root/radiance/ray/src/rt/rview.c
Revision: 2.10
Committed: Wed Feb 10 14:03:01 1993 UTC (32 years, 2 months ago) by greg
Changes since 2.9: +12 -4 lines
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rview.c - routines and variables for interactive view generation.
9 *
10 * 3/24/87
11 */
12
13 #include "ray.h"
14
15 #include "rpaint.h"
16
17 #include <signal.h>
18
19 #include <ctype.h>
20
21 VIEW ourview = STDVIEW; /* viewing parameters */
22 int hresolu, vresolu; /* image resolution */
23
24 int dimlist[MAXDIM]; /* sampling dimensions */
25 int ndims = 0; /* number of sampling dimensions */
26 int samplendx = 0; /* index for this sample */
27
28 int psample = 8; /* pixel sample size */
29 double maxdiff = .15; /* max. sample difference */
30
31 double exposure = 1.0; /* exposure for scene */
32
33 double dstrsrc = 0.0; /* square source distribution */
34 double shadthresh = .1; /* shadow threshold */
35 double shadcert = .25; /* shadow certainty */
36 int directrelay = 0; /* number of source relays */
37 int vspretest = 128; /* virtual source pretest density */
38 int directvis = 1; /* sources visible? */
39 double srcsizerat = 0.; /* maximum ratio source size/dist. */
40
41 double specthresh = .3; /* specular sampling threshold */
42 double specjitter = 1.; /* specular sampling jitter */
43
44 int maxdepth = 4; /* maximum recursion depth */
45 double minweight = 1e-2; /* minimum ray weight */
46
47 COLOR ambval = BLKCOLOR; /* ambient value */
48 double ambacc = 0.2; /* ambient accuracy */
49 int ambres = 8; /* ambient resolution */
50 int ambdiv = 32; /* ambient divisions */
51 int ambssamp = 0; /* ambient super-samples */
52 int ambounce = 0; /* ambient bounces */
53 char *amblist[128]; /* ambient include/exclude list */
54 int ambincl = -1; /* include == 1, exclude == 0 */
55
56 int greyscale = 0; /* map colors to brightness? */
57 char *devname = dev_default; /* output device name */
58
59 struct driver *dev = NULL; /* driver functions */
60
61 VIEW oldview; /* previous view parameters */
62
63 PNODE ptrunk; /* the base of our image */
64 RECT pframe; /* current frame boundaries */
65 int pdepth; /* image depth in current frame */
66
67 static char *reserve_mem = NULL; /* pre-allocated reserve memory */
68
69 #define RESERVE_AMT 32768 /* amount of memory to reserve */
70
71 #define CTRL(c) ((c)-'@')
72
73
74 quit(code) /* quit program */
75 int code;
76 {
77 #ifdef MSTATS
78 if (code == 2 && errno == ENOMEM)
79 printmemstats(stderr);
80 #endif
81 devclose();
82 exit(code);
83 }
84
85
86 devopen(dname) /* open device driver */
87 char *dname;
88 {
89 extern char *progname, *octname;
90 char *id;
91 register int i;
92
93 id = octname!=NULL ? octname : progname;
94 /* check device table */
95 for (i = 0; devtable[i].name; i++)
96 if (!strcmp(dname, devtable[i].name))
97 if ((dev = (*devtable[i].init)(dname, id)) == NULL) {
98 sprintf(errmsg, "cannot initialize %s", dname);
99 error(USER, errmsg);
100 } else
101 return;
102 #ifndef NIX
103 /* not there, try exec */
104 if ((dev = comm_init(dname, id)) == NULL) {
105 sprintf(errmsg, "cannot start device \"%s\"", dname);
106 error(USER, errmsg);
107 }
108 #endif
109 }
110
111
112 devclose() /* close our device */
113 {
114 if (dev != NULL)
115 (*dev->close)();
116 dev = NULL;
117 }
118
119
120 printdevices() /* print list of output devices */
121 {
122 register int i;
123
124 for (i = 0; devtable[i].name; i++)
125 printf("%-16s # %s\n", devtable[i].name, devtable[i].descrip);
126 }
127
128
129 rview() /* do a view */
130 {
131 char buf[32];
132
133 devopen(devname); /* open device */
134 newimage(); /* start image (calls fillreserves) */
135
136 for ( ; ; ) { /* quit in command() */
137 while (hresolu <= 1<<pdepth && vresolu <= 1<<pdepth)
138 command("done: ");
139 while (reserve_mem == NULL)
140 command("out of memory: ");
141 errno = 0;
142 if (hresolu <= psample<<pdepth && vresolu <= psample<<pdepth) {
143 sprintf(buf, "%d sampling...\n", 1<<pdepth);
144 (*dev->comout)(buf);
145 rsample();
146 } else {
147 sprintf(buf, "%d refining...\n", 1<<pdepth);
148 (*dev->comout)(buf);
149 refine(&ptrunk, 0, 0, hresolu, vresolu, pdepth+1);
150 }
151 if (errno == ENOMEM) /* ran out of memory */
152 freereserves();
153 else if (dev->inpready) /* noticed some input */
154 command(": ");
155 else /* finished this depth */
156 pdepth++;
157 }
158 }
159
160
161 fillreserves() /* fill memory reserves */
162 {
163 if (reserve_mem != NULL)
164 return;
165 reserve_mem = malloc(RESERVE_AMT);
166 }
167
168
169 freereserves() /* free memory reserves */
170 {
171 if (reserve_mem == NULL)
172 return;
173 free(reserve_mem);
174 reserve_mem = NULL;
175 }
176
177
178 command(prompt) /* get/execute command */
179 char *prompt;
180 {
181 #define badcom(s) strncmp(s, inpbuf, args-inpbuf-1)
182 char inpbuf[256];
183 char *args;
184 again:
185 (*dev->comin)(inpbuf, prompt); /* get command + arguments */
186 for (args = inpbuf; *args && *args != ' '; args++)
187 ;
188 if (*args) *args++ = '\0';
189 else *++args = '\0';
190
191 switch (inpbuf[0]) {
192 case 'f': /* new frame (or free mem.) */
193 if (badcom("frame")) {
194 if (badcom("free"))
195 goto commerr;
196 free_objmem();
197 break;
198 }
199 getframe(args);
200 break;
201 case 'v': /* view */
202 if (badcom("view"))
203 goto commerr;
204 getview(args);
205 break;
206 case 'l': /* last view */
207 if (badcom("last"))
208 goto commerr;
209 lastview(args);
210 break;
211 case 'e': /* exposure */
212 if (badcom("exposure"))
213 goto commerr;
214 getexposure(args);
215 break;
216 case 's': /* set a parameter */
217 if (badcom("set"))
218 goto commerr;
219 setparam(args);
220 break;
221 case 'n': /* new picture */
222 if (badcom("new"))
223 goto commerr;
224 newimage();
225 break;
226 case 't': /* trace a ray */
227 if (badcom("trace"))
228 goto commerr;
229 traceray(args);
230 break;
231 case 'a': /* aim camera */
232 if (badcom("aim"))
233 goto commerr;
234 getaim(args);
235 break;
236 case 'm': /* move camera (or memstats) */
237 if (badcom("move"))
238 #ifdef MSTATS
239 {
240 if (badcom("memory"))
241 goto commerr;
242 printmemstats(stderr);
243 break;
244 }
245 #else
246 goto commerr;
247 #endif
248 getmove(args);
249 break;
250 case 'r': /* rotate/repaint */
251 if (badcom("rotate")) {
252 if (badcom("repaint"))
253 goto commerr;
254 getrepaint(args);
255 break;
256 }
257 getrotate(args);
258 break;
259 case 'p': /* pivot view */
260 if (badcom("pivot"))
261 goto commerr;
262 getpivot(args);
263 break;
264 case CTRL('R'): /* redraw */
265 redraw();
266 break;
267 case 'w': /* write */
268 if (badcom("write"))
269 goto commerr;
270 writepict(args);
271 break;
272 case 'q': /* quit */
273 if (badcom("quit"))
274 goto commerr;
275 quit(0);
276 case CTRL('C'): /* interrupt */
277 goto again;
278 #ifdef SIGTSTP
279 case CTRL('Z'): /* stop */
280 devclose();
281 kill(0, SIGTSTP);
282 /* pc stops here */
283 devopen(devname);
284 redraw();
285 break;
286 #endif
287 case '\0': /* continue */
288 break;
289 default:;
290 commerr:
291 if (iscntrl(inpbuf[0]))
292 sprintf(errmsg, "^%c: unknown control",
293 inpbuf[0]|0100);
294 else
295 sprintf(errmsg, "%s: unknown command", inpbuf);
296 error(COMMAND, errmsg);
297 break;
298 }
299 #undef badcom
300 }
301
302
303 rsample() /* sample the image */
304 {
305 int xsiz, ysiz, y;
306 RECT r;
307 PNODE *p;
308 register RECT *rl;
309 register PNODE **pl;
310 register int x;
311 /*
312 * We initialize the bottom row in the image at our current
313 * resolution. During sampling, we check super-pixels to the
314 * right and above by calling bigdiff(). If there is a significant
315 * difference, we subsample the super-pixels. The testing process
316 * includes initialization of the next row.
317 */
318 xsiz = (((pframe.r-pframe.l)<<pdepth)+hresolu-1) / hresolu;
319 ysiz = (((pframe.u-pframe.d)<<pdepth)+vresolu-1) / vresolu;
320 rl = (RECT *)malloc(xsiz*sizeof(RECT));
321 if (rl == NULL)
322 return;
323 pl = (PNODE **)malloc(xsiz*sizeof(PNODE *));
324 if (pl == NULL) {
325 free((char *)rl);
326 return;
327 }
328 /*
329 * Initialize the bottom row.
330 */
331 rl[0].l = rl[0].d = 0;
332 rl[0].r = hresolu; rl[0].u = vresolu;
333 pl[0] = findrect(pframe.l, pframe.d, &ptrunk, rl, pdepth);
334 for (x = 1; x < xsiz; x++) {
335 rl[x].l = rl[x].d = 0;
336 rl[x].r = hresolu; rl[x].u = vresolu;
337 pl[x] = findrect(pframe.l+((x*hresolu)>>pdepth),
338 pframe.d, &ptrunk, rl+x, pdepth);
339 }
340 /* sample the image */
341 for (y = 0; /* y < ysiz */ ; y++) {
342 for (x = 0; x < xsiz-1; x++) {
343 if (dev->inpready || errno == ENOMEM)
344 goto escape;
345 /*
346 * Test super-pixel to the right.
347 */
348 if (pl[x] != pl[x+1] && bigdiff(pl[x]->v,
349 pl[x+1]->v, maxdiff)) {
350 refine(pl[x], rl[x].l, rl[x].d,
351 rl[x].r, rl[x].u, 1);
352 refine(pl[x+1], rl[x+1].l, rl[x+1].d,
353 rl[x+1].r, rl[x+1].u, 1);
354 }
355 }
356 if (y >= ysiz-1)
357 break;
358 for (x = 0; x < xsiz; x++) {
359 if (dev->inpready || errno == ENOMEM)
360 goto escape;
361 /*
362 * Find super-pixel at this position in next row.
363 */
364 r.l = r.d = 0;
365 r.r = hresolu; r.u = vresolu;
366 p = findrect(pframe.l+((x*hresolu)>>pdepth),
367 pframe.d+(((y+1)*vresolu)>>pdepth),
368 &ptrunk, &r, pdepth);
369 /*
370 * Test super-pixel in next row.
371 */
372 if (pl[x] != p && bigdiff(pl[x]->v, p->v, maxdiff)) {
373 refine(pl[x], rl[x].l, rl[x].d,
374 rl[x].r, rl[x].u, 1);
375 refine(p, r.l, r.d, r.r, r.u, 1);
376 }
377 /*
378 * Copy into super-pixel array.
379 */
380 rl[x].l = r.l; rl[x].d = r.d;
381 rl[x].r = r.r; rl[x].u = r.u;
382 pl[x] = p;
383 }
384 }
385 escape:
386 free((char *)rl);
387 free((char *)pl);
388 }
389
390
391 int
392 refine(p, xmin, ymin, xmax, ymax, pd) /* refine a node */
393 register PNODE *p;
394 int xmin, ymin, xmax, ymax;
395 int pd;
396 {
397 int growth;
398 int mx, my;
399 int i;
400
401 if (dev->inpready) /* quit for input */
402 return(0);
403
404 if (pd <= 0) /* depth limit */
405 return(0);
406
407 mx = (xmin + xmax) >> 1;
408 my = (ymin + ymax) >> 1;
409 growth = 0;
410
411 if (p->kid == NULL) { /* subdivide */
412
413 if ((p->kid = newptree()) == NULL)
414 return(0);
415 /*
416 * The following paint order can leave a black pixel
417 * if redraw() is called in (*dev->paintr)().
418 */
419 if (p->x >= mx && p->y >= my)
420 pcopy(p, p->kid+UR);
421 else
422 paint(p->kid+UR, mx, my, xmax, ymax);
423 if (p->x < mx && p->y >= my)
424 pcopy(p, p->kid+UL);
425 else
426 paint(p->kid+UL, xmin, my, mx, ymax);
427 if (p->x >= mx && p->y < my)
428 pcopy(p, p->kid+DR);
429 else
430 paint(p->kid+DR, mx, ymin, xmax, my);
431 if (p->x < mx && p->y < my)
432 pcopy(p, p->kid+DL);
433 else
434 paint(p->kid+DL, xmin, ymin, mx, my);
435
436 growth++;
437 }
438 /* do children */
439 if (mx > pframe.l) {
440 if (my > pframe.d)
441 growth += refine(p->kid+DL, xmin, ymin, mx, my, pd-1);
442 if (my < pframe.u)
443 growth += refine(p->kid+UL, xmin, my, mx, ymax, pd-1);
444 }
445 if (mx < pframe.r) {
446 if (my > pframe.d)
447 growth += refine(p->kid+DR, mx, ymin, xmax, my, pd-1);
448 if (my < pframe.u)
449 growth += refine(p->kid+UR, mx, my, xmax, ymax, pd-1);
450 }
451 /* recompute sum */
452 if (growth) {
453 setcolor(p->v, 0.0, 0.0, 0.0);
454 for (i = 0; i < 4; i++)
455 addcolor(p->v, p->kid[i].v);
456 scalecolor(p->v, 0.25);
457 }
458 return(growth);
459 }
