--- ray/src/rt/rv2.c 1989/06/07 08:35:26 1.5 +++ ray/src/rt/rv2.c 1990/01/05 18:04:25 1.13 @@ -28,58 +28,34 @@ extern char *progname; getframe(s) /* get a new frame */ char *s; { - int x0, y0, x1, y1; - - if (!strcmp("all", s)) { - pframe.l = pframe.d = 0; - pframe.r = ourview.hresolu; - pframe.u = ourview.vresolu; - pdepth = 0; + if (getrect(s, &pframe) < 0) return; - } - if (sscanf(s, "%d %d %d %d", &x0, &y0, &x1, &y1) != 4) { - if (dev->getcur == NULL) - return; - (*dev->comout)("Pick first corner\n"); - if ((*dev->getcur)(&x0, &y0) == ABORT) - return; - (*dev->comout)("Pick second corner\n"); - if ((*dev->getcur)(&x1, &y1) == ABORT) - return; - } - if (x0 < x1) { - pframe.l = x0; - pframe.r = x1; - } else { - pframe.l = x1; - pframe.r = x0; - } - if (y0 < y1) { - pframe.d = y0; - pframe.u = y1; - } else { - pframe.d = y1; - pframe.u = y0; - } - if (pframe.l < 0) pframe.l = 0; - if (pframe.d < 0) pframe.d = 0; - if (pframe.r > ourview.hresolu) pframe.r = ourview.hresolu; - if (pframe.u > ourview.vresolu) pframe.u = ourview.vresolu; pdepth = 0; } +getrepaint(s) /* get area and repaint */ +char *s; +{ + RECT box; + + if (getrect(s, &box) < 0) + return; + paintrect(&ptrunk, 0, 0, ourview.hresolu, ourview.vresolu, &box); +} + + getview(s) /* get/show view parameters */ char *s; { FILE *fp; char buf[128]; - char *fname, *getpath(); + char *fname; int change = 0; VIEW nv; if (sscanf(s, "%s", buf) == 1) { /* write parameters to a file */ - if ((fname = getpath(buf, NULL)) == NULL || + if ((fname = getpath(buf, NULL, 0)) == NULL || (fp = fopen(fname, "a")) == NULL) { sprintf(errmsg, "cannot open \"%s\"", buf); error(COMMAND, errmsg); @@ -156,13 +132,13 @@ lastview(s) /* return to a previous view */ char *s; { char buf[128]; - char *fname, *getpath(); + char *fname; int success; VIEW nv; if (sscanf(s, "%s", buf) == 1) { /* get parameters from a file */ bcopy(&stdview, &nv, sizeof(VIEW)); - if ((fname = getpath(buf, NULL)) == NULL || + if ((fname = getpath(buf, NULL, 0)) == NULL || (success = viewfile(fname, &nv)) == -1) { sprintf(errmsg, "cannot open \"%s\"", buf); error(COMMAND, errmsg); @@ -185,53 +161,6 @@ char *s; } -getinterest(s, direc, vec, mp) /* get area of interest */ -char *s; -int direc; -FVECT vec; -double *mp; -{ - int x, y; - RAY thisray; - register int i; - - if (sscanf(s, "%lf", mp) != 1) - *mp = 1.0; - else if (*mp < -FTINY) /* negative zoom is reduction */ - *mp = -1.0 / *mp; - else if (*mp <= FTINY) { /* too small */ - error(COMMAND, "illegal magnification"); - return(-1); - } - if (sscanf(s, "%*lf %lf %lf %lf", &vec[0], &vec[1], &vec[2]) != 3) { - if (dev->getcur == NULL) - return(-1); - (*dev->comout)("Pick view center\n"); - if ((*dev->getcur)(&x, &y) == ABORT) - return(-1); - rayview(thisray.rorg, thisray.rdir, &ourview, x+.5, y+.5); - if (!direc || ourview.type == VT_PAR) { - rayorigin(&thisray, NULL, PRIMARY, 1.0); - if (!localhit(&thisray, &thescene)) { - error(COMMAND, "not a local object"); - return(-1); - } - } - if (direc) - if (ourview.type == VT_PAR) - for (i = 0; i < 3; i++) - vec[i] = thisray.rop[i] - ourview.vp[i]; - else - VCOPY(vec, thisray.rdir); - else - VCOPY(vec, thisray.rop); - } else if (direc) - for (i = 0; i < 3; i++) - vec[i] -= ourview.vp[i]; - return(0); -} - - getaim(s) /* aim camera */ char *s; { @@ -369,11 +298,11 @@ char *s; e *= atof(cp); } if (p != NULL) { /* relative setting */ - if (intens(p->v) <= FTINY) { + if (bright(p->v) <= FTINY) { error(COMMAND, "cannot normalize to zero"); return; } - e *= 0.5 / intens(p->v); + e *= 0.5 / bright(p->v); } if (e <= FTINY || fabs(1.0 - e) <= FTINY) return; @@ -392,6 +321,7 @@ register char *s; extern int maxdepth; extern double dstrsrc; extern double shadthresh; + extern double shadcert; extern COLOR ambval; extern double ambacc; extern double minarad; @@ -404,7 +334,7 @@ register char *s; char buf[128]; if (s[0] == '\0') { - (*dev->comout)("aa ab ad ar as av dj dt lr lw sd sp: "); + (*dev->comout)("aa ab ad ar as av dc dj dt lr lw sp st: "); (*dev->comin)(buf); s = buf; } @@ -450,6 +380,17 @@ register char *s; } dstrsrc = d0; break; + case 'c': /* certainty */ + if (sscanf(s+2, "%lf", &d0) != 1) { + sprintf(buf, "direct certainty (%.6g): ", + shadcert); + (*dev->comout)(buf); + (*dev->comin)(buf); + if (sscanf(buf, "%lf", &d0) != 1) + break; + } + shadcert = d0; + break; case 't': /* threshold */ if (sscanf(s+2, "%lf", &d0) != 1) { sprintf(buf, "direct threshold (%.6g): ", @@ -555,9 +496,9 @@ register char *s; psample = i0; pdepth = 0; break; - case 'd': /* difference */ + case 't': /* threshold */ if (sscanf(s+2, "%lf", &d0) != 1) { - sprintf(buf, "sample difference (%.6g): ", + sprintf(buf, "sample threshold (%.6g): ", maxdiff); (*dev->comout)(buf); (*dev->comin)(buf); @@ -641,7 +582,7 @@ writepict(s) /* write the picture to a file */ char *s; { static char buf[128]; - char *fname, *getpath(); + char *fname; FILE *fp; COLR *scanline; int y; @@ -650,7 +591,7 @@ char *s; error(COMMAND, "no file"); return; } - if ((fname = getpath(buf, NULL)) == NULL || + if ((fname = getpath(buf, NULL, 0)) == NULL || (fp = fopen(fname, "w")) == NULL) { sprintf(errmsg, "cannot open \"%s\"", buf); error(COMMAND, errmsg); @@ -662,10 +603,11 @@ char *s; /* write header */ fputs(progname, fp); fprintview(&ourview, fp); - fputs("\n", fp); + putc('\n', fp); if (exposure != 1.0) - fprintf(fp, "EXPOSURE=%e\n", exposure); - fprintf(fp, "\n-Y %d +X %d\n", ourview.vresolu, ourview.hresolu); + fputexpos(exposure, fp); + putc('\n', fp); + fputresolu(YMAJOR|YDECR, ourview.hresolu, ourview.vresolu, fp); scanline = (COLR *)malloc(ourview.hresolu*sizeof(COLR)); if (scanline == NULL)
