--- ray/src/rt/rv2.c 1995/12/08 21:27:34 2.32 +++ ray/src/rt/rv2.c 2003/06/05 19:29:34 2.40 @@ -1,27 +1,24 @@ -/* Copyright (c) 1995 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: rv2.c,v 2.40 2003/06/05 19:29:34 schorsch Exp $"; #endif - /* * rv2.c - command routines used in tracing a view. * - * 3/24/87 + * External symbols declared in rpaint.h */ -#include "ray.h" +#include -#include "octree.h" +#include "copyright.h" +#include "platform.h" +#include "ray.h" #include "otypes.h" - #include "rpaint.h" -#include "resolu.h" +extern int psample; /* pixel sample size */ +extern double maxdiff; /* max. sample difference */ -#include - #define CTRL(c) ((c)-'@') #ifdef SMLFLT @@ -30,17 +27,13 @@ static char SCCSid[] = "$SunId$ LBL"; #define sscanvec(s,v) (sscanf(s,"%lf %lf %lf",v,v+1,v+2)==3) #endif -extern char *atos(); - -extern FILE *popen(); - extern char rifname[128]; /* rad input file name */ -extern char VersionID[]; extern char *progname; extern char *octname; +void getframe(s) /* get a new frame */ char *s; { @@ -50,6 +43,7 @@ char *s; } +void getrepaint(s) /* get area and repaint */ char *s; { @@ -61,6 +55,7 @@ char *s; } +void getview(s) /* get/show view parameters */ char *s; { @@ -165,6 +160,7 @@ char *s; } +void lastview(s) /* return to a previous view */ char *s; { @@ -198,6 +194,7 @@ char *s; } +void saveview(s) /* save view to rad file */ char *s; { @@ -234,6 +231,7 @@ char *s; } +void loadview(s) /* load view from rad file */ char *s; { @@ -275,6 +273,7 @@ char *s; } +void getaim(s) /* aim camera */ char *s; { @@ -294,6 +293,7 @@ char *s; } +void getmove(s) /* move camera */ char *s; { @@ -306,6 +306,7 @@ char *s; } +void getrotate(s) /* rotate camera */ char *s; { @@ -335,6 +336,7 @@ char *s; } +void getpivot(s) /* pivot viewpoint */ register char *s; { @@ -346,12 +348,13 @@ register char *s; error(COMMAND, "missing angle"); return; } - if (getinterest(sskip(sskip(s)), 0, vc, &mag) < 0) + if (getinterest(sskip2(s,2), 0, vc, &mag) < 0) return; moveview(angle, elev, mag, vc); } +void getexposure(s) /* get new exposure */ char *s; { @@ -417,13 +420,15 @@ char *s; redraw(); } +typedef union {int i; double d; COLOR C;} *MyUptr; -getparam(str, dsc, typ, ptr) /* get variable from user */ +int +getparam(str, dsc, typ, p) /* get variable from user */ char *str, *dsc; int typ; -register union {int i; double d; COLOR C;} *ptr; +void *p; { - extern char *index(); + register MyUptr ptr = (MyUptr)p; int i0; double d0, d1, d2; char buf[48]; @@ -481,37 +486,15 @@ register union {int i; double d; COLOR C;} *ptr; } +void setparam(s) /* get/set program parameter */ register char *s; { - extern int psample; - extern double maxdiff; - extern double minweight; - extern int maxdepth; - extern double dstrsrc; - extern double shadthresh; - extern double shadcert; - extern COLOR ambval; - extern double ambacc; - extern int ambres; - extern int ambdiv; - extern int ambssamp; - extern int ambounce; - extern COLOR cextinction; - extern double salbedo; - extern double seccg; - extern double ssampdist; - extern int directvis; - extern double srcsizerat; - extern int do_irrad; - extern double specjitter; - extern double specthresh; - extern int backvis; char buf[128]; if (s[0] == '\0') { (*dev->comout)( - "aa ab ad ar as av b dc dv dj ds dt i lr lw me ma mg ms ps pt sj st bv: "); + "aa ab ad ar as av aw b dc dv dj ds dt i lr lw me ma mg ms ps pt sj st bv: "); (*dev->comin)(buf, NULL); s = buf; } @@ -519,10 +502,12 @@ register char *s; case 'l': /* limit */ switch (s[1]) { case 'w': /* weight */ - getparam(s+2, "limit weight", 'r', &minweight); + getparam(s+2, "limit weight", 'r', + (void *)&minweight); break; case 'r': /* reflection */ - getparam(s+2, "limit reflection", 'i', &maxdepth); + getparam(s+2, "limit reflection", 'i', + (void *)&maxdepth); break; default: goto badparam; @@ -531,20 +516,24 @@ register char *s; case 'd': /* direct */ switch (s[1]) { case 'j': /* jitter */ - getparam(s+2, "direct jitter", 'r', &dstrsrc); + getparam(s+2, "direct jitter", 'r', + (void *)&dstrsrc); break; case 'c': /* certainty */ - getparam(s+2, "direct certainty", 'r', &shadcert); + getparam(s+2, "direct certainty", 'r', + (void *)&shadcert); break; case 't': /* threshold */ - getparam(s+2, "direct threshold", 'r', &shadthresh); + getparam(s+2, "direct threshold", 'r', + (void *)&shadthresh); break; case 'v': /* visibility */ - getparam(s+2, "direct visibility", - 'b', &directvis); + getparam(s+2, "direct visibility", 'b', + (void *)&directvis); break; case 's': /* sampling */ - getparam(s+2, "direct sampling", 'r', &srcsizerat); + getparam(s+2, "direct sampling", 'r', + (void *)&srcsizerat); break; default: goto badparam; @@ -553,41 +542,54 @@ register char *s; case 'b': /* back faces or black and white */ switch (s[1]) { case 'v': /* back face visibility */ - getparam(s+2, "back face visibility", 'b', &backvis); + getparam(s+2, "back face visibility", 'b', + (void *)&backvis); break; case '\0': /* black and white */ case ' ': case 'y': case 'Y': case 't': case 'T': case '1': case '+': case 'n': case 'N': case 'f': case 'F': case '0': case '-': - getparam(s+1, "black and white", 'b', &greyscale); + getparam(s+1, "black and white", 'b', + (void *)&greyscale); break; default: goto badparam; } break; case 'i': /* irradiance */ - getparam(s+1, "irradiance", 'b', &do_irrad); + getparam(s+1, "irradiance", 'b', + (void *)&do_irrad); break; case 'a': /* ambient */ switch (s[1]) { case 'v': /* value */ - getparam(s+2, "ambient value", 'C', (COLOR *)ambval); + getparam(s+2, "ambient value", 'C', + (void *)ambval); break; + case 'w': /* weight */ + getparam(s+2, "ambient value weight", 'i', + (void *)&ambvwt); + break; case 'a': /* accuracy */ - if (getparam(s+2, "ambient accuracy", 'r', &ambacc)) + if (getparam(s+2, "ambient accuracy", 'r', + (void *)&ambacc)) setambacc(ambacc); break; case 'd': /* divisions */ - getparam(s+2, "ambient divisions", 'i', &ambdiv); + getparam(s+2, "ambient divisions", 'i', + (void *)&ambdiv); break; case 's': /* samples */ - getparam(s+2, "ambient super-samples", 'i', &ambssamp); + getparam(s+2, "ambient super-samples", 'i', + (void *)&ambssamp); break; case 'b': /* bounces */ - getparam(s+2, "ambient bounces", 'i', &ambounce); + getparam(s+2, "ambient bounces", 'i', + (void *)&ambounce); break; case 'r': - if (getparam(s+2, "ambient resolution", 'i', &ambres)) + if (getparam(s+2, "ambient resolution", 'i', + (void *)&ambres)) setambres(ambres); break; default: @@ -598,17 +600,19 @@ register char *s; switch (s[1]) { case 'e': /* extinction coefficient */ getparam(s+2, "extinction coefficient", 'C', - (COLOR *)cextinction); + (void *)cextinction); break; case 'a': /* scattering albedo */ - getparam(s+2, "scattering albedo", 'r', &salbedo); + getparam(s+2, "scattering albedo", 'C', + (void *)salbedo); break; case 'g': /* scattering eccentricity */ - getparam(s+2, "scattering eccentricity", 'r', &seccg); + getparam(s+2, "scattering eccentricity", 'r', + (void *)&seccg); break; case 's': /* sampling distance */ getparam(s+2, "mist sampling distance", 'r', - &ssampdist); + (void *)&ssampdist); break; default: goto badparam; @@ -617,11 +621,13 @@ register char *s; case 'p': /* pixel */ switch (s[1]) { case 's': /* sample */ - if (getparam(s+2, "pixel sample", 'i', &psample)) + if (getparam(s+2, "pixel sample", 'i', + (void *)&psample)) pdepth = 0; break; case 't': /* threshold */ - if (getparam(s+2, "pixel threshold", 'r', &maxdiff)) + if (getparam(s+2, "pixel threshold", 'r', + (void *)&maxdiff)) pdepth = 0; break; default: @@ -631,10 +637,12 @@ register char *s; case 's': /* specular */ switch (s[1]) { case 'j': /* jitter */ - getparam(s+2, "specular jitter", 'r', &specjitter); + getparam(s+2, "specular jitter", 'r', + (void *)&specjitter); break; case 't': /* threshold */ - getparam(s+2, "specular threshold", 'r', &specthresh); + getparam(s+2, "specular threshold", 'r', + (void *)&specthresh); break; default: goto badparam; @@ -652,17 +660,19 @@ badparam: } +void traceray(s) /* trace a single ray */ char *s; { char buf[128]; int x, y; + OBJREC *ino; RAY thisray; thisray.rmax = 0.0; if (!sscanvec(s, thisray.rorg) || - !sscanvec(sskip(sskip(sskip(s))), thisray.rdir)) { + !sscanvec(sskip2(s,3), thisray.rdir)) { if (dev->getcur == NULL) return; @@ -694,6 +704,9 @@ char *s; objptr(thisray.ro->omod)->oname, ofun[thisray.ro->otype].funame, thisray.ro->oname); + if ((ino = objptr(thisray.robj)) != thisray.ro) + sprintf(buf+strlen(buf), " in %s \"%s\"", + ofun[ino->otype].funame, ino->oname); (*dev->comout)(buf); (*dev->comin)(buf, NULL); if (thisray.rot >= FHUGE) @@ -705,7 +718,7 @@ char *s; (*dev->comout)(buf); } (*dev->comin)(buf, NULL); - sprintf(buf, "value (%.5g %.5g %.5g) (%.1fL)", + sprintf(buf, "value (%.5g %.5g %.5g) (%.3gL)", colval(thisray.rcol,RED), colval(thisray.rcol,GRN), colval(thisray.rcol,BLU), @@ -716,6 +729,7 @@ char *s; } +void writepict(s) /* write the picture to a file */ char *s; { @@ -739,9 +753,7 @@ char *s; error(COMMAND, errmsg); return; } -#ifdef MSDOS - setmode(fileno(fp), O_BINARY); -#endif + SET_FILE_BINARY(fp); (*dev->comout)("writing \""); (*dev->comout)(fname); (*dev->comout)("\"...\n"); @@ -754,6 +766,7 @@ char *s; else putc('\n', fp); fprintf(fp, "SOFTWARE= %s\n", VersionID); + fputnow(fp); if (exposure != 1.0) fputexpos(exposure, fp); if (dev->pixaspect != 1.0) @@ -774,7 +787,7 @@ char *s; if (fwritecolrs(scanline, hresolu, fp) < 0) break; } - free((char *)scanline); + free((void *)scanline); if (fclose(fp) < 0) error(COMMAND, "write error"); }
