root/radiance/ray/src/rt/rview.c
Revision: 1.10
Committed: Tue Jan 30 11:37:41 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.9: +1 -2 lines
1 /* Copyright (c) 1987 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rview.c - routines and variables for interactive view generation.
9 *
10 * 3/24/87
11 */
12
13 #include "standard.h"
14
15 #include "color.h"
16
17 #include "rpaint.h"
18
19 #include <signal.h>
20
21 #include <ctype.h>
22
23 VIEW ourview = STDVIEW; /* viewing parameters */
24 int hresolu, vresolu; /* image resolution */
25
26 int psample = 8; /* pixel sample size */
27 double maxdiff = .15; /* max. sample difference */
28
29 double exposure = 1.0; /* exposure for scene */
30
31 double dstrsrc = 0.0; /* square source distribution */
32 double shadthresh = .1; /* shadow threshold */
33 double shadcert = .25; /* shadow certainty */
34
35 int maxdepth = 4; /* maximum recursion depth */
36 double minweight = 1e-2; /* minimum ray weight */
37
38 COLOR ambval = BLKCOLOR; /* ambient value */
39 double ambacc = 0.2; /* ambient accuracy */
40 int ambres = 8; /* ambient resolution */
41 int ambdiv = 32; /* ambient divisions */
42 int ambssamp = 0; /* ambient super-samples */
43 int ambounce = 0; /* ambient bounces */
44 char *amblist[128]; /* ambient include/exclude list */
45 int ambincl = -1; /* include == 1, exclude == 0 */
46
47 int greyscale = 0; /* map colors to brightness? */
48 char *devname = "X"; /* output device name */
49
50 struct driver *dev = NULL; /* driver functions */
51
52 VIEW oldview; /* previous view parameters */
53
54 PNODE ptrunk; /* the base of our image */
55 RECT pframe; /* current frame boundaries */
56 int pdepth; /* image depth in current frame */
57
58 #define CTRL(c) ('c'-'@')
59
60
61 quit(code) /* quit program */
62 int code;
63 {
64 devclose();
65 exit(code);
66 }
67
68
69 devopen(dname) /* open device driver */
70 char *dname;
71 {
72 extern char *progname, *octname;
73 char *id;
74 register int i;
75
76 id = octname!=NULL ? octname : progname;
77 /* check device table */
78 for (i = 0; devtable[i].name; i++)
79 if (!strcmp(dname, devtable[i].name))
80 if ((dev = (*devtable[i].init)(dname, id)) == NULL) {
81 sprintf(errmsg, "cannot initialize %s", dname);
82 error(USER, errmsg);
83 } else
84 return;
85 /* not there, try exec */
86 if ((dev = comm_init(dname, id)) == NULL) {
87 sprintf(errmsg, "cannot start device \"%s\"", dname);
88 error(USER, errmsg);
89 }
90 }
91
92
93 devclose() /* close our device */
94 {
95 if (dev != NULL)
96 (*dev->close)();
97 dev = NULL;
98 }
99
100
101 printdevices() /* print list of output devices */
102 {
103 register int i;
104
105 for (i = 0; devtable[i].name; i++)
106 printf("%-16s # %s\n", devtable[i].name, devtable[i].descrip);
107 }
108
109
110 rview() /* do a view */
111 {
112 char buf[32];
113
114 devopen(devname); /* open device */
115 newimage(); /* set up image */
116
117 for ( ; ; ) { /* quit in command() */
118 while (hresolu <= 1<<pdepth &&
119 vresolu <= 1<<pdepth)
120 command("done: ");
121
122 if (hresolu <= psample<<pdepth &&
123 vresolu <= psample<<pdepth) {
124 sprintf(buf, "%d sampling...\n", 1<<pdepth);
125 (*dev->comout)(buf);
126 rsample();
127 } else {
128 sprintf(buf, "%d refining...\n", 1<<pdepth);
129 (*dev->comout)(buf);
130 refine(&ptrunk, 0, 0, hresolu, vresolu, pdepth+1);
131 }
132 if (dev->inpready)
133 command(": ");
134 else
135 pdepth++;
136 }
137 }
138
139
140 command(prompt) /* get/execute command */
141 char *prompt;
142 {
143 #define badcom(s) strncmp(s, inpbuf, args-inpbuf-1)
144 double atof();
145 char inpbuf[256];
146 char *args;
147 again:
148 (*dev->comin)(inpbuf, prompt); /* get command + arguments */
149 for (args = inpbuf; *args && *args != ' '; args++)
150 ;
151 if (*args) *args++ = '\0';
152 else *++args = '\0';
153
154 switch (inpbuf[0]) {
155 case 'f': /* new frame */
156 if (badcom("frame"))
157 goto commerr;
158 getframe(args);
159 break;
160 case 'v': /* view */
161 if (badcom("view"))
162 goto commerr;
163 getview(args);
164 break;
165 case 'l': /* last view */
166 if (badcom("last"))
167 goto commerr;
168 lastview(args);
169 break;
170 case 'e': /* exposure */
171 if (badcom("exposure"))
172 goto commerr;
173 getexposure(args);
174 break;
175 case 's': /* set a parameter */
176 if (badcom("set"))
177 goto commerr;
178 setparam(args);
179 break;
180 case 'n': /* new picture */
181 if (badcom("new"))
182 goto commerr;
183 newimage();
184 break;
185 case 't': /* trace a ray */
186 if (badcom("trace"))
187 goto commerr;
188 traceray(args);
189 break;
190 case 'a': /* aim camera */
191 if (badcom("aim"))
192 goto commerr;
193 getaim(args);
194 break;
195 case 'm': /* move camera */
196 if (badcom("move"))
197 goto commerr;
198 getmove(args);
199 break;
200 case 'r': /* rotate/repaint */
201 if (badcom("rotate")) {
202 if (badcom("repaint"))
203 goto commerr;
204 getrepaint(args);
205 break;
206 }
207 getrotate(args);
208 break;
209 case 'p': /* pivot view */
210 if (badcom("pivot"))
211 goto commerr;
212 getpivot(args);
213 break;
214 case CTRL(R): /* redraw */
215 redraw();
216 break;
217 case 'w': /* write */
218 if (badcom("write"))
219 goto commerr;
220 writepict(args);
221 break;
222 case 'q': /* quit */
223 if (badcom("quit"))
224 goto commerr;
225 quit(0);
226 case CTRL(C): /* interrupt */
227 goto again;
228 #ifdef SIGTSTP
229 case CTRL(Z): /* stop */
230 devclose();
231 kill(0, SIGTSTP);
232 /* pc stops here */
233 devopen(devname);
234 redraw();
235 break;
236 #endif
237 case '\0': /* continue */
238 break;
239 default:;
240 commerr:
241 if (iscntrl(inpbuf[0]))
242 sprintf(errmsg, "^%c: unknown control",
243 inpbuf[0]|0100);
244 else
245 sprintf(errmsg, "%s: unknown command", inpbuf);
246 error(COMMAND, errmsg);
247 break;
248 }
249 #undef badcom
250 }
251
252
253 rsample() /* sample the image */
254 {
255 int xsiz, ysiz, y;
256 RECT r;
257 PNODE *p;
258 register RECT *rl;
259 register PNODE **pl;
260 register int x;
261 /*
262 * We initialize the bottom row in the image at our current
263 * resolution. During sampling, we check super-pixels to the
264 * right and above by calling bigdiff(). If there is a significant
265 * difference, we subsample the super-pixels. The testing process
266 * includes initialization of the next row.
267 */
268 xsiz = (((pframe.r-pframe.l)<<pdepth)+hresolu-1) / hresolu;
269 ysiz = (((pframe.u-pframe.d)<<pdepth)+vresolu-1) / vresolu;
270 rl = (RECT *)malloc(xsiz*sizeof(RECT));
271 pl = (PNODE **)malloc(xsiz*sizeof(PNODE *));
272 if (rl == NULL || pl == NULL)
273 error(SYSTEM, "out of memory in rsample");
274 /*
275 * Initialize the bottom row.
276 */
277 rl[0].l = rl[0].d = 0;
278 rl[0].r = hresolu; rl[0].u = vresolu;
279 pl[0] = findrect(pframe.l, pframe.d, &ptrunk, rl, pdepth);
280 for (x = 1; x < xsiz; x++) {
281 rl[x].l = rl[x].d = 0;
282 rl[x].r = hresolu; rl[x].u = vresolu;
283 pl[x] = findrect(pframe.l+((x*hresolu)>>pdepth),
284 pframe.d, &ptrunk, rl+x, pdepth);
285 }
286 /* sample the image */
287 for (y = 0; /* y < ysiz */ ; y++) {
288 for (x = 0; x < xsiz-1; x++) {
289 if (dev->inpready)
290 goto escape;
291 /*
292 * Test super-pixel to the right.
293 */
294 if (pl[x] != pl[x+1] && bigdiff(pl[x]->v,
295 pl[x+1]->v, maxdiff)) {
296 refine(pl[x], rl[x].l, rl[x].d,
297 rl[x].r, rl[x].u, 1);
298 refine(pl[x+1], rl[x+1].l, rl[x+1].d,
299 rl[x+1].r, rl[x+1].u, 1);
300 }
301 }
302 if (y >= ysiz-1)
303 break;
304 for (x = 0; x < xsiz; x++) {
305 if (dev->inpready)
306 goto escape;
307 /*
308 * Find super-pixel at this position in next row.
309 */
310 r.l = r.d = 0;
311 r.r = hresolu; r.u = vresolu;
312 p = findrect(pframe.l+((x*hresolu)>>pdepth),
313 pframe.d+(((y+1)*vresolu)>>pdepth),
314 &ptrunk, &r, pdepth);
315 /*
316 * Test super-pixel in next row.
317 */
318 if (pl[x] != p && bigdiff(pl[x]->v, p->v, maxdiff)) {
319 refine(pl[x], rl[x].l, rl[x].d,
320 rl[x].r, rl[x].u, 1);
321 refine(p, r.l, r.d, r.r, r.u, 1);
322 }
323 /*
324 * Copy into super-pixel array.
325 */
326 rl[x].l = r.l; rl[x].d = r.d;
327 rl[x].r = r.r; rl[x].u = r.u;
328 pl[x] = p;
329 }
330 }
331 escape:
332 free((char *)rl);
333 free((char *)pl);
334 }
335
336
337 int
338 refine(p, xmin, ymin, xmax, ymax, pd) /* refine a node */
339 register PNODE *p;
340 int xmin, ymin, xmax, ymax;
341 int pd;
342 {
343 int growth;
344 int mx, my;
345 int i;
346
347 if (dev->inpready) /* quit for input */
348 return(0);
349
350 if (pd <= 0) /* depth limit */
351 return(0);
352
353 mx = (xmin + xmax) >> 1;
354 my = (ymin + ymax) >> 1;
355 growth = 0;
356
357 if (p->kid == NULL) { /* subdivide */
358
359 if ((p->kid = newptree()) == NULL)
360 error(SYSTEM, "out of memory in refine");
361 /*
362 * The following paint order can leave a black pixel
363 * when redraw() is called in (*dev->paintr)().
364 */
365 if (p->x >= mx && p->y >= my)
366 pcopy(p, p->kid+UR);
367 else
368 paint(p->kid+UR, mx, my, xmax, ymax);
369 if (p->x < mx && p->y >= my)
370 pcopy(p, p->kid+UL);
371 else
372 paint(p->kid+UL, xmin, my, mx, ymax);
373 if (p->x >= mx && p->y < my)
374 pcopy(p, p->kid+DR);
375 else
376 paint(p->kid+DR, mx, ymin, xmax, my);
377 if (p->x < mx && p->y < my)
378 pcopy(p, p->kid+DL);
379 else
380 paint(p->kid+DL, xmin, ymin, mx, my);
381
382 growth++;
383 }
384 /* do children */
385 if (mx > pframe.l) {
386 if (my > pframe.d)
387 growth += refine(p->kid+DL, xmin, ymin, mx, my, pd-1);
388 if (my < pframe.u)
389 growth += refine(p->kid+UL, xmin, my, mx, ymax, pd-1);
390 }
391 if (mx < pframe.r) {
392 if (my > pframe.d)
393 growth += refine(p->kid+DR, mx, ymin, xmax, my, pd-1);
394 if (my < pframe.u)
395 growth += refine(p->kid+UR, mx, my, xmax, ymax, pd-1);
396 }
397 /* recompute sum */
398 if (growth) {
399 setcolor(p->v, 0.0, 0.0, 0.0);
400 for (i = 0; i < 4; i++)
401 addcolor(p->v, p->kid[i].v);
402 scalecolor(p->v, 0.25);
403 }
404 return(growth);
405 }
