Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
refinement on last change
added object number to ray structure for instance tracking
replaced sskip() behavior and added new sskip2() function
added participating media and -m* options
fixed error in set options list
added effective ray length to ray reporting
minor bug fix in b setting switch
made view changes properly manage fore and aft clipping planes
added -bv option for back face visibility (normally on)
fixed bug in e @ specification
added newheader() call
added mention of hitting backside of surface in traceray()
added check for void modifier in traceray()
added missing popen() declaration
bug fixes in default name usage for MS-DOS
minor improvements in use of getpath()
added L and V commands
fixed problem with resetting of ambient accuracy
added "exposure @" subcommand
changed error sense for zero in getexpos()
changed -di to ! -dv
added setmode(fd,O_BINARY) where needed for MSDOS
changes for 32-bit PC port
changed view command to accept options
lowered minimum allowed exposure in getexpos()
fixed bug in use of scanf() with SMLFLT defined
added change of s options and changed old s options to p options
fixed CTRL(c) macro for ANSII compilers
removed atof() declarations for NeXT
added '?' to boolean query
changed calls to viewfile() and fputresolu()
added luminance to printed values in traceray()
added -ds option
added ds setting
added octree name to picture header
changed SOFT= to SOFTWARE=
improved memory handing
fixed error message for unknown set variable
made boolean parameter setting more forgiving
simplified setparam() procedure
added set options for di, i and b
added format info to headers
added fisheye view types
minor fixes in comments etc.
added ability to comment view in getview()
changed reading and writing of z-files and viewfiles
added writing of pixel aspect ratio to writepict()
replaced fprintf() with fputexpos() in writepicture()
added repaint command
Added calls to picture resolution get/put routines
Changed getpath() to check access modes
Changed back to threshold testing for direct
Changed "direct threshold" name to "direct tolerance"
Efficient approximation to direct component with many sources Glow type changed Spot type eliminated
Added elevation to pivot and zoom to rotate commands
Fixed unintentional change of view in getview()
Changed view parameters string back to progname
