root/radiance/ray/src/rt/rview.c
Revision: 2.28
Committed: Mon Jun 13 20:07:56 2005 UTC (19 years, 10 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad3R8, rad3R9
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.28 static const char RCSid[] = "$Id: rview.c,v 2.27 2005/01/21 00:52:59 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * rview.c - routines and variables for interactive view generation.
6     *
7 greg 2.18 * External symbols declared in rpaint.h
8     */
9
10 greg 2.19 #include "copyright.h"
11 greg 1.1
12 schorsch 2.20 #include <signal.h>
13     #include <ctype.h>
14
15 greg 1.15 #include "ray.h"
16 greg 1.1 #include "rpaint.h"
17
18
19 greg 2.18 CUBE thescene; /* our scene */
20     OBJECT nsceneobjs; /* number of objects in our scene */
21 greg 1.15
22     int dimlist[MAXDIM]; /* sampling dimensions */
23     int ndims = 0; /* number of sampling dimensions */
24     int samplendx = 0; /* index for this sample */
25 greg 1.1
26 greg 2.18 extern void ambnotify();
27     void (*addobjnotify[])() = {ambnotify, NULL};
28
29     VIEW ourview = STDVIEW; /* viewing parameters */
30     int hresolu, vresolu; /* image resolution */
31
32     void (*trace)() = NULL; /* trace call */
33
34     int do_irrad = 0; /* compute irradiance? */
35
36 greg 2.28 int rand_samp = 0; /* pure Monte Carlo sampling? */
37
38 greg 1.1 int psample = 8; /* pixel sample size */
39 greg 2.8 double maxdiff = .15; /* max. sample difference */
40 greg 1.1
41 greg 2.8 double exposure = 1.0; /* exposure for scene */
42 greg 1.1
43 greg 2.8 double dstrsrc = 0.0; /* square source distribution */
44     double shadthresh = .1; /* shadow threshold */
45     double shadcert = .25; /* shadow certainty */
46 greg 1.16 int directrelay = 0; /* number of source relays */
47 greg 1.18 int vspretest = 128; /* virtual source pretest density */
48 greg 2.9 int directvis = 1; /* sources visible? */
49 greg 2.8 double srcsizerat = 0.; /* maximum ratio source size/dist. */
50 greg 2.15
51     COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
52 greg 2.17 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
53 greg 2.15 double seccg = 0.; /* global scattering eccentricity */
54     double ssampdist = 0.; /* scatter sampling distance */
55 greg 1.1
56 greg 2.8 double specthresh = .3; /* specular sampling threshold */
57     double specjitter = 1.; /* specular sampling jitter */
58 greg 2.5
59 greg 2.14 int backvis = 1; /* back face visibility */
60
61 greg 2.24 int maxdepth = 6; /* maximum recursion depth */
62 greg 2.8 double minweight = 1e-2; /* minimum ray weight */
63 greg 1.1
64 greg 2.18 char *ambfile = NULL; /* ambient file name */
65 greg 1.1 COLOR ambval = BLKCOLOR; /* ambient value */
66 greg 2.16 int ambvwt = 0; /* initial weight for ambient value */
67 greg 2.25 double ambacc = 0.3; /* ambient accuracy */
68 greg 2.24 int ambres = 32; /* ambient resolution */
69 greg 2.25 int ambdiv = 256; /* ambient divisions */
70     int ambssamp = 64; /* ambient super-samples */
71 greg 1.1 int ambounce = 0; /* ambient bounces */
72 greg 2.26 char *amblist[AMBLLEN]; /* ambient include/exclude list */
73 greg 1.1 int ambincl = -1; /* include == 1, exclude == 0 */
74
75     int greyscale = 0; /* map colors to brightness? */
76 greg 2.18 char *dvcname = dev_default; /* output device name */
77 greg 1.1
78     struct driver *dev = NULL; /* driver functions */
79
80 greg 2.11 char rifname[128]; /* rad input file name */
81
82 greg 1.1 VIEW oldview; /* previous view parameters */
83
84     PNODE ptrunk; /* the base of our image */
85     RECT pframe; /* current frame boundaries */
86     int pdepth; /* image depth in current frame */
87
88 greg 1.12 static char *reserve_mem = NULL; /* pre-allocated reserve memory */
89
90 greg 1.20 #define RESERVE_AMT 32768 /* amount of memory to reserve */
91 greg 1.12
92 greg 2.8 #define CTRL(c) ((c)-'@')
93 greg 1.1
94
95 greg 2.18 void
96 greg 1.1 quit(code) /* quit program */
97     int code;
98     {
99 greg 2.10 #ifdef MSTATS
100     if (code == 2 && errno == ENOMEM)
101     printmemstats(stderr);
102     #endif
103 greg 1.1 devclose();
104     exit(code);
105     }
106
107
108 greg 2.18 void
109 greg 1.1 devopen(dname) /* open device driver */
110     char *dname;
111     {
112 greg 1.6 extern char *progname, *octname;
113 greg 1.7 char *id;
114 greg 1.1 register int i;
115 greg 1.6
116 greg 1.7 id = octname!=NULL ? octname : progname;
117 greg 1.1 /* check device table */
118     for (i = 0; devtable[i].name; i++)
119 schorsch 2.23 if (!strcmp(dname, devtable[i].name)) {
120 greg 1.7 if ((dev = (*devtable[i].init)(dname, id)) == NULL) {
121 greg 1.1 sprintf(errmsg, "cannot initialize %s", dname);
122     error(USER, errmsg);
123     } else
124     return;
125 schorsch 2.23 }
126 greg 1.1 /* not there, try exec */
127 greg 1.7 if ((dev = comm_init(dname, id)) == NULL) {
128 greg 1.1 sprintf(errmsg, "cannot start device \"%s\"", dname);
129     error(USER, errmsg);
130     }
131     }
132
133
134 greg 2.18 void
135 greg 1.1 devclose() /* close our device */
136     {
137     if (dev != NULL)
138     (*dev->close)();
139     dev = NULL;
140     }
141
142
143 greg 2.18 void
144 greg 1.1 printdevices() /* print list of output devices */
145     {
146     register int i;
147
148     for (i = 0; devtable[i].name; i++)
149     printf("%-16s # %s\n", devtable[i].name, devtable[i].descrip);
150     }
151
152
153 greg 2.18 void
154 greg 1.1 rview() /* do a view */
155     {
156     char buf[32];
157
158 greg 2.18 devopen(dvcname); /* open device */
159 greg 1.14 newimage(); /* start image (calls fillreserves) */
160
161 greg 1.1 for ( ; ; ) { /* quit in command() */
162 greg 1.14 while (hresolu <= 1<<pdepth && vresolu <= 1<<pdepth)
163 greg 1.1 command("done: ");
164 greg 1.14 while (reserve_mem == NULL)
165     command("out of memory: ");
166     errno = 0;
167     if (hresolu <= psample<<pdepth && vresolu <= psample<<pdepth) {
168 greg 1.1 sprintf(buf, "%d sampling...\n", 1<<pdepth);
169     (*dev->comout)(buf);
170     rsample();
171     } else {
172     sprintf(buf, "%d refining...\n", 1<<pdepth);
173     (*dev->comout)(buf);
174 greg 1.9 refine(&ptrunk, 0, 0, hresolu, vresolu, pdepth+1);
175 greg 1.1 }
176 greg 1.14 if (errno == ENOMEM) /* ran out of memory */
177     freereserves();
178     else if (dev->inpready) /* noticed some input */
179 greg 1.1 command(": ");
180 greg 1.14 else /* finished this depth */
181 greg 1.1 pdepth++;
182     }
183     }
184
185
186 greg 2.18 void
187 greg 1.14 fillreserves() /* fill memory reserves */
188 greg 1.12 {
189     if (reserve_mem != NULL)
190 greg 1.14 return;
191 greg 2.18 reserve_mem = (char *)malloc(RESERVE_AMT);
192 greg 1.12 }
193
194
195 greg 2.18 void
196 greg 1.14 freereserves() /* free memory reserves */
197 greg 1.12 {
198 greg 1.14 if (reserve_mem == NULL)
199     return;
200 greg 1.12 free(reserve_mem);
201     reserve_mem = NULL;
202     }
203
204
205 greg 2.18 void
206 greg 1.1 command(prompt) /* get/execute command */
207     char *prompt;
208     {
209 greg 2.8 #define badcom(s) strncmp(s, inpbuf, args-inpbuf-1)
210 greg 1.1 char inpbuf[256];
211     char *args;
212     again:
213 greg 1.10 (*dev->comin)(inpbuf, prompt); /* get command + arguments */
214 greg 1.1 for (args = inpbuf; *args && *args != ' '; args++)
215     ;
216     if (*args) *args++ = '\0';
217     else *++args = '\0';
218
219     switch (inpbuf[0]) {
220 greg 2.27 case 'f': /* new frame (|focus|free) */
221 greg 2.10 if (badcom("frame")) {
222 greg 2.27 if (badcom("focus")) {
223     if (badcom("free"))
224     goto commerr;
225     free_objmem();
226     break;
227     }
228     getfocus(args);
229 greg 2.10 break;
230     }
231 greg 1.1 getframe(args);
232     break;
233     case 'v': /* view */
234     if (badcom("view"))
235     goto commerr;
236     getview(args);
237     break;
238     case 'l': /* last view */
239     if (badcom("last"))
240     goto commerr;
241     lastview(args);
242 greg 2.11 break;
243     case 'V': /* save view */
244     if (badcom("V"))
245     goto commerr;
246     saveview(args);
247     break;
248     case 'L': /* load view */
249     if (badcom("L"))
250     goto commerr;
251     loadview(args);
252 greg 1.1 break;
253     case 'e': /* exposure */
254     if (badcom("exposure"))
255     goto commerr;
256     getexposure(args);
257     break;
258     case 's': /* set a parameter */
259 greg 2.13 if (badcom("set")) {
260     #ifdef SIGTSTP
261     if (!badcom("stop"))
262     goto dostop;
263     #endif
264 greg 1.1 goto commerr;
265 greg 2.13 }
266 greg 1.1 setparam(args);
267     break;
268     case 'n': /* new picture */
269     if (badcom("new"))
270     goto commerr;
271     newimage();
272     break;
273     case 't': /* trace a ray */
274     if (badcom("trace"))
275     goto commerr;
276     traceray(args);
277     break;
278     case 'a': /* aim camera */
279     if (badcom("aim"))
280     goto commerr;
281     getaim(args);
282     break;
283 greg 2.10 case 'm': /* move camera (or memstats) */
284 greg 1.1 if (badcom("move"))
285 greg 2.8 #ifdef MSTATS
286 greg 2.2 {
287     if (badcom("memory"))
288     goto commerr;
289     printmemstats(stderr);
290     break;
291     }
292     #else
293 greg 1.1 goto commerr;
294 greg 2.2 #endif
295 greg 1.1 getmove(args);
296     break;
297 greg 1.8 case 'r': /* rotate/repaint */
298     if (badcom("rotate")) {
299 greg 2.13 if (badcom("repaint")) {
300     if (badcom("redraw"))
301     goto commerr;
302     redraw();
303     break;
304     }
305 greg 1.8 getrepaint(args);
306     break;
307     }
308 greg 1.1 getrotate(args);
309     break;
310     case 'p': /* pivot view */
311 greg 2.13 if (badcom("pivot")) {
312     if (badcom("pause"))
313     goto commerr;
314     goto again;
315     }
316 greg 1.1 getpivot(args);
317     break;
318 greg 2.4 case CTRL('R'): /* redraw */
319 greg 1.1 redraw();
320     break;
321     case 'w': /* write */
322     if (badcom("write"))
323     goto commerr;
324     writepict(args);
325     break;
326     case 'q': /* quit */
327     if (badcom("quit"))
328     goto commerr;
329     quit(0);
330 greg 2.4 case CTRL('C'): /* interrupt */
331 greg 1.1 goto again;
332 greg 2.8 #ifdef SIGTSTP
333 greg 2.13 case CTRL('Z'):; /* stop */
334     dostop:
335 greg 1.1 devclose();
336     kill(0, SIGTSTP);
337     /* pc stops here */
338 greg 2.18 devopen(dvcname);
339 greg 1.1 redraw();
340     break;
341     #endif
342     case '\0': /* continue */
343     break;
344     default:;
345     commerr:
346     if (iscntrl(inpbuf[0]))
347     sprintf(errmsg, "^%c: unknown control",
348     inpbuf[0]|0100);
349     else
350     sprintf(errmsg, "%s: unknown command", inpbuf);
351     error(COMMAND, errmsg);
352     break;
353     }
354 greg 2.8 #undef badcom
355 greg 1.1 }
356
357
358 greg 2.18 void
359 greg 1.1 rsample() /* sample the image */
360     {
361     int xsiz, ysiz, y;
362     RECT r;
363     PNODE *p;
364     register RECT *rl;
365 greg 2.8 register PNODE **pl;
366 greg 1.1 register int x;
367     /*
368     * We initialize the bottom row in the image at our current
369 greg 2.8 * resolution. During sampling, we check super-pixels to the
370 greg 1.1 * right and above by calling bigdiff(). If there is a significant
371     * difference, we subsample the super-pixels. The testing process
372     * includes initialization of the next row.
373     */
374 greg 2.12 xsiz = (((long)(pframe.r-pframe.l)<<pdepth)+hresolu-1) / hresolu;
375     ysiz = (((long)(pframe.u-pframe.d)<<pdepth)+vresolu-1) / vresolu;
376 greg 1.1 rl = (RECT *)malloc(xsiz*sizeof(RECT));
377 greg 1.12 if (rl == NULL)
378 greg 1.14 return;
379 greg 1.1 pl = (PNODE **)malloc(xsiz*sizeof(PNODE *));
380 greg 2.7 if (pl == NULL) {
381 greg 2.18 free((void *)rl);
382 greg 1.14 return;
383 greg 2.7 }
384 greg 1.1 /*
385     * Initialize the bottom row.
386     */
387     rl[0].l = rl[0].d = 0;
388 greg 1.9 rl[0].r = hresolu; rl[0].u = vresolu;
389 greg 1.1 pl[0] = findrect(pframe.l, pframe.d, &ptrunk, rl, pdepth);
390     for (x = 1; x < xsiz; x++) {
391     rl[x].l = rl[x].d = 0;
392 greg 1.9 rl[x].r = hresolu; rl[x].u = vresolu;
393     pl[x] = findrect(pframe.l+((x*hresolu)>>pdepth),
394 greg 1.1 pframe.d, &ptrunk, rl+x, pdepth);
395     }
396     /* sample the image */
397     for (y = 0; /* y < ysiz */ ; y++) {
398     for (x = 0; x < xsiz-1; x++) {
399 greg 1.20 if (dev->inpready || errno == ENOMEM)
400 greg 1.1 goto escape;
401     /*
402     * Test super-pixel to the right.
403     */
404     if (pl[x] != pl[x+1] && bigdiff(pl[x]->v,
405     pl[x+1]->v, maxdiff)) {
406     refine(pl[x], rl[x].l, rl[x].d,
407     rl[x].r, rl[x].u, 1);
408     refine(pl[x+1], rl[x+1].l, rl[x+1].d,
409     rl[x+1].r, rl[x+1].u, 1);
410     }
411     }
412     if (y >= ysiz-1)
413     break;
414     for (x = 0; x < xsiz; x++) {
415 greg 1.20 if (dev->inpready || errno == ENOMEM)
416 greg 1.1 goto escape;
417     /*
418     * Find super-pixel at this position in next row.
419     */
420     r.l = r.d = 0;
421 greg 1.9 r.r = hresolu; r.u = vresolu;
422     p = findrect(pframe.l+((x*hresolu)>>pdepth),
423     pframe.d+(((y+1)*vresolu)>>pdepth),
424 greg 1.1 &ptrunk, &r, pdepth);
425     /*
426     * Test super-pixel in next row.
427     */
428     if (pl[x] != p && bigdiff(pl[x]->v, p->v, maxdiff)) {
429     refine(pl[x], rl[x].l, rl[x].d,
430     rl[x].r, rl[x].u, 1);
431     refine(p, r.l, r.d, r.r, r.u, 1);
432     }
433     /*
434     * Copy into super-pixel array.
435     */
436     rl[x].l = r.l; rl[x].d = r.d;
437     rl[x].r = r.r; rl[x].u = r.u;
438     pl[x] = p;
439     }
440     }
441     escape:
442 greg 2.18 free((void *)rl);
443     free((void *)pl);
444 greg 1.1 }
445
446
447     int
448     refine(p, xmin, ymin, xmax, ymax, pd) /* refine a node */
449 greg 2.8 register PNODE *p;
450 greg 1.1 int xmin, ymin, xmax, ymax;
451     int pd;
452     {
453     int growth;
454     int mx, my;
455     int i;
456
457     if (dev->inpready) /* quit for input */
458     return(0);
459
460     if (pd <= 0) /* depth limit */
461     return(0);
462
463     mx = (xmin + xmax) >> 1;
464     my = (ymin + ymax) >> 1;
465     growth = 0;
466
467     if (p->kid == NULL) { /* subdivide */
468
469     if ((p->kid = newptree()) == NULL)
470 greg 1.20 return(0);
471 greg 1.1 /*
472     * The following paint order can leave a black pixel
473 greg 2.7 * if redraw() is called in (*dev->paintr)().
474 greg 1.1 */
475     if (p->x >= mx && p->y >= my)
476     pcopy(p, p->kid+UR);
477     else
478     paint(p->kid+UR, mx, my, xmax, ymax);
479     if (p->x < mx && p->y >= my)
480     pcopy(p, p->kid+UL);
481     else
482     paint(p->kid+UL, xmin, my, mx, ymax);
483     if (p->x >= mx && p->y < my)
484     pcopy(p, p->kid+DR);
485     else
486     paint(p->kid+DR, mx, ymin, xmax, my);
487     if (p->x < mx && p->y < my)
488     pcopy(p, p->kid+DL);
489     else
490     paint(p->kid+DL, xmin, ymin, mx, my);
491
492     growth++;
493     }
494     /* do children */
495     if (mx > pframe.l) {
496     if (my > pframe.d)
497     growth += refine(p->kid+DL, xmin, ymin, mx, my, pd-1);
498     if (my < pframe.u)
499     growth += refine(p->kid+UL, xmin, my, mx, ymax, pd-1);
500     }
501     if (mx < pframe.r) {
502     if (my > pframe.d)
503     growth += refine(p->kid+DR, mx, ymin, xmax, my, pd-1);
504     if (my < pframe.u)
505     growth += refine(p->kid+UR, mx, my, xmax, ymax, pd-1);
506     }
507     /* recompute sum */
508     if (growth) {
509     setcolor(p->v, 0.0, 0.0, 0.0);
510     for (i = 0; i < 4; i++)
511     addcolor(p->v, p->kid[i].v);
512     scalecolor(p->v, 0.25);
513     }
514     return(growth);
515     }
