p->y < my)
461 pcopy(p, p->kid+DR);
462 else
463 paint(p->kid+DR, mx, ymin, xmax, my);
464 if (p->x < mx && p->y < my)
465 pcopy(p, p->kid+DL);
466 else
467 paint(p->kid+DL, xmin, ymin, mx, my);
468
469 growth++;
470 }
471 /* do children */
472 if (mx > pframe.l) {
473 if (my > pframe.d)
474 growth += refine(p->kid+DL, xmin, ymin, mx, my, pd-1);
475 if (my < pframe.u)
476 growth += refine(p->kid+UL, xmin, my, mx, ymax, pd-1);
477 }
478 if (mx < pframe.r) {
479 if (my > pframe.d)
480 growth += refine(p->kid+DR, mx, ymin, xmax, my, pd-1);
481 if (my < pframe.u)
482 growth += refine(p->kid+UR, mx, my, xmax, ymax, pd-1);
483 }
484 /* recompute sum */
485 if (growth) {
486 setcolor(p->v, 0.0, 0.0, 0.0);
487 for (i = 0; i < 4; i++)
488 addcolor(p->v, p->kid[i].v);
489 scalecolor(p->v, 0.25);
490 }
491 return(growth);
492 }
