root/radiance/ray/src/rt/rv3.c
Revision: 2.45
Committed: Fri Nov 17 20:02:07 2023 UTC (18 months, 1 week ago) by greg
Changes since 2.44: +3 -3 lines
2 static const char RCSid[] = "$Id: rv3.c,v 2.44 2023/11/15 18:02:53 greg Exp $";
5 * rv3.c - miscellaneous routines for rview.
6 *
7 * External symbols declared in rpaint.h
8 */
9
10 #include "copyright.h"
11
12 #include <string.h>
13
14 #include "ray.h"
15 #include "rpaint.h"
16 #include "otypes.h"
17 #include "otspecial.h"
18 #include "random.h"
19
20 #ifndef WFLUSH
21 #define WFLUSH 64 /* flush after this many primary rays */
22 #endif
23 #ifndef WFLUSH1
24 #define WFLUSH1 512 /* or this many total rays */
25 #endif
26
27
28 #ifdef SMLFLT
29 #define sscanvec(s,v) (sscanf(s,"%f %f %f",v,v+1,v+2)==3)
30 #else
31 #define sscanvec(s,v) (sscanf(s,"%lf %lf %lf",v,v+1,v+2)==3)
32 #endif
33
34 extern int ray_pnprocs;
35
36 static RNUMBER niflush; /* flushes since newimage() */
37
38 int
39 getrect( /* get a box */
40 char *s,
41 RECT *r
42 )
43 {
44 int x0, y0, x1, y1;
45
46 if (*s && !strncmp(s, "all", strlen(s))) {
47 r->l = r->d = 0;
48 r->r = hresolu;
49 r->u = vresolu;
50 return(0);
51 }
52 if (sscanf(s, "%d %d %d %d", &x0, &y0, &x1, &y1) != 4) {
53 if (dev->getcur == NULL)
54 return(-1);
55 (*dev->comout)("Pick first corner\n");
56 if ((*dev->getcur)(&x0, &y0) == ABORT)
57 return(-1);
58 (*dev->comout)("Pick second corner\n");
59 if ((*dev->getcur)(&x1, &y1) == ABORT)
60 return(-1);
61 }
62 if (x0 < x1) {
63 r->l = x0;
64 r->r = x1;
65 } else {
66 r->l = x1;
67 r->r = x0;
68 }
69 if (y0 < y1) {
70 r->d = y0;
71 r->u = y1;
72 } else {
73 r->d = y1;
74 r->u = y0;
75 }
76 if (r->l < 0) r->l = 0;
77 if (r->d < 0) r->d = 0;
78 if (r->r > hresolu) r->r = hresolu;
79 if (r->u > vresolu) r->u = vresolu;
80 if (r->l > r->r) r->l = r->r;
81 if (r->d > r->u) r->d = r->u;
82 return(0);
83 }
84
85
86 int
87 getinterest( /* get area of interest */
88 char *s,
89 int direc,
90 FVECT vec,
91 double *mp
92 )
93 {
94 if (sscanf(s, "%lf", mp) != 1)
95 *mp = 1.0;
96 else if (*mp < -FTINY) /* negative zoom is reduction */
97 *mp = -1.0 / *mp;
98 else if (*mp <= FTINY) { /* too small */
99 error(COMMAND, "illegal magnification");
100 return(-1);
101 }
102 if (!sscanvec(sskip(s), vec)) {
103 RAY thisray;
104 int x, y;
105 if (dev->getcur == NULL)
106 return(-1);
107 (*dev->comout)("Pick view center\n");
108 if ((*dev->getcur)(&x, &y) == ABORT)
109 return(-1);
110 if ((thisray.rmax = viewray(thisray.rorg, thisray.rdir,
111 &ourview, (x+.5)/hresolu, (y+.5)/vresolu)) < -FTINY) {
112 error(COMMAND, "not on image");
113 return(-1);
114 }
115 if (!direc || ourview.type == VT_PAR) {
116 int weakhit = 0;
117 FVECT weakpt;
118 rayorigin(&thisray, PRIMARY, NULL, NULL);
119 while (localhit(&thisray, &thescene)) {
120 OBJREC *m = NULL;
121 if (thisray.clipset == NULL ||
122 !inset(thisray.clipset,
123 thisray.ro->omod))
124 m = findmaterial(thisray.ro);
125 if ((m != NULL) & !weakhit &&
126 istransp(m->otype) &&
127 m->otype != MAT_MIST) {
128 weakhit = 1;
129 VCOPY(weakpt, thisray.rop);
130 } else if (m != NULL && !istransp(m->otype) &&
131 !isBSDFproxy(m))
132 break; /* something solid */
133 VCOPY(thisray.rorg, thisray.rop);
134 rayclear(&thisray); /* skip invisible */
135 }
136 if ((thisray.ro == NULL) | (thisray.ro == &Aftplane)) {
137 if (!weakhit) {
138 error(COMMAND, "not a local object");
139 return(-1);
140 } /* else use weak obj. */
141 VCOPY(thisray.rop, weakpt);
142 }
143 }
144 if (direc)
145 if (ourview.type == VT_PAR)
146 VSUB(vec, thisray.rop, ourview.vp);
147 else
148 VCOPY(vec, thisray.rdir);
149 else
150 VCOPY(vec, thisray.rop);
151 } else if (direc) {
152 VSUB(vec, vec, ourview.vp);
153 if (normalize(vec) == 0.0) {
154 error(COMMAND, "point at view origin");
155 return(-1);
156 }
157 }
158 return(0);
159 }
160
161
162 COLORV *
163 greyof( /* convert color to greyscale */
164 COLOR col
165 )
166 {
167 static COLOR gcol;
168 double b;
169
170 b = bright(col);
171 setcolor(gcol, b, b, b);
172 return(gcol);
173 }
174
175 static void
176 recolor( /* recolor the given node */
177 PNODE *p
178 )
179 {
180 while (p->kid != NULL) { /* need to propogate down */
181 int mx = (p->xmin + p->xmax) >> 1;
182 int my = (p->ymin + p->ymax) >> 1;
183 int ki;
184 if (p->x >= mx)
185 ki = (p->y >= my) ? UR : DR;
186 else
187 ki = (p->y >= my) ? UL : DL;
188 pcopy(p, p->kid+ki);
189 p = p->kid + ki;
190 }
191
192 (*dev->paintr)(greyscale?greyof(p->v):p->v,
193 p->xmin, p->ymin, p->xmax, p->ymax);
194 }
195
196 int
197 paint( /* compute and paint a rectangle */
198 PNODE *p
199 )
200 {
201 static RAY thisray;
202 double h, v;
203
204 if ((p->xmax <= p->xmin) | (p->ymax <= p->ymin)) { /* empty */
205 p->x = p->xmin;
206 p->y = p->ymin;
207 setcolor(p->v, 0.0, 0.0, 0.0);
208 return(0);
209 }
210 /* jitter ray direction */
211 p->x = h = p->xmin + (p->xmax-p->xmin)*frandom();
212 p->y = v = p->ymin + (p->ymax-p->ymin)*frandom();
213
214 if ((thisray.rmax = viewray(thisray.rorg, thisray.rdir, &ourview,
215 h/hresolu, v/vresolu)) < -FTINY) {
216 scolorblack(thisray.rcol);
217 } else if (!ray_pnprocs) { /* immediate mode */
218 ray_trace(&thisray);
219 } else { /* queuing mode */
220 int rval;
221 rayorigin(&thisray, PRIMARY, NULL, NULL);
222 thisray.rno = (RNUMBER)p;
223 rval = ray_pqueue(&thisray);
224 if (!rval)
225 return(0);
226 if (rval < 0)
227 return(-1);
228 /* get node for returned ray */
229 p = (PNODE *)thisray.rno;
230 }
231
232 scolor_rgb(p->v, thisray.rcol);
233 scalecolor(p->v, exposure);
234
235 recolor(p); /* paint it */
236
237 if (dev->flush != NULL) { /* shall we check for input? */
238 static RNUMBER lastflush = 0;
239 RNUMBER counter = raynum;
240 int flushintvl;
241 if (!ray_pnprocs) {
242 counter = nrays;
243 flushintvl = WFLUSH1;
244 } else if (ambounce == 0)
245 flushintvl = ray_pnprocs*WFLUSH;
246 else if (niflush < WFLUSH)
247 flushintvl = ray_pnprocs*niflush/(ambounce*(ambounce>0)+1);
248 else
249 flushintvl = ray_pnprocs*WFLUSH/(ambounce*(ambounce>0)+1);
250 if (lastflush > counter)
251 lastflush = 0; /* counter wrapped */
252
253 if (counter - lastflush >= flushintvl) {
254 lastflush = counter;
255 (*dev->flush)();
256 niflush++;
257 }
258 }
259 return(1);
260 }
261
262
263 int
264 waitrays(void) /* finish up pending rays */
265 {
266 int nwaited = 0;
267 int rval;
268 RAY raydone;
269
270 if (!ray_pnprocs) /* immediate mode? */
271 return(0);
272 while ((rval = ray_presult(&raydone, 0)) > 0) {
273 PNODE *p = (PNODE *)raydone.rno;
274 scolor_rgb(p->v, raydone.rcol);
275 scalecolor(p->v, exposure);
276 recolor(p);
277 nwaited++;
278 }
279 if (rval < 0)
280 return(-1);
281 return(nwaited);
282 }
283
284
285 void
286 newimage( /* start a new image */
287 char *s
288 )
289 {
290 int newnp = 0;
291 /* # rendering procs arg? */
292 if (s != NULL)
293 sscanf(s, "%d", &newnp);
294 /* free old image */
295 freepkids(&ptrunk);
296 /* compute resolution */
297 hresolu = dev->xsiz;
298 vresolu = dev->ysiz;
299 normaspect(viewaspect(&ourview), &dev->pixaspect, &hresolu, &vresolu);
300 ptrunk.xmin = ptrunk.ymin = pframe.l = pframe.d = 0;
301 ptrunk.xmax = pframe.r = hresolu;
302 ptrunk.ymax = pframe.u = vresolu;
303 pdepth = 0;
304 /* clear device */
305 (*dev->clear)(hresolu, vresolu);
306
307 if (newparam) { /* (re)start rendering procs */
308 if (ray_pnprocs)
309 ray_pclose(0); /* should already be closed */
310 if (newnp > 0)
311 nproc = newnp;
312 if (nproc > 1)
313 ray_popen(nproc);
314 newparam = 0;
315 } else if ((newnp > 0) & (newnp != nproc)) {
316 if (newnp == 1) /* change # rendering procs */
317 ray_pclose(0);
318 else if (newnp < ray_pnprocs)
319 ray_pclose(ray_pnprocs - newnp);
320 else
321 ray_popen(newnp - ray_pnprocs);
322 nproc = newnp;
323 }
324 niflush = 0; /* get first value */
325 paint(&ptrunk);
326 }
327
328
329 void
330 redraw(void) /* redraw the image */
331 {
332 (*dev->clear)(hresolu, vresolu);
333 (*dev->comout)("redrawing...\n");
334 repaint(0, 0, hresolu, vresolu);
335 (*dev->comout)("\n");
336 }
337
338
339 void
340 repaint( /* repaint a region */
341 int xmin,
342 int ymin,
343 int xmax,
344 int ymax
345 )
346 {
347 RECT reg;
348
349 reg.l = xmin; reg.r = xmax;
350 reg.d = ymin; reg.u = ymax;
351
352 paintrect(&ptrunk, &reg);
353 }
354
355
356 void
357 paintrect( /* paint picture rectangle */
358 PNODE *p,
359 RECT *r
360 )
361 {
362 int mx, my;
363
364 if (p->xmax - p->xmin <= 0 || p->ymax - p->ymin <= 0)
365 return;
366
367 if (p->kid == NULL) {
368 (*dev->paintr)(greyscale?greyof(p->v):p->v,
369 p->xmin, p->ymin, p->xmax, p->ymax); /* do this */
370 return;
371 }
372 mx = (p->xmin + p->xmax) >> 1; /* do kids */
373 my = (p->ymin + p->ymax) >> 1;
374 if (mx > r->l) {
375 if (my > r->d)
376 paintrect(p->kid+DL, r);
377 if (my < r->u)
378 paintrect(p->kid+UL, r);
379 }
380 if (mx < r->r) {
381 if (my > r->d)
382 paintrect(p->kid+DR, r);
383 if (my < r->u)
384 paintrect(p->kid+UR, r);
385 }
386 }
387
388
389 PNODE *
390 findrect( /* find a rectangle */
391 int x,
392 int y,
393 PNODE *p,
394 int pd
395 )
396 {
397 int mx, my;
398
399 while (p->kid != NULL && pd--) {
400
401 mx = (p->xmin + p->xmax) >> 1;
402 my = (p->ymin + p->ymax) >> 1;
403
404 if (x < mx) {
405 if (y < my) {
406 p = p->kid+DL;
407 } else {
408 p = p->kid+UL;
409 }
410 } else {
411 if (y < my) {
412 p = p->kid+DR;
413 } else {
414 p = p->kid+UR;
415 }
416 }
417 }
418 return(p);
419 }
420
421
422 void
423 compavg( /* recompute averages */
424 PNODE *p
425 )
426 {
427 int i, navg;
428
429 if (p->kid == NULL)
430 return;
431
432 setcolor(p->v, .0, .0, .0);
433 navg = 0;
434 for (i = 0; i < 4; i++) {
435 if (p->kid[i].xmin >= p->kid[i].xmax) continue;
436 if (p->kid[i].ymin >= p->kid[i].ymax) continue;
437 compavg(p->kid+i);
438 addcolor(p->v, p->kid[i].v);
439 navg++;
440 }
441 if (navg > 1)
442 scalecolor(p->v, 1./navg);
443 }
444
445
446 void
447 scalepict( /* scale picture values */
448 PNODE *p,
449 double sf
450 )
451 {
452 scalecolor(p->v, sf); /* do this node */
453
454 if (p->kid == NULL)
455 return;
456 /* do children */
457 scalepict(p->kid+DL, sf);
458 scalepict(p->kid+DR, sf);
459 scalepict(p->kid+UL, sf);
460 scalepict(p->kid+UR, sf);
461 }
462
463
464 void
465 getpictcolrs( /* get scanline from picture */
466 int yoff,
467 COLR *scan,
468 PNODE *p,
469 int xsiz,
470 int ysiz
471 )
472 {
473 int mx;
474 int my;
475
476 if (p->kid == NULL) { /* do this node */
477 setcolr(scan[0], colval(p->v,RED),
478 colval(p->v,GRN),
479 colval(p->v,BLU));
480 for (mx = 1; mx < xsiz; mx++)
481 copycolr(scan[mx], scan[0]);
482 return;
483 }
484 /* do kids */
485 mx = xsiz >> 1;
486 my = ysiz >> 1;
487 if (yoff < my) {
488 getpictcolrs(yoff, scan, p->kid+DL, mx, my);
489 getpictcolrs(yoff, scan+mx, p->kid+DR, xsiz-mx, my);
490 } else {
491 getpictcolrs(yoff-my, scan, p->kid+UL, mx, ysiz-my);
492 getpictcolrs(yoff-my, scan+mx, p->kid+UR, xsiz-mx, ysiz-my);
493 }
494 }
495
496
497 void
498 freepkids( /* free pnode's children */
499 PNODE *p
500 )
501 {
502 if (p->kid == NULL)
503 return;
504 freepkids(p->kid+DL);
505 freepkids(p->kid+DR);
506 freepkids(p->kid+UL);
507 freepkids(p->kid+UR);
508 free((void *)p->kid);
509 p->kid = NULL;
510 }
511
512
513 void
514 newview( /* change viewing parameters */
515 VIEW *vp
516 )
517 {
518 char *err;
519
520 if ((err = setview(vp)) != NULL) {
521 sprintf(errmsg, "view not set - %s", err);
522 error(COMMAND, errmsg);
523 } else if (memcmp((char *)vp, (char *)&ourview, sizeof(VIEW))) {
524 oldview = ourview;
525 ourview = *vp;
526 newimage(NULL);
527 }
528 }
529
530
531 void
532 moveview( /* move viewpoint */
533 double angle,
534 double elev,
535 double mag,
536 FVECT vc
537 )
538 {
539 double d;
540 VIEW nv = ourview;
541 int i;
542
543 spinvector(nv.vdir, ourview.vdir, ourview.vup, angle*(PI/180.));
544 if (elev != 0.0)
545 geodesic(nv.vdir, nv.vdir, nv.vup, elev*(-PI/180.), GEOD_RAD);
546
547 if (nv.type == VT_PAR) {
548 nv.horiz /= mag;
549 nv.vert /= mag;
550 d = 0.0; /* don't move closer */
551 for (i = 0; i < 3; i++)
552 d += (vc[i] - ourview.vp[i])*ourview.vdir[i];
553 } else {
554 d = sqrt(dist2(ourview.vp, vc)) / mag;
555 if (nv.vfore > FTINY) {
556 nv.vfore += d - d*mag;
557 if (nv.vfore < 0.0) nv.vfore = 0.0;
558 }
559 if (nv.vaft > FTINY) {
560 nv.vaft += d - d*mag;
561 if (nv.vaft <= nv.vfore) nv.vaft = 0.0;
562 }
563 nv.vdist /= mag;
564 }
565 for (i = 0; i < 3; i++)
566 nv.vp[i] = vc[i] - d*nv.vdir[i];
567 newview(&nv);
568 }
569
570
571 void
572 pcopy( /* copy paint node p1 into p2 */
573 PNODE *p1,
574 PNODE *p2
575 )
576 {
577 copycolor(p2->v, p1->v);
578 p2->x = p1->x;
579 p2->y = p1->y;
580 }
581
582
583 void
584 zoomview( /* zoom in or out */
585 VIEW *vp,
586 double zf
587 )
588 {
589 switch (vp->type) {
590 case VT_PAR: /* parallel view */
591 vp->horiz /= zf;
592 vp->vert /= zf;
593 return;
594 case VT_ANG: /* angular fisheye */
595 vp->horiz /= zf;
596 if (vp->horiz > 360.)
597 vp->horiz = 360.;
598 vp->vert /= zf;
599 if (vp->vert > 360.)
600 vp->vert = 360.;
601 return;
602 case VT_PLS: /* planisphere fisheye */
603 vp->horiz = sin((PI/180./2.)*vp->horiz) /
604 (1.0 + cos((PI/180./2.)*vp->horiz)) / zf;
605 vp->horiz *= vp->horiz;
606 vp->horiz = (2.*180./PI)*acos((1. - vp->horiz) /
607 (1. + vp->horiz));
608 vp->vert = sin((PI/180./2.)*vp->vert) /
609 (1.0 + cos((PI/180./2.)*vp->vert)) / zf;
610 vp->vert *= vp->vert;
611 vp->vert = (2.*180./PI)*acos((1. - vp->vert) /
612 (1. + vp->vert));
613 return;
614 case VT_CYL: /* cylindrical panorama */
615 vp->horiz /= zf;
616 if (vp->horiz > 360.)
617 vp->horiz = 360.;
618 vp->vert = atan(tan(vp->vert*(PI/180./2.))/zf) / (PI/180./2.);
619 return;
620 case VT_PER: /* perspective view */
621 vp->horiz = atan(tan(vp->horiz*(PI/180./2.))/zf) /
622 (PI/180./2.);
623 vp->vert = atan(tan(vp->vert*(PI/180./2.))/zf) /
624 (PI/180./2.);
625 return;
626 case VT_HEM: /* hemispherical fisheye */
627 vp->horiz = sin(vp->horiz*(PI/180./2.))/zf;
628 if (vp->horiz >= 1.0-FTINY)
629 vp->horiz = 180.;
630 else
631 vp->horiz = asin(vp->horiz) / (PI/180./2.);
632 vp->vert = sin(vp->vert*(PI/180./2.))/zf;
633 if (vp->vert >= 1.0-FTINY)
634 vp->vert = 180.;
635 else
636 vp->vert = asin(vp->vert) / (PI/180./2.);
637 return;
638 }
639 }
