--- ray/src/rt/rv2.c 2021/02/12 00:41:19 2.72 +++ ray/src/rt/rv2.c 2025/06/20 03:43:17 2.81 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rv2.c,v 2.72 2021/02/12 00:41:19 greg Exp $"; +static const char RCSid[] = "$Id: rv2.c,v 2.81 2025/06/20 03:43:17 greg Exp $"; #endif /* * rv2.c - command routines used in tracing a view. @@ -14,7 +14,6 @@ static const char RCSid[] = "$Id: rv2.c,v 2.72 2021/02 #include "platform.h" #include "rtprocess.h" /* win_popen() */ -#include "paths.h" #include "ray.h" #include "ambient.h" #include "otypes.h" @@ -374,13 +373,20 @@ getorigin( /* origin viewpoint */ ) { VIEW nv = ourview; + FVECT voff; + int i; double d; - /* get new view origin */ - if (sscanf(s, "%lf %lf", &d, &d) == 1) { - /* just moving some distance */ - VSUM(nv.vp, nv.vp, nv.vdir, d); - } else if (!sscanvec(s, nv.vp)) { - int x, y; /* need to pick origin */ + /* check for view origin shift */ + if (sscanf(s, "%lf", &d) == 1) { + double d_fore=d, d_right=0, d_up=0; + sscanf(s, "%*f %lf %lf", &d_right, &d_up); + d_right /= sqrt(nv.hn2); + for (i = 3; i--; ) + nv.vp[i] += d_fore*nv.vdir[i] + + d_right*nv.hvec[i] + + d_up*nv.vup[i]; + } else { /* else pick new origin */ + int x, y; RAY thisray; if (dev->getcur == NULL) return; @@ -401,17 +407,15 @@ getorigin( /* origin viewpoint */ flipsurface(&thisray); VSUM(nv.vp, thisray.rop, thisray.ron, 20.0*FTINY); VCOPY(nv.vdir, thisray.ron); - } else if (!sscanvec(sskip2(s,3), nv.vdir) || normalize(nv.vdir) == 0.0) - VCOPY(nv.vdir, ourview.vdir); - - d = DOT(nv.vdir, nv.vup); /* need different up vector? */ - if (d*d >= 1.-2.*FTINY) { - int i; - nv.vup[0] = nv.vup[1] = nv.vup[2] = 0.0; - for (i = 3; i--; ) - if (nv.vdir[i]*nv.vdir[i] < 0.34) - break; - nv.vup[i] = 1.; + d = DOT(nv.vdir, nv.vup); + if (d*d >= 1.-2.*FTINY) { + /* need different up vector */ + nv.vup[0] = nv.vup[1] = nv.vup[2] = 0.0; + for (i = 3; i--; ) + if (nv.vdir[i]*nv.vdir[i] < 0.34) + break; + nv.vup[i] = 1.; + } } newview(&nv); } @@ -459,7 +463,7 @@ getexposure( /* get new exposure */ return; } } - if (*cp == '+' || *cp == '-') /* f-stops */ + if ((*cp == '+') | (*cp == '-')) /* f-stops */ e *= pow(2.0, atof(cp)); else /* multiplier */ e *= atof(cp); @@ -520,7 +524,7 @@ getparam( /* get variable from user */ if (sscanf(buf, "%lf", &d0) != 1) return(0); } - if (FABSEQ(ptr->d, d0)) + if (FRELEQ(ptr->d, d0)) return(0); ptr->d = d0; break; @@ -552,9 +556,9 @@ getparam( /* get variable from user */ if (sscanf(buf, "%lf %lf %lf", &d0, &d1, &d2) != 3) return(0); } - if (FABSEQ(colval(ptr->C,RED), d0) && - FABSEQ(colval(ptr->C,GRN), d1) && - FABSEQ(colval(ptr->C,BLU), d2)) + if (FRELEQ(colval(ptr->C,RED), d0) && + FRELEQ(colval(ptr->C,GRN), d1) && + FRELEQ(colval(ptr->C,BLU), d2)) return(0); setcolor(ptr->C, d0, d1, d2); break; @@ -582,18 +586,17 @@ setparam( /* get/set program parameter */ } switch (s[0]) { case 'u': /* uncorrelated sampling */ - getparam(s+1, "uncorrelated sampling", 'b', - (void *)&rand_samp); + if (getparam(s+1, "uncorrelated sampling", 'b', + (void *)&rand_samp)) + reset_random(); break; case 'l': /* limit */ switch (s[1]) { case 'w': /* weight */ - getparam(s+2, "limit weight", 'r', - (void *)&minweight); + getparam(s+2, "limit weight", 'r', &minweight); break; case 'r': /* reflection */ - getparam(s+2, "limit reflection", 'i', - (void *)&maxdepth); + getparam(s+2, "limit reflection", 'i', &maxdepth); break; default: goto badparam; @@ -602,24 +605,19 @@ setparam( /* get/set program parameter */ case 'd': /* direct */ switch (s[1]) { case 'j': /* jitter */ - getparam(s+2, "direct jitter", 'r', - (void *)&dstrsrc); + getparam(s+2, "direct jitter", 'r', &dstrsrc); break; case 'c': /* certainty */ - getparam(s+2, "direct certainty", 'r', - (void *)&shadcert); + getparam(s+2, "direct certainty", 'r', &shadcert); break; case 't': /* threshold */ - getparam(s+2, "direct threshold", 'r', - (void *)&shadthresh); + getparam(s+2, "direct threshold", 'r', &shadthresh); break; case 'v': /* visibility */ - getparam(s+2, "direct visibility", 'b', - (void *)&directvis); + getparam(s+2, "direct visibility", 'b', &directvis); break; case 's': /* sampling */ - getparam(s+2, "direct sampling", 'r', - (void *)&srcsizerat); + getparam(s+2, "direct sampling", 'r', &srcsizerat); break; default: goto badparam; @@ -635,8 +633,7 @@ setparam( /* get/set program parameter */ case ' ': case 'y': case 'Y': case 't': case 'T': case '1': case '+': case 'n': case 'N': case 'f': case 'F': case '0': case '-': - getparam(s+1, "black and white", 'b', - (void *)&greyscale); + getparam(s+1, "black and white", 'b', &greyscale); newparam = prev_newp; break; default: @@ -644,39 +641,31 @@ setparam( /* get/set program parameter */ } break; case 'i': /* irradiance */ - getparam(s+1, "irradiance", 'b', - (void *)&do_irrad); + getparam(s+1, "irradiance", 'b', &do_irrad); break; case 'a': /* ambient */ switch (s[1]) { case 'v': /* value */ - getparam(s+2, "ambient value", 'C', - (void *)ambval); + getparam(s+2, "ambient value", 'C', ambval); break; case 'w': /* weight */ - getparam(s+2, "ambient value weight", 'i', - (void *)&ambvwt); + getparam(s+2, "ambient value weight", 'i', &ambvwt); break; case 'a': /* accuracy */ - if (getparam(s+2, "ambient accuracy", 'r', - (void *)&ambacc)) + if (getparam(s+2, "ambient accuracy", 'r', &ambacc)) setambacc(ambacc); break; case 'd': /* divisions */ - getparam(s+2, "ambient divisions", 'i', - (void *)&ambdiv); + getparam(s+2, "ambient divisions", 'i', &ambdiv); break; case 's': /* samples */ - getparam(s+2, "ambient super-samples", 'i', - (void *)&ambssamp); + getparam(s+2, "ambient super-samples", 'i', &ambssamp); break; case 'b': /* bounces */ - getparam(s+2, "ambient bounces", 'i', - (void *)&ambounce); + getparam(s+2, "ambient bounces", 'i', &ambounce); break; case 'r': - if (getparam(s+2, "ambient resolution", 'i', - (void *)&ambres)) + if (getparam(s+2, "ambient resolution", 'i', &ambres)) setambres(ambres); break; default: @@ -686,20 +675,16 @@ setparam( /* get/set program parameter */ case 'm': /* medium */ switch (s[1]) { case 'e': /* extinction coefficient */ - getparam(s+2, "extinction coefficient", 'C', - (void *)cextinction); + getparam(s+2, "extinction coefficient", 'C', cextinction); break; case 'a': /* scattering albedo */ - getparam(s+2, "scattering albedo", 'C', - (void *)salbedo); + getparam(s+2, "scattering albedo", 'C', salbedo); break; case 'g': /* scattering eccentricity */ - getparam(s+2, "scattering eccentricity", 'r', - (void *)&seccg); + getparam(s+2, "scattering eccentricity", 'r', &seccg); break; case 's': /* sampling distance */ - getparam(s+2, "mist sampling distance", 'r', - (void *)&ssampdist); + getparam(s+2, "mist sampling distance", 'r', &ssampdist); break; default: goto badparam; @@ -708,13 +693,11 @@ setparam( /* get/set program parameter */ case 'p': /* pixel */ switch (s[1]) { case 's': /* sample */ - if (getparam(s+2, "pixel sample", 'i', - (void *)&psample)) + if (getparam(s+2, "pixel sample", 'i', &psample)) pdepth = 0; break; case 't': /* threshold */ - if (getparam(s+2, "pixel threshold", 'r', - (void *)&maxdiff)) + if (getparam(s+2, "pixel threshold", 'r', &maxdiff)) pdepth = 0; break; default: @@ -725,12 +708,10 @@ setparam( /* get/set program parameter */ case 's': /* specular */ switch (s[1]) { case 's': /* sampling */ - getparam(s+2, "specular sampling", 'r', - (void *)&specjitter); + getparam(s+2, "specular sampling", 'r', &specjitter); break; case 't': /* threshold */ - getparam(s+2, "specular threshold", 'r', - (void *)&specthresh); + getparam(s+2, "specular threshold", 'r', &specthresh); break; default: goto badparam; @@ -755,6 +736,7 @@ traceray( /* trace a single ray */ { RAY thisray; char buf[512]; + COLOR col; thisray.rmax = 0.0; @@ -814,17 +796,18 @@ traceray( /* trace a single ray */ if (thisray.rot >= FHUGE*.99) (*dev->comout)("at infinity"); else { - sprintf(buf, "at (%.6g %.6g %.6g) (%.6g)", + sprintf(buf, "at (%.3f %.3f %.3f) (%.6g)", thisray.rop[0], thisray.rop[1], thisray.rop[2], raydistance(&thisray)); (*dev->comout)(buf); } (*dev->comin)(buf, NULL); - sprintf(buf, "value (%.5g %.5g %.5g) (%.3gL)", - colval(thisray.rcol,RED), - colval(thisray.rcol,GRN), - colval(thisray.rcol,BLU), - luminance(thisray.rcol)); + scolor_rgb(col, thisray.rcol); + sprintf(buf, "value (%.4g %.4g %.4g) (%.3gL)", + colval(col,RED), + colval(col,GRN), + colval(col,BLU), + luminance(col)); (*dev->comout)(buf); } (*dev->comin)(buf, NULL); @@ -870,6 +853,7 @@ writepict( /* write the picture to a file */ fputexpos(exposure, fp); if (dev->pixaspect != 1.0) fputaspect(dev->pixaspect, fp); + fputprims(stdprims, fp); fputformat(COLRFMT, fp); putc('\n', fp); fprtresolu(hresolu, vresolu, fp);
