--- ray/src/rt/rv2.c 1990/10/14 11:04:56 1.21 +++ ray/src/rt/rv2.c 1992/01/15 16:55:21 2.5 @@ -1,4 +1,4 @@ -/* Copyright (c) 1987 Regents of the University of California */ +/* Copyright (c) 1991 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -18,11 +18,15 @@ static char SCCSid[] = "$SunId$ LBL"; #include "rpaint.h" +#include "resolu.h" + #include -#define CTRL(c) ('c'-'@') +#define CTRL(c) ((c)-'@') +extern char VersionID[]; extern char *progname; +extern char *octname; getframe(s) /* get a new frame */ @@ -71,7 +75,7 @@ char *s; sprintf(buf, "view type (%c): ", ourview.type); (*dev->comout)(buf); (*dev->comin)(buf, NULL); - if (buf[0] == CTRL(C)) return; + if (buf[0] == CTRL('C')) return; if (buf[0] && buf[0] != ourview.type) { nv.type = buf[0]; change++; @@ -81,7 +85,7 @@ char *s; ourview.vp[0], ourview.vp[1], ourview.vp[2]); (*dev->comout)(buf); (*dev->comin)(buf, NULL); - if (buf[0] == CTRL(C)) return; + if (buf[0] == CTRL('C')) return; if (sscanf(buf, "%lf %lf %lf", &nv.vp[0], &nv.vp[1], &nv.vp[2]) == 3) change++; else @@ -90,7 +94,7 @@ char *s; ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]); (*dev->comout)(buf); (*dev->comin)(buf, NULL); - if (buf[0] == CTRL(C)) return; + if (buf[0] == CTRL('C')) return; if (sscanf(buf,"%lf %lf %lf",&nv.vdir[0],&nv.vdir[1],&nv.vdir[2]) == 3) change++; else @@ -99,7 +103,7 @@ char *s; ourview.vup[0], ourview.vup[1], ourview.vup[2]); (*dev->comout)(buf); (*dev->comin)(buf, NULL); - if (buf[0] == CTRL(C)) return; + if (buf[0] == CTRL('C')) return; if (sscanf(buf,"%lf %lf %lf",&nv.vup[0],&nv.vup[1],&nv.vup[2]) == 3) change++; else @@ -108,7 +112,7 @@ char *s; ourview.horiz, ourview.vert); (*dev->comout)(buf); (*dev->comin)(buf, NULL); - if (buf[0] == CTRL(C)) return; + if (buf[0] == CTRL('C')) return; if (sscanf(buf, "%lf %lf", &nv.horiz, &nv.vert) == 2) change++; else { @@ -118,7 +122,7 @@ char *s; ourview.hoff, ourview.voff); (*dev->comout)(buf); (*dev->comin)(buf, NULL); - if (buf[0] == CTRL(C)) return; + if (buf[0] == CTRL('C')) return; if (sscanf(buf, "%lf %lf", &nv.hoff, &nv.voff) == 2) change++; else { @@ -140,7 +144,7 @@ char *s; if (sscanf(s, "%s", buf) == 1) { /* get parameters from a file */ copystruct(&nv, &stdview); if ((fname = getpath(buf, NULL, 0)) == NULL || - (success = viewfile(fname, &nv, 0, 0)) == -1) { + (success = viewfile(fname, &nv, NULL)) == -1) { sprintf(errmsg, "cannot open \"%s\"", buf); error(COMMAND, errmsg); return; @@ -242,7 +246,6 @@ register char *s; getexposure(s) /* get new exposure */ char *s; { - double atof(), pow(), fabs(); char buf[128]; register char *cp; register PNODE *p; @@ -301,6 +304,69 @@ char *s; } +getparam(str, dsc, typ, ptr) /* get variable from user */ +char *str, *dsc; +int typ; +register union {int i; double d; COLOR C;} *ptr; +{ + extern char *index(); + int i0; + double d0, d1, d2; + char buf[48]; + + switch (typ) { + case 'i': /* integer */ + if (sscanf(str, "%d", &i0) != 1) { + (*dev->comout)(dsc); + sprintf(buf, " (%d): ", ptr->i); + (*dev->comout)(buf); + (*dev->comin)(buf, NULL); + if (sscanf(buf, "%d", &i0) != 1) + return(0); + } + ptr->i = i0; + return(1); + case 'r': /* real */ + if (sscanf(str, "%lf", &d0) != 1) { + (*dev->comout)(dsc); + sprintf(buf, " (%.6g): ", ptr->d); + (*dev->comout)(buf); + (*dev->comin)(buf, NULL); + if (sscanf(buf, "%lf", &d0) != 1) + return(0); + } + ptr->d = d0; + return(1); + case 'b': /* boolean */ + if (sscanf(str, "%1s", buf) != 1) { + (*dev->comout)(dsc); + sprintf(buf, "? (%c): ", ptr->i ? 'y' : 'n'); + (*dev->comout)(buf); + (*dev->comin)(buf, NULL); + if (buf[0] == '\0' || + index("yY+1tTnN-0fF", buf[0]) == NULL) + return(0); + } + ptr->i = index("yY+1tT", buf[0]) != NULL; + return(1); + case 'C': /* color */ + if (sscanf(str, "%lf %lf %lf", &d0, &d1, &d2) != 3) { + (*dev->comout)(dsc); + sprintf(buf, " (%.6g %.6g %.6g): ", + colval(ptr->C,RED), + colval(ptr->C,GRN), + colval(ptr->C,BLU)); + (*dev->comout)(buf); + (*dev->comin)(buf, NULL); + if (sscanf(buf, "%lf %lf %lf", &d0, &d1, &d2) != 3) + return(0); + } + setcolor(ptr->C, d0, d1, d2); + return(1); + } +} + + setparam(s) /* get/set program parameter */ register char *s; { @@ -318,12 +384,16 @@ register char *s; extern int ambdiv; extern int ambssamp; extern int ambounce; - int i0; - double d0, d1, d2; + extern int directinvis; + extern double srcsizerat; + extern int do_irrad; + extern double specjitter; + extern double specthresh; char buf[128]; if (s[0] == '\0') { - (*dev->comout)("aa ab ad ar as av dc dj dt lr lw sp st: "); + (*dev->comout)( + "aa ab ad ar as av b dc di dj ds dt i lr lw ps pt sj st: "); (*dev->comin)(buf, NULL); s = buf; } @@ -331,26 +401,10 @@ register char *s; case 'l': /* limit */ switch (s[1]) { case 'w': /* weight */ - if (sscanf(s+2, "%lf", &d0) != 1) { - sprintf(buf, "limit weight (%.6g): ", - minweight); - (*dev->comout)(buf); - (*dev->comin)(buf, NULL); - if (sscanf(buf, "%lf", &d0) != 1) - break; - } - minweight = d0; + getparam(s+2, "limit weight", 'r', &minweight); break; case 'r': /* reflection */ - if (sscanf(s+2, "%d", &i0) != 1) { - sprintf(buf, "limit reflection (%d): ", - maxdepth); - (*dev->comout)(buf); - (*dev->comin)(buf, NULL); - if (sscanf(buf, "%d", &i0) != 1) - break; - } - maxdepth = i0; + getparam(s+2, "limit reflection", 'i', &maxdepth); break; default: goto badparam; @@ -359,152 +413,88 @@ register char *s; case 'd': /* direct */ switch (s[1]) { case 'j': /* jitter */ - if (sscanf(s+2, "%lf", &d0) != 1) { - sprintf(buf, "direct jitter (%.6g): ", - dstrsrc); - (*dev->comout)(buf); - (*dev->comin)(buf, NULL); - if (sscanf(buf, "%lf", &d0) != 1) - break; - } - dstrsrc = d0; + getparam(s+2, "direct jitter", 'r', &dstrsrc); break; case 'c': /* certainty */ - if (sscanf(s+2, "%lf", &d0) != 1) { - sprintf(buf, "direct certainty (%.6g): ", - shadcert); - (*dev->comout)(buf); - (*dev->comin)(buf, NULL); - if (sscanf(buf, "%lf", &d0) != 1) - break; - } - shadcert = d0; + getparam(s+2, "direct certainty", 'r', &shadcert); break; case 't': /* threshold */ - if (sscanf(s+2, "%lf", &d0) != 1) { - sprintf(buf, "direct threshold (%.6g): ", - shadthresh); - (*dev->comout)(buf); - (*dev->comin)(buf, NULL); - if (sscanf(buf, "%lf", &d0) != 1) - break; - } - shadthresh = d0; + getparam(s+2, "direct threshold", 'r', &shadthresh); break; + case 'i': /* invisibility */ + getparam(s+2, "direct invisibility", + 'b', &directinvis); + break; + case 's': /* sampling */ + getparam(s+2, "direct sampling", 'r', &srcsizerat); + break; default: goto badparam; } break; + case 'b': /* black and white */ + getparam(s+1, "black and white", 'b', &greyscale); + break; + case 'i': /* irradiance */ + getparam(s+1, "irradiance", 'b', &do_irrad); + break; case 'a': /* ambient */ switch (s[1]) { case 'v': /* value */ - if (sscanf(s+2, "%lf %lf %lf", &d0, &d1, &d2) != 3) { - sprintf(buf, - "ambient value (%.6g %.6g %.6g): ", - colval(ambval,RED), - colval(ambval,GRN), - colval(ambval,BLU)); - (*dev->comout)(buf); - (*dev->comin)(buf, NULL); - if (sscanf(buf, "%lf %lf %lf", - &d0, &d1, &d2) != 3) - break; - } - setcolor(ambval, d0, d1, d2); + getparam(s+2, "ambient value", 'C', ambval); break; case 'a': /* accuracy */ - if (sscanf(s+2, "%lf", &d0) != 1) { - sprintf(buf, "ambient accuracy (%.6g): ", - ambacc); - (*dev->comout)(buf); - (*dev->comin)(buf, NULL); - if (sscanf(buf, "%lf", &d0) != 1) - break; - } - ambacc = d0; + getparam(s+2, "ambient accuracy", 'r', &ambacc); break; case 'd': /* divisions */ - if (sscanf(s+2, "%d", &i0) != 1) { - sprintf(buf, "ambient divisions (%d): ", - ambdiv); - (*dev->comout)(buf); - (*dev->comin)(buf, NULL); - if (sscanf(buf, "%d", &i0) != 1) - break; - } - ambdiv = i0; + getparam(s+2, "ambient divisions", 'i', &ambdiv); break; case 's': /* samples */ - if (sscanf(s+2, "%d", &i0) != 1) { - sprintf(buf, "ambient super-samples (%d): ", - ambssamp); - (*dev->comout)(buf); - (*dev->comin)(buf, NULL); - if (sscanf(buf, "%d", &i0) != 1) - break; - } - ambssamp = i0; + getparam(s+2, "ambient super-samples", 'i', &ambssamp); break; case 'b': /* bounces */ - if (sscanf(s+2, "%d", &i0) != 1) { - sprintf(buf, "ambient bounces (%d): ", - ambounce); - (*dev->comout)(buf); - (*dev->comin)(buf, NULL); - if (sscanf(buf, "%d", &i0) != 1) - break; - } - ambounce = i0; + getparam(s+2, "ambient bounces", 'i', &ambounce); break; case 'r': - if (sscanf(s+2, "%d", &i0) != 1) { - sprintf(buf, "ambient resolution (%d): ", - ambres); - (*dev->comout)(buf); - (*dev->comin)(buf, NULL); - if (sscanf(buf, "%d", &i0) != 1) - break; - } - ambres = i0; - minarad = ambres > 0 ? thescene.cusize/ambres : 0.0; + if (getparam(s+2, "ambient resolution", 'i', &ambres)) + minarad = ambres > 0 ? + thescene.cusize/ambres : 0.0; break; default: goto badparam; } break; - case 's': /* sample */ + case 'p': /* pixel */ switch (s[1]) { - case 'p': /* pixel */ - if (sscanf(s+2, "%d", &i0) != 1) { - sprintf(buf, "sample pixel (%d): ", psample); - (*dev->comout)(buf); - (*dev->comin)(buf, NULL); - if (sscanf(buf, "%d", &i0) != 1) - break; - } - psample = i0; - pdepth = 0; + case 's': /* sample */ + if (getparam(s+2, "pixel sample", 'i', &psample)) + pdepth = 0; break; case 't': /* threshold */ - if (sscanf(s+2, "%lf", &d0) != 1) { - sprintf(buf, "sample threshold (%.6g): ", - maxdiff); - (*dev->comout)(buf); - (*dev->comin)(buf, NULL); - if (sscanf(buf, "%lf", &d0) != 1) - break; - } - maxdiff = d0; - pdepth = 0; + if (getparam(s+2, "pixel threshold", 'r', &maxdiff)) + pdepth = 0; break; default: goto badparam; } break; + case 's': /* specular */ + switch (s[1]) { + case 'j': /* jitter */ + getparam(s+2, "specular jitter", 'r', &specjitter); + break; + case 't': /* threshold */ + getparam(s+2, "specular threshold", 'r', &specthresh); + break; + default: + goto badparam; + } + break; case '\0': /* nothing */ break; default:; badparam: + *sskip(s) = '\0'; sprintf(errmsg, "%s: unknown variable", s); error(COMMAND, errmsg); break; @@ -561,10 +551,11 @@ char *s; (*dev->comout)(buf); } (*dev->comin)(buf, NULL); - sprintf(buf, "with value (%.6g %.6g %.6g)", + sprintf(buf, "value (%.5g %.5g %.5g) (%.1fL)", colval(thisray.rcol,RED), colval(thisray.rcol,GRN), - colval(thisray.rcol,BLU)); + colval(thisray.rcol,BLU), + luminance(thisray.rcol)); (*dev->comout)(buf); } (*dev->comin)(buf, NULL); @@ -596,23 +587,32 @@ char *s; /* write header */ fputs(progname, fp); fprintview(&ourview, fp); - putc('\n', fp); + if (octname != NULL) + fprintf(fp, " %s\n", octname); + else + putc('\n', fp); + fprintf(fp, "SOFTWARE= %s\n", VersionID); if (exposure != 1.0) fputexpos(exposure, fp); if (dev->pixaspect != 1.0) fputaspect(dev->pixaspect, fp); + fputformat(COLRFMT, fp); putc('\n', fp); - fputresolu(YMAJOR|YDECR, hresolu, vresolu, fp); + fprtresolu(hresolu, vresolu, fp); scanline = (COLR *)malloc(hresolu*sizeof(COLR)); - if (scanline == NULL) - error(SYSTEM, "out of memory in writepict"); + if (scanline == NULL) { + error(COMMAND, "not enough memory!"); + fclose(fp); + unlink(fname); + return; + } for (y = vresolu-1; y >= 0; y--) { getpictcolrs(y, scanline, &ptrunk, hresolu, vresolu); if (fwritecolrs(scanline, hresolu, fp) < 0) break; } + free((char *)scanline); if (fclose(fp) < 0) error(COMMAND, "write error"); - free((char *)scanline); }
