root/radiance/ray/src/rt/rv3.c
Thu Sep 6 00:07:43 2012 UTC (11 years, 9 months ago) by greg
Changes since 2.37: +4 -7 lines
Diff to previous 2.37 , to selected 1.16
Tue Mar 20 03:37:08 2012 UTC (12 years, 2 months ago) by greg
Changes since 2.36: +11 -10 lines
Diff to previous 2.36 , to selected 1.16
Improved immediate mode switching
Tue Mar 20 02:56:08 2012 UTC (12 years, 2 months ago) by greg
Diff to previous 2.35 , to selected 1.16
Sat Oct 16 15:08:14 2010 UTC (13 years, 7 months ago) by greg
Changes since 2.34: +15 -15 lines
Diff to previous 2.34 , to selected 1.16
Simplified process handling logic in newimage()
Sat Oct 9 22:38:35 2010 UTC (13 years, 8 months ago) by greg
Changes since 2.33: +1 -3 lines
Diff to previous 2.33 , to selected 1.16
Fixed problem with refining due to random setting of errno
Fri Oct 8 20:41:04 2010 UTC (13 years, 8 months ago) by greg
Changes since 2.32: +4 -1 lines
Diff to previous 2.32 , to selected 1.16
Fixed problem with refining in multiprocessing mode
Sat Dec 12 00:03:42 2009 UTC (14 years, 6 months ago) by greg
Changes since 2.31: +6 -6 lines
Diff to previous 2.31 , to selected 1.16
Wed Dec 3 06:57:48 2008 UTC (15 years, 6 months ago) by greg
Diff to previous 2.30 , to selected 1.16
Took care of ray flush counter wrap
Tue Sep 16 21:14:11 2008 UTC (15 years, 8 months ago) by greg
Changes since 2.29: +7 -8 lines
Diff to previous 2.29 , to selected 1.16
Cosmetic changes
Tue Sep 16 18:35:56 2008 UTC (15 years, 8 months ago) by greg
Changes since 2.28: +44 -24 lines
Diff to previous 2.28 , to selected 1.16
Modified procedure so -n 1 does not invoke subprocess
Fri Sep 5 21:34:09 2008 UTC (15 years, 9 months ago) by greg
Changes since 2.27: +14 -10 lines
Diff to previous 2.27 , to selected 1.16
Really fixed the exposure bug this time
Fri Sep 5 19:45:41 2008 UTC (15 years, 9 months ago) by greg
Changes since 2.26: +21 -1 lines
Diff to previous 2.26 , to selected 1.16
Fixed bug that broke "exposure" command
Fri Aug 29 05:46:03 2008 UTC (15 years, 9 months ago) by greg
Changes since 2.25: +23 -17 lines
Diff to previous 2.25 , to selected 1.16
Additional refinement on repainting algorithm
Thu Aug 28 23:50:39 2008 UTC (15 years, 9 months ago) by greg
Changes since 2.24: +13 -1 lines
Diff to previous 2.24 , to selected 1.16
Fixed bug in redraw for multiprocessing operation
Fri Aug 22 17:39:26 2008 UTC (15 years, 9 months ago) by greg
Changes since 2.23: +12 -5 lines
Diff to previous 2.23 , to selected 1.16
Further improvements to interactivity
Thu Aug 21 16:13:00 2008 UTC (15 years, 9 months ago) by greg
Changes since 2.22: +8 -4 lines
Diff to previous 2.22 , to selected 1.16
Improved responsiveness to command input
Thu Aug 21 07:05:59 2008 UTC (15 years, 9 months ago) by greg
Changes since 2.21: +146 -88 lines
Diff to previous 2.21 , to selected 1.16
Tue Mar 11 02:21:47 2008 UTC (16 years, 3 months ago) by greg
Changes since 2.20: +13 -1 lines
Diff to previous 2.20 , to selected 1.16
Wed Apr 5 06:22:57 2006 UTC (18 years, 2 months ago) by greg
Diff to previous 2.19 , to selected 1.16
Made -u+ option truly random
Mon Sep 19 02:23:58 2005 UTC (18 years, 8 months ago) by greg
Changes since 2.18: +2 -6 lines
Diff to previous 2.18 , to selected 1.16
Mon Jun 13 20:07:56 2005 UTC (19 years ago) by greg
Diff to previous 2.17 , to selected 1.16
Tue Apr 19 01:15:07 2005 UTC (19 years, 1 month ago) by greg
Diff to previous 2.16 , to selected 1.16
Fri Feb 18 17:47:53 2005 UTC (19 years, 3 months ago) by greg
Diff to previous 2.15 , to selected 1.16
Fixed bug in view distance adjustment with "move" command
Fri Jan 21 00:52:59 2005 UTC (19 years, 4 months ago) by greg
Changes since 2.14: +15 -11 lines
Diff to previous 2.14 , to selected 1.16
Tue Jan 18 00:33:16 2005 UTC (19 years, 4 months ago) by greg
Changes since 2.13: +4 -8 lines
Diff to previous 2.13 , to selected 1.16
Diff to previous 2.12 , to selected 1.16
Diff to previous 2.11 , to selected 1.16
Diff to previous 2.10 , to selected 1.16
Changes since 2.9: +83 -18 lines
Diff to previous 2.9 , to selected 1.16
Fri Aug 18 10:27:11 1995 UTC (28 years, 9 months ago) by greg
Changes since 2.8: +14 -1 lines
Diff to previous 2.8 , to selected 1.16
added cylindrical view type
Wed Jan 25 16:08:57 1995 UTC (29 years, 4 months ago) by greg
Diff to previous 2.7 , to selected 1.16
bug fix in aft clipping plane setting in moveview()
Thu Dec 22 11:46:19 1994 UTC (29 years, 5 months ago) by greg
Changes since 2.6: +6 -0 lines
Diff to previous 2.6 , to selected 1.16
made view changes properly manage fore and aft clipping planes
Tue Dec 20 20:18:41 1994 UTC (29 years, 5 months ago) by greg
Diff to previous 2.5 , to selected 1.16
Thu Aug 5 13:05:01 1993 UTC (30 years, 10 months ago) by greg
Diff to previous 2.4 , to selected 1.16
*** empty log message ***
Thu Feb 11 16:42:22 1993 UTC (31 years, 4 months ago) by greg
Diff to previous 2.3 , to selected 1.16
changed WFLUSH to be defined using SPEED if available
Fri Oct 2 16:19:56 1992 UTC (31 years, 8 months ago) by greg
Diff to previous 2.2 , to selected 1.16
Fri Jan 17 09:27:21 1992 UTC (32 years, 5 months ago) by greg
Changes since 2.1: +7 -1 lines
Diff to previous 2.1 , to selected 1.16
fixed bug in use of scanf() with SMLFLT defined
Tue Nov 12 17:09:47 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.20 , to selected 1.16
Tue May 21 17:41:19 1991 UTC (33 years ago) by greg
Changes since 1.19: +1 -0 lines
Diff to previous 1.19 , to selected 1.16
Fri May 3 16:12:38 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.18 , to selected 1.16
Tue Mar 19 13:14:03 1991 UTC (33 years, 3 months ago) by greg
Changes since 1.17: +0 -23 lines
Diff to previous 1.17 , to selected 1.16
moved spinvector() to fvect.c
Sun Oct 14 11:06:27 1990 UTC (33 years, 8 months ago) by greg
Changes since 1.16: +44 -5 lines
Diff to previous 1.16
added fisheye view types
Revision 1.16 - (view) (download) (annotate) - [selected]
Tue Jun 26 09:00:19 1990 UTC (33 years, 11 months ago) by greg
Changes since 1.15: +0 -1 lines
Diff to previous 1.15
Thu Mar 8 10:28:29 1990 UTC (34 years, 3 months ago) by greg
Changes since 1.14: +5 -8 lines
Diff to previous 1.14 , to selected 1.16
cosmetic change to paint()
Tue Feb 27 09:51:00 1990 UTC (34 years, 3 months ago) by greg
Diff to previous 1.13 , to selected 1.16
minor fixes in comments etc.
Thu Feb 22 11:46:15 1990 UTC (34 years, 3 months ago) by greg
Changes since 1.12: +11 -0 lines
Diff to previous 1.12 , to selected 1.16
Fri Jan 19 00:00:31 1990 UTC (34 years, 4 months ago) by greg
Diff to previous 1.11 , to selected 1.16
Tue Jan 9 11:38:19 1990 UTC (34 years, 5 months ago) by greg
Diff to previous 1.10 , to selected 1.16
changed interface to normaspect()
Tue Jan 9 09:07:33 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.9: +3 -7 lines
Diff to previous 1.9 , to selected 1.16
Mon Jan 8 13:38:09 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.8: +26 -26 lines
Diff to previous 1.8 , to selected 1.16
Wed Nov 1 16:12:20 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.7: +0 -3 lines
Diff to previous 1.7 , to selected 1.16
Added ability to call repaint in detached drivers
Fri Oct 27 11:48:23 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.6: +95 -0 lines
Diff to previous 1.6 , to selected 1.16
added repaint command
Mon Jun 19 13:30:04 1989 UTC (34 years, 11 months ago) by greg
Changes since 1.5: +11 -5 lines
Diff to previous 1.5 , to selected 1.16
Added auto-shrink for view parameters on small devices
Tue Jun 13 08:17:24 1989 UTC (35 years ago) by greg
Diff to previous 1.4 , to selected 1.16
Changed sense of elevation in pivot command
Tue May 30 09:57:16 1989 UTC (35 years ago) by greg
Changes since 1.3: +8 -2 lines
Diff to previous 1.3 , to selected 1.16
Added elevation to pivot and zoom to rotate commands
Wed May 24 13:55:54 1989 UTC (35 years ago) by greg
Changes since 1.2: +2 -3 lines
Diff to previous 1.2 , to selected 1.16
more efficient computation of distance
Wed Apr 5 09:38:12 1989 UTC (35 years, 2 months ago) by greg
Diff to previous 1.1 , to selected 1.16
Changed behavior of move command for parallel views
Thu Feb 2 10:41:39 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 1.16
