root/radiance/ray/src/rt/rv2.c
Revision: 2.52
Committed: Thu Jun 16 01:55:44 2005 UTC (20 years, 1 month ago) by greg
CVS Tags: rad3R7P1
Removed extra semicolon (syntax error on some compilers)
2 static const char RCSid[] = "$Id: rv2.c,v 2.51 2005/06/14 03:34:14 greg Exp $";
5 * rv2.c - command routines used in tracing a view.
6 *
7 * External symbols declared in rpaint.h
8 */
9
10 #include "copyright.h"
11
12 #include <ctype.h>
13 #include <string.h>
14
15 #include "platform.h"
16 #include "ray.h"
17 #include "source.h"
18 #include "ambient.h"
19 #include "otypes.h"
20 #include "rpaint.h"
21
22 extern int psample; /* pixel sample size */
23 extern double maxdiff; /* max. sample difference */
24
25 #define CTRL(c) ((c)-'@')
26
27 #ifdef SMLFLT
28 #define sscanvec(s,v) (sscanf(s,"%f %f %f",v,v+1,v+2)==3)
29 #else
30 #define sscanvec(s,v) (sscanf(s,"%lf %lf %lf",v,v+1,v+2)==3)
31 #endif
32
33 extern char rifname[128]; /* rad input file name */
34
35 extern char *progname;
36 extern char *octname;
37
38
39 extern void
40 getframe( /* get a new frame */
41 char *s
42 )
43 {
44 if (getrect(s, &pframe) < 0)
45 return;
46 pdepth = 0;
47 }
48
49
50 extern void
51 getrepaint( /* get area and repaint */
52 char *s
53 )
54 {
55 RECT box;
56
57 if (getrect(s, &box) < 0)
58 return;
59 paintrect(&ptrunk, 0, 0, hresolu, vresolu, &box);
60 }
61
62
63 extern void
64 getview( /* get/show view parameters */
65 char *s
66 )
67 {
68 FILE *fp;
69 char buf[128];
70 char *fname;
71 int change = 0;
72 VIEW nv = ourview;
73
74 while (isspace(*s))
75 s++;
76 if (*s == '-') { /* command line parameters */
77 if (sscanview(&nv, s))
78 newview(&nv);
79 else
80 error(COMMAND, "bad view option(s)");
81 return;
82 }
83 if (sscanf(s, "%s", buf) == 1) { /* write parameters to a file */
84 if ((fname = getpath(buf, NULL, 0)) == NULL ||
85 (fp = fopen(fname, "a")) == NULL) {
86 sprintf(errmsg, "cannot open \"%s\"", buf);
87 error(COMMAND, errmsg);
88 return;
89 }
90 fputs(progname, fp);
91 fprintview(&ourview, fp);
92 fputs(sskip(s), fp);
93 putc('\n', fp);
94 fclose(fp);
95 return;
96 }
97 sprintf(buf, "view type (%c): ", ourview.type);
98 (*dev->comout)(buf);
99 (*dev->comin)(buf, NULL);
100 if (buf[0] == CTRL('C')) return;
101 if (buf[0] && buf[0] != ourview.type) {
102 nv.type = buf[0];
103 change++;
104 }
105 sprintf(buf, "view point (%.6g %.6g %.6g): ",
106 ourview.vp[0], ourview.vp[1], ourview.vp[2]);
107 (*dev->comout)(buf);
108 (*dev->comin)(buf, NULL);
109 if (buf[0] == CTRL('C')) return;
110 if (sscanvec(buf, nv.vp))
111 change++;
112 sprintf(buf, "view direction (%.6g %.6g %.6g): ",
113 ourview.vdir[0]*ourview.vdist,
114 ourview.vdir[1]*ourview.vdist,
115 ourview.vdir[2]*ourview.vdist);
116 (*dev->comout)(buf);
117 (*dev->comin)(buf, NULL);
118 if (buf[0] == CTRL('C')) return;
119 if (sscanvec(buf, nv.vdir)) {
120 nv.vdist = 1.;
121 change++;
122 }
123 sprintf(buf, "view up (%.6g %.6g %.6g): ",
124 ourview.vup[0], ourview.vup[1], ourview.vup[2]);
125 (*dev->comout)(buf);
126 (*dev->comin)(buf, NULL);
127 if (buf[0] == CTRL('C')) return;
128 if (sscanvec(buf, nv.vup))
129 change++;
130 sprintf(buf, "view horiz and vert size (%.6g %.6g): ",
131 ourview.horiz, ourview.vert);
132 (*dev->comout)(buf);
133 (*dev->comin)(buf, NULL);
134 if (buf[0] == CTRL('C')) return;
135 if (sscanf(buf, "%lf %lf", &nv.horiz, &nv.vert) == 2)
136 change++;
137 sprintf(buf, "fore and aft clipping plane (%.6g %.6g): ",
138 ourview.vfore, ourview.vaft);
139 (*dev->comout)(buf);
140 (*dev->comin)(buf, NULL);
141 if (buf[0] == CTRL('C')) return;
142 if (sscanf(buf, "%lf %lf", &nv.vfore, &nv.vaft) == 2)
143 change++;
144 sprintf(buf, "view shift and lift (%.6g %.6g): ",
145 ourview.hoff, ourview.voff);
146 (*dev->comout)(buf);
147 (*dev->comin)(buf, NULL);
148 if (buf[0] == CTRL('C')) return;
149 if (sscanf(buf, "%lf %lf", &nv.hoff, &nv.voff) == 2)
150 change++;
151 if (change)
152 newview(&nv);
153 }
154
155
156 extern void
157 lastview( /* return to a previous view */
158 char *s
159 )
160 {
161 char buf[128];
162 char *fname;
163 int success;
164 VIEW nv;
165
166 if (sscanf(s, "%s", buf) == 1) { /* get parameters from a file */
167 nv = stdview;
168 if ((fname = getpath(buf, "", R_OK)) == NULL ||
169 (success = viewfile(fname, &nv, NULL)) == -1) {
170 sprintf(errmsg, "cannot open \"%s\"", buf);
171 error(COMMAND, errmsg);
172 return;
173 }
174 if (!success)
175 error(COMMAND, "wrong file format");
176 else
177 newview(&nv);
178 return;
179 }
180 if (oldview.type == 0) { /* no old view! */
181 error(COMMAND, "no previous view");
182 return;
183 }
184 nv = ourview;
185 ourview = oldview;
186 oldview = nv;
187 newimage();
188 }
189
190
191 extern void
192 saveview( /* save view to rad file */
193 char *s
194 )
195 {
196 char view[64];
197 char *fname;
198 FILE *fp;
199
200 if (*atos(view, sizeof(view), s)) {
201 if (isint(view)) {
202 error(COMMAND, "cannot write view by number");
203 return;
204 }
205 s = sskip(s);
206 }
207 while (isspace(*s))
208 s++;
209 if (*s)
210 atos(rifname, sizeof(rifname), s);
211 else if (rifname[0] == '\0') {
212 error(COMMAND, "no previous rad file");
213 return;
214 }
215 if ((fname = getpath(rifname, NULL, 0)) == NULL ||
216 (fp = fopen(fname, "a")) == NULL) {
217 sprintf(errmsg, "cannot open \"%s\"", rifname);
218 error(COMMAND, errmsg);
219 return;
220 }
221 fputs("view= ", fp);
222 fputs(view, fp);
223 fprintview(&ourview, fp);
224 putc('\n', fp);
225 fclose(fp);
226 }
227
228
229 extern void
230 loadview( /* load view from rad file */
231 char *s
232 )
233 {
234 char buf[512];
235 char *fname;
236 FILE *fp;
237 VIEW nv;
238
239 strcpy(buf, "rad -n -s -V -v ");
240 if (sscanf(s, "%s", buf+strlen(buf)) == 1)
241 s = sskip(s);
242 else
243 strcat(buf, "1");
244 if (*s)
245 atos(rifname, sizeof(rifname), s);
246 else if (rifname[0] == '\0') {
247 error(COMMAND, "no previous rad file");
248 return;
249 }
250 if ((fname = getpath(rifname, "", R_OK)) == NULL) {
251 sprintf(errmsg, "cannot access \"%s\"", rifname);
252 error(COMMAND, errmsg);
253 return;
254 }
255 sprintf(buf+strlen(buf), " %s", fname);
256 if ((fp = popen(buf, "r")) == NULL) {
257 error(COMMAND, "cannot run rad");
258 return;
259 }
260 buf[0] = '\0';
261 fgets(buf, sizeof(buf), fp);
262 pclose(fp);
263 nv = stdview;
264 if (!sscanview(&nv, buf)) {
265 error(COMMAND, "rad error -- no such view?");
266 return;
267 }
268 newview(&nv);
269 }
270
271
272 extern void
273 getaim( /* aim camera */
274 char *s
275 )
276 {
277 VIEW nv = ourview;
278 double zfact;
279
280 if (getinterest(s, 1, nv.vdir, &zfact) < 0)
281 return;
282 zoomview(&nv, zfact);
283 newview(&nv);
284 }
285
286
287 extern void
288 getfocus( /* set focus distance */
289 char *s
290 )
291 {
292 FVECT vc;
293 double dist;
294
295 if (sscanf(s, "%lf", &dist) < 1) {
296 int x, y;
297 RAY thisray;
298 if (dev->getcur == NULL)
299 return;
300 (*dev->comout)("Pick focus point\n");
301 if ((*dev->getcur)(&x, &y) == ABORT)
302 return;
303 if ((thisray.rmax = viewray(thisray.rorg, thisray.rdir,
304 &ourview, (x+.5)/hresolu, (y+.5)/vresolu)) < -FTINY) {
305 error(COMMAND, "not on image");
306 return;
307 }
308 rayorigin(&thisray, PRIMARY, NULL, NULL);
309 if (!localhit(&thisray, &thescene)) {
310 error(COMMAND, "not a local object");
311 return;
312 }
313 dist = thisray.rot;
314 } else if (dist <= .0) {
315 error(COMMAND, "focus distance must be positive");
316 return;
317 }
318 ourview.vdist = dist;
319 }
320
321
322 extern void
323 getmove( /* move camera */
324 char *s
325 )
326 {
327 FVECT vc;
328 double mag;
329
330 if (getinterest(s, 0, vc, &mag) < 0)
331 return;
332 moveview(0.0, 0.0, mag, vc);
333 }
334
335
336 extern void
337 getrotate( /* rotate camera */
338 char *s
339 )
340 {
341 VIEW nv = ourview;
342 FVECT v1;
343 double angle, elev, zfact;
344
345 elev = 0.0; zfact = 1.0;
346 if (sscanf(s, "%lf %lf %lf", &angle, &elev, &zfact) < 1) {
347 error(COMMAND, "missing angle");
348 return;
349 }
350 spinvector(nv.vdir, ourview.vdir, ourview.vup, angle*(PI/180.));
351 if (elev != 0.0) {
352 fcross(v1, nv.vdir, ourview.vup);
353 normalize(v1);
354 spinvector(nv.vdir, nv.vdir, v1, elev*(PI/180.));
355 }
356 zoomview(&nv, zfact);
357 newview(&nv);
358 }
359
360
361 extern void
362 getpivot( /* pivot viewpoint */
363 register char *s
364 )
365 {
366 FVECT vc;
367 double angle, elev, mag;
368
369 elev = 0.0;
370 if (sscanf(s, "%lf %lf", &angle, &elev) < 1) {
371 error(COMMAND, "missing angle");
372 return;
373 }
374 if (getinterest(sskip2(s,2), 0, vc, &mag) < 0)
375 return;
376 moveview(angle, elev, mag, vc);
377 }
378
379
380 extern void
381 getexposure( /* get new exposure */
382 char *s
383 )
384 {
385 char buf[128];
386 register char *cp;
387 RECT r;
388 int x, y;
389 register PNODE *p = &ptrunk;
390 int adapt = 0;
391 double e = 1.0;
392
393 for (cp = s; isspace(*cp); cp++)
394 ;
395 if (*cp == '@') {
396 adapt++;
397 while (isspace(*++cp))
398 ;
399 }
400 if (*cp == '\0') { /* normalize to point */
401 if (dev->getcur == NULL)
402 return;
403 (*dev->comout)("Pick point for exposure\n");
404 if ((*dev->getcur)(&x, &y) == ABORT)
405 return;
406 r.l = r.d = 0;
407 r.r = hresolu; r.u = vresolu;
408 p = findrect(x, y, &ptrunk, &r, -1);
409 } else {
410 if (*cp == '=') { /* absolute setting */
411 p = NULL;
412 e = 1.0/exposure;
413 for (cp++; isspace(*cp); cp++)
414 ;
415 if (*cp == '\0') { /* interactive */
416 sprintf(buf, "exposure (%f): ", exposure);
417 (*dev->comout)(buf);
418 (*dev->comin)(buf, NULL);
419 for (cp = buf; isspace(*cp); cp++)
420 ;
421 if (*cp == '\0')
422 return;
423 }
424 }
425 if (*cp == '+' || *cp == '-') /* f-stops */
426 e *= pow(2.0, atof(cp));
427 else /* multiplier */
428 e *= atof(cp);
429 }
430 if (p != NULL) { /* relative setting */
431 if (bright(p->v) < 1e-15) {
432 error(COMMAND, "cannot normalize to zero");
433 return;
434 }
435 if (adapt)
436 e *= 106./pow(1.219+pow(luminance(p->v)/exposure,.4),2.5)/exposure;
437 else
438 e *= 0.5 / bright(p->v);
439 }
440 if (e <= FTINY || fabs(1.0 - e) <= FTINY)
441 return;
442 scalepict(&ptrunk, e);
443 exposure *= e;
444 redraw();
445 }
446
447 typedef union {int i; double d; COLOR C;} *MyUptr;
448
449 extern int
450 getparam( /* get variable from user */
451 char *str,
452 char *dsc,
453 int typ,
454 void *p
455 )
456 {
457 register MyUptr ptr = (MyUptr)p;
458 int i0;
459 double d0, d1, d2;
460 char buf[48];
461
462 switch (typ) {
463 case 'i': /* integer */
464 if (sscanf(str, "%d", &i0) != 1) {
465 (*dev->comout)(dsc);
466 sprintf(buf, " (%d): ", ptr->i);
467 (*dev->comout)(buf);
468 (*dev->comin)(buf, NULL);
469 if (sscanf(buf, "%d", &i0) != 1)
470 return(0);
471 }
472 ptr->i = i0;
473 return(1);
474 case 'r': /* real */
475 if (sscanf(str, "%lf", &d0) != 1) {
476 (*dev->comout)(dsc);
477 sprintf(buf, " (%.6g): ", ptr->d);
478 (*dev->comout)(buf);
479 (*dev->comin)(buf, NULL);
480 if (sscanf(buf, "%lf", &d0) != 1)
481 return(0);
482 }
483 ptr->d = d0;
484 return(1);
485 case 'b': /* boolean */
486 if (sscanf(str, "%1s", buf) != 1) {
487 (*dev->comout)(dsc);
488 sprintf(buf, "? (%c): ", ptr->i ? 'y' : 'n');
489 (*dev->comout)(buf);
490 (*dev->comin)(buf, NULL);
491 if (buf[0] == '\0' ||
492 strchr("yY+1tTnN-0fF", buf[0]) == NULL)
493 return(0);
494 }
495 ptr->i = strchr("yY+1tT", buf[0]) != NULL;
496 return(1);
497 case 'C': /* color */
498 if (sscanf(str, "%lf %lf %lf", &d0, &d1, &d2) != 3) {
499 (*dev->comout)(dsc);
500 sprintf(buf, " (%.6g %.6g %.6g): ",
501 colval(ptr->C,RED),
502 colval(ptr->C,GRN),
503 colval(ptr->C,BLU));
504 (*dev->comout)(buf);
505 (*dev->comin)(buf, NULL);
506 if (sscanf(buf, "%lf %lf %lf", &d0, &d1, &d2) != 3)
507 return(0);
508 }
509 setcolor(ptr->C, d0, d1, d2);
510 return(1);
511 }
512 return 0; /* nothing matched */
513 }
514
515
516 extern void
517 setparam( /* get/set program parameter */
518 register char *s
519 )
520 {
521 char buf[128];
522
523 if (s[0] == '\0') {
524 (*dev->comout)(
525 "aa ab ad ar as av aw b bv dc dv dj ds dt i lr lw me ma mg ms ps pt sj st u: ");
526 (*dev->comin)(buf, NULL);
527 s = buf;
528 }
529 switch (s[0]) {
530 case 'u': /* uncorrelated sampling */
531 getparam(s+1, "uncorrelated sampling", 'b',
532 (void *)&rand_samp);
533 break;
534 case 'l': /* limit */
535 switch (s[1]) {
536 case 'w': /* weight */
537 getparam(s+2, "limit weight", 'r',
538 (void *)&minweight);
539 break;
540 case 'r': /* reflection */
541 getparam(s+2, "limit reflection", 'i',
542 (void *)&maxdepth);
543 break;
544 default:
545 goto badparam;
546 }
547 break;
548 case 'd': /* direct */
549 switch (s[1]) {
550 case 'j': /* jitter */
551 getparam(s+2, "direct jitter", 'r',
552 (void *)&dstrsrc);
553 break;
554 case 'c': /* certainty */
555 getparam(s+2, "direct certainty", 'r',
556 (void *)&shadcert);
557 break;
558 case 't': /* threshold */
559 getparam(s+2, "direct threshold", 'r',
560 (void *)&shadthresh);
561 break;
562 case 'v': /* visibility */
563 getparam(s+2, "direct visibility", 'b',
564 (void *)&directvis);
565 break;
566 case 's': /* sampling */
567 getparam(s+2, "direct sampling", 'r',
568 (void *)&srcsizerat);
569 break;
570 default:
571 goto badparam;
572 }
573 break;
574 case 'b': /* back faces or black and white */
575 switch (s[1]) {
576 case 'v': /* back face visibility */
577 getparam(s+2, "back face visibility", 'b',
578 (void *)&backvis);
579 break;
580 case '\0': /* black and white */
581 case ' ':
582 case 'y': case 'Y': case 't': case 'T': case '1': case '+':
583 case 'n': case 'N': case 'f': case 'F': case '0': case '-':
584 getparam(s+1, "black and white", 'b',
585 (void *)&greyscale);
586 break;
587 default:
588 goto badparam;
589 }
590 break;
591 case 'i': /* irradiance */
592 getparam(s+1, "irradiance", 'b',
593 (void *)&do_irrad);
594 break;
595 case 'a': /* ambient */
596 switch (s[1]) {
597 case 'v': /* value */
598 getparam(s+2, "ambient value", 'C',
599 (void *)ambval);
600 break;
601 case 'w': /* weight */
602 getparam(s+2, "ambient value weight", 'i',
603 (void *)&ambvwt);
604 break;
605 case 'a': /* accuracy */
606 if (getparam(s+2, "ambient accuracy", 'r',
607 (void *)&ambacc))
608 setambacc(ambacc);
609 break;
610 case 'd': /* divisions */
611 getparam(s+2, "ambient divisions", 'i',
612 (void *)&ambdiv);
613 break;
614 case 's': /* samples */
615 getparam(s+2, "ambient super-samples", 'i',
616 (void *)&ambssamp);
617 break;
618 case 'b': /* bounces */
619 getparam(s+2, "ambient bounces", 'i',
620 (void *)&ambounce);
621 break;
622 case 'r':
623 if (getparam(s+2, "ambient resolution", 'i',
624 (void *)&ambres))
625 setambres(ambres);
626 break;
627 default:
628 goto badparam;
629 }
630 break;
631 case 'm': /* medium */
632 switch (s[1]) {
633 case 'e': /* extinction coefficient */
634 getparam(s+2, "extinction coefficient", 'C',
635 (void *)cextinction);
636 break;
637 case 'a': /* scattering albedo */
638 getparam(s+2, "scattering albedo", 'C',
639 (void *)salbedo);
640 break;
641 case 'g': /* scattering eccentricity */
642 getparam(s+2, "scattering eccentricity", 'r',
643 (void *)&seccg);
644 break;
645 case 's': /* sampling distance */
646 getparam(s+2, "mist sampling distance", 'r',
647 (void *)&ssampdist);
648 break;
649 default:
650 goto badparam;
651 }
652 break;
653 case 'p': /* pixel */
654 switch (s[1]) {
655 case 's': /* sample */
656 if (getparam(s+2, "pixel sample", 'i',
657 (void *)&psample))
658 pdepth = 0;
659 break;
660 case 't': /* threshold */
661 if (getparam(s+2, "pixel threshold", 'r',
662 (void *)&maxdiff))
663 pdepth = 0;
664 break;
665 default:
666 goto badparam;
667 }
668 break;
669 case 's': /* specular */
670 switch (s[1]) {
671 case 'j': /* jitter */
672 getparam(s+2, "specular jitter", 'r',
673 (void *)&specjitter);
674 break;
675 case 't': /* threshold */
676 getparam(s+2, "specular threshold", 'r',
677 (void *)&specthresh);
678 break;
679 default:
680 goto badparam;
681 }
682 break;
683 case '\0': /* nothing */
684 break;
685 default:;
686 badparam:
687 *sskip(s) = '\0';
688 sprintf(errmsg, "%s: unknown variable", s);
689 error(COMMAND, errmsg);
690 break;
691 }
692 }
693
694
695 extern void
696 traceray(s) /* trace a single ray */
697 char *s;
698 {
699 char buf[128];
700 int x, y;
701 OBJREC *ino;
702 RAY thisray;
703
704 thisray.rmax = 0.0;
705
706 if (!sscanvec(s, thisray.rorg) ||
707 !sscanvec(sskip2(s,3), thisray.rdir)) {
708
709 if (dev->getcur == NULL)
710 return;
711 (*dev->comout)("Pick ray\n");
712 if ((*dev->getcur)(&x, &y) == ABORT)
713 return;
714
715 if ((thisray.rmax = viewray(thisray.rorg, thisray.rdir,
716 &ourview, (x+.5)/hresolu, (y+.5)/vresolu)) < -FTINY) {
717 error(COMMAND, "not on image");
718 return;
719 }
720
721 } else if (normalize(thisray.rdir) == 0.0) {
722 error(COMMAND, "zero ray direction");
723 return;
724 }
725
726 rayorigin(&thisray, PRIMARY, NULL, NULL);
727
728 rayvalue(&thisray);
729
730 if (thisray.ro == NULL)
731 (*dev->comout)("ray hit nothing");
732 else {
733 OBJREC *mat = NULL;
734 OBJREC *mod = NULL;
735 char matspec[256];
736 matspec[0] = '\0';
737 if (thisray.ro->omod != OVOID) {
738 mod = objptr(thisray.ro->omod);
739 mat = findmaterial(mod);
740 }
741 if (thisray.rod < 0.0)
742 strcpy(matspec, "back of ");
743 if (mod != NULL) {
744 strcat(matspec, mod->oname);
745 if (mat != mod && mat != NULL)
746 sprintf(matspec+strlen(matspec),
747 " (%s)", mat->oname);
748 } else
749 strcat(matspec, VOIDID);
750 sprintf(buf, "ray hit %s %s \"%s\"", matspec,
751 ofun[thisray.ro->otype].funame,
752 thisray.ro->oname);
753 if ((ino = objptr(thisray.robj)) != thisray.ro)
754 sprintf(buf+strlen(buf), " in %s \"%s\"",
755 ofun[ino->otype].funame, ino->oname);
756 (*dev->comout)(buf);
757 (*dev->comin)(buf, NULL);
758 if (thisray.rot >= FHUGE)
759 (*dev->comout)("at infinity");
760 else {
761 sprintf(buf, "at (%.6g %.6g %.6g) (%.6g)",
762 thisray.rop[0], thisray.rop[1],
763 thisray.rop[2], thisray.rt);
764 (*dev->comout)(buf);
765 }
766 (*dev->comin)(buf, NULL);
767 sprintf(buf, "value (%.5g %.5g %.5g) (%.3gL)",
768 colval(thisray.rcol,RED),
769 colval(thisray.rcol,GRN),
770 colval(thisray.rcol,BLU),
771 luminance(thisray.rcol));
772 (*dev->comout)(buf);
773 }
774 (*dev->comin)(buf, NULL);
775 }
776
777
778 extern void
779 writepict(s) /* write the picture to a file */
780 char *s;
781 {
782 static char buf[128];
783 char *fname;
784 FILE *fp;
785 COLR *scanline;
786 int y;
787
788 while (isspace(*s))
789 s++;
790 if (*s)
791 atos(buf, sizeof(buf), s);
792 else if (buf[0] == '\0') {
793 error(COMMAND, "no file");
794 return;
795 }
796 if ((fname = getpath(buf, NULL, 0)) == NULL ||
797 (fp = fopen(fname, "w")) == NULL) {
798 sprintf(errmsg, "cannot open \"%s\"", buf);
799 error(COMMAND, errmsg);
800 return;
801 }
802 SET_FILE_BINARY(fp);
803 (*dev->comout)("writing \"");
804 (*dev->comout)(fname);
805 (*dev->comout)("\"...\n");
806 /* write header */
807 newheader("RADIANCE", fp);
808 fputs(progname, fp);
809 fprintview(&ourview, fp);
810 if (octname != NULL)
811 fprintf(fp, " %s\n", octname);
812 else
813 putc('\n', fp);
814 fprintf(fp, "SOFTWARE= %s\n", VersionID);
815 fputnow(fp);
816 if (exposure != 1.0)
817 fputexpos(exposure, fp);
818 if (dev->pixaspect != 1.0)
819 fputaspect(dev->pixaspect, fp);
820 fputformat(COLRFMT, fp);
821 putc('\n', fp);
822 fprtresolu(hresolu, vresolu, fp);
823
824 scanline = (COLR *)malloc(hresolu*sizeof(COLR));
825 if (scanline == NULL) {
826 error(COMMAND, "not enough memory!");
827 fclose(fp);
828 unlink(fname);
829 return;
830 }
831 for (y = vresolu-1; y >= 0; y--) {
832 getpictcolrs(y, scanline, &ptrunk, hresolu, vresolu);
833 if (fwritecolrs(scanline, hresolu, fp) < 0)
834 break;
835 }
836 free((void *)scanline);
837 if (fclose(fp) < 0)
838 error(COMMAND, "write error");
839 }
