root/radiance/ray/src/rt/rview.c
Revision: 2.15
Committed: Fri Dec 8 18:49:24 1995 UTC (28 years, 6 months ago) by greg
Changes since 2.14: +6 -1 lines
1 /* Copyright (c) 1995 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rview.c - routines and variables for interactive view generation.
9 *
10 * 3/24/87
11 */
12
13 #include "ray.h"
14
15 #include "rpaint.h"
16
17 #include <signal.h>
18
19 #include <ctype.h>
20
21 VIEW ourview = STDVIEW; /* viewing parameters */
22 int hresolu, vresolu; /* image resolution */
23
24 int dimlist[MAXDIM]; /* sampling dimensions */
25 int ndims = 0; /* number of sampling dimensions */
26 int samplendx = 0; /* index for this sample */
27
28 int psample = 8; /* pixel sample size */
29 double maxdiff = .15; /* max. sample difference */
30
31 double exposure = 1.0; /* exposure for scene */
32
33 double dstrsrc = 0.0; /* square source distribution */
34 double shadthresh = .1; /* shadow threshold */
35 double shadcert = .25; /* shadow certainty */
36 int directrelay = 0; /* number of source relays */
37 int vspretest = 128; /* virtual source pretest density */
38 int directvis = 1; /* sources visible? */
39 double srcsizerat = 0.; /* maximum ratio source size/dist. */
40
41 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
42 double salbedo = 0.; /* global scattering albedo */
43 double seccg = 0.; /* global scattering eccentricity */
44 double ssampdist = 0.; /* scatter sampling distance */
45
46 double specthresh = .3; /* specular sampling threshold */
47 double specjitter = 1.; /* specular sampling jitter */
48
49 int backvis = 1; /* back face visibility */
50
51 int maxdepth = 4; /* maximum recursion depth */
52 double minweight = 1e-2; /* minimum ray weight */
53
54 COLOR ambval = BLKCOLOR; /* ambient value */
55 double ambacc = 0.2; /* ambient accuracy */
56 int ambres = 8; /* ambient resolution */
57 int ambdiv = 32; /* ambient divisions */
58 int ambssamp = 0; /* ambient super-samples */
59 int ambounce = 0; /* ambient bounces */
60 char *amblist[128]; /* ambient include/exclude list */
61 int ambincl = -1; /* include == 1, exclude == 0 */
62
63 int greyscale = 0; /* map colors to brightness? */
64 char *devname = dev_default; /* output device name */
65
66 struct driver *dev = NULL; /* driver functions */
67
68 char rifname[128]; /* rad input file name */
69
70 VIEW oldview; /* previous view parameters */
71
72 PNODE ptrunk; /* the base of our image */
73 RECT pframe; /* current frame boundaries */
74 int pdepth; /* image depth in current frame */
75
76 static char *reserve_mem = NULL; /* pre-allocated reserve memory */
77
78 #define RESERVE_AMT 32768 /* amount of memory to reserve */
79
80 #define CTRL(c) ((c)-'@')
81
82
83 quit(code) /* quit program */
84 int code;
85 {
86 #ifdef MSTATS
87 if (code == 2 && errno == ENOMEM)
88 printmemstats(stderr);
89 #endif
90 devclose();
91 exit(code);
92 }
93
94
95 devopen(dname) /* open device driver */
96 char *dname;
97 {
98 extern char *progname, *octname;
99 char *id;
100 register int i;
101
102 id = octname!=NULL ? octname : progname;
103 /* check device table */
104 for (i = 0; devtable[i].name; i++)
105 if (!strcmp(dname, devtable[i].name))
106 if ((dev = (*devtable[i].init)(dname, id)) == NULL) {
107 sprintf(errmsg, "cannot initialize %s", dname);
108 error(USER, errmsg);
109 } else
110 return;
111 #ifndef NIX
112 /* not there, try exec */
113 if ((dev = comm_init(dname, id)) == NULL) {
114 sprintf(errmsg, "cannot start device \"%s\"", dname);
115 error(USER, errmsg);
116 }
117 #endif
118 }
119
120
121 devclose() /* close our device */
122 {
123 if (dev != NULL)
124 (*dev->close)();
125 dev = NULL;
126 }
127
128
129 printdevices() /* print list of output devices */
130 {
131 register int i;
132
133 for (i = 0; devtable[i].name; i++)
134 printf("%-16s # %s\n", devtable[i].name, devtable[i].descrip);
135 }
136
137
138 rview() /* do a view */
139 {
140 char buf[32];
141
142 devopen(devname); /* open device */
143 newimage(); /* start image (calls fillreserves) */
144
145 for ( ; ; ) { /* quit in command() */
146 while (hresolu <= 1<<pdepth && vresolu <= 1<<pdepth)
147 command("done: ");
148 while (reserve_mem == NULL)
149 command("out of memory: ");
150 errno = 0;
151 if (hresolu <= psample<<pdepth && vresolu <= psample<<pdepth) {
152 sprintf(buf, "%d sampling...\n", 1<<pdepth);
153 (*dev->comout)(buf);
154 rsample();
155 } else {
156 sprintf(buf, "%d refining...\n", 1<<pdepth);
157 (*dev->comout)(buf);
158 refine(&ptrunk, 0, 0, hresolu, vresolu, pdepth+1);
159 }
160 if (errno == ENOMEM) /* ran out of memory */
161 freereserves();
162 else if (dev->inpready) /* noticed some input */
163 command(": ");
164 else /* finished this depth */
165 pdepth++;
166 }
167 }
168
169
170 fillreserves() /* fill memory reserves */
171 {
172 if (reserve_mem != NULL)
173 return;
174 reserve_mem = malloc(RESERVE_AMT);
175 }
176
177
178 freereserves() /* free memory reserves */
179 {
180 if (reserve_mem == NULL)
181 return;
182 free(reserve_mem);
183 reserve_mem = NULL;
184 }
185
186
187 command(prompt) /* get/execute command */
188 char *prompt;
189 {
190 #define badcom(s) strncmp(s, inpbuf, args-inpbuf-1)
191 char inpbuf[256];
192 char *args;
193 again:
194 (*dev->comin)(inpbuf, prompt); /* get command + arguments */
195 for (args = inpbuf; *args && *args != ' '; args++)
196 ;
197 if (*args) *args++ = '\0';
198 else *++args = '\0';
199
200 switch (inpbuf[0]) {
201 case 'f': /* new frame (or free mem.) */
202 if (badcom("frame")) {
203 if (badcom("free"))
204 goto commerr;
205 free_objmem();
206 break;
207 }
208 getframe(args);
209 break;
210 case 'v': /* view */
211 if (badcom("view"))
212 goto commerr;
213 getview(args);
214 break;
215 case 'l': /* last view */
216 if (badcom("last"))
217 goto commerr;
218 lastview(args);
219 break;
220 case 'V': /* save view */
221 if (badcom("V"))
222 goto commerr;
223 saveview(args);
224 break;
225 case 'L': /* load view */
226 if (badcom("L"))
227 goto commerr;
228 loadview(args);
229 break;
230 case 'e': /* exposure */
231 if (badcom("exposure"))
232 goto commerr;
233 getexposure(args);
234 break;
235 case 's': /* set a parameter */
236 if (badcom("set")) {
237 #ifdef SIGTSTP
238 if (!badcom("stop"))
239 goto dostop;
240 #endif
241 goto commerr;
242 }
243 setparam(args);
244 break;
245 case 'n': /* new picture */
246 if (badcom("new"))
247 goto commerr;
248 newimage();
249 break;
250 case 't': /* trace a ray */
251 if (badcom("trace"))
252 goto commerr;
253 traceray(args);
254 break;
255 case 'a': /* aim camera */
256 if (badcom("aim"))
257 goto commerr;
258 getaim(args);
259 break;
260 case 'm': /* move camera (or memstats) */
261 if (badcom("move"))
262 #ifdef MSTATS
263 {
264 if (badcom("memory"))
265 goto commerr;
266 printmemstats(stderr);
267 break;
268 }
269 #else
270 goto commerr;
271 #endif
272 getmove(args);
273 break;
274 case 'r': /* rotate/repaint */
275 if (badcom("rotate")) {
276 if (badcom("repaint")) {
277 if (badcom("redraw"))
278 goto commerr;
279 redraw();
280 break;
281 }
282 getrepaint(args);
283 break;
284 }
285 getrotate(args);
286 break;
287 case 'p': /* pivot view */
288 if (badcom("pivot")) {
289 if (badcom("pause"))
290 goto commerr;
291 goto again;
292 }
293 getpivot(args);
294 break;
295 case CTRL('R'): /* redraw */
296 redraw();
297 break;
298 case 'w': /* write */
299 if (badcom("write"))
300 goto commerr;
301 writepict(args);
302 break;
303 case 'q': /* quit */
304 if (badcom("quit"))
305 goto commerr;
306 quit(0);
307 case CTRL('C'): /* interrupt */
308 goto again;
309 #ifdef SIGTSTP
310 case CTRL('Z'):; /* stop */
311 dostop:
312 devclose();
313 kill(0, SIGTSTP);
314 /* pc stops here */
315 devopen(devname);
316 redraw();
317 break;
318 #endif
319 case '\0': /* continue */
320 break;
321 default:;
322 commerr:
323 if (iscntrl(inpbuf[0]))
324 sprintf(errmsg, "^%c: unknown control",
325 inpbuf[0]|0100);
326 else
327 sprintf(errmsg, "%s: unknown command", inpbuf);
328 error(COMMAND, errmsg);
329 break;
330 }
331 #undef badcom
332 }
333
334
335 rsample() /* sample the image */
336 {
337 int xsiz, ysiz, y;
338 RECT r;
339 PNODE *p;
340 register RECT *rl;
341 register PNODE **pl;
342 register int x;
343 /*
344 * We initialize the bottom row in the image at our current
345 * resolution. During sampling, we check super-pixels to the
346 * right and above by calling bigdiff(). If there is a significant
347 * difference, we subsample the super-pixels. The testing process
348 * includes initialization of the next row.
349 */
350 xsiz = (((long)(pframe.r-pframe.l)<<pdepth)+hresolu-1) / hresolu;
351 ysiz = (((long)(pframe.u-pframe.d)<<pdepth)+vresolu-1) / vresolu;
352 rl = (RECT *)malloc(xsiz*sizeof(RECT));
353 if (rl == NULL)
354 return;
355 pl = (PNODE **)malloc(xsiz*sizeof(PNODE *));
356 if (pl == NULL) {
357 free((char *)rl);
358 return;
359 }
360 /*
361 * Initialize the bottom row.
362 */
363 rl[0].l = rl[0].d = 0;
364 rl[0].r = hresolu; rl[0].u = vresolu;
365 pl[0] = findrect(pframe.l, pframe.d, &ptrunk, rl, pdepth);
366 for (x = 1; x < xsiz; x++) {
367 rl[x].l = rl[x].d = 0;
368 rl[x].r = hresolu; rl[x].u = vresolu;
369 pl[x] = findrect(pframe.l+((x*hresolu)>>pdepth),
370 pframe.d, &ptrunk, rl+x, pdepth);
371 }
372 /* sample the image */
373 for (y = 0; /* y < ysiz */ ; y++) {
374 for (x = 0; x < xsiz-1; x++) {
375 if (dev->inpready || errno == ENOMEM)
376 goto escape;
377 /*
378 * Test super-pixel to the right.
379 */
380 if (pl[x] != pl[x+1] && bigdiff(pl[x]->v,
381 pl[x+1]->v, maxdiff)) {
382 refine(pl[x], rl[x].l, rl[x].d,
383 rl[x].r, rl[x].u, 1);
384 refine(pl[x+1], rl[x+1].l, rl[x+1].d,
385 rl[x+1].r, rl[x+1].u, 1);
386 }
387 }
388 if (y >= ysiz-1)
389 break;
390 for (x = 0; x < xsiz; x++) {
391 if (dev->inpready || errno == ENOMEM)
392 goto escape;
393 /*
394 * Find super-pixel at this position in next row.
395 */
396 r.l = r.d = 0;
397 r.r = hresolu; r.u = vresolu;
398 p = findrect(pframe.l+((x*hresolu)>>pdepth),
399 pframe.d+(((y+1)*vresolu)>>pdepth),
400 &ptrunk, &r, pdepth);
401 /*
402 * Test super-pixel in next row.
403 */
404 if (pl[x] != p && bigdiff(pl[x]->v, p->v, maxdiff)) {
405 refine(pl[x], rl[x].l, rl[x].d,
406 rl[x].r, rl[x].u, 1);
407 refine(p, r.l, r.d, r.r, r.u, 1);
408 }
409 /*
410 * Copy into super-pixel array.
411 */
412 rl[x].l = r.l; rl[x].d = r.d;
413 rl[x].r = r.r; rl[x].u = r.u;
414 pl[x] = p;
415 }
416 }
417 escape:
418 free((char *)rl);
419 free((char *)pl);
420 }
421
422
423 int
424 refine(p, xmin, ymin, xmax, ymax, pd) /* refine a node */
425 register PNODE *p;
426 int xmin, ymin, xmax, ymax;
427 int pd;
428 {
429 int growth;
430 int mx, my;
431 int i;
432
433 if (dev->inpready) /* quit for input */
434 return(0);
435
436 if (pd <= 0) /* depth limit */
437 return(0);
438
439 mx = (xmin + xmax) >> 1;
440 my = (ymin + ymax) >> 1;
441 growth = 0;
442
443 if (p->kid == NULL) { /* subdivide */
444
445 if ((p->kid = newptree()) == NULL)
446 return(0);
447 /*
448 * The following paint order can leave a black pixel
449 * if redraw() is called in (*dev->paintr)().
450 */
451 if (p->x >= mx && p->y >= my)
452 pcopy(p, p->kid+UR);
453 else
454 paint(p->kid+UR, mx, my, xmax, ymax);
455 if (p->x < mx && p->y >= my)
456 pcopy(p, p->kid+UL);
457 else
458 paint(p->kid+UL, xmin, my, mx, ymax);
459 if (p->x >= mx && p->y < my)
460 pcopy(p, p->kid+DR);
461 else
462 paint(p->kid+DR, mx, ymin, xmax, my);
463 if (p->x < mx && p->y < my)
464 pcopy(p, p->kid+DL);
465 else
466 paint(p->kid+DL, xmin, ymin, mx, my);
467
468 growth++;
469 }
470 /* do children */
471 if (mx > pframe.l) {
472 if (my > pframe.d)
473 growth += refine(p->kid+DL, xmin, ymin, mx, my, pd-1);
474 if (my < pframe.u)
475 growth += refine(p->kid+UL, xmin, my, mx, ymax, pd-1);
476 }
477 if (mx < pframe.r) {
478 if (my > pframe.d)
479 growth += refine(p->kid+DR, mx, ymin, xmax, my, pd-1);
480 if (my < pframe.u)
481 growth += refine(p->kid+UR, mx, my, xmax, ymax, pd-1);
482 }
483 /* recompute sum */
484 if (growth) {
485 setcolor(p->v, 0.0, 0.0, 0.0);
486 for (i = 0; i < 4; i++)
487 addcolor(p->v, p->kid[i].v);
488 scalecolor(p->v, 0.25);
489 }
490 return(growth);
491 }
