Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added cylindrical view type
bug fix in aft clipping plane setting in moveview()
made view changes properly manage fore and aft clipping planes
*** empty log message ***
changed WFLUSH to be defined using SPEED if available
fixed bug in use of scanf() with SMLFLT defined
moved spinvector() to fvect.c
added fisheye view types
cosmetic change to paint()
minor fixes in comments etc.
changed interface to normaspect()
Added ability to call repaint in detached drivers
added repaint command
Added auto-shrink for view parameters on small devices
Changed sense of elevation in pivot command
Added elevation to pivot and zoom to rotate commands
more efficient computation of distance
Changed behavior of move command for parallel views
