--- ray/src/rt/rv2.c 2006/06/07 17:52:04 2.54 +++ ray/src/rt/rv2.c 2008/08/21 07:05:59 2.55 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rv2.c,v 2.54 2006/06/07 17:52:04 schorsch Exp $"; +static const char RCSid[] = "$Id: rv2.c,v 2.55 2008/08/21 07:05:59 greg Exp $"; #endif /* * rv2.c - command routines used in tracing a view. @@ -36,7 +36,7 @@ extern char *progname; extern char *octname; -extern void +void getframe( /* get a new frame */ char *s ) @@ -47,7 +47,7 @@ getframe( /* get a new frame */ } -extern void +void getrepaint( /* get area and repaint */ char *s ) @@ -56,11 +56,11 @@ getrepaint( /* get area and repaint */ if (getrect(s, &box) < 0) return; - paintrect(&ptrunk, 0, 0, hresolu, vresolu, &box); + paintrect(&ptrunk, &box); } -extern void +void getview( /* get/show view parameters */ char *s ) @@ -153,7 +153,7 @@ getview( /* get/show view parameters */ } -extern void +void lastview( /* return to a previous view */ char *s ) @@ -184,11 +184,11 @@ lastview( /* return to a previous view */ nv = ourview; ourview = oldview; oldview = nv; - newimage(); + newimage(NULL); } -extern void +void saveview( /* save view to rad file */ char *s ) @@ -226,7 +226,7 @@ saveview( /* save view to rad file */ } -extern void +void loadview( /* load view from rad file */ char *s ) @@ -269,7 +269,7 @@ loadview( /* load view from rad file */ } -extern void +void getaim( /* aim camera */ char *s ) @@ -284,7 +284,7 @@ getaim( /* aim camera */ } -extern void +void getfocus( /* set focus distance */ char *s ) @@ -321,7 +321,7 @@ getfocus( /* set focus distance */ } -extern void +void getmove( /* move camera */ char *s ) @@ -335,7 +335,7 @@ getmove( /* move camera */ } -extern void +void getrotate( /* rotate camera */ char *s ) @@ -360,9 +360,9 @@ getrotate( /* rotate camera */ } -extern void +void getpivot( /* pivot viewpoint */ - register char *s + char *s ) { FVECT vc; @@ -379,16 +379,15 @@ getpivot( /* pivot viewpoint */ } -extern void +void getexposure( /* get new exposure */ char *s ) { char buf[128]; - register char *cp; - RECT r; + char *cp; int x, y; - register PNODE *p = &ptrunk; + PNODE *p = &ptrunk; int adapt = 0; double e = 1.0; @@ -405,9 +404,7 @@ getexposure( /* get new exposure */ (*dev->comout)("Pick point for exposure\n"); if ((*dev->getcur)(&x, &y) == ABORT) return; - r.l = r.d = 0; - r.r = hresolu; r.u = vresolu; - p = findrect(x, y, &ptrunk, &r, -1); + p = findrect(x, y, &ptrunk, -1); } else { if (*cp == '=') { /* absolute setting */ p = NULL; @@ -448,7 +445,7 @@ getexposure( /* get new exposure */ typedef union {int i; double d; COLOR C;} *MyUptr; -extern int +int getparam( /* get variable from user */ char *str, char *dsc, @@ -456,7 +453,7 @@ getparam( /* get variable from user */ void *p ) { - register MyUptr ptr = (MyUptr)p; + MyUptr ptr = (MyUptr)p; int i0; double d0, d1, d2; char buf[48]; @@ -472,7 +469,7 @@ getparam( /* get variable from user */ return(0); } ptr->i = i0; - return(1); + break; case 'r': /* real */ if (sscanf(str, "%lf", &d0) != 1) { (*dev->comout)(dsc); @@ -483,7 +480,7 @@ getparam( /* get variable from user */ return(0); } ptr->d = d0; - return(1); + break; case 'b': /* boolean */ if (sscanf(str, "%1s", buf) != 1) { (*dev->comout)(dsc); @@ -495,7 +492,7 @@ getparam( /* get variable from user */ return(0); } ptr->i = strchr("yY+1tT", buf[0]) != NULL; - return(1); + break; case 'C': /* color */ if (sscanf(str, "%lf %lf %lf", &d0, &d1, &d2) != 3) { (*dev->comout)(dsc); @@ -509,15 +506,18 @@ getparam( /* get variable from user */ return(0); } setcolor(ptr->C, d0, d1, d2); - return(1); + break; + default: + return(0); /* shouldn't happen */ } - return 0; /* nothing matched */ + newparam++; + return(1); } -extern void +void setparam( /* get/set program parameter */ - register char *s + char *s ) { char buf[128]; @@ -694,9 +694,10 @@ badparam: } -extern void -traceray(s) /* trace a single ray */ -char *s; +void +traceray( /* trace a single ray */ + char *s +) { char buf[128]; int x, y; @@ -777,9 +778,10 @@ char *s; } -extern void -writepict(s) /* write the picture to a file */ -char *s; +void +writepict( /* write the picture to a file */ + char *s +) { static char buf[128]; char *fname;
