root/radiance/ray/src/rt/rv2.c
Fri May 2 23:56:18 2025 UTC (4 weeks, 3 days ago) by greg
Changes since 2.78: +23 -18 lines
Diff to previous 2.78
feat(rvu): Altered the "origin" command to take shift distances
Tue Apr 22 16:39:20 2025 UTC (5 weeks, 6 days ago) by greg
Changes since 2.77: +3 -3 lines
Diff to previous 2.77
feat(rvu): Changed output format for trace results
Tue Apr 22 15:47:47 2025 UTC (5 weeks, 6 days ago) by greg
Changes since 2.76: +29 -53 lines
Diff to previous 2.76
fix(rvu): Issue with tiny changes that are significant to me setting (others?)
Tue Dec 3 19:36:58 2024 UTC (5 months, 4 weeks ago) by greg
Diff to previous 2.75
perf: Minor conditional optimizations
Fri Nov 17 20:02:07 2023 UTC (18 months, 2 weeks ago) by greg
Changes since 2.74: +7 -5 lines
Diff to previous 2.74
Wed Nov 15 18:02:53 2023 UTC (18 months, 2 weeks ago) by greg
Changes since 2.73: +5 -5 lines
Diff to previous 2.73
Sun Nov 14 17:30:02 2021 UTC (3 years, 6 months ago) by greg
Changes since 2.72: +2 -1 lines
Diff to previous 2.72
feat(rpict, rvu): added Sharp RGB primary rendering ability with -DSHARP_RGB
Fri Feb 12 00:41:19 2021 UTC (4 years, 3 months ago) by greg
Changes since 2.71: +5 -6 lines
Diff to previous 2.71
refactor: Created comparison macros for RREAL and FVECT types
Mon Feb 1 16:19:49 2021 UTC (4 years, 4 months ago) by greg
Changes since 2.70: +2 -2 lines
Diff to previous 2.70
perf: made use of OVOID and findmaterial() more consistent and efficient
Thu Mar 12 17:19:18 2020 UTC (5 years, 2 months ago) by greg
Diff to previous 2.69
Added precautionary testing when checking for FHUGE
Tue Nov 13 19:58:33 2018 UTC (6 years, 6 months ago) by greg
Changes since 2.68: +2 -2 lines
Diff to previous 2.68
Thu Nov 8 00:54:07 2018 UTC (6 years, 6 months ago) by greg
Diff to previous 2.67
Thu Apr 12 16:21:53 2018 UTC (7 years, 1 month ago) by greg
Diff to previous 2.66
Increased distance in front of selected point to avoid view errors
Fri Mar 30 23:14:07 2018 UTC (7 years, 2 months ago) by greg
Changes since 2.65: +6 -3 lines
Diff to previous 2.65
Added single-argument mode to John M's "origin" command in rvu
Fri Apr 11 20:27:23 2014 UTC (11 years, 1 month ago) by greg
Changes since 2.64: +2 -6 lines
Diff to previous 2.64
Made reading of vectors more consistent with FVFORMAT macro
Fri Oct 18 17:04:13 2013 UTC (11 years, 7 months ago) by greg
Changes since 2.63: +47 -1 lines
Diff to previous 2.63
Added rvu "origin" command requested by John M.
Thu Sep 6 00:07:43 2012 UTC (12 years, 8 months ago) by greg
Changes since 2.62: +4 -7 lines
Diff to previous 2.62
Wed Oct 5 17:20:55 2011 UTC (13 years, 8 months ago) by greg
Changes since 2.61: +11 -19 lines
Diff to previous 2.61
Windows compatibility changes from Bill Hoffman
Wed Oct 20 16:36:10 2010 UTC (14 years, 7 months ago) by greg
Changes since 2.60: +6 -5 lines
Diff to previous 2.60
Minor code cleanup
Fri Oct 8 22:55:49 2010 UTC (14 years, 7 months ago) by greg
Changes since 2.59: +4 -4 lines
Diff to previous 2.59
Changed -sj option to -ss
Wed Jan 14 20:27:00 2009 UTC (16 years, 4 months ago) by greg
Changes since 2.58: +4 -1 lines
Diff to previous 2.58
Nullify newparam setting for non-rendering changes
Fri Sep 5 19:45:41 2008 UTC (16 years, 9 months ago) by greg
Changes since 2.57: +2 -1 lines
Diff to previous 2.57
Fixed bug that broke "exposure" command
Fri Aug 29 00:30:51 2008 UTC (16 years, 9 months ago) by greg
Changes since 2.56: +17 -4 lines
Diff to previous 2.56
Improved determination of when we actually have a new parameter
Thu Aug 21 16:13:00 2008 UTC (16 years, 9 months ago) by greg
Changes since 2.55: +2 -4 lines
Diff to previous 2.55
Improved responsiveness to command input
Thu Aug 21 07:05:59 2008 UTC (16 years, 9 months ago) by greg
Changes since 2.54: +39 -37 lines
Diff to previous 2.54
Wed Jun 7 17:52:04 2006 UTC (19 years ago) by schorsch
CVS Tags: rad3R8, rad3R9
Changes since 2.53: +1 -2 lines
Diff to previous 2.53
Mon Aug 22 07:02:21 2005 UTC (19 years, 9 months ago) by greg
CVS Tags: rad3R7P2
Changes since 2.52: +4 -1 lines
Diff to previous 2.52
Added feedback as to focus distance set with "focus" command
Thu Jun 16 01:55:44 2005 UTC (19 years, 11 months ago) by greg
CVS Tags: rad3R7P1
Diff to previous 2.51
Removed extra semicolon (syntax error on some compilers)
Tue Jun 14 03:34:14 2005 UTC (19 years, 11 months ago) by greg
Changes since 2.50: +4 -4 lines
Diff to previous 2.50
Had to change new -R rendering option to -u to avoid conflict with rpiece
Mon Jun 13 20:07:56 2005 UTC (19 years, 11 months ago) by greg
Changes since 2.49: +6 -2 lines
Diff to previous 2.49
Tue Apr 19 01:15:06 2005 UTC (20 years, 1 month ago) by greg
Diff to previous 2.48
Thu Apr 14 17:38:06 2005 UTC (20 years, 1 month ago) by greg
Changes since 2.47: +4 -4 lines
Diff to previous 2.47
Minor fix to last change in trace reporting for mixtures
Thu Apr 14 17:34:49 2005 UTC (20 years, 1 month ago) by greg
Changes since 2.46: +19 -5 lines
Diff to previous 2.46
Changed trace command so both modifier and (material) are reported
Thu Apr 14 04:42:33 2005 UTC (20 years, 1 month ago) by greg
Diff to previous 2.45
Made it so "trace" command reports material rather than modifier
Fri Jan 21 00:52:59 2005 UTC (20 years, 4 months ago) by greg
Changes since 2.44: +42 -3 lines
Diff to previous 2.44
Tue Jan 18 00:33:16 2005 UTC (20 years, 4 months ago) by greg
Changes since 2.43: +5 -34 lines
Diff to previous 2.43
Tue Mar 30 16:13:01 2004 UTC (21 years, 2 months ago) by schorsch
Changes since 2.42: +60 -44 lines
Diff to previous 2.42
Mon Jul 21 22:30:19 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 2.41: +7 -7 lines
Diff to previous 2.41
Mon Jun 30 14:59:13 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.40: +6 -5 lines
Diff to previous 2.40
Thu Jun 5 19:29:34 2003 UTC (22 years ago) by schorsch
Changes since 2.39: +5 -8 lines
Diff to previous 2.39
Tue Feb 25 02:47:23 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.38: +1 -56 lines
Diff to previous 2.38
Sat Feb 22 02:07:29 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.37: +131 -69 lines
Diff to previous 2.37
Tue Mar 18 18:09:15 1997 UTC (28 years, 2 months ago) by greg
Changes since 2.36: +4 -4 lines
Diff to previous 2.36
refinement on last change
Fri Mar 7 16:58:58 1997 UTC (28 years, 3 months ago) by greg
Changes since 2.35: +4 -0 lines
Diff to previous 2.35
added object number to ray structure for instance tracking
Wed Apr 17 14:02:12 1996 UTC (29 years, 1 month ago) by greg
Changes since 2.34: +3 -2 lines
Diff to previous 2.34
Wed Feb 14 15:25:34 1996 UTC (29 years, 3 months ago) by greg
Changes since 2.33: +5 -1 lines
Diff to previous 2.33
Wed Jan 17 11:00:09 1996 UTC (29 years, 4 months ago) by greg
Diff to previous 2.32
replaced sskip() behavior and added new sskip2() function
Fri Dec 8 21:27:34 1995 UTC (29 years, 6 months ago) by greg
Changes since 2.31: +26 -2 lines
Diff to previous 2.31
added participating media and -m* options
Thu May 4 15:50:26 1995 UTC (30 years, 1 month ago) by greg
Diff to previous 2.30
fixed error in set options list
Tue Mar 21 14:40:14 1995 UTC (30 years, 2 months ago) by greg
Changes since 2.29: +3 -2 lines
Diff to previous 2.29
added effective ray length to ray reporting
Fri Feb 3 08:58:47 1995 UTC (30 years, 4 months ago) by greg
Changes since 2.28: +1 -0 lines
Diff to previous 2.28
minor bug fix in b setting switch
Thu Dec 22 11:46:14 1994 UTC (30 years, 5 months ago) by greg
Diff to previous 2.27
made view changes properly manage fore and aft clipping planes
Wed Dec 21 09:52:03 1994 UTC (30 years, 5 months ago) by greg
Changes since 2.26: +15 -3 lines
Diff to previous 2.26
added -bv option for back face visibility (normally on)
Tue Dec 20 20:18:37 1994 UTC (30 years, 5 months ago) by greg
Changes since 2.25: +15 -3 lines
Diff to previous 2.25
Tue Jul 12 15:24:28 1994 UTC (30 years, 10 months ago) by greg
Diff to previous 2.24
fixed bug in e @ specification
Mon Feb 28 09:24:43 1994 UTC (31 years, 3 months ago) by greg
Changes since 2.23: +1 -0 lines
Diff to previous 2.23
added newheader() call
Thu Jan 6 15:52:17 1994 UTC (31 years, 5 months ago) by greg
Changes since 2.22: +2 -1 lines
Diff to previous 2.22
added mention of hitting backside of surface in traceray()
Wed Dec 15 16:59:14 1993 UTC (31 years, 5 months ago) by greg
Diff to previous 2.21
added check for void modifier in traceray()
Thu Sep 9 14:57:53 1993 UTC (31 years, 9 months ago) by greg
Changes since 2.20: +2 -0 lines
Diff to previous 2.20
added missing popen() declaration
Thu Sep 9 13:47:55 1993 UTC (31 years, 9 months ago) by greg
Changes since 2.19: +14 -4 lines
Diff to previous 2.19
bug fixes in default name usage for MS-DOS
Thu Aug 26 11:24:04 1993 UTC (31 years, 9 months ago) by greg
Changes since 2.18: +8 -4 lines
Diff to previous 2.18
minor improvements in use of getpath()
Wed Aug 25 14:13:51 1993 UTC (31 years, 9 months ago) by greg
Changes since 2.17: +71 -1 lines
Diff to previous 2.17
added L and V commands
Thu Aug 5 13:17:54 1993 UTC (31 years, 10 months ago) by greg
Changes since 2.16: +2 -1 lines
Diff to previous 2.16
fixed problem with resetting of ambient accuracy
Wed Jun 2 21:04:02 1993 UTC (32 years ago) by greg
Changes since 2.15: +13 -9 lines
Diff to previous 2.15
added "exposure @" subcommand
Mon Mar 8 12:37:35 1993 UTC (32 years, 3 months ago) by greg
Diff to previous 2.14
Fri Dec 11 17:56:22 1992 UTC (32 years, 5 months ago) by greg
Diff to previous 2.13
changed error sense for zero in getexpos()
Thu Nov 19 20:27:03 1992 UTC (32 years, 6 months ago) by greg
Diff to previous 2.12
changed -di to ! -dv
Thu Oct 15 21:13:14 1992 UTC (32 years, 7 months ago) by greg
Changes since 2.11: +3 -0 lines
added setmode(fd,O_BINARY) where needed for MSDOS
Tue Oct 6 17:13:42 1992 UTC (32 years, 8 months ago) by greg
changes for 32-bit PC port
Fri Oct 2 16:19:43 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.9: +0 -2 lines
Mon Apr 6 18:04:19 1992 UTC (33 years, 2 months ago) by greg
Changes since 2.8: +11 -1 lines
changed view command to accept options
Wed Mar 4 16:52:10 1992 UTC (33 years, 3 months ago) by greg
Changes since 2.7: +1 -3 lines
Tue Feb 18 16:38:51 1992 UTC (33 years, 3 months ago) by greg
lowered minimum allowed exposure in getexpos()
Fri Jan 17 09:27:17 1992 UTC (33 years, 4 months ago) by greg
Changes since 2.5: +12 -6 lines
fixed bug in use of scanf() with SMLFLT defined
Wed Jan 15 16:55:21 1992 UTC (33 years, 4 months ago) by greg
Changes since 2.4: +19 -5 lines
added change of s options and changed old s options to p options
Mon Dec 23 23:18:31 1991 UTC (33 years, 5 months ago) by greg
Changes since 2.3: +7 -7 lines
fixed CTRL(c) macro for ANSII compilers
Thu Dec 19 14:54:55 1991 UTC (33 years, 5 months ago) by greg
removed atof() declarations for NeXT
Thu Nov 21 10:10:30 1991 UTC (33 years, 6 months ago) by greg
added '?' to boolean query
Tue Nov 12 17:09:52 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.33: +0 -0 lines
Diff to previous 1.33
Mon Nov 11 17:42:19 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.32: +4 -2 lines
Diff to previous 1.32
changed calls to viewfile() and fputresolu()
Tue Oct 29 12:06:44 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.31: +3 -2 lines
Diff to previous 1.31
added luminance to printed values in traceray()
Tue Oct 22 11:58:17 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.30: +16 -15 lines
Diff to previous 1.30
added -ds option
Mon Oct 21 13:30:43 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.29: +4 -0 lines
Diff to previous 1.29
added ds setting
Fri Oct 11 12:12:40 1991 UTC (33 years, 8 months ago) by greg
Changes since 1.28: +6 -2 lines
Diff to previous 1.28
added octree name to picture header
Thu Oct 10 12:08:58 1991 UTC (33 years, 8 months ago) by greg
Changes since 1.27: +2 -0 lines
Diff to previous 1.27
changed SOFT= to SOFTWARE=
Mon Aug 26 12:53:21 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.26: +7 -3 lines
Diff to previous 1.26
improved memory handing
Mon Aug 26 10:12:02 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.25: +2 -1 lines
Diff to previous 1.25
fixed error message for unknown set variable
Fri Jul 19 15:22:02 1991 UTC (33 years, 10 months ago) by greg
Changes since 1.24: +5 -1 lines
Diff to previous 1.24
made boolean parameter setting more forgiving
Thu Jul 18 16:37:59 1991 UTC (33 years, 10 months ago) by greg
Changes since 1.23: +78 -151 lines
Diff to previous 1.23
simplified setparam() procedure
Thu Jul 18 15:49:06 1991 UTC (33 years, 10 months ago) by greg
Changes since 1.22: +38 -2 lines
Diff to previous 1.22
added set options for di, i and b
Fri Apr 19 12:45:34 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.21: +1 -0 lines
Diff to previous 1.21
added format info to headers
Sun Oct 14 11:04:56 1990 UTC (34 years, 7 months ago) by greg
Changes since 1.20: +12 -21 lines
Diff to previous 1.20
added fisheye view types
Tue Feb 27 09:50:56 1990 UTC (35 years, 3 months ago) by greg
Diff to previous 1.19
minor fixes in comments etc.
Mon Feb 5 09:57:45 1990 UTC (35 years, 4 months ago) by greg
Changes since 1.18: +1 -0 lines
Diff to previous 1.18
added ability to comment view in getview()
Tue Jan 30 11:37:37 1990 UTC (35 years, 4 months ago) by greg
Changes since 1.17: +24 -24 lines
Diff to previous 1.17
Fri Jan 19 00:00:29 1990 UTC (35 years, 4 months ago) by greg
Changes since 1.16: +4 -4 lines
Diff to previous 1.16
Tue Jan 16 11:30:13 1990 UTC (35 years, 4 months ago) by greg
Diff to previous 1.15
changed reading and writing of z-files and viewfiles
Thu Jan 11 09:03:39 1990 UTC (35 years, 4 months ago) by greg
Changes since 1.14: +2 -0 lines
Diff to previous 1.14
added writing of pixel aspect ratio to writepict()
Mon Jan 8 13:38:05 1990 UTC (35 years, 5 months ago) by greg
Changes since 1.13: +20 -20 lines
Diff to previous 1.13
Fri Jan 5 18:04:25 1990 UTC (35 years, 5 months ago) by greg
Diff to previous 1.12
replaced fprintf() with fputexpos() in writepicture()
Fri Oct 27 11:48:19 1989 UTC (35 years, 7 months ago) by greg
Changes since 1.11: +12 -85 lines
Diff to previous 1.11
added repaint command
Wed Sep 13 13:40:13 1989 UTC (35 years, 8 months ago) by greg
Diff to previous 1.10
Added calls to picture resolution get/put routines
Thu Jul 27 22:58:26 1989 UTC (35 years, 10 months ago) by greg
Changes since 1.9: +6 -6 lines
Diff to previous 1.9
Changed getpath() to check access modes
Tue Jun 13 10:57:45 1989 UTC (35 years, 11 months ago) by greg
Changes since 1.8: +15 -1 lines
Diff to previous 1.8
Thu Jun 8 17:04:40 1989 UTC (36 years ago) by greg
Changes since 1.7: +5 -5 lines
Diff to previous 1.7
Changed back to threshold testing for direct
Wed Jun 7 22:22:40 1989 UTC (36 years ago) by greg
Diff to previous 1.6
Changed "direct threshold" name to "direct tolerance"
Wed Jun 7 08:38:35 1989 UTC (36 years ago) by greg
Diff to previous 1.5
Wed Jun 7 08:35:26 1989 UTC (36 years ago) by greg
Changes since 1.4: +27 -10 lines
Diff to previous 1.4
Glow type changed
Spot type eliminated
Tue May 30 09:57:13 1989 UTC (36 years ago) by greg
Changes since 1.3: +19 -11 lines
Added elevation to pivot and zoom to rotate commands
Fri Mar 3 18:34:33 1989 UTC (36 years, 3 months ago) by greg
Changes since 1.2: +21 -8 lines
Fixed unintentional change of view in getview()
Fri Feb 3 07:58:07 1989 UTC (36 years, 4 months ago) by greg
Changed view parameters string back to progname
Thu Feb 2 10:41:37 1989 UTC (36 years, 4 months ago) by greg
