root/radiance/ray/src/rt/rv3.c
Revision 2.13 - (view) (download) (annotate) - [selected]
Diff to previous 2.12
Changes since 2.9: +83 -18 lines
Fri Aug 18 10:27:11 1995 UTC (28 years, 8 months ago) by greg
Changes since 2.8: +14 -1 lines
added cylindrical view type
Wed Jan 25 16:08:57 1995 UTC (29 years, 3 months ago) by greg
bug fix in aft clipping plane setting in moveview()
Thu Dec 22 11:46:19 1994 UTC (29 years, 4 months ago) by greg
Changes since 2.6: +6 -0 lines
made view changes properly manage fore and aft clipping planes
Tue Dec 20 20:18:41 1994 UTC (29 years, 4 months ago) by greg
Thu Aug 5 13:05:01 1993 UTC (30 years, 9 months ago) by greg
*** empty log message ***
Thu Feb 11 16:42:22 1993 UTC (31 years, 2 months ago) by greg
changed WFLUSH to be defined using SPEED if available
Fri Oct 2 16:19:56 1992 UTC (31 years, 7 months ago) by greg
Fri Jan 17 09:27:21 1992 UTC (32 years, 3 months ago) by greg
Changes since 2.1: +7 -1 lines
fixed bug in use of scanf() with SMLFLT defined
Tue Nov 12 17:09:47 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.20 , to selected 2.13
Tue May 21 17:41:19 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.19: +1 -0 lines
Diff to previous 1.19 , to selected 2.13
Fri May 3 16:12:38 1991 UTC (33 years ago) by greg
Diff to previous 1.18 , to selected 2.13
Tue Mar 19 13:14:03 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.17: +0 -23 lines
Diff to previous 1.17 , to selected 2.13
moved spinvector() to fvect.c
Sun Oct 14 11:06:27 1990 UTC (33 years, 6 months ago) by greg
Changes since 1.16: +44 -5 lines
Diff to previous 1.16 , to selected 2.13
added fisheye view types
Tue Jun 26 09:00:19 1990 UTC (33 years, 10 months ago) by greg
Changes since 1.15: +0 -1 lines
Diff to previous 1.15 , to selected 2.13
Thu Mar 8 10:28:29 1990 UTC (34 years, 2 months ago) by greg
Changes since 1.14: +5 -8 lines
Diff to previous 1.14 , to selected 2.13
cosmetic change to paint()
Tue Feb 27 09:51:00 1990 UTC (34 years, 2 months ago) by greg
Diff to previous 1.13 , to selected 2.13
minor fixes in comments etc.
Thu Feb 22 11:46:15 1990 UTC (34 years, 2 months ago) by greg
Changes since 1.12: +11 -0 lines
Diff to previous 1.12 , to selected 2.13
Fri Jan 19 00:00:31 1990 UTC (34 years, 3 months ago) by greg
Diff to previous 1.11 , to selected 2.13
Tue Jan 9 11:38:19 1990 UTC (34 years, 3 months ago) by greg
Diff to previous 1.10 , to selected 2.13
changed interface to normaspect()
Tue Jan 9 09:07:33 1990 UTC (34 years, 3 months ago) by greg
Changes since 1.9: +3 -7 lines
Diff to previous 1.9 , to selected 2.13
Mon Jan 8 13:38:09 1990 UTC (34 years, 3 months ago) by greg
Changes since 1.8: +26 -26 lines
Diff to previous 1.8 , to selected 2.13
Wed Nov 1 16:12:20 1989 UTC (34 years, 6 months ago) by greg
Changes since 1.7: +0 -3 lines
Diff to previous 1.7 , to selected 2.13
Added ability to call repaint in detached drivers
Fri Oct 27 11:48:23 1989 UTC (34 years, 6 months ago) by greg
Changes since 1.6: +95 -0 lines
Diff to previous 1.6 , to selected 2.13
added repaint command
Mon Jun 19 13:30:04 1989 UTC (34 years, 10 months ago) by greg
Changes since 1.5: +11 -5 lines
Diff to previous 1.5 , to selected 2.13
Added auto-shrink for view parameters on small devices
Tue Jun 13 08:17:24 1989 UTC (34 years, 10 months ago) by greg
Diff to previous 1.4 , to selected 2.13
Changed sense of elevation in pivot command
Tue May 30 09:57:16 1989 UTC (34 years, 11 months ago) by greg
Changes since 1.3: +8 -2 lines
Diff to previous 1.3 , to selected 2.13
Added elevation to pivot and zoom to rotate commands
Wed May 24 13:55:54 1989 UTC (34 years, 11 months ago) by greg
Changes since 1.2: +2 -3 lines
Diff to previous 1.2 , to selected 2.13
more efficient computation of distance
Wed Apr 5 09:38:12 1989 UTC (35 years, 1 month ago) by greg
Diff to previous 1.1 , to selected 2.13
Changed behavior of move command for parallel views
Thu Feb 2 10:41:39 1989 UTC (35 years, 3 months ago) by greg
Diff to selected 2.13
