root/radiance/ray/src/rt/rview.c
Revision: 2.14
Committed: Wed Dec 21 09:52:07 1994 UTC (30 years, 6 months ago) by greg
Changes since 2.13: +2 -0 lines
added -bv option for back face visibility (normally on)
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rview.c - routines and variables for interactive view generation.
9 *
10 * 3/24/87
11 */
12
13 #include "ray.h"
14
15 #include "rpaint.h"
16
17 #include <signal.h>
18
19 #include <ctype.h>
20
21 VIEW ourview = STDVIEW; /* viewing parameters */
22 int hresolu, vresolu; /* image resolution */
23
24 int dimlist[MAXDIM]; /* sampling dimensions */
25 int ndims = 0; /* number of sampling dimensions */
26 int samplendx = 0; /* index for this sample */
27
28 int psample = 8; /* pixel sample size */
29 double maxdiff = .15; /* max. sample difference */
30
31 double exposure = 1.0; /* exposure for scene */
32
33 double dstrsrc = 0.0; /* square source distribution */
34 double shadthresh = .1; /* shadow threshold */
35 double shadcert = .25; /* shadow certainty */
36 int directrelay = 0; /* number of source relays */
37 int vspretest = 128; /* virtual source pretest density */
38 int directvis = 1; /* sources visible? */
39 double srcsizerat = 0.; /* maximum ratio source size/dist. */
40
41 double specthresh = .3; /* specular sampling threshold */
42 double specjitter = 1.; /* specular sampling jitter */
43
44 int backvis = 1; /* back face visibility */
45
46 int maxdepth = 4; /* maximum recursion depth */
47 double minweight = 1e-2; /* minimum ray weight */
48
49 COLOR ambval = BLKCOLOR; /* ambient value */
50 double ambacc = 0.2; /* ambient accuracy */
51 int ambres = 8; /* ambient resolution */
52 int ambdiv = 32; /* ambient divisions */
53 int ambssamp = 0; /* ambient super-samples */
54 int ambounce = 0; /* ambient bounces */
55 char *amblist[128]; /* ambient include/exclude list */
56 int ambincl = -1; /* include == 1, exclude == 0 */
57
58 int greyscale = 0; /* map colors to brightness? */
59 char *devname = dev_default; /* output device name */
60
61 struct driver *dev = NULL; /* driver functions */
62
63 char rifname[128]; /* rad input file name */
64
65 VIEW oldview; /* previous view parameters */
66
67 PNODE ptrunk; /* the base of our image */
68 RECT pframe; /* current frame boundaries */
69 int pdepth; /* image depth in current frame */
70
71 static char *reserve_mem = NULL; /* pre-allocated reserve memory */
72
73 #define RESERVE_AMT 32768 /* amount of memory to reserve */
74
75 #define CTRL(c) ((c)-'@')
76
77
78 quit(code) /* quit program */
79 int code;
80 {
81 #ifdef MSTATS
82 if (code == 2 && errno == ENOMEM)
83 printmemstats(stderr);
84 #endif
85 devclose();
86 exit(code);
87 }
88
89
90 devopen(dname) /* open device driver */
91 char *dname;
92 {
93 extern char *progname, *octname;
94 char *id;
95 register int i;
96
97 id = octname!=NULL ? octname : progname;
98 /* check device table */
99 for (i = 0; devtable[i].name; i++)
100 if (!strcmp(dname, devtable[i].name))
101 if ((dev = (*devtable[i].init)(dname, id)) == NULL) {
102 sprintf(errmsg, "cannot initialize %s", dname);
103 error(USER, errmsg);
104 } else
105 return;
106 #ifndef NIX
107 /* not there, try exec */
108 if ((dev = comm_init(dname, id)) == NULL) {
109 sprintf(errmsg, "cannot start device \"%s\"", dname);
110 error(USER, errmsg);
111 }
112 #endif
113 }
114
115
116 devclose() /* close our device */
117 {
118 if (dev != NULL)
119 (*dev->close)();
120 dev = NULL;
121 }
122
123
124 printdevices() /* print list of output devices */
125 {
126 register int i;
127
128 for (i = 0; devtable[i].name; i++)
129 printf("%-16s # %s\n", devtable[i].name, devtable[i].descrip);
130 }
131
132
133 rview() /* do a view */
134 {
135 char buf[32];
136
137 devopen(devname); /* open device */
138 newimage(); /* start image (calls fillreserves) */
139
140 for ( ; ; ) { /* quit in command() */
141 while (hresolu <= 1<<pdepth && vresolu <= 1<<pdepth)
142 command("done: ");
143 while (reserve_mem == NULL)
144 command("out of memory: ");
145 errno = 0;
146 if (hresolu <= psample<<pdepth && vresolu <= psample<<pdepth) {
147 sprintf(buf, "%d sampling...\n", 1<<pdepth);
148 (*dev->comout)(buf);
149 rsample();
150 } else {
151 sprintf(buf, "%d refining...\n", 1<<pdepth);
152 (*dev->comout)(buf);
153 refine(&ptrunk, 0, 0, hresolu, vresolu, pdepth+1);
154 }
155 if (errno == ENOMEM) /* ran out of memory */
156 freereserves();
157 else if (dev->inpready) /* noticed some input */
158 command(": ");
159 else /* finished this depth */
160 pdepth++;
161 }
162 }
163
164
165 fillreserves() /* fill memory reserves */
166 {
167 if (reserve_mem != NULL)
168 return;
169 reserve_mem = malloc(RESERVE_AMT);
170 }
171
172
173 freereserves() /* free memory reserves */
174 {
175 if (reserve_mem == NULL)
176 return;
177 free(reserve_mem);
178 reserve_mem = NULL;
179 }
180
181
182 command(prompt) /* get/execute command */
183 char *prompt;
184 {
185 #define badcom(s) strncmp(s, inpbuf, args-inpbuf-1)
186 char inpbuf[256];
187 char *args;
188 again:
189 (*dev->comin)(inpbuf, prompt); /* get command + arguments */
190 for (args = inpbuf; *args && *args != ' '; args++)
191 ;
192 if (*args) *args++ = '\0';
193 else *++args = '\0';
194
195 switch (inpbuf[0]) {
196 case 'f': /* new frame (or free mem.) */
197 if (badcom("frame")) {
198 if (badcom("free"))
199 goto commerr;
200 free_objmem();
201 break;
202 }
203 getframe(args);
204 break;
205 case 'v': /* view */
206 if (badcom("view"))
207 goto commerr;
208 getview(args);
209 break;
210 case 'l': /* last view */
211 if (badcom("last"))
212 goto commerr;
213 lastview(args);
214 break;
215 case 'V': /* save view */
216 if (badcom("V"))
217 goto commerr;
218 saveview(args);
219 break;
220 case 'L': /* load view */
221 if (badcom("L"))
222 goto commerr;
223 loadview(args);
224 break;
225 case 'e': /* exposure */
226 if (badcom("exposure"))
227 goto commerr;
228 getexposure(args);
229 break;
230 case 's': /* set a parameter */
231 if (badcom("set")) {
232 #ifdef SIGTSTP
233 if (!badcom("stop"))
234 goto dostop;
235 #endif
236 goto commerr;
237 }
238 setparam(args);
239 break;
240 case 'n': /* new picture */
241 if (badcom("new"))
242 goto commerr;
243 newimage();
244 break;
245 case 't': /* trace a ray */
246 if (badcom("trace"))
247 goto commerr;
248 traceray(args);
249 break;
250 case 'a': /* aim camera */
251 if (badcom("aim"))
252 goto commerr;
253 getaim(args);
254 break;
255 case 'm': /* move camera (or memstats) */
256 if (badcom("move"))
257 #ifdef MSTATS
258 {
259 if (badcom("memory"))
260 goto commerr;
261 printmemstats(stderr);
262 break;
263 }
264 #else
265 goto commerr;
266 #endif
267 getmove(args);
268 break;
269 case 'r': /* rotate/repaint */
270 if (badcom("rotate")) {
271 if (badcom("repaint")) {
272 if (badcom("redraw"))
273 goto commerr;
274 redraw();
275 break;
276 }
277 getrepaint(args);
278 break;
279 }
280 getrotate(args);
281 break;
282 case 'p': /* pivot view */
283 if (badcom("pivot")) {
284 if (badcom("pause"))
285 goto commerr;
286 goto again;
287 }
288 getpivot(args);
289 break;
290 case CTRL('R'): /* redraw */
291 redraw();
292 break;
293 case 'w': /* write */
294 if (badcom("write"))
295 goto commerr;
296 writepict(args);
297 break;
298 case 'q': /* quit */
299 if (badcom("quit"))
300 goto commerr;
301 quit(0);
302 case CTRL('C'): /* interrupt */
303 goto again;
304 #ifdef SIGTSTP
305 case CTRL('Z'):; /* stop */
306 dostop:
307 devclose();
308 kill(0, SIGTSTP);
309 /* pc stops here */
310 devopen(devname);
311 redraw();
312 break;
313 #endif
314 case '\0': /* continue */
315 break;
316 default:;
317 commerr:
318 if (iscntrl(inpbuf[0]))
319 sprintf(errmsg, "^%c: unknown control",
320 inpbuf[0]|0100);
321 else
322 sprintf(errmsg, "%s: unknown command", inpbuf);
323 error(COMMAND, errmsg);
324 break;
325 }
326 #undef badcom
327 }
328
329
330 rsample() /* sample the image */
331 {
332 int xsiz, ysiz, y;
333 RECT r;
334 PNODE *p;
335 register RECT *rl;
336 register PNODE **pl;
337 register int x;
338 /*
339 * We initialize the bottom row in the image at our current
340 * resolution. During sampling, we check super-pixels to the
341 * right and above by calling bigdiff(). If there is a significant
342 * difference, we subsample the super-pixels. The testing process
343 * includes initialization of the next row.
344 */
345 xsiz = (((long)(pframe.r-pframe.l)<<pdepth)+hresolu-1) / hresolu;
346 ysiz = (((long)(pframe.u-pframe.d)<<pdepth)+vresolu-1) / vresolu;
347 rl = (RECT *)malloc(xsiz*sizeof(RECT));
348 if (rl == NULL)
349 return;
350 pl = (PNODE **)malloc(xsiz*sizeof(PNODE *));
351 if (pl == NULL) {
352 free((char *)rl);
353 return;
354 }
355 /*
356 * Initialize the bottom row.
357 */
358 rl[0].l = rl[0].d = 0;
359 rl[0].r = hresolu; rl[0].u = vresolu;
360 pl[0] = findrect(pframe.l, pframe.d, &ptrunk, rl, pdepth);
361 for (x = 1; x < xsiz; x++) {
362 rl[x].l = rl[x].d = 0;
363 rl[x].r = hresolu; rl[x].u = vresolu;
364 pl[x] = findrect(pframe.l+((x*hresolu)>>pdepth),
365 pframe.d, &ptrunk, rl+x, pdepth);
366 }
367 /* sample the image */
368 for (y = 0; /* y < ysiz */ ; y++) {
369 for (x = 0; x < xsiz-1; x++) {
370 if (dev->inpready || errno == ENOMEM)
371 goto escape;
372 /*
373 * Test super-pixel to the right.
374 */
375 if (pl[x] != pl[x+1] && bigdiff(pl[x]->v,
376 pl[x+1]->v, maxdiff)) {
377 refine(pl[x], rl[x].l, rl[x].d,
378 rl[x].r, rl[x].u, 1);
379 refine(pl[x+1], rl[x+1].l, rl[x+1].d,
380 rl[x+1].r, rl[x+1].u, 1);
381 }
382 }
383 if (y >= ysiz-1)
384 break;
385 for (x = 0; x < xsiz; x++) {
386 if (dev->inpready || errno == ENOMEM)
387 goto escape;
388 /*
389 * Find super-pixel at this position in next row.
390 */
391 r.l = r.d = 0;
392 r.r = hresolu; r.u = vresolu;
393 p = findrect(pframe.l+((x*hresolu)>>pdepth),
394 pframe.d+(((y+1)*vresolu)>>pdepth),
395 &ptrunk, &r, pdepth);
396 /*
397 * Test super-pixel in next row.
398 */
399 if (pl[x] != p && bigdiff(pl[x]->v, p->v, maxdiff)) {
400 refine(pl[x], rl[x].l, rl[x].d,
401 rl[x].r, rl[x].u, 1);
402 refine(p, r.l, r.d, r.r, r.u, 1);
403 }
404 /*
405 * Copy into super-pixel array.
406 */
407 rl[x].l = r.l; rl[x].d = r.d;
408 rl[x].r = r.r; rl[x].u = r.u;
409 pl[x] = p;
410 }
411 }
412 escape:
413 free((char *)rl);
414 free((char *)pl);
415 }
416
417
418 int
419 refine(p, xmin, ymin, xmax, ymax, pd) /* refine a node */
420 register PNODE *p;
421 int xmin, ymin, xmax, ymax;
422 int pd;
423 {
424 int growth;
425 int mx, my;
426 int i;
427
428 if (dev->inpready) /* quit for input */
429 return(0);
430
431 if (pd <= 0) /* depth limit */
432 return(0);
433
434 mx = (xmin + xmax) >> 1;
435 my = (ymin + ymax) >> 1;
436 growth = 0;
437
438 if (p->kid == NULL) { /* subdivide */
439
440 if ((p->kid = newptree()) == NULL)
441 return(0);
442 /*
443 * The following paint order can leave a black pixel
444 * if redraw() is called in (*dev->paintr)().
445 */
446 if (p->x >= mx && p->y >= my)
447 pcopy(p, p->kid+UR);
448 else
449 paint(p->kid+UR, mx, my, xmax, ymax);
450 if (p->x < mx && p->y >= my)
451 pcopy(p, p->kid+UL);
452 else
453 paint(p->kid+UL, xmin, my, mx, ymax);
454 if (p->x >= mx && p->y < my)
455 pcopy(p, p->kid+DR);
456 else
457 paint(p->kid+DR, mx, ymin, xmax, my);
458 if (p->x < mx && p->y < my)
459 pcopy(p, p->kid+DL);
460 else
461 paint(p->kid+DL, xmin, ymin, mx, my);
462
463 growth++;
464 }
465 /* do children */
466 if (mx > pframe.l) {
467 if (my > pframe.d)
468 growth += refine(p->kid+DL, xmin, ymin, mx, my, pd-1);
469 if (my < pframe.u)
470 growth += refine(p->kid+UL, xmin, my, mx, ymax, pd-1);
471 }
472 if (mx < pframe.r) {
473 if (my > pframe.d)
474 growth += refine(p->kid+DR, mx, ymin, xmax, my, pd-1);
475 if (my < pframe.u)
476 growth += refine(p->kid+UR, mx, my, xmax, ymax, pd-1);
477 }
478 /* recompute sum */
479 if (growth) {
480 setcolor(p->v, 0.0, 0.0, 0.0);
481 for (i = 0; i < 4; i++)
482 addcolor(p->v, p->kid[i].v);
483 scalecolor(p->v, 0.25);
484 }
485 return(growth);
486 }
