root/radiance/ray/src/rt/rv3.c
Revision: 2.15
Committed: Fri Jan 21 00:52:59 2005 UTC (20 years, 4 months ago) by greg
Changes since 2.14: +15 -11 lines
2 static const char RCSid[] = "$Id: rv3.c,v 2.14 2005/01/18 00:33:16 greg Exp $";
5 * rv3.c - miscellaneous routines for rview.
6 *
7 * External symbols declared in rpaint.h
8 */
9
10 #include "copyright.h"
11
12 #include <string.h>
13
14 #include "ray.h"
15 #include "rpaint.h"
16 #include "random.h"
17
18 #ifndef WFLUSH
19 #ifdef SPEED
20 #define WFLUSH (5*SPEED)
21 #else
22 #define WFLUSH 100 /* flush after this many rays */
23 #endif
24 #endif
25
26 #ifdef SMLFLT
27 #define sscanvec(s,v) (sscanf(s,"%f %f %f",v,v+1,v+2)==3)
28 #else
29 #define sscanvec(s,v) (sscanf(s,"%lf %lf %lf",v,v+1,v+2)==3)
30 #endif
31
32
33 int
34 getrect(s, r) /* get a box */
35 char *s;
36 register RECT *r;
37 {
38 int x0, y0, x1, y1;
39
40 if (*s && !strncmp(s, "all", strlen(s))) {
41 r->l = r->d = 0;
42 r->r = hresolu;
43 r->u = vresolu;
44 return(0);
45 }
46 if (sscanf(s, "%d %d %d %d", &x0, &y0, &x1, &y1) != 4) {
47 if (dev->getcur == NULL)
48 return(-1);
49 (*dev->comout)("Pick first corner\n");
50 if ((*dev->getcur)(&x0, &y0) == ABORT)
51 return(-1);
52 (*dev->comout)("Pick second corner\n");
53 if ((*dev->getcur)(&x1, &y1) == ABORT)
54 return(-1);
55 }
56 if (x0 < x1) {
57 r->l = x0;
58 r->r = x1;
59 } else {
60 r->l = x1;
61 r->r = x0;
62 }
63 if (y0 < y1) {
64 r->d = y0;
65 r->u = y1;
66 } else {
67 r->d = y1;
68 r->u = y0;
69 }
70 if (r->l < 0) r->l = 0;
71 if (r->d < 0) r->d = 0;
72 if (r->r > hresolu) r->r = hresolu;
73 if (r->u > vresolu) r->u = vresolu;
74 if (r->l > r->r) r->l = r->r;
75 if (r->d > r->u) r->d = r->u;
76 return(0);
77 }
78
79
80 int
81 getinterest(s, direc, vec, mp) /* get area of interest */
82 char *s;
83 int direc;
84 FVECT vec;
85 double *mp;
86 {
87 int x, y;
88 RAY thisray;
89 register int i;
90
91 if (sscanf(s, "%lf", mp) != 1)
92 *mp = 1.0;
93 else if (*mp < -FTINY) /* negative zoom is reduction */
94 *mp = -1.0 / *mp;
95 else if (*mp <= FTINY) { /* too small */
96 error(COMMAND, "illegal magnification");
97 return(-1);
98 }
99 if (!sscanvec(sskip(s), vec)) {
100 if (dev->getcur == NULL)
101 return(-1);
102 (*dev->comout)("Pick view center\n");
103 if ((*dev->getcur)(&x, &y) == ABORT)
104 return(-1);
105 if ((thisray.rmax = viewray(thisray.rorg, thisray.rdir,
106 &ourview, (x+.5)/hresolu, (y+.5)/vresolu)) < -FTINY) {
107 error(COMMAND, "not on image");
108 return(-1);
109 }
110 if (!direc || ourview.type == VT_PAR) {
111 rayorigin(&thisray, NULL, PRIMARY, 1.0);
112 if (!localhit(&thisray, &thescene)) {
113 error(COMMAND, "not a local object");
114 return(-1);
115 }
116 }
117 if (direc)
118 if (ourview.type == VT_PAR)
119 for (i = 0; i < 3; i++)
120 vec[i] = thisray.rop[i] - ourview.vp[i];
121 else
122 VCOPY(vec, thisray.rdir);
123 else
124 VCOPY(vec, thisray.rop);
125 } else if (direc) {
126 for (i = 0; i < 3; i++)
127 vec[i] -= ourview.vp[i];
128 if (normalize(vec) == 0.0) {
129 error(COMMAND, "point at view origin");
130 return(-1);
131 }
132 }
133 return(0);
134 }
135
136
137 float * /* keep consistent with COLOR typedef */
138 greyof(col) /* convert color to greyscale */
139 register COLOR col;
140 {
141 static COLOR gcol;
142 double b;
143
144 b = bright(col);
145 setcolor(gcol, b, b, b);
146 return(gcol);
147 }
148
149
150 void
151 paint(p, xmin, ymin, xmax, ymax) /* compute and paint a rectangle */
152 register PNODE *p;
153 int xmin, ymin, xmax, ymax;
154 {
155 static unsigned long lastflush = 0;
156 static RAY thisray;
157 double h, v;
158
159 if (xmax - xmin <= 0 || ymax - ymin <= 0) { /* empty */
160 p->x = xmin;
161 p->y = ymin;
162 setcolor(p->v, 0.0, 0.0, 0.0);
163 return;
164 }
165 /* jitter ray direction */
166 h = xmin + (xmax-xmin)*frandom();
167 v = ymin + (ymax-ymin)*frandom();
168
169 if ((thisray.rmax = viewray(thisray.rorg, thisray.rdir, &ourview,
170 h/hresolu, v/vresolu)) < -FTINY) {
171 setcolor(thisray.rcol, 0.0, 0.0, 0.0);
172 } else {
173 rayorigin(&thisray, NULL, PRIMARY, 1.0);
174 samplendx++;
175 rayvalue(&thisray);
176 }
177
178 p->x = h;
179 p->y = v;
180 copycolor(p->v, thisray.rcol);
181 scalecolor(p->v, exposure);
182
183 (*dev->paintr)(greyscale?greyof(p->v):p->v, xmin, ymin, xmax, ymax);
184
185 if (dev->flush != NULL && nrays - lastflush >= WFLUSH) {
186 lastflush = nrays;
187 (*dev->flush)();
188 }
189 }
190
191
192 void
193 newimage() /* start a new image */
194 {
195 /* free old image */
196 freepkids(&ptrunk);
197 /* save reserve memory */
198 fillreserves();
199 /* compute resolution */
200 hresolu = dev->xsiz;
201 vresolu = dev->ysiz;
202 normaspect(viewaspect(&ourview), &dev->pixaspect, &hresolu, &vresolu);
203 pframe.l = pframe.d = 0;
204 pframe.r = hresolu; pframe.u = vresolu;
205 pdepth = 0;
206 /* clear device */
207 (*dev->clear)(hresolu, vresolu);
208 /* get first value */
209 paint(&ptrunk, 0, 0, hresolu, vresolu);
210 }
211
212
213 void
214 redraw() /* redraw the image */
215 {
216 (*dev->clear)(hresolu, vresolu);
217 (*dev->comout)("redrawing...\n");
218 repaint(0, 0, hresolu, vresolu);
219 (*dev->comout)("\n");
220 }
221
222
223 void
224 repaint(xmin, ymin, xmax, ymax) /* repaint a region */
225 int xmin, ymin, xmax, ymax;
226 {
227 RECT reg;
228
229 reg.l = xmin; reg.r = xmax;
230 reg.d = ymin; reg.u = ymax;
231
232 paintrect(&ptrunk, 0, 0, hresolu, vresolu, &reg);
233 }
234
235
236 void
237 paintrect(p, xmin, ymin, xmax, ymax, r) /* paint picture rectangle */
238 register PNODE *p;
239 int xmin, ymin, xmax, ymax;
240 register RECT *r;
241 {
242 int mx, my;
243
244 if (xmax - xmin <= 0 || ymax - ymin <= 0)
245 return;
246
247 if (p->kid == NULL) {
248 (*dev->paintr)(greyscale?greyof(p->v):p->v,
249 xmin, ymin, xmax, ymax); /* do this */
250 return;
251 }
252 mx = (xmin + xmax) >> 1; /* do kids */
253 my = (ymin + ymax) >> 1;
254 if (mx > r->l) {
255 if (my > r->d)
256 paintrect(p->kid+DL, xmin, ymin, mx, my, r);
257 if (my < r->u)
258 paintrect(p->kid+UL, xmin, my, mx, ymax, r);
259 }
260 if (mx < r->r) {
261 if (my > r->d)
262 paintrect(p->kid+DR, mx, ymin, xmax, my, r);
263 if (my < r->u)
264 paintrect(p->kid+UR, mx, my, xmax, ymax, r);
265 }
266 }
267
268
269 PNODE *
270 findrect(x, y, p, r, pd) /* find a rectangle */
271 int x, y;
272 register PNODE *p;
273 register RECT *r;
274 int pd;
275 {
276 int mx, my;
277
278 while (p->kid != NULL && pd--) {
279
280 mx = (r->l + r->r) >> 1;
281 my = (r->d + r->u) >> 1;
282
283 if (x < mx) {
284 r->r = mx;
285 if (y < my) {
286 r->u = my;
287 p = p->kid+DL;
288 } else {
289 r->d = my;
290 p = p->kid+UL;
291 }
292 } else {
293 r->l = mx;
294 if (y < my) {
295 r->u = my;
296 p = p->kid+DR;
297 } else {
298 r->d = my;
299 p = p->kid+UR;
300 }
301 }
302 }
303 return(p);
304 }
305
306
307 void
308 scalepict(p, sf) /* scale picture values */
309 register PNODE *p;
310 double sf;
311 {
312 scalecolor(p->v, sf); /* do this node */
313
314 if (p->kid == NULL)
315 return;
316 /* do children */
317 scalepict(p->kid+DL, sf);
318 scalepict(p->kid+DR, sf);
319 scalepict(p->kid+UL, sf);
320 scalepict(p->kid+UR, sf);
321 }
322
323
324 void
325 getpictcolrs(yoff, scan, p, xsiz, ysiz) /* get scanline from picture */
326 int yoff;
327 register COLR *scan;
328 register PNODE *p;
329 int xsiz, ysiz;
330 {
331 register int mx;
332 int my;
333
334 if (p->kid == NULL) { /* do this node */
335 setcolr(scan[0], colval(p->v,RED),
336 colval(p->v,GRN),
337 colval(p->v,BLU));
338 for (mx = 1; mx < xsiz; mx++)
339 copycolr(scan[mx], scan[0]);
340 return;
341 }
342 /* do kids */
343 mx = xsiz >> 1;
344 my = ysiz >> 1;
345 if (yoff < my) {
346 getpictcolrs(yoff, scan, p->kid+DL, mx, my);
347 getpictcolrs(yoff, scan+mx, p->kid+DR, xsiz-mx, my);
348 } else {
349 getpictcolrs(yoff-my, scan, p->kid+UL, mx, ysiz-my);
350 getpictcolrs(yoff-my, scan+mx, p->kid+UR, xsiz-mx, ysiz-my);
351 }
352 }
353
354
355 void
356 freepkids(p) /* free pnode's children */
357 register PNODE *p;
358 {
359 if (p->kid == NULL)
360 return;
361 freepkids(p->kid+DL);
362 freepkids(p->kid+DR);
363 freepkids(p->kid+UL);
364 freepkids(p->kid+UR);
365 free((void *)p->kid);
366 p->kid = NULL;
367 }
368
369
370 void
371 newview(vp) /* change viewing parameters */
372 register VIEW *vp;
373 {
374 char *err;
375
376 if ((err = setview(vp)) != NULL) {
377 sprintf(errmsg, "view not set - %s", err);
378 error(COMMAND, errmsg);
379 } else if (memcmp((char *)vp, (char *)&ourview, sizeof(VIEW))) {
380 oldview = ourview;
381 ourview = *vp;
382 newimage();
383 }
384 }
385
386
387 void
388 moveview(angle, elev, mag, vc) /* move viewpoint */
389 double angle, elev, mag;
390 FVECT vc;
391 {
392 double d;
393 FVECT v1;
394 VIEW nv = ourview;
395 register int i;
396
397 spinvector(nv.vdir, ourview.vdir, ourview.vup, angle*(PI/180.));
398 if (elev != 0.0) {
399 fcross(v1, ourview.vup, nv.vdir);
400 normalize(v1);
401 spinvector(nv.vdir, nv.vdir, v1, elev*(PI/180.));
402 }
403 if (nv.type == VT_PAR) {
404 nv.horiz /= mag;
405 nv.vert /= mag;
406 d = 0.0; /* don't move closer */
407 for (i = 0; i < 3; i++)
408 d += (vc[i] - ourview.vp[i])*ourview.vdir[i];
409 } else {
410 d = sqrt(dist2(ourview.vp, vc)) / mag;
411 if (nv.vfore > FTINY) {
412 nv.vfore += d - d*mag;
413 if (nv.vfore < 0.0) nv.vfore = 0.0;
414 }
415 if (nv.vaft > FTINY) {
416 nv.vaft += d - d*mag;
417 if (nv.vaft <= nv.vfore) nv.vaft = 0.0;
418 }
419 nv.vdist += d - d*mag;
420 }
421 for (i = 0; i < 3; i++)
422 nv.vp[i] = vc[i] - d*nv.vdir[i];
423 newview(&nv);
424 }
425
426
427 void
428 pcopy(p1, p2) /* copy paint node p1 into p2 */
429 register PNODE *p1, *p2;
430 {
431 copycolor(p2->v, p1->v);
432 p2->x = p1->x;
433 p2->y = p1->y;
434 }
435
436
437 void
438 zoomview(vp, zf) /* zoom in or out */
439 register VIEW *vp;
440 double zf;
441 {
442 switch (vp->type) {
443 case VT_PAR: /* parallel view */
444 vp->horiz /= zf;
445 vp->vert /= zf;
446 return;
447 case VT_ANG: /* angular fisheye */
448 vp->horiz /= zf;
449 if (vp->horiz > 360.)
450 vp->horiz = 360.;
451 vp->vert /= zf;
452 if (vp->vert > 360.)
453 vp->vert = 360.;
454 return;
455 case VT_CYL: /* cylindrical panorama */
456 vp->horiz /= zf;
457 if (vp->horiz > 360.)
458 vp->horiz = 360.;
459 vp->vert = atan(tan(vp->vert*(PI/180./2.))/zf) / (PI/180./2.);
460 return;
461 case VT_PER: /* perspective view */
462 vp->horiz = atan(tan(vp->horiz*(PI/180./2.))/zf) /
463 (PI/180./2.);
464 vp->vert = atan(tan(vp->vert*(PI/180./2.))/zf) /
465 (PI/180./2.);
466 return;
467 case VT_HEM: /* hemispherical fisheye */
468 vp->horiz = sin(vp->horiz*(PI/180./2.))/zf;
469 if (vp->horiz >= 1.0-FTINY)
470 vp->horiz = 180.;
471 else
472 vp->horiz = asin(vp->horiz) / (PI/180./2.);
473 vp->vert = sin(vp->vert*(PI/180./2.))/zf;
474 if (vp->vert >= 1.0-FTINY)
475 vp->vert = 180.;
476 else
477 vp->vert = asin(vp->vert) / (PI/180./2.);
478 return;
479 }
480 }
