--- ray/src/rt/rv2.c 1992/01/17 09:27:17 2.6 +++ ray/src/rt/rv2.c 1994/07/12 15:24:28 2.25 @@ -1,4 +1,4 @@ -/* Copyright (c) 1991 Regents of the University of California */ +/* Copyright (c) 1993 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -30,7 +30,12 @@ static char SCCSid[] = "$SunId$ LBL"; #define sscanvec(s,v) (sscanf(s,"%lf %lf %lf",v,v+1,v+2)==3) #endif +extern char *atos(); +extern FILE *popen(); + +extern char rifname[128]; /* rad input file name */ + extern char VersionID[]; extern char *progname; extern char *octname; @@ -65,6 +70,16 @@ char *s; int change = 0; VIEW nv; + while (isspace(*s)) + s++; + if (*s == '-') { /* command line parameters */ + copystruct(&nv, &ourview); + if (sscanview(&nv, s)) + newview(&nv); + else + error(COMMAND, "bad view option(s)"); + return; + } if (sscanf(s, "%s", buf) == 1) { /* write parameters to a file */ if ((fname = getpath(buf, NULL, 0)) == NULL || (fp = fopen(fname, "a")) == NULL) { @@ -75,7 +90,7 @@ char *s; fputs(progname, fp); fprintview(&ourview, fp); fputs(sskip(s), fp); - fputs("\n", fp); + putc('\n', fp); fclose(fp); return; } @@ -150,7 +165,7 @@ char *s; if (sscanf(s, "%s", buf) == 1) { /* get parameters from a file */ copystruct(&nv, &stdview); - if ((fname = getpath(buf, NULL, 0)) == NULL || + if ((fname = getpath(buf, "", R_OK)) == NULL || (success = viewfile(fname, &nv, NULL)) == -1) { sprintf(errmsg, "cannot open \"%s\"", buf); error(COMMAND, errmsg); @@ -173,10 +188,86 @@ char *s; } +saveview(s) /* save view to rad file */ +char *s; +{ + char view[64]; + char *fname; + FILE *fp; + + if (*atos(view, sizeof(view), s)) { + if (isint(view)) { + error(COMMAND, "cannot write view by number"); + return; + } + s = sskip(s); + } + while (isspace(*s)) + s++; + if (*s) + atos(rifname, sizeof(rifname), s); + else if (rifname[0] == '\0') { + error(COMMAND, "no previous rad file"); + return; + } + if ((fname = getpath(rifname, NULL, 0)) == NULL || + (fp = fopen(fname, "a")) == NULL) { + sprintf(errmsg, "cannot open \"%s\"", rifname); + error(COMMAND, errmsg); + return; + } + fputs("view= ", fp); + fputs(view, fp); + fprintview(&ourview, fp); + putc('\n', fp); + fclose(fp); +} + + +loadview(s) /* load view from rad file */ +char *s; +{ + char buf[512]; + char *fname; + FILE *fp; + VIEW nv; + + strcpy(buf, "rad -n -s -V -v "); + if (sscanf(s, "%s", buf+strlen(buf)) == 1) + s = sskip(s); + else + strcat(buf, "1"); + if (*s) + atos(rifname, sizeof(rifname), s); + else if (rifname[0] == '\0') { + error(COMMAND, "no previous rad file"); + return; + } + if ((fname = getpath(rifname, "", R_OK)) == NULL) { + sprintf(errmsg, "cannot access \"%s\"", rifname); + error(COMMAND, errmsg); + return; + } + sprintf(buf+strlen(buf), " %s", fname); + if ((fp = popen(buf, "r")) == NULL) { + error(COMMAND, "cannot run rad"); + return; + } + buf[0] = '\0'; + fgets(buf, sizeof(buf), fp); + pclose(fp); + copystruct(&nv, &stdview); + if (!sscanview(&nv, buf)) { + error(COMMAND, "rad error -- no such view?"); + return; + } + newview(&nv); +} + + getaim(s) /* aim camera */ char *s; { - extern double tan(), atan(); double zfact; VIEW nv; @@ -207,7 +298,6 @@ char *s; getrotate(s) /* rotate camera */ char *s; { - extern double normalize(), tan(), atan(); VIEW nv; FVECT v1; double angle, elev, zfact; @@ -255,13 +345,19 @@ char *s; { char buf[128]; register char *cp; - register PNODE *p; RECT r; int x, y; - double e; + register PNODE *p = &ptrunk; + int adapt = 0; + double e = 1.0; for (cp = s; isspace(*cp); cp++) ; + if (*cp == '@') { + adapt++; + while (isspace(*++cp)) + ; + } if (*cp == '\0') { /* normalize to point */ if (dev->getcur == NULL) return; @@ -271,7 +367,6 @@ char *s; r.l = r.d = 0; r.r = hresolu; r.u = vresolu; p = findrect(x, y, &ptrunk, &r, -1); - e = 1.0; } else { if (*cp == '=') { /* absolute setting */ p = NULL; @@ -279,7 +374,7 @@ char *s; for (cp++; isspace(*cp); cp++) ; if (*cp == '\0') { /* interactive */ - sprintf(buf, "exposure (%lf): ", exposure); + sprintf(buf, "exposure (%f): ", exposure); (*dev->comout)(buf); (*dev->comin)(buf, NULL); for (cp = buf; isspace(*cp); cp++) @@ -287,9 +382,6 @@ char *s; if (*cp == '\0') return; } - } else { /* normalize to average */ - p = &ptrunk; - e = 1.0; } if (*cp == '+' || *cp == '-') /* f-stops */ e *= pow(2.0, atof(cp)); @@ -297,11 +389,14 @@ char *s; e *= atof(cp); } if (p != NULL) { /* relative setting */ - if (bright(p->v) <= FTINY) { + if (bright(p->v) < 1e-15) { error(COMMAND, "cannot normalize to zero"); return; } - e *= 0.5 / bright(p->v); + if (adapt) + e *= 106./pow(1.219+pow(luminance(p->v)/exposure,.4),2.5)/exposure; + else + e *= 0.5 / bright(p->v); } if (e <= FTINY || fabs(1.0 - e) <= FTINY) return; @@ -386,12 +481,11 @@ register char *s; extern double shadcert; extern COLOR ambval; extern double ambacc; - extern double minarad; extern int ambres; extern int ambdiv; extern int ambssamp; extern int ambounce; - extern int directinvis; + extern int directvis; extern double srcsizerat; extern int do_irrad; extern double specjitter; @@ -428,9 +522,9 @@ register char *s; case 't': /* threshold */ getparam(s+2, "direct threshold", 'r', &shadthresh); break; - case 'i': /* invisibility */ - getparam(s+2, "direct invisibility", - 'b', &directinvis); + case 'v': /* visibility */ + getparam(s+2, "direct visibility", + 'b', &directvis); break; case 's': /* sampling */ getparam(s+2, "direct sampling", 'r', &srcsizerat); @@ -448,10 +542,11 @@ register char *s; case 'a': /* ambient */ switch (s[1]) { case 'v': /* value */ - getparam(s+2, "ambient value", 'C', ambval); + getparam(s+2, "ambient value", 'C', (COLOR *)ambval); break; case 'a': /* accuracy */ - getparam(s+2, "ambient accuracy", 'r', &ambacc); + if (getparam(s+2, "ambient accuracy", 'r', &ambacc)) + setambacc(ambacc); break; case 'd': /* divisions */ getparam(s+2, "ambient divisions", 'i', &ambdiv); @@ -464,8 +559,7 @@ register char *s; break; case 'r': if (getparam(s+2, "ambient resolution", 'i', &ambres)) - minarad = ambres > 0 ? - thescene.cusize/ambres : 0.0; + setambres(ambres); break; default: goto badparam; @@ -543,8 +637,10 @@ char *s; if (thisray.ro == NULL) (*dev->comout)("ray hit nothing"); else { - sprintf(buf, "ray hit %s %s \"%s\"", - objptr(thisray.ro->omod)->oname, + sprintf(buf, "ray hit %s%s %s \"%s\"", + thisray.rod < 0.0 ? "back of " : "", + thisray.ro->omod == OVOID ? VOIDID : + objptr(thisray.ro->omod)->oname, ofun[thisray.ro->otype].funame, thisray.ro->oname); (*dev->comout)(buf); @@ -577,7 +673,11 @@ char *s; COLR *scanline; int y; - if (sscanf(s, "%s", buf) != 1 && buf[0] == '\0') { + while (isspace(*s)) + s++; + if (*s) + atos(buf, sizeof(buf), s); + else if (buf[0] == '\0') { error(COMMAND, "no file"); return; } @@ -587,10 +687,14 @@ char *s; error(COMMAND, errmsg); return; } +#ifdef MSDOS + setmode(fileno(fp), O_BINARY); +#endif (*dev->comout)("writing \""); (*dev->comout)(fname); (*dev->comout)("\"...\n"); /* write header */ + newheader("RADIANCE", fp); fputs(progname, fp); fprintview(&ourview, fp); if (octname != NULL)
