root/radiance/ray/src/rt/rview.c
Revision: 1.9
Committed: Mon Jan 8 13:38:12 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.8: +15 -17 lines
1 /* Copyright (c) 1987 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rview.c - routines and variables for interactive view generation.
9 *
10 * 3/24/87
11 */
12
13 #include "standard.h"
14
15 #include "color.h"
16
17 #include "rpaint.h"
18
19 #include <signal.h>
20
21 #include <ctype.h>
22
23 VIEW ourview = STDVIEW; /* viewing parameters */
24 int hresolu, vresolu; /* image resolution */
25
26 int psample = 8; /* pixel sample size */
27 double maxdiff = .15; /* max. sample difference */
28
29 double exposure = 1.0; /* exposure for scene */
30
31 double dstrsrc = 0.0; /* square source distribution */
32 double shadthresh = .1; /* shadow threshold */
33 double shadcert = .25; /* shadow certainty */
34
35 int maxdepth = 4; /* maximum recursion depth */
36 double minweight = 1e-2; /* minimum ray weight */
37
38 COLOR ambval = BLKCOLOR; /* ambient value */
39 double ambacc = 0.2; /* ambient accuracy */
40 int ambres = 8; /* ambient resolution */
41 int ambdiv = 32; /* ambient divisions */
42 int ambssamp = 0; /* ambient super-samples */
43 int ambounce = 0; /* ambient bounces */
44 char *amblist[128]; /* ambient include/exclude list */
45 int ambincl = -1; /* include == 1, exclude == 0 */
46
47 int greyscale = 0; /* map colors to brightness? */
48 char *devname = "X"; /* output device name */
49
50 struct driver *dev = NULL; /* driver functions */
51
52 VIEW oldview; /* previous view parameters */
53
54 PNODE ptrunk; /* the base of our image */
55 RECT pframe; /* current frame boundaries */
56 int pdepth; /* image depth in current frame */
57
58 #define CTRL(c) ('c'-'@')
59
60
61 quit(code) /* quit program */
62 int code;
63 {
64 devclose();
65 exit(code);
66 }
67
68
69 devopen(dname) /* open device driver */
70 char *dname;
71 {
72 extern char *progname, *octname;
73 char *id;
74 register int i;
75
76 id = octname!=NULL ? octname : progname;
77 /* check device table */
78 for (i = 0; devtable[i].name; i++)
79 if (!strcmp(dname, devtable[i].name))
80 if ((dev = (*devtable[i].init)(dname, id)) == NULL) {
81 sprintf(errmsg, "cannot initialize %s", dname);
82 error(USER, errmsg);
83 } else
84 return;
85 /* not there, try exec */
86 if ((dev = comm_init(dname, id)) == NULL) {
87 sprintf(errmsg, "cannot start device \"%s\"", dname);
88 error(USER, errmsg);
89 }
90 }
91
92
93 devclose() /* close our device */
94 {
95 if (dev != NULL)
96 (*dev->close)();
97 dev = NULL;
98 }
99
100
101 printdevices() /* print list of output devices */
102 {
103 register int i;
104
105 for (i = 0; devtable[i].name; i++)
106 printf("%-16s # %s\n", devtable[i].name, devtable[i].descrip);
107 }
108
109
110 rview() /* do a view */
111 {
112 char buf[32];
113
114 devopen(devname); /* open device */
115 newimage(); /* set up image */
116
117 for ( ; ; ) { /* quit in command() */
118 while (hresolu <= 1<<pdepth &&
119 vresolu <= 1<<pdepth)
120 command("done: ");
121
122 if (hresolu <= psample<<pdepth &&
123 vresolu <= psample<<pdepth) {
124 sprintf(buf, "%d sampling...\n", 1<<pdepth);
125 (*dev->comout)(buf);
126 rsample();
127 } else {
128 sprintf(buf, "%d refining...\n", 1<<pdepth);
129 (*dev->comout)(buf);
130 refine(&ptrunk, 0, 0, hresolu, vresolu, pdepth+1);
131 }
132 if (dev->inpready)
133 command(": ");
134 else
135 pdepth++;
136 }
137 }
138
139
140 command(prompt) /* get/execute command */
141 char *prompt;
142 {
143 #define badcom(s) strncmp(s, inpbuf, args-inpbuf-1)
144 double atof();
145 char inpbuf[256];
146 char *args;
147 again:
148 (*dev->comout)(prompt); /* get command + arguments */
149 (*dev->comin)(inpbuf);
150 for (args = inpbuf; *args && *args != ' '; args++)
151 ;
152 if (*args) *args++ = '\0';
153 else *++args = '\0';
154
155 switch (inpbuf[0]) {
156 case 'f': /* new frame */
157 if (badcom("frame"))
158 goto commerr;
159 getframe(args);
160 break;
161 case 'v': /* view */
162 if (badcom("view"))
163 goto commerr;
164 getview(args);
165 break;
166 case 'l': /* last view */
167 if (badcom("last"))
168 goto commerr;
169 lastview(args);
170 break;
171 case 'e': /* exposure */
172 if (badcom("exposure"))
173 goto commerr;
174 getexposure(args);
175 break;
176 case 's': /* set a parameter */
177 if (badcom("set"))
178 goto commerr;
179 setparam(args);
180 break;
181 case 'n': /* new picture */
182 if (badcom("new"))
183 goto commerr;
184 newimage();
185 break;
186 case 't': /* trace a ray */
187 if (badcom("trace"))
188 goto commerr;
189 traceray(args);
190 break;
191 case 'a': /* aim camera */
192 if (badcom("aim"))
193 goto commerr;
194 getaim(args);
195 break;
196 case 'm': /* move camera */
197 if (badcom("move"))
198 goto commerr;
199 getmove(args);
200 break;
201 case 'r': /* rotate/repaint */
202 if (badcom("rotate")) {
203 if (badcom("repaint"))
204 goto commerr;
205 getrepaint(args);
206 break;
207 }
208 getrotate(args);
209 break;
210 case 'p': /* pivot view */
211 if (badcom("pivot"))
212 goto commerr;
213 getpivot(args);
214 break;
215 case CTRL(R): /* redraw */
216 redraw();
217 break;
218 case 'w': /* write */
219 if (badcom("write"))
220 goto commerr;
221 writepict(args);
222 break;
223 case 'q': /* quit */
224 if (badcom("quit"))
225 goto commerr;
226 quit(0);
227 case CTRL(C): /* interrupt */
228 goto again;
229 #ifdef SIGTSTP
230 case CTRL(Z): /* stop */
231 devclose();
232 kill(0, SIGTSTP);
233 /* pc stops here */
234 devopen(devname);
235 redraw();
236 break;
237 #endif
238 case '\0': /* continue */
239 break;
240 default:;
241 commerr:
242 if (iscntrl(inpbuf[0]))
243 sprintf(errmsg, "^%c: unknown control",
244 inpbuf[0]|0100);
245 else
246 sprintf(errmsg, "%s: unknown command", inpbuf);
247 error(COMMAND, errmsg);
248 break;
249 }
250 #undef badcom
251 }
252
253
254 rsample() /* sample the image */
255 {
256 int xsiz, ysiz, y;
257 RECT r;
258 PNODE *p;
259 register RECT *rl;
260 register PNODE **pl;
261 register int x;
262 /*
263 * We initialize the bottom row in the image at our current
264 * resolution. During sampling, we check super-pixels to the
265 * right and above by calling bigdiff(). If there is a significant
266 * difference, we subsample the super-pixels. The testing process
267 * includes initialization of the next row.
268 */
269 xsiz = (((pframe.r-pframe.l)<<pdepth)+hresolu-1) / hresolu;
270 ysiz = (((pframe.u-pframe.d)<<pdepth)+vresolu-1) / vresolu;
271 rl = (RECT *)malloc(xsiz*sizeof(RECT));
272 pl = (PNODE **)malloc(xsiz*sizeof(PNODE *));
273 if (rl == NULL || pl == NULL)
274 error(SYSTEM, "out of memory in rsample");
275 /*
276 * Initialize the bottom row.
277 */
278 rl[0].l = rl[0].d = 0;
279 rl[0].r = hresolu; rl[0].u = vresolu;
280 pl[0] = findrect(pframe.l, pframe.d, &ptrunk, rl, pdepth);
281 for (x = 1; x < xsiz; x++) {
282 rl[x].l = rl[x].d = 0;
283 rl[x].r = hresolu; rl[x].u = vresolu;
284 pl[x] = findrect(pframe.l+((x*hresolu)>>pdepth),
285 pframe.d, &ptrunk, rl+x, pdepth);
286 }
287 /* sample the image */
288 for (y = 0; /* y < ysiz */ ; y++) {
289 for (x = 0; x < xsiz-1; x++) {
290 if (dev->inpready)
291 goto escape;
292 /*
293 * Test super-pixel to the right.
294 */
295 if (pl[x] != pl[x+1] && bigdiff(pl[x]->v,
296 pl[x+1]->v, maxdiff)) {
297 refine(pl[x], rl[x].l, rl[x].d,
298 rl[x].r, rl[x].u, 1);
299 refine(pl[x+1], rl[x+1].l, rl[x+1].d,
300 rl[x+1].r, rl[x+1].u, 1);
301 }
302 }
303 if (y >= ysiz-1)
304 break;
305 for (x = 0; x < xsiz; x++) {
306 if (dev->inpready)
307 goto escape;
308 /*
309 * Find super-pixel at this position in next row.
310 */
311 r.l = r.d = 0;
312 r.r = hresolu; r.u = vresolu;
313 p = findrect(pframe.l+((x*hresolu)>>pdepth),
314 pframe.d+(((y+1)*vresolu)>>pdepth),
315 &ptrunk, &r, pdepth);
316 /*
317 * Test super-pixel in next row.
318 */
319 if (pl[x] != p && bigdiff(pl[x]->v, p->v, maxdiff)) {
320 refine(pl[x], rl[x].l, rl[x].d,
321 rl[x].r, rl[x].u, 1);
322 refine(p, r.l, r.d, r.r, r.u, 1);
323 }
324 /*
325 * Copy into super-pixel array.
326 */
327 rl[x].l = r.l; rl[x].d = r.d;
328 rl[x].r = r.r; rl[x].u = r.u;
329 pl[x] = p;
330 }
331 }
332 escape:
333 free((char *)rl);
334 free((char *)pl);
335 }
336
337
338 int
339 refine(p, xmin, ymin, xmax, ymax, pd) /* refine a node */
340 register PNODE *p;
341 int xmin, ymin, xmax, ymax;
342 int pd;
343 {
344 int growth;
345 int mx, my;
346 int i;
347
348 if (dev->inpready) /* quit for input */
349 return(0);
350
351 if (pd <= 0) /* depth limit */
352 return(0);
353
354 mx = (xmin + xmax) >> 1;
355 my = (ymin + ymax) >> 1;
356 growth = 0;
357
358 if (p->kid == NULL) { /* subdivide */
359
360 if ((p->kid = newptree()) == NULL)
361 error(SYSTEM, "out of memory in refine");
362 /*
363 * The following paint order can leave a black pixel
364 * when redraw() is called in (*dev->paintr)().
365 */
366 if (p->x >= mx && p->y >= my)
367 pcopy(p, p->kid+UR);
368 else
369 paint(p->kid+UR, mx, my, xmax, ymax);
370 if (p->x < mx && p->y >= my)
371 pcopy(p, p->kid+UL);
372 else
373 paint(p->kid+UL, xmin, my, mx, ymax);
374 if (p->x >= mx && p->y < my)
375 pcopy(p, p->kid+DR);
376 else
377 paint(p->kid+DR, mx, ymin, xmax, my);
378 if (p->x < mx && p->y < my)
379 pcopy(p, p->kid+DL);
380 else
381 paint(p->kid+DL, xmin, ymin, mx, my);
382
383 growth++;
384 }
385 /* do children */
386 if (mx > pframe.l) {
387 if (my > pframe.d)
388 growth += refine(p->kid+DL, xmin, ymin, mx, my, pd-1);
389 if (my < pframe.u)
390 growth += refine(p->kid+UL, xmin, my, mx, ymax, pd-1);
391 }
392 if (mx < pframe.r) {
393 if (my > pframe.d)
394 growth += refine(p->kid+DR, mx, ymin, xmax, my, pd-1);
395 if (my < pframe.u)
396 growth += refine(p->kid+UR, mx, my, xmax, ymax, pd-1);
397 }
398 /* recompute sum */
399 if (growth) {
400 setcolor(p->v, 0.0, 0.0, 0.0);
401 for (i = 0; i < 4; i++)
402 addcolor(p->v, p->kid[i].v);
403 scalecolor(p->v, 0.25);
404 }
405 return(growth);
406 }
