--- ray/src/rt/rv3.c 1989/05/24 13:55:54 1.3 +++ ray/src/rt/rv3.c 2003/02/25 02:47:23 2.11 @@ -1,22 +1,134 @@ -/* Copyright (c) 1987 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: rv3.c,v 2.11 2003/02/25 02:47:23 greg Exp $"; #endif - /* * rv3.c - miscellaneous routines for rview. * - * 5/11/87 + * External symbols declared in rpaint.h */ +#include "copyright.h" + #include "ray.h" #include "rpaint.h" #include "random.h" +#ifndef WFLUSH +#ifdef SPEED +#define WFLUSH (5*SPEED) +#else +#define WFLUSH 100 /* flush after this many rays */ +#endif +#endif +#ifdef SMLFLT +#define sscanvec(s,v) (sscanf(s,"%f %f %f",v,v+1,v+2)==3) +#else +#define sscanvec(s,v) (sscanf(s,"%lf %lf %lf",v,v+1,v+2)==3) +#endif + + +int +getrect(s, r) /* get a box */ +char *s; +register RECT *r; +{ + int x0, y0, x1, y1; + + if (*s && !strncmp(s, "all", strlen(s))) { + r->l = r->d = 0; + r->r = hresolu; + r->u = vresolu; + return(0); + } + if (sscanf(s, "%d %d %d %d", &x0, &y0, &x1, &y1) != 4) { + if (dev->getcur == NULL) + return(-1); + (*dev->comout)("Pick first corner\n"); + if ((*dev->getcur)(&x0, &y0) == ABORT) + return(-1); + (*dev->comout)("Pick second corner\n"); + if ((*dev->getcur)(&x1, &y1) == ABORT) + return(-1); + } + if (x0 < x1) { + r->l = x0; + r->r = x1; + } else { + r->l = x1; + r->r = x0; + } + if (y0 < y1) { + r->d = y0; + r->u = y1; + } else { + r->d = y1; + r->u = y0; + } + if (r->l < 0) r->l = 0; + if (r->d < 0) r->d = 0; + if (r->r > hresolu) r->r = hresolu; + if (r->u > vresolu) r->u = vresolu; + if (r->l > r->r) r->l = r->r; + if (r->d > r->u) r->d = r->u; + return(0); +} + + +int +getinterest(s, direc, vec, mp) /* get area of interest */ +char *s; +int direc; +FVECT vec; +double *mp; +{ + int x, y; + RAY thisray; + register int i; + + if (sscanf(s, "%lf", mp) != 1) + *mp = 1.0; + else if (*mp < -FTINY) /* negative zoom is reduction */ + *mp = -1.0 / *mp; + else if (*mp <= FTINY) { /* too small */ + error(COMMAND, "illegal magnification"); + return(-1); + } + if (!sscanvec(sskip(s), vec)) { + if (dev->getcur == NULL) + return(-1); + (*dev->comout)("Pick view center\n"); + if ((*dev->getcur)(&x, &y) == ABORT) + return(-1); + if ((thisray.rmax = viewray(thisray.rorg, thisray.rdir, + &ourview, (x+.5)/hresolu, (y+.5)/vresolu)) < -FTINY) { + error(COMMAND, "not on image"); + return(-1); + } + if (!direc || ourview.type == VT_PAR) { + rayorigin(&thisray, NULL, PRIMARY, 1.0); + if (!localhit(&thisray, &thescene)) { + error(COMMAND, "not a local object"); + return(-1); + } + } + if (direc) + if (ourview.type == VT_PAR) + for (i = 0; i < 3; i++) + vec[i] = thisray.rop[i] - ourview.vp[i]; + else + VCOPY(vec, thisray.rdir); + else + VCOPY(vec, thisray.rop); + } else if (direc) + for (i = 0; i < 3; i++) + vec[i] -= ourview.vp[i]; + return(0); +} + + float * /* keep consistent with COLOR typedef */ greyof(col) /* convert color to greyscale */ register COLOR col; @@ -30,13 +142,14 @@ register COLOR col; } +void paint(p, xmin, ymin, xmax, ymax) /* compute and paint a rectangle */ register PNODE *p; int xmin, ymin, xmax, ymax; { + static unsigned long lastflush = 0; static RAY thisray; double h, v; - register int i; if (xmax - xmin <= 0 || ymax - ymin <= 0) { /* empty */ p->x = xmin; @@ -45,49 +158,64 @@ int xmin, ymin, xmax, ymax; return; } /* jitter ray direction */ - p->x = h = xmin + (xmax-xmin)*frandom(); - p->y = v = ymin + (ymax-ymin)*frandom(); + h = xmin + (xmax-xmin)*frandom(); + v = ymin + (ymax-ymin)*frandom(); - rayview(thisray.rorg, thisray.rdir, &ourview, h, v); + if ((thisray.rmax = viewray(thisray.rorg, thisray.rdir, &ourview, + h/hresolu, v/vresolu)) < -FTINY) { + setcolor(thisray.rcol, 0.0, 0.0, 0.0); + } else { + rayorigin(&thisray, NULL, PRIMARY, 1.0); + samplendx++; + rayvalue(&thisray); + } - rayorigin(&thisray, NULL, PRIMARY, 1.0); - - rayvalue(&thisray); - + p->x = h; + p->y = v; copycolor(p->v, thisray.rcol); - scalecolor(p->v, exposure); (*dev->paintr)(greyscale?greyof(p->v):p->v, xmin, ymin, xmax, ymax); + + if (dev->flush != NULL && nrays - lastflush >= WFLUSH) { + lastflush = nrays; + (*dev->flush)(); + } } +void newimage() /* start a new image */ { /* free old image */ freepkids(&ptrunk); - /* set up frame */ - if (ourview.hresolu > dev->xsiz || ourview.vresolu > dev->ysiz) - error(USER, "resolution mismatch"); + /* save reserve memory */ + fillreserves(); + /* compute resolution */ + hresolu = dev->xsiz; + vresolu = dev->ysiz; + normaspect(viewaspect(&ourview), &dev->pixaspect, &hresolu, &vresolu); pframe.l = pframe.d = 0; - pframe.r = ourview.hresolu; pframe.u = ourview.vresolu; + pframe.r = hresolu; pframe.u = vresolu; pdepth = 0; /* clear device */ - (*dev->clear)(ourview.hresolu, ourview.vresolu); + (*dev->clear)(hresolu, vresolu); /* get first value */ - paint(&ptrunk, 0, 0, ourview.hresolu, ourview.vresolu); + paint(&ptrunk, 0, 0, hresolu, vresolu); } +void redraw() /* redraw the image */ { - (*dev->clear)(ourview.hresolu, ourview.vresolu); + (*dev->clear)(hresolu, vresolu); (*dev->comout)("redrawing...\n"); - repaint(0, 0, ourview.hresolu, ourview.vresolu); + repaint(0, 0, hresolu, vresolu); (*dev->comout)("\n"); } +void repaint(xmin, ymin, xmax, ymax) /* repaint a region */ int xmin, ymin, xmax, ymax; { @@ -96,10 +224,11 @@ int xmin, ymin, xmax, ymax; reg.l = xmin; reg.r = xmax; reg.d = ymin; reg.u = ymax; - paintrect(&ptrunk, 0, 0, ourview.hresolu, ourview.vresolu, ®); + paintrect(&ptrunk, 0, 0, hresolu, vresolu, ®); } +void paintrect(p, xmin, ymin, xmax, ymax, r) /* paint picture rectangle */ register PNODE *p; int xmin, ymin, xmax, ymax; @@ -107,9 +236,6 @@ register RECT *r; { int mx, my; - if (dev->inpready) - return; /* break for input */ - if (xmax - xmin <= 0 || ymax - ymin <= 0) return; @@ -173,6 +299,7 @@ int pd; } +void scalepict(p, sf) /* scale picture values */ register PNODE *p; double sf; @@ -189,6 +316,7 @@ double sf; } +void getpictcolrs(yoff, scan, p, xsiz, ysiz) /* get scanline from picture */ int yoff; register COLR *scan; @@ -219,15 +347,7 @@ int xsiz, ysiz; } -pcopy(p1, p2) /* copy paint node p1 into p2 */ -register PNODE *p1, *p2; -{ - copycolor(p2->v, p1->v); - p2->x = p1->x; - p2->y = p1->y; -} - - +void freepkids(p) /* free pnode's children */ register PNODE *p; { @@ -237,51 +357,66 @@ register PNODE *p; freepkids(p->kid+DR); freepkids(p->kid+UL); freepkids(p->kid+UR); - free((char *)p->kid); + free((void *)p->kid); p->kid = NULL; } +void newview(vp) /* change viewing parameters */ register VIEW *vp; { char *err; - if (vp->hresolu > dev->xsiz || vp->vresolu > dev->ysiz) { - error(COMMAND, "view not set - resolution mismatch"); - } else if ((err = setview(vp)) != NULL) { + if ((err = setview(vp)) != NULL) { sprintf(errmsg, "view not set - %s", err); error(COMMAND, errmsg); - } else if (bcmp(vp, &ourview, sizeof(VIEW))) { - bcopy(&ourview, &oldview, sizeof(VIEW)); - bcopy(vp, &ourview, sizeof(VIEW)); + } else if (bcmp((char *)vp, (char *)&ourview, sizeof(VIEW))) { + copystruct(&oldview, &ourview); + copystruct(&ourview, vp); newimage(); } } -moveview(angle, mag, vc) /* move viewpoint */ -double angle, mag; +void +moveview(angle, elev, mag, vc) /* move viewpoint */ +double angle, elev, mag; FVECT vc; { - extern double sqrt(), dist2(); double d; + FVECT v1; VIEW nv; register int i; VCOPY(nv.vup, ourview.vup); - nv.hresolu = ourview.hresolu; nv.vresolu = ourview.vresolu; + nv.hoff = ourview.hoff; nv.voff = ourview.voff; spinvector(nv.vdir, ourview.vdir, ourview.vup, angle*(PI/180.)); + if (elev != 0.0) { + fcross(v1, ourview.vup, nv.vdir); + normalize(v1); + spinvector(nv.vdir, nv.vdir, v1, elev*(PI/180.)); + } if ((nv.type = ourview.type) == VT_PAR) { nv.horiz = ourview.horiz / mag; nv.vert = ourview.vert / mag; d = 0.0; /* don't move closer */ for (i = 0; i < 3; i++) d += (vc[i] - ourview.vp[i])*ourview.vdir[i]; + nv.vfore = ourview.vfore; + nv.vaft = ourview.vaft; } else { nv.horiz = ourview.horiz; nv.vert = ourview.vert; d = sqrt(dist2(ourview.vp, vc)) / mag; + if ((nv.vfore = ourview.vfore) > FTINY) { + nv.vfore += d - d*mag; + if (nv.vfore < 0.0) nv.vfore = 0.0; + } + if ((nv.vaft = ourview.vaft) > FTINY) { + nv.vaft += d - d*mag; + if (nv.vaft <= nv.vfore) nv.vaft = 0.0; + } } for (i = 0; i < 3; i++) nv.vp[i] = vc[i] - d*nv.vdir[i]; @@ -289,24 +424,57 @@ FVECT vc; } -spinvector(vres, vorig, vnorm, theta) /* rotate vector around normal */ -FVECT vres, vorig, vnorm; -double theta; +void +pcopy(p1, p2) /* copy paint node p1 into p2 */ +register PNODE *p1, *p2; { - extern double sin(), cos(); - double sint, cost, dotp; - FVECT vperp; - register int i; - - if (theta == 0.0) { - VCOPY(vres, vorig); + copycolor(p2->v, p1->v); + p2->x = p1->x; + p2->y = p1->y; +} + + +void +zoomview(vp, zf) /* zoom in or out */ +register VIEW *vp; +double zf; +{ + switch (vp->type) { + case VT_PAR: /* parallel view */ + vp->horiz /= zf; + vp->vert /= zf; return; + case VT_ANG: /* angular fisheye */ + vp->horiz /= zf; + if (vp->horiz > 360.) + vp->horiz = 360.; + vp->vert /= zf; + if (vp->vert > 360.) + vp->vert = 360.; + return; + case VT_CYL: /* cylindrical panorama */ + vp->horiz /= zf; + if (vp->horiz > 360.) + vp->horiz = 360.; + vp->vert = atan(tan(vp->vert*(PI/180./2.))/zf) / (PI/180./2.); + return; + case VT_PER: /* perspective view */ + vp->horiz = atan(tan(vp->horiz*(PI/180./2.))/zf) / + (PI/180./2.); + vp->vert = atan(tan(vp->vert*(PI/180./2.))/zf) / + (PI/180./2.); + return; + case VT_HEM: /* hemispherical fisheye */ + vp->horiz = sin(vp->horiz*(PI/180./2.))/zf; + if (vp->horiz >= 1.0-FTINY) + vp->horiz = 180.; + else + vp->horiz = asin(vp->horiz) / (PI/180./2.); + vp->vert = sin(vp->vert*(PI/180./2.))/zf; + if (vp->vert >= 1.0-FTINY) + vp->vert = 180.; + else + vp->vert = asin(vp->vert) / (PI/180./2.); + return; } - sint = sin(theta); - cost = cos(theta); - dotp = DOT(vorig, vnorm); - fcross(vperp, vnorm, vorig); - for (i = 0; i < 3; i++) - vres[i] = vnorm[i]*dotp*(1.-cost) + - vorig[i]*cost + vperp[i]*sint; }
