--- ray/src/rt/rview.c 1990/01/30 11:37:41 1.10 +++ ray/src/rt/rview.c 1991/06/24 16:10:49 1.17 @@ -10,10 +10,8 @@ static char SCCSid[] = "$SunId$ LBL"; * 3/24/87 */ -#include "standard.h" +#include "ray.h" -#include "color.h" - #include "rpaint.h" #include @@ -23,6 +21,10 @@ static char SCCSid[] = "$SunId$ LBL"; VIEW ourview = STDVIEW; /* viewing parameters */ int hresolu, vresolu; /* image resolution */ +int dimlist[MAXDIM]; /* sampling dimensions */ +int ndims = 0; /* number of sampling dimensions */ +int samplendx = 0; /* index for this sample */ + int psample = 8; /* pixel sample size */ double maxdiff = .15; /* max. sample difference */ @@ -31,6 +33,8 @@ double exposure = 1.0; /* exposure for scene */ double dstrsrc = 0.0; /* square source distribution */ double shadthresh = .1; /* shadow threshold */ double shadcert = .25; /* shadow certainty */ +int directrelay = 0; /* number of source relays */ +int vspretest = 32; /* virtual source pretest density */ int maxdepth = 4; /* maximum recursion depth */ double minweight = 1e-2; /* minimum ray weight */ @@ -45,7 +49,7 @@ char *amblist[128]; /* ambient include/exclude list int ambincl = -1; /* include == 1, exclude == 0 */ int greyscale = 0; /* map colors to brightness? */ -char *devname = "X"; /* output device name */ +char *devname = dev_default; /* output device name */ struct driver *dev = NULL; /* driver functions */ @@ -55,6 +59,10 @@ PNODE ptrunk; /* the base of our image */ RECT pframe; /* current frame boundaries */ int pdepth; /* image depth in current frame */ +static char *reserve_mem = NULL; /* pre-allocated reserve memory */ + +#define RESERVE_AMT 8192 /* amount of memory to reserve */ + #define CTRL(c) ('c'-'@') @@ -112,15 +120,15 @@ rview() /* do a view */ char buf[32]; devopen(devname); /* open device */ - newimage(); /* set up image */ + newimage(); /* start image (calls fillreserves) */ for ( ; ; ) { /* quit in command() */ - while (hresolu <= 1<comout)(buf); rsample(); @@ -129,14 +137,33 @@ rview() /* do a view */ (*dev->comout)(buf); refine(&ptrunk, 0, 0, hresolu, vresolu, pdepth+1); } - if (dev->inpready) + if (errno == ENOMEM) /* ran out of memory */ + freereserves(); + else if (dev->inpready) /* noticed some input */ command(": "); - else + else /* finished this depth */ pdepth++; } } +fillreserves() /* fill memory reserves */ +{ + if (reserve_mem != NULL) + return; + reserve_mem = malloc(RESERVE_AMT); +} + + +freereserves() /* free memory reserves */ +{ + if (reserve_mem == NULL) + return; + free(reserve_mem); + reserve_mem = NULL; +} + + command(prompt) /* get/execute command */ char *prompt; { @@ -268,9 +295,11 @@ rsample() /* sample the image */ xsiz = (((pframe.r-pframe.l)<kid == NULL) { /* subdivide */ if ((p->kid = newptree()) == NULL) - error(SYSTEM, "out of memory in refine"); + return(growth); /* * The following paint order can leave a black pixel * when redraw() is called in (*dev->paintr)().
