1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rtrace.c,v 2.79 2019/05/06 16:49:38 greg Exp $"; |
3 |
#endif |
4 |
5 |
* rtrace.c - program and variables for individual ray tracing. |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
11 |
* Input is in the form: |
12 |
13 |
* xorg yorg zorg xdir ydir zdir |
14 |
15 |
* The direction need not be normalized. Output is flexible. |
16 |
* If the direction vector is (0,0,0), then the output is flushed. |
17 |
* All values default to ascii representation of real |
18 |
* numbers. Binary representations can be selected |
19 |
* with '-ff' for float or '-fd' for double. By default, |
20 |
* radiance is computed. The '-i' or '-I' options indicate that |
21 |
* irradiance values are desired. |
22 |
23 |
24 |
#include <time.h> |
25 |
26 |
#include "platform.h" |
27 |
#include "ray.h" |
28 |
#include "ambient.h" |
29 |
#include "source.h" |
30 |
#include "otypes.h" |
31 |
#include "otspecial.h" |
32 |
#include "resolu.h" |
33 |
#include "random.h" |
34 |
35 |
extern int inform; /* input format */ |
36 |
extern int outform; /* output format */ |
37 |
extern char *outvals; /* output values */ |
38 |
39 |
extern int imm_irrad; /* compute immediate irradiance? */ |
40 |
extern int lim_dist; /* limit distance? */ |
41 |
42 |
extern char *tralist[]; /* list of modifers to trace (or no) */ |
43 |
extern int traincl; /* include == 1, exclude == 0 */ |
44 |
45 |
extern int hresolu; /* horizontal resolution */ |
46 |
extern int vresolu; /* vertical resolution */ |
47 |
48 |
static int castonly = 0; |
49 |
50 |
#ifndef MAXTSET |
51 |
#define MAXTSET 8191 /* maximum number in trace set */ |
52 |
#endif |
53 |
OBJECT traset[MAXTSET+1]={0}; /* trace include/exclude set */ |
54 |
55 |
static RAY thisray; /* for our convenience */ |
56 |
57 |
typedef void putf_t(RREAL *v, int n); |
58 |
static putf_t puta, putd, putf, putrgbe; |
59 |
60 |
typedef void oputf_t(RAY *r); |
61 |
static oputf_t oputo, oputd, oputv, oputV, oputl, oputL, oputc, oputp, |
62 |
oputr, oputR, oputx, oputX, oputn, oputN, oputs, |
63 |
oputw, oputW, oputm, oputM, oputtilde; |
64 |
65 |
static void setoutput(char *vs); |
66 |
extern void tranotify(OBJECT obj); |
67 |
static void bogusray(void); |
68 |
static void raycast(RAY *r); |
69 |
static void rayirrad(RAY *r); |
70 |
static void rtcompute(FVECT org, FVECT dir, double dmax); |
71 |
static int printvals(RAY *r); |
72 |
static int getvec(FVECT vec, int fmt, FILE *fp); |
73 |
static void tabin(RAY *r); |
74 |
static void ourtrace(RAY *r); |
75 |
76 |
static oputf_t *ray_out[32], *every_out[32]; |
77 |
static putf_t *putreal; |
78 |
79 |
80 |
void |
81 |
quit( /* quit program */ |
82 |
int code |
83 |
84 |
85 |
if (ray_pnprocs > 0) /* close children if any */ |
86 |
ray_pclose(0); |
87 |
#ifndef NON_POSIX |
88 |
else if (!ray_pnprocs) { |
89 |
headclean(); /* delete header file */ |
90 |
pfclean(); /* clean up persist files */ |
91 |
92 |
#endif |
93 |
exit(code); |
94 |
95 |
96 |
97 |
char * |
98 |
formstr( /* return format identifier */ |
99 |
int f |
100 |
101 |
102 |
switch (f) { |
103 |
case 'a': return("ascii"); |
104 |
case 'f': return("float"); |
105 |
case 'd': return("double"); |
106 |
case 'c': return(COLRFMT); |
107 |
108 |
return("unknown"); |
109 |
110 |
111 |
112 |
extern void |
113 |
rtrace( /* trace rays from file */ |
114 |
char *fname, |
115 |
int nproc |
116 |
117 |
118 |
unsigned long vcount = (hresolu > 1) ? (unsigned long)hresolu*vresolu |
119 |
: (unsigned long)vresolu; |
120 |
long nextflush = (vresolu > 0) & (hresolu > 1) ? 0 : hresolu; |
121 |
int something2flush = 0; |
122 |
FILE *fp; |
123 |
double d; |
124 |
FVECT orig, direc; |
125 |
/* set up input */ |
126 |
if (fname == NULL) |
127 |
fp = stdin; |
128 |
else if ((fp = fopen(fname, "r")) == NULL) { |
129 |
sprintf(errmsg, "cannot open input file \"%s\"", fname); |
130 |
error(SYSTEM, errmsg); |
131 |
132 |
if (inform != 'a') |
133 |
SET_FILE_BINARY(fp); |
134 |
/* set up output */ |
135 |
setoutput(outvals); |
136 |
if (imm_irrad) |
137 |
castonly = 0; |
138 |
else if (castonly) |
139 |
nproc = 1; /* don't bother multiprocessing */ |
140 |
if ((nextflush > 0) & (nproc > nextflush)) { |
141 |
error(WARNING, "reducing number of processes to match flush interval"); |
142 |
nproc = nextflush; |
143 |
144 |
switch (outform) { |
145 |
case 'a': putreal = puta; break; |
146 |
case 'f': putreal = putf; break; |
147 |
case 'd': putreal = putd; break; |
148 |
case 'c': |
149 |
if (outvals[0] && (outvals[1] || !strchr("vVWrx", outvals[0]))) |
150 |
error(USER, "color format only with one of 'vVWrx'"); |
151 |
putreal = putrgbe; break; |
152 |
default: |
153 |
error(CONSISTENCY, "botched output format"); |
154 |
155 |
if (nproc > 1) { /* start multiprocessing */ |
156 |
ray_popen(nproc); |
157 |
ray_fifo_out = printvals; |
158 |
159 |
if (hresolu > 0) { |
160 |
if (vresolu > 0) |
161 |
fprtresolu(hresolu, vresolu, stdout); |
162 |
else |
163 |
fflush(stdout); |
164 |
165 |
/* process file */ |
166 |
while (getvec(orig, inform, fp) == 0 && |
167 |
getvec(direc, inform, fp) == 0) { |
168 |
169 |
d = normalize(direc); |
170 |
if (d == 0.0) { /* zero ==> flush */ |
171 |
if ((--nextflush <= 0) | !vcount && something2flush) { |
172 |
if (ray_pnprocs > 1 && ray_fifo_flush() < 0) |
173 |
error(USER, "child(ren) died"); |
174 |
bogusray(); |
175 |
fflush(stdout); |
176 |
177 |
nextflush = (vresolu > 0) & (hresolu > 1) ? 0 : |
178 |
hresolu; |
179 |
} else |
180 |
bogusray(); |
181 |
} else { /* compute and print */ |
182 |
rtcompute(orig, direc, lim_dist ? d : 0.0); |
183 |
/* flush if time */ |
184 |
if (!--nextflush) { |
185 |
186 |
187 |
fflush(stdout); |
188 |
nextflush = hresolu; |
189 |
} else |
190 |
something2flush = 1; |
191 |
192 |
if (ferror(stdout)) |
193 |
error(SYSTEM, "write error"); |
194 |
if (vcount && !--vcount) /* check for end */ |
195 |
break; |
196 |
197 |
if (ray_pnprocs > 1) { /* clean up children */ |
198 |
if (ray_fifo_flush() < 0) |
199 |
error(USER, "unable to complete processing"); |
200 |
ray_pclose(0); |
201 |
202 |
if (fflush(stdout) < 0) |
203 |
204 |
if (vcount) |
205 |
error(USER, "unexpected EOF on input"); |
206 |
if (fname != NULL) |
207 |
fclose(fp); |
208 |
209 |
210 |
211 |
static void |
212 |
trace_sources(void) /* trace rays to light sources, also */ |
213 |
214 |
int sn; |
215 |
216 |
for (sn = 0; sn < nsources; sn++) |
217 |
source[sn].sflags |= SFOLLOW; |
218 |
219 |
220 |
221 |
static void |
222 |
setoutput( /* set up output tables */ |
223 |
char *vs |
224 |
225 |
226 |
oputf_t **table = ray_out; |
227 |
228 |
castonly = 1; |
229 |
while (*vs) |
230 |
switch (*vs++) { |
231 |
case 'T': /* trace sources */ |
232 |
if (!*vs) break; |
233 |
trace_sources(); |
234 |
/* fall through */ |
235 |
case 't': /* trace */ |
236 |
if (!*vs) break; |
237 |
*table = NULL; |
238 |
table = every_out; |
239 |
trace = ourtrace; |
240 |
castonly = 0; |
241 |
break; |
242 |
case 'o': /* origin */ |
243 |
*table++ = oputo; |
244 |
break; |
245 |
case 'd': /* direction */ |
246 |
*table++ = oputd; |
247 |
break; |
248 |
case 'r': /* reflected contrib. */ |
249 |
*table++ = oputr; |
250 |
castonly = 0; |
251 |
break; |
252 |
case 'R': /* reflected distance */ |
253 |
*table++ = oputR; |
254 |
castonly = 0; |
255 |
break; |
256 |
case 'x': /* xmit contrib. */ |
257 |
*table++ = oputx; |
258 |
castonly = 0; |
259 |
break; |
260 |
case 'X': /* xmit distance */ |
261 |
*table++ = oputX; |
262 |
castonly = 0; |
263 |
break; |
264 |
case 'v': /* value */ |
265 |
*table++ = oputv; |
266 |
castonly = 0; |
267 |
break; |
268 |
case 'V': /* contribution */ |
269 |
*table++ = oputV; |
270 |
castonly = 0; |
271 |
if (ambounce > 0 && (ambacc > FTINY || ambssamp > 0)) |
272 |
error(WARNING, |
273 |
"-otV accuracy depends on -aa 0 -as 0"); |
274 |
break; |
275 |
case 'l': /* effective distance */ |
276 |
*table++ = oputl; |
277 |
castonly = 0; |
278 |
break; |
279 |
case 'c': /* local coordinates */ |
280 |
*table++ = oputc; |
281 |
break; |
282 |
case 'L': /* single ray length */ |
283 |
*table++ = oputL; |
284 |
break; |
285 |
case 'p': /* point */ |
286 |
*table++ = oputp; |
287 |
break; |
288 |
case 'n': /* perturbed normal */ |
289 |
*table++ = oputn; |
290 |
castonly = 0; |
291 |
break; |
292 |
case 'N': /* unperturbed normal */ |
293 |
*table++ = oputN; |
294 |
break; |
295 |
case 's': /* surface */ |
296 |
*table++ = oputs; |
297 |
break; |
298 |
case 'w': /* weight */ |
299 |
*table++ = oputw; |
300 |
break; |
301 |
case 'W': /* coefficient */ |
302 |
*table++ = oputW; |
303 |
castonly = 0; |
304 |
if (ambounce > 0 && (ambacc > FTINY) | (ambssamp > 0)) |
305 |
error(WARNING, |
306 |
"-otW accuracy depends on -aa 0 -as 0"); |
307 |
break; |
308 |
case 'm': /* modifier */ |
309 |
*table++ = oputm; |
310 |
break; |
311 |
case 'M': /* material */ |
312 |
*table++ = oputM; |
313 |
break; |
314 |
case '~': /* tilde */ |
315 |
*table++ = oputtilde; |
316 |
break; |
317 |
318 |
*table = NULL; |
319 |
if (do_irrad | imm_irrad) /* compatibile? */ |
320 |
for (table = ray_out; *table != NULL; table++) |
321 |
if ((*table == oputr) | (*table == oputR) | |
322 |
(*table == oputx) | (*table == oputX)) { |
323 |
error(WARNING, "-orRxX options incompatible with -I+ and -i+"); |
324 |
break; |
325 |
326 |
327 |
328 |
329 |
static void |
330 |
bogusray(void) /* print out empty record */ |
331 |
332 |
rayorigin(&thisray, PRIMARY, NULL, NULL); |
333 |
printvals(&thisray); |
334 |
335 |
336 |
337 |
static void |
338 |
raycast( /* compute first ray intersection only */ |
339 |
RAY *r |
340 |
341 |
342 |
if (!localhit(r, &thescene)) { |
343 |
if (r->ro == &Aftplane) { /* clipped */ |
344 |
r->ro = NULL; |
345 |
r->rot = FHUGE; |
346 |
} else |
347 |
sourcehit(r); |
348 |
349 |
350 |
351 |
352 |
static void |
353 |
rayirrad( /* compute irradiance rather than radiance */ |
354 |
RAY *r |
355 |
356 |
357 |
void (*old_revf)(RAY *) = r->revf; |
358 |
/* pretend we hit surface */ |
359 |
r->rxt = r->rot = 1e-5; |
360 |
VSUM(r->rop, r->rorg, r->rdir, r->rot); |
361 |
r->ron[0] = -r->rdir[0]; |
362 |
r->ron[1] = -r->rdir[1]; |
363 |
r->ron[2] = -r->rdir[2]; |
364 |
r->rod = 1.0; |
365 |
/* compute result */ |
366 |
r->revf = raytrace; |
367 |
(*ofun[Lamb.otype].funp)(&Lamb, r); |
368 |
r->revf = old_revf; |
369 |
370 |
371 |
372 |
static void |
373 |
rtcompute( /* compute and print ray value(s) */ |
374 |
FVECT org, |
375 |
FVECT dir, |
376 |
double dmax |
377 |
378 |
379 |
/* set up ray */ |
380 |
381 |
if (imm_irrad) { |
382 |
VSUM(thisray.rorg, org, dir, 1.1e-4); |
383 |
thisray.rdir[0] = -dir[0]; |
384 |
thisray.rdir[1] = -dir[1]; |
385 |
thisray.rdir[2] = -dir[2]; |
386 |
thisray.rmax = 0.0; |
387 |
thisray.revf = rayirrad; |
388 |
} else { |
389 |
VCOPY(thisray.rorg, org); |
390 |
VCOPY(thisray.rdir, dir); |
391 |
thisray.rmax = dmax; |
392 |
if (castonly) |
393 |
thisray.revf = raycast; |
394 |
395 |
if (ray_pnprocs > 1) { /* multiprocessing FIFO? */ |
396 |
if (ray_fifo_in(&thisray) < 0) |
397 |
error(USER, "lost children"); |
398 |
return; |
399 |
400 |
samplendx++; /* else do it ourselves */ |
401 |
rayvalue(&thisray); |
402 |
403 |
404 |
405 |
406 |
static int |
407 |
printvals( /* print requested ray values */ |
408 |
RAY *r |
409 |
410 |
411 |
oputf_t **tp; |
412 |
413 |
if (ray_out[0] == NULL) |
414 |
return(0); |
415 |
for (tp = ray_out; *tp != NULL; tp++) |
416 |
(**tp)(r); |
417 |
if (outform == 'a') |
418 |
putchar('\n'); |
419 |
return(1); |
420 |
421 |
422 |
423 |
static int |
424 |
getvec( /* get a vector from fp */ |
425 |
FVECT vec, |
426 |
int fmt, |
427 |
FILE *fp |
428 |
429 |
430 |
static float vf[3]; |
431 |
static double vd[3]; |
432 |
char buf[32]; |
433 |
int i; |
434 |
435 |
switch (fmt) { |
436 |
case 'a': /* ascii */ |
437 |
for (i = 0; i < 3; i++) { |
438 |
if (fgetword(buf, sizeof(buf), fp) == NULL || |
439 |
!isflt(buf)) |
440 |
return(-1); |
441 |
vec[i] = atof(buf); |
442 |
443 |
break; |
444 |
case 'f': /* binary float */ |
445 |
if (getbinary(vf, sizeof(float), 3, fp) != 3) |
446 |
return(-1); |
447 |
VCOPY(vec, vf); |
448 |
break; |
449 |
case 'd': /* binary double */ |
450 |
if (getbinary(vd, sizeof(double), 3, fp) != 3) |
451 |
return(-1); |
452 |
VCOPY(vec, vd); |
453 |
break; |
454 |
default: |
455 |
error(CONSISTENCY, "botched input format"); |
456 |
457 |
return(0); |
458 |
459 |
460 |
461 |
void |
462 |
tranotify( /* record new modifier */ |
463 |
OBJECT obj |
464 |
465 |
466 |
static int hitlimit = 0; |
467 |
OBJREC *o = objptr(obj); |
468 |
char **tralp; |
469 |
470 |
if (obj == OVOID) { /* starting over */ |
471 |
traset[0] = 0; |
472 |
hitlimit = 0; |
473 |
return; |
474 |
475 |
if (hitlimit || !ismodifier(o->otype)) |
476 |
return; |
477 |
for (tralp = tralist; *tralp != NULL; tralp++) |
478 |
if (!strcmp(o->oname, *tralp)) { |
479 |
if (traset[0] >= MAXTSET) { |
480 |
error(WARNING, "too many modifiers in trace list"); |
481 |
hitlimit++; |
482 |
return; /* should this be fatal? */ |
483 |
484 |
insertelem(traset, obj); |
485 |
return; |
486 |
487 |
488 |
489 |
490 |
static void |
491 |
ourtrace( /* print ray values */ |
492 |
RAY *r |
493 |
494 |
495 |
oputf_t **tp; |
496 |
497 |
if (every_out[0] == NULL) |
498 |
return; |
499 |
if (r->ro == NULL) { |
500 |
if (traincl == 1) |
501 |
return; |
502 |
} else if (traincl != -1 && traincl != inset(traset, r->ro->omod)) |
503 |
return; |
504 |
tabin(r); |
505 |
for (tp = every_out; *tp != NULL; tp++) |
506 |
(**tp)(r); |
507 |
508 |
putchar('\n'); |
509 |
510 |
511 |
512 |
static void |
513 |
tabin( /* tab in appropriate amount */ |
514 |
RAY *r |
515 |
516 |
517 |
const RAY *rp; |
518 |
519 |
for (rp = r->parent; rp != NULL; rp = rp->parent) |
520 |
putchar('\t'); |
521 |
522 |
523 |
524 |
static void |
525 |
oputo( /* print origin */ |
526 |
RAY *r |
527 |
528 |
529 |
(*putreal)(r->rorg, 3); |
530 |
531 |
532 |
533 |
static void |
534 |
oputd( /* print direction */ |
535 |
RAY *r |
536 |
537 |
538 |
(*putreal)(r->rdir, 3); |
539 |
540 |
541 |
542 |
static void |
543 |
oputr( /* print mirrored contribution */ |
544 |
RAY *r |
545 |
546 |
547 |
RREAL cval[3]; |
548 |
549 |
cval[0] = colval(r->mcol,RED); |
550 |
cval[1] = colval(r->mcol,GRN); |
551 |
cval[2] = colval(r->mcol,BLU); |
552 |
(*putreal)(cval, 3); |
553 |
554 |
555 |
556 |
557 |
static void |
558 |
oputR( /* print mirrored distance */ |
559 |
RAY *r |
560 |
561 |
562 |
(*putreal)(&r->rmt, 1); |
563 |
564 |
565 |
566 |
static void |
567 |
oputx( /* print unmirrored contribution */ |
568 |
RAY *r |
569 |
570 |
571 |
RREAL cval[3]; |
572 |
573 |
cval[0] = colval(r->rcol,RED) - colval(r->mcol,RED); |
574 |
cval[1] = colval(r->rcol,GRN) - colval(r->mcol,GRN); |
575 |
cval[2] = colval(r->rcol,BLU) - colval(r->mcol,BLU); |
576 |
577 |
578 |
579 |
580 |
static void |
581 |
oputX( /* print unmirrored distance */ |
582 |
RAY *r |
583 |
584 |
585 |
(*putreal)(&r->rxt, 1); |
586 |
587 |
588 |
589 |
static void |
590 |
oputv( /* print value */ |
591 |
RAY *r |
592 |
593 |
594 |
RREAL cval[3]; |
595 |
596 |
cval[0] = colval(r->rcol,RED); |
597 |
cval[1] = colval(r->rcol,GRN); |
598 |
cval[2] = colval(r->rcol,BLU); |
599 |
600 |
601 |
602 |
603 |
static void |
604 |
oputV( /* print value contribution */ |
605 |
RAY *r |
606 |
607 |
608 |
RREAL contr[3]; |
609 |
610 |
raycontrib(contr, r, PRIMARY); |
611 |
multcolor(contr, r->rcol); |
612 |
(*putreal)(contr, 3); |
613 |
614 |
615 |
616 |
static void |
617 |
oputl( /* print effective distance */ |
618 |
RAY *r |
619 |
620 |
621 |
RREAL d = raydistance(r); |
622 |
623 |
(*putreal)(&d, 1); |
624 |
625 |
626 |
627 |
static void |
628 |
oputL( /* print single ray length */ |
629 |
RAY *r |
630 |
631 |
632 |
(*putreal)(&r->rot, 1); |
633 |
634 |
635 |
636 |
static void |
637 |
oputc( /* print local coordinates */ |
638 |
RAY *r |
639 |
640 |
641 |
(*putreal)(r->uv, 2); |
642 |
643 |
644 |
645 |
static RREAL vdummy[3] = {0.0, 0.0, 0.0}; |
646 |
647 |
648 |
static void |
649 |
oputp( /* print point */ |
650 |
RAY *r |
651 |
652 |
653 |
if (r->rot < FHUGE) |
654 |
(*putreal)(r->rop, 3); |
655 |
else |
656 |
(*putreal)(vdummy, 3); |
657 |
658 |
659 |
660 |
static void |
661 |
oputN( /* print unperturbed normal */ |
662 |
RAY *r |
663 |
664 |
665 |
666 |
(*putreal)(r->ron, 3); |
667 |
else |
668 |
669 |
670 |
671 |
672 |
static void |
673 |
oputn( /* print perturbed normal */ |
674 |
RAY *r |
675 |
676 |
677 |
FVECT pnorm; |
678 |
679 |
if (r->rot >= FHUGE) { |
680 |
681 |
return; |
682 |
683 |
raynormal(pnorm, r); |
684 |
(*putreal)(pnorm, 3); |
685 |
686 |
687 |
688 |
static void |
689 |
oputs( /* print name */ |
690 |
RAY *r |
691 |
692 |
693 |
if (r->ro != NULL) |
694 |
fputs(r->ro->oname, stdout); |
695 |
else |
696 |
putchar('*'); |
697 |
putchar('\t'); |
698 |
699 |
700 |
701 |
static void |
702 |
oputw( /* print weight */ |
703 |
RAY *r |
704 |
705 |
706 |
RREAL rwt = r->rweight; |
707 |
708 |
(*putreal)(&rwt, 1); |
709 |
710 |
711 |
712 |
static void |
713 |
oputW( /* print coefficient */ |
714 |
RAY *r |
715 |
716 |
717 |
RREAL contr[3]; |
718 |
/* shadow ray not on source? */ |
719 |
if (r->rsrc >= 0 && source[r->rsrc].so != r->ro) |
720 |
setcolor(contr, 0.0, 0.0, 0.0); |
721 |
else |
722 |
723 |
724 |
725 |
726 |
727 |
728 |
static void |
729 |
oputm( /* print modifier */ |
730 |
RAY *r |
731 |
732 |
733 |
734 |
if (r->ro->omod != OVOID) |
735 |
fputs(objptr(r->ro->omod)->oname, stdout); |
736 |
else |
737 |
fputs(VOIDID, stdout); |
738 |
else |
739 |
putchar('*'); |
740 |
putchar('\t'); |
741 |
742 |
743 |
744 |
static void |
745 |
oputM( /* print material */ |
746 |
RAY *r |
747 |
748 |
749 |
OBJREC *mat; |
750 |
751 |
if (r->ro != NULL) { |
752 |
if ((mat = findmaterial(r->ro)) != NULL) |
753 |
fputs(mat->oname, stdout); |
754 |
else |
755 |
756 |
} else |
757 |
putchar('*'); |
758 |
putchar('\t'); |
759 |
760 |
761 |
762 |
static void |
763 |
oputtilde( /* output tilde (spacer) */ |
764 |
RAY *r |
765 |
766 |
767 |
fputs("~\t", stdout); |
768 |
769 |
770 |
771 |
static void |
772 |
puta( /* print ascii value(s) */ |
773 |
RREAL *v, int n |
774 |
775 |
776 |
if (n == 3) { |
777 |
printf("%e\t%e\t%e\t", v[0], v[1], v[2]); |
778 |
return; |
779 |
780 |
while (n--) |
781 |
printf("%e\t", *v++); |
782 |
783 |
784 |
785 |
static void |
786 |
putd(RREAL *v, int n) /* output binary double(s) */ |
787 |
788 |
#ifdef SMLFLT |
789 |
double da[3]; |
790 |
int i; |
791 |
792 |
if (n > 3) |
793 |
error(INTERNAL, "code error in putd()"); |
794 |
for (i = n; i--; ) |
795 |
da[i] = v[i]; |
796 |
putbinary(da, sizeof(double), n, stdout); |
797 |
#else |
798 |
putbinary(v, sizeof(RREAL), n, stdout); |
799 |
#endif |
800 |
801 |
802 |
803 |
static void |
804 |
putf(RREAL *v, int n) /* output binary float(s) */ |
805 |
806 |
#ifndef SMLFLT |
807 |
float fa[3]; |
808 |
int i; |
809 |
810 |
if (n > 3) |
811 |
error(INTERNAL, "code error in putf()"); |
812 |
813 |
fa[i] = v[i]; |
814 |
putbinary(fa, sizeof(float), n, stdout); |
815 |
#else |
816 |
817 |
#endif |
818 |
819 |
820 |
821 |
static void |
822 |
putrgbe(RREAL *v, int n) /* output RGBE color */ |
823 |
824 |
COLR cout; |
825 |
826 |
if (n != 3) |
827 |
error(INTERNAL, "putrgbe() not called with 3 components"); |
828 |
setcolr(cout, v[0], v[1], v[2]); |
829 |
putbinary(cout, sizeof(cout), 1, stdout); |
830 |
