--- ray/src/rt/rv2.c 1991/10/11 12:12:40 1.29 +++ ray/src/rt/rv2.c 1992/12/11 17:56:22 2.14 @@ -1,4 +1,4 @@ -/* Copyright (c) 1991 Regents of the University of California */ +/* Copyright (c) 1992 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -18,10 +18,19 @@ static char SCCSid[] = "$SunId$ LBL"; #include "rpaint.h" +#include "resolu.h" + #include -#define CTRL(c) ('c'-'@') +#define CTRL(c) ((c)-'@') +#ifdef SMLFLT +#define sscanvec(s,v) (sscanf(s,"%f %f %f",v,v+1,v+2)==3) +#else +#define sscanvec(s,v) (sscanf(s,"%lf %lf %lf",v,v+1,v+2)==3) +#endif + + extern char VersionID[]; extern char *progname; extern char *octname; @@ -56,6 +65,16 @@ char *s; int change = 0; VIEW nv; + while (isspace(*s)) + s++; + if (*s == '-') { /* command line parameters */ + copystruct(&nv, &ourview); + if (sscanview(&nv, s)) + newview(&nv); + else + error(COMMAND, "bad view option(s)"); + return; + } if (sscanf(s, "%s", buf) == 1) { /* write parameters to a file */ if ((fname = getpath(buf, NULL, 0)) == NULL || (fp = fopen(fname, "a")) == NULL) { @@ -73,7 +92,7 @@ char *s; sprintf(buf, "view type (%c): ", ourview.type); (*dev->comout)(buf); (*dev->comin)(buf, NULL); - if (buf[0] == CTRL(C)) return; + if (buf[0] == CTRL('C')) return; if (buf[0] && buf[0] != ourview.type) { nv.type = buf[0]; change++; @@ -83,8 +102,8 @@ char *s; ourview.vp[0], ourview.vp[1], ourview.vp[2]); (*dev->comout)(buf); (*dev->comin)(buf, NULL); - if (buf[0] == CTRL(C)) return; - if (sscanf(buf, "%lf %lf %lf", &nv.vp[0], &nv.vp[1], &nv.vp[2]) == 3) + if (buf[0] == CTRL('C')) return; + if (sscanvec(buf, nv.vp)) change++; else VCOPY(nv.vp, ourview.vp); @@ -92,8 +111,8 @@ char *s; ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]); (*dev->comout)(buf); (*dev->comin)(buf, NULL); - if (buf[0] == CTRL(C)) return; - if (sscanf(buf,"%lf %lf %lf",&nv.vdir[0],&nv.vdir[1],&nv.vdir[2]) == 3) + if (buf[0] == CTRL('C')) return; + if (sscanvec(buf, nv.vdir)) change++; else VCOPY(nv.vdir, ourview.vdir); @@ -101,8 +120,8 @@ char *s; ourview.vup[0], ourview.vup[1], ourview.vup[2]); (*dev->comout)(buf); (*dev->comin)(buf, NULL); - if (buf[0] == CTRL(C)) return; - if (sscanf(buf,"%lf %lf %lf",&nv.vup[0],&nv.vup[1],&nv.vup[2]) == 3) + if (buf[0] == CTRL('C')) return; + if (sscanvec(buf, nv.vup)) change++; else VCOPY(nv.vup, ourview.vup); @@ -110,7 +129,7 @@ char *s; ourview.horiz, ourview.vert); (*dev->comout)(buf); (*dev->comin)(buf, NULL); - if (buf[0] == CTRL(C)) return; + if (buf[0] == CTRL('C')) return; if (sscanf(buf, "%lf %lf", &nv.horiz, &nv.vert) == 2) change++; else { @@ -120,7 +139,7 @@ char *s; ourview.hoff, ourview.voff); (*dev->comout)(buf); (*dev->comin)(buf, NULL); - if (buf[0] == CTRL(C)) return; + if (buf[0] == CTRL('C')) return; if (sscanf(buf, "%lf %lf", &nv.hoff, &nv.voff) == 2) change++; else { @@ -142,7 +161,7 @@ char *s; if (sscanf(s, "%s", buf) == 1) { /* get parameters from a file */ copystruct(&nv, &stdview); if ((fname = getpath(buf, NULL, 0)) == NULL || - (success = viewfile(fname, &nv, 0, 0)) == -1) { + (success = viewfile(fname, &nv, NULL)) == -1) { sprintf(errmsg, "cannot open \"%s\"", buf); error(COMMAND, errmsg); return; @@ -167,7 +186,6 @@ char *s; getaim(s) /* aim camera */ char *s; { - extern double tan(), atan(); double zfact; VIEW nv; @@ -198,7 +216,6 @@ char *s; getrotate(s) /* rotate camera */ char *s; { - extern double normalize(), tan(), atan(); VIEW nv; FVECT v1; double angle, elev, zfact; @@ -244,7 +261,6 @@ register char *s; getexposure(s) /* get new exposure */ char *s; { - double atof(), pow(), fabs(); char buf[128]; register char *cp; register PNODE *p; @@ -289,7 +305,7 @@ char *s; e *= atof(cp); } if (p != NULL) { /* relative setting */ - if (bright(p->v) <= FTINY) { + if (bright(p->v) < 1e-15) { error(COMMAND, "cannot normalize to zero"); return; } @@ -321,10 +337,10 @@ register union {int i; double d; COLOR C;} *ptr; (*dev->comout)(buf); (*dev->comin)(buf, NULL); if (sscanf(buf, "%d", &i0) != 1) - break; + return(0); } ptr->i = i0; - break; + return(1); case 'r': /* real */ if (sscanf(str, "%lf", &d0) != 1) { (*dev->comout)(dsc); @@ -332,22 +348,22 @@ register union {int i; double d; COLOR C;} *ptr; (*dev->comout)(buf); (*dev->comin)(buf, NULL); if (sscanf(buf, "%lf", &d0) != 1) - break; + return(0); } ptr->d = d0; - break; + return(1); case 'b': /* boolean */ if (sscanf(str, "%1s", buf) != 1) { (*dev->comout)(dsc); - sprintf(buf, " (%c): ", ptr->i ? 'y' : 'n'); + sprintf(buf, "? (%c): ", ptr->i ? 'y' : 'n'); (*dev->comout)(buf); (*dev->comin)(buf, NULL); if (buf[0] == '\0' || index("yY+1tTnN-0fF", buf[0]) == NULL) - break; + return(0); } ptr->i = index("yY+1tT", buf[0]) != NULL; - break; + return(1); case 'C': /* color */ if (sscanf(str, "%lf %lf %lf", &d0, &d1, &d2) != 3) { (*dev->comout)(dsc); @@ -358,10 +374,10 @@ register union {int i; double d; COLOR C;} *ptr; (*dev->comout)(buf); (*dev->comin)(buf, NULL); if (sscanf(buf, "%lf %lf %lf", &d0, &d1, &d2) != 3) - break; + return(0); } setcolor(ptr->C, d0, d1, d2); - break; + return(1); } } @@ -378,18 +394,20 @@ register char *s; extern double shadcert; extern COLOR ambval; extern double ambacc; - extern double minarad; extern int ambres; extern int ambdiv; extern int ambssamp; extern int ambounce; - extern int directinvis; + extern int directvis; + extern double srcsizerat; extern int do_irrad; + extern double specjitter; + extern double specthresh; char buf[128]; if (s[0] == '\0') { (*dev->comout)( - "aa ab ad ar as av b dc di dj dt i lr lw sp st: "); + "aa ab ad ar as av b dc di dj ds dt i lr lw ps pt sj st: "); (*dev->comin)(buf, NULL); s = buf; } @@ -417,10 +435,13 @@ register char *s; case 't': /* threshold */ getparam(s+2, "direct threshold", 'r', &shadthresh); break; - case 'i': /* invisibility */ - getparam(s+2, "direct invisibility", - 'b', &directinvis); + case 'v': /* visibility */ + getparam(s+2, "direct visibility", + 'b', &directvis); break; + case 's': /* sampling */ + getparam(s+2, "direct sampling", 'r', &srcsizerat); + break; default: goto badparam; } @@ -434,7 +455,7 @@ register char *s; case 'a': /* ambient */ switch (s[1]) { case 'v': /* value */ - getparam(s+2, "ambient value", 'C', ambval); + getparam(s+2, "ambient value", 'C', (COLOR *)ambval); break; case 'a': /* accuracy */ getparam(s+2, "ambient accuracy", 'r', &ambacc); @@ -449,27 +470,39 @@ register char *s; getparam(s+2, "ambient bounces", 'i', &ambounce); break; case 'r': - getparam(s+2, "ambient resolution", 'i', &ambres); - minarad = ambres > 0 ? thescene.cusize/ambres : 0.0; + if (getparam(s+2, "ambient resolution", 'i', &ambres)) + setambres(ambres); break; default: goto badparam; } break; - case 's': /* sample */ + case 'p': /* pixel */ switch (s[1]) { - case 'p': /* pixel */ - getparam(s+2, "sample pixel", 'i', &psample); - pdepth = 0; + case 's': /* sample */ + if (getparam(s+2, "pixel sample", 'i', &psample)) + pdepth = 0; break; case 't': /* threshold */ - getparam(s+2, "sample threshold", 'r', &maxdiff); - pdepth = 0; + if (getparam(s+2, "pixel threshold", 'r', &maxdiff)) + pdepth = 0; break; default: goto badparam; } break; + case 's': /* specular */ + switch (s[1]) { + case 'j': /* jitter */ + getparam(s+2, "specular jitter", 'r', &specjitter); + break; + case 't': /* threshold */ + getparam(s+2, "specular threshold", 'r', &specthresh); + break; + default: + goto badparam; + } + break; case '\0': /* nothing */ break; default:; @@ -489,9 +522,8 @@ char *s; int x, y; RAY thisray; - if (sscanf(s, "%lf %lf %lf %lf %lf %lf", - &thisray.rorg[0], &thisray.rorg[1], &thisray.rorg[2], - &thisray.rdir[0], &thisray.rdir[1], &thisray.rdir[2]) != 6) { + if (!sscanvec(s, thisray.rorg) || + !sscanvec(sskip(sskip(sskip(s))), thisray.rdir)) { if (dev->getcur == NULL) return; @@ -531,10 +563,11 @@ char *s; (*dev->comout)(buf); } (*dev->comin)(buf, NULL); - sprintf(buf, "with value (%.6g %.6g %.6g)", + sprintf(buf, "value (%.5g %.5g %.5g) (%.1fL)", colval(thisray.rcol,RED), colval(thisray.rcol,GRN), - colval(thisray.rcol,BLU)); + colval(thisray.rcol,BLU), + luminance(thisray.rcol)); (*dev->comout)(buf); } (*dev->comin)(buf, NULL); @@ -560,6 +593,9 @@ char *s; error(COMMAND, errmsg); return; } +#ifdef MSDOS + setmode(fileno(fp), O_BINARY); +#endif (*dev->comout)("writing \""); (*dev->comout)(fname); (*dev->comout)("\"...\n"); @@ -577,7 +613,7 @@ char *s; fputaspect(dev->pixaspect, fp); fputformat(COLRFMT, fp); putc('\n', fp); - fputresolu(YMAJOR|YDECR, hresolu, vresolu, fp); + fprtresolu(hresolu, vresolu, fp); scanline = (COLR *)malloc(hresolu*sizeof(COLR)); if (scanline == NULL) {
