--- ray/src/rt/rv2.c 1992/01/15 16:55:21 2.5 +++ ray/src/rt/rv2.c 1993/08/25 14:13:51 2.18 @@ -1,4 +1,4 @@ -/* Copyright (c) 1991 Regents of the University of California */ +/* Copyright (c) 1993 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -24,6 +24,16 @@ static char SCCSid[] = "$SunId$ LBL"; #define CTRL(c) ((c)-'@') +#ifdef SMLFLT +#define sscanvec(s,v) (sscanf(s,"%f %f %f",v,v+1,v+2)==3) +#else +#define sscanvec(s,v) (sscanf(s,"%lf %lf %lf",v,v+1,v+2)==3) +#endif + +extern char *atos(); + +extern char rifname[]; /* rad input file name */ + extern char VersionID[]; extern char *progname; extern char *octname; @@ -58,6 +68,16 @@ char *s; int change = 0; VIEW nv; + while (isspace(*s)) + s++; + if (*s == '-') { /* command line parameters */ + copystruct(&nv, &ourview); + if (sscanview(&nv, s)) + newview(&nv); + else + error(COMMAND, "bad view option(s)"); + return; + } if (sscanf(s, "%s", buf) == 1) { /* write parameters to a file */ if ((fname = getpath(buf, NULL, 0)) == NULL || (fp = fopen(fname, "a")) == NULL) { @@ -68,7 +88,7 @@ char *s; fputs(progname, fp); fprintview(&ourview, fp); fputs(sskip(s), fp); - fputs("\n", fp); + putc('\n', fp); fclose(fp); return; } @@ -86,7 +106,7 @@ char *s; (*dev->comout)(buf); (*dev->comin)(buf, NULL); if (buf[0] == CTRL('C')) return; - if (sscanf(buf, "%lf %lf %lf", &nv.vp[0], &nv.vp[1], &nv.vp[2]) == 3) + if (sscanvec(buf, nv.vp)) change++; else VCOPY(nv.vp, ourview.vp); @@ -95,7 +115,7 @@ char *s; (*dev->comout)(buf); (*dev->comin)(buf, NULL); if (buf[0] == CTRL('C')) return; - if (sscanf(buf,"%lf %lf %lf",&nv.vdir[0],&nv.vdir[1],&nv.vdir[2]) == 3) + if (sscanvec(buf, nv.vdir)) change++; else VCOPY(nv.vdir, ourview.vdir); @@ -104,7 +124,7 @@ char *s; (*dev->comout)(buf); (*dev->comin)(buf, NULL); if (buf[0] == CTRL('C')) return; - if (sscanf(buf,"%lf %lf %lf",&nv.vup[0],&nv.vup[1],&nv.vup[2]) == 3) + if (sscanvec(buf, nv.vup)) change++; else VCOPY(nv.vup, ourview.vup); @@ -166,10 +186,76 @@ char *s; } +saveview(s) /* save view to rad file */ +char *s; +{ + char view[64]; + char *fname; + FILE *fp; + + if (*atos(view, sizeof(view), s)) + s = sskip(s); + if (sscanf(s, "%s", rifname) != 1 && rifname[0] == '\0') { + error(COMMAND, "no previous rad file"); + return; + } + if ((fname = getpath(rifname, NULL, 0)) == NULL || + (fp = fopen(fname, "a")) == NULL) { + sprintf(errmsg, "cannot open \"%s\"", rifname); + error(COMMAND, errmsg); + return; + } + fputs("view= ", fp); + fputs(view, fp); + fprintview(&ourview, fp); + putc('\n', fp); + fclose(fp); +} + + +loadview(s) /* load view from rad file */ +char *s; +{ + char buf[512]; + char *fname; + FILE *fp; + VIEW nv; + + strcpy(buf, "rad -n -s -V -v "); + if (sscanf(s, "%s", buf+strlen(buf)) == 1) + s = sskip(s); + else + strcat(buf, "1"); + if (sscanf(s, "%s", rifname) != 1 && rifname[0] == '\0') { + error(COMMAND, "no previous rad file"); + return; + } + fname = getpath(rifname, NULL, 0); + if (fname == NULL || access(fname, R_OK) == -1) { + sprintf(errmsg, "cannot access \"%s\"", rifname); + error(COMMAND, errmsg); + return; + } + sprintf(buf+strlen(buf), " %s", fname); + if ((fp = popen(buf, "r")) == NULL) { + error(COMMAND, "cannot run rad"); + return; + } + buf[0] = '\0'; + fgets(buf, sizeof(buf), fp); + pclose(fp); + copystruct(&nv, &stdview); + if (!sscanview(&nv, buf)) { + error(COMMAND, "rad error -- no such view?"); + return; + } + newview(&nv); +} + + getaim(s) /* aim camera */ char *s; { - extern double tan(), atan(); double zfact; VIEW nv; @@ -200,7 +286,6 @@ char *s; getrotate(s) /* rotate camera */ char *s; { - extern double normalize(), tan(), atan(); VIEW nv; FVECT v1; double angle, elev, zfact; @@ -248,13 +333,18 @@ char *s; { char buf[128]; register char *cp; - register PNODE *p; RECT r; int x, y; - double e; - + register PNODE *p = &ptrunk; + int adapt = 0; + double e = 1.0; +start: for (cp = s; isspace(*cp); cp++) ; + if (*cp == '@') { + adapt++; + goto start; + } if (*cp == '\0') { /* normalize to point */ if (dev->getcur == NULL) return; @@ -264,7 +354,6 @@ char *s; r.l = r.d = 0; r.r = hresolu; r.u = vresolu; p = findrect(x, y, &ptrunk, &r, -1); - e = 1.0; } else { if (*cp == '=') { /* absolute setting */ p = NULL; @@ -272,7 +361,7 @@ char *s; for (cp++; isspace(*cp); cp++) ; if (*cp == '\0') { /* interactive */ - sprintf(buf, "exposure (%lf): ", exposure); + sprintf(buf, "exposure (%f): ", exposure); (*dev->comout)(buf); (*dev->comin)(buf, NULL); for (cp = buf; isspace(*cp); cp++) @@ -280,9 +369,6 @@ char *s; if (*cp == '\0') return; } - } else { /* normalize to average */ - p = &ptrunk; - e = 1.0; } if (*cp == '+' || *cp == '-') /* f-stops */ e *= pow(2.0, atof(cp)); @@ -290,11 +376,14 @@ char *s; e *= atof(cp); } if (p != NULL) { /* relative setting */ - if (bright(p->v) <= FTINY) { + if (bright(p->v) < 1e-15) { error(COMMAND, "cannot normalize to zero"); return; } - e *= 0.5 / bright(p->v); + if (adapt) + e *= 106./pow(1.219+pow(luminance(p->v)/exposure,.4),2.5)/exposure; + else + e *= 0.5 / bright(p->v); } if (e <= FTINY || fabs(1.0 - e) <= FTINY) return; @@ -379,12 +468,11 @@ register char *s; extern double shadcert; extern COLOR ambval; extern double ambacc; - extern double minarad; extern int ambres; extern int ambdiv; extern int ambssamp; extern int ambounce; - extern int directinvis; + extern int directvis; extern double srcsizerat; extern int do_irrad; extern double specjitter; @@ -421,9 +509,9 @@ register char *s; case 't': /* threshold */ getparam(s+2, "direct threshold", 'r', &shadthresh); break; - case 'i': /* invisibility */ - getparam(s+2, "direct invisibility", - 'b', &directinvis); + case 'v': /* visibility */ + getparam(s+2, "direct visibility", + 'b', &directvis); break; case 's': /* sampling */ getparam(s+2, "direct sampling", 'r', &srcsizerat); @@ -441,10 +529,11 @@ register char *s; case 'a': /* ambient */ switch (s[1]) { case 'v': /* value */ - getparam(s+2, "ambient value", 'C', ambval); + getparam(s+2, "ambient value", 'C', (COLOR *)ambval); break; case 'a': /* accuracy */ - getparam(s+2, "ambient accuracy", 'r', &ambacc); + if (getparam(s+2, "ambient accuracy", 'r', &ambacc)) + setambacc(ambacc); break; case 'd': /* divisions */ getparam(s+2, "ambient divisions", 'i', &ambdiv); @@ -457,8 +546,7 @@ register char *s; break; case 'r': if (getparam(s+2, "ambient resolution", 'i', &ambres)) - minarad = ambres > 0 ? - thescene.cusize/ambres : 0.0; + setambres(ambres); break; default: goto badparam; @@ -509,9 +597,8 @@ char *s; int x, y; RAY thisray; - if (sscanf(s, "%lf %lf %lf %lf %lf %lf", - &thisray.rorg[0], &thisray.rorg[1], &thisray.rorg[2], - &thisray.rdir[0], &thisray.rdir[1], &thisray.rdir[2]) != 6) { + if (!sscanvec(s, thisray.rorg) || + !sscanvec(sskip(sskip(sskip(s))), thisray.rdir)) { if (dev->getcur == NULL) return; @@ -581,6 +668,9 @@ char *s; error(COMMAND, errmsg); return; } +#ifdef MSDOS + setmode(fileno(fp), O_BINARY); +#endif (*dev->comout)("writing \""); (*dev->comout)(fname); (*dev->comout)("\"...\n");
