root/radiance/ray/src/rt/rtrace.c
Revision: 2.7
Committed: Tue Jul 21 10:36:37 1992 UTC (32 years, 10 months ago) by greg
Changes since 2.6: +0 -2 lines
fixed bug introduced in last change with -h- option of rtrace
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rtrace.c - program and variables for individual ray tracing.
9 *
10 * 6/11/86
11 */
12
13 /*
14 * Input is in the form:
15 *
16 * xorg yorg zorg xdir ydir zdir
17 *
18 * The direction need not be normalized. Output is flexible.
19 * If the direction vector is (0,0,0), then the output is flushed.
20 * All values default to ascii representation of real
21 * numbers. Binary representations can be selected
22 * with '-ff' for float or '-fd' for double. By default,
23 * radiance is computed. The '-i' or '-I' options indicate that
24 * irradiance values are desired.
25 */
26
27 #include "ray.h"
28
29 #include "octree.h"
30
31 #include "otypes.h"
32
33 #include "resolu.h"
34
35 int dimlist[MAXDIM]; /* sampling dimensions */
36 int ndims = 0; /* number of sampling dimensions */
37 int samplendx = 0; /* index for this sample */
38
39 int imm_irrad = 0; /* compute immediate irradiance? */
40
41 int inform = 'a'; /* input format */
42 int outform = 'a'; /* output format */
43 char *outvals = "v"; /* output specification */
44
45 int hresolu = 0; /* horizontal (scan) size */
46 int vresolu = 0; /* vertical resolution */
47
48 double dstrsrc = 0.0; /* square source distribution */
49 double shadthresh = .05; /* shadow threshold */
50 double shadcert = .5; /* shadow certainty */
51 int directrelay = 1; /* number of source relays */
52 int vspretest = 512; /* virtual source pretest density */
53 int directinvis = 0; /* sources invisible? */
54 double srcsizerat = .25; /* maximum ratio source size/dist. */
55
56 double specthresh = .15; /* specular sampling threshold */
57 double specjitter = 1.; /* specular sampling jitter */
58
59 int maxdepth = 6; /* maximum recursion depth */
60 double minweight = 4e-3; /* minimum ray weight */
61
62 COLOR ambval = BLKCOLOR; /* ambient value */
63 double ambacc = 0.2; /* ambient accuracy */
64 int ambres = 32; /* ambient resolution */
65 int ambdiv = 128; /* ambient divisions */
66 int ambssamp = 0; /* ambient super-samples */
67 int ambounce = 0; /* ambient bounces */
68 char *amblist[128]; /* ambient include/exclude list */
69 int ambincl = -1; /* include == 1, exclude == 0 */
70
71 extern OBJREC Lamb; /* a Lambertian surface */
72
73 static RAY thisray; /* for our convenience */
74
75 static int oputo(), oputd(), oputv(), oputl(), oputL(),
76 oputp(), oputn(), oputs(), oputw(), oputm();
77
78 static int (*ray_out[10])(), (*every_out[10])();
79 static int castonly;
80
81 static int puta(), putf(), putd();
82
83 static int (*putreal)();
84
85
86 quit(code) /* quit program */
87 int code;
88 {
89 exit(code);
90 }
91
92
93 char *
94 formstr(f) /* return format identifier */
95 int f;
96 {
97 switch (f) {
98 case 'a': return("ascii");
99 case 'f': return("float");
100 case 'd': return("double");
101 case 'c': return(COLRFMT);
102 }
103 return("unknown");
104 }
105
106
107 rtrace(fname) /* trace rays from file */
108 char *fname;
109 {
110 long vcount = hresolu>1 ? hresolu*vresolu : vresolu;
111 long nextflush = hresolu;
112 FILE *fp;
113 FVECT orig, direc;
114 /* set up input */
115 if (fname == NULL)
116 fp = stdin;
117 else if ((fp = fopen(fname, "r")) == NULL) {
118 sprintf(errmsg, "cannot open input file \"%s\"", fname);
119 error(SYSTEM, errmsg);
120 }
121 /* set up output */
122 setoutput(outvals);
123 switch (outform) {
124 case 'a': putreal = puta; break;
125 case 'f': putreal = putf; break;
126 case 'd': putreal = putd; break;
127 case 'c':
128 if (strcmp(outvals, "v"))
129 error(USER, "color format with value output only");
130 break;
131 default:
132 error(CONSISTENCY, "botched output format");
133 }
134 if (hresolu > 0 && vresolu > 0)
135 fprtresolu(hresolu, vresolu, stdout);
136 /* process file */
137 while (getvec(orig, inform, fp) == 0 &&
138 getvec(direc, inform, fp) == 0) {
139
140 if (normalize(direc) == 0.0) { /* zero ==> flush */
141 fflush(stdout);
142 continue;
143 }
144 samplendx++;
145 /* compute and print */
146 if (imm_irrad)
147 irrad(orig, direc);
148 else
149 traceray(orig, direc);
150 /* flush if time */
151 if (--nextflush == 0) {
152 fflush(stdout);
153 nextflush = hresolu;
154 }
155 if (ferror(stdout))
156 error(SYSTEM, "write error");
157 if (--vcount == 0) /* check for end */
158 break;
159 }
160 if (vcount > 0)
161 error(USER, "read error");
162 fclose(fp);
163 }
164
165
166 setoutput(vs) /* set up output tables */
167 register char *vs;
168 {
169 extern int ourtrace(), (*trace)();
170 register int (**table)() = ray_out;
171
172 castonly = 1;
173 while (*vs)
174 switch (*vs++) {
175 case 't': /* trace */
176 *table = NULL;
177 table = every_out;
178 trace = ourtrace;
179 castonly = 0;
180 break;
181 case 'o': /* origin */
182 *table++ = oputo;
183 break;
184 case 'd': /* direction */
185 *table++ = oputd;
186 break;
187 case 'v': /* value */
188 *table++ = oputv;
189 castonly = 0;
190 break;
191 case 'l': /* effective distance */
192 *table++ = oputl;
193 castonly = 0;
194 break;
195 case 'L': /* single ray length */
196 *table++ = oputL;
197 break;
198 case 'p': /* point */
199 *table++ = oputp;
200 break;
201 case 'n': /* normal */
202 *table++ = oputn;
203 break;
204 case 's': /* surface */
205 *table++ = oputs;
206 break;
207 case 'w': /* weight */
208 *table++ = oputw;
209 break;
210 case 'm': /* modifier */
211 *table++ = oputm;
212 break;
213 }
214 *table = NULL;
215 }
216
217
218 traceray(org, dir) /* compute and print ray value(s) */
219 FVECT org, dir;
220 {
221 register int (**tp)();
222
223 VCOPY(thisray.rorg, org);
224 VCOPY(thisray.rdir, dir);
225 rayorigin(&thisray, NULL, PRIMARY, 1.0);
226 if (castonly)
227 localhit(&thisray, &thescene) || sourcehit(&thisray);
228 else
229 rayvalue(&thisray);
230
231 if (ray_out[0] == NULL)
232 return;
233 for (tp = ray_out; *tp != NULL; tp++)
234 (**tp)(&thisray);
235 if (outform == 'a')
236 putchar('\n');
237 }
238
239
240 irrad(org, dir) /* compute immediate irradiance value */
241 FVECT org, dir;
242 {
243 register int i;
244
245 for (i = 0; i < 3; i++) {
246 thisray.rorg[i] = org[i] + dir[i];
247 thisray.rdir[i] = -dir[i];
248 }
249 rayorigin(&thisray, NULL, PRIMARY, 1.0);
250 /* pretend we hit surface */
251 thisray.rot = 1.0;
252 thisray.rod = 1.0;
253 VCOPY(thisray.ron, dir);
254 for (i = 0; i < 3; i++) /* fudge factor */
255 thisray.rop[i] = org[i] + 1e-4*dir[i];
256 /* compute and print */
257 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
258 oputv(&thisray);
259 if (outform == 'a')
260 putchar('\n');
261 }
262
263
264 getvec(vec, fmt, fp) /* get a vector from fp */
265 register FVECT vec;
266 int fmt;
267 FILE *fp;
268 {
269 extern char *fgetword();
270 static float vf[3];
271 static double vd[3];
272 char buf[32];
273 register int i;
274
275 switch (fmt) {
276 case 'a': /* ascii */
277 for (i = 0; i < 3; i++) {
278 if (fgetword(buf, sizeof(buf), fp) == NULL ||
279 !isflt(buf))
280 return(-1);
281 vec[i] = atof(buf);
282 }
283 break;
284 case 'f': /* binary float */
285 if (fread((char *)vf, sizeof(float), 3, fp) != 3)
286 return(-1);
287 vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2];
288 break;
289 case 'd': /* binary double */
290 if (fread((char *)vd, sizeof(double), 3, fp) != 3)
291 return(-1);
292 vec[0] = vd[0]; vec[1] = vd[1]; vec[2] = vd[2];
293 break;
294 default:
295 error(CONSISTENCY, "botched input format");
296 }
297 return(0);
298 }
299
300
301 static
302 ourtrace(r) /* print ray values */
303 RAY *r;
304 {
305 register int (**tp)();
306
307 if (every_out[0] == NULL)
308 return;
309 tabin(r);
310 for (tp = every_out; *tp != NULL; tp++)
311 (**tp)(r);
312 putchar('\n');
313 }
314
315
316 static
317 tabin(r) /* tab in appropriate amount */
318 RAY *r;
319 {
320 register RAY *rp;
321
322 for (rp = r->parent; rp != NULL; rp = rp->parent)
323 putchar('\t');
324 }
325
326
327 static
328 oputo(r) /* print origin */
329 register RAY *r;
330 {
331 (*putreal)(r->rorg[0]);
332 (*putreal)(r->rorg[1]);
333 (*putreal)(r->rorg[2]);
334 }
335
336
337 static
338 oputd(r) /* print direction */
339 register RAY *r;
340 {
341 (*putreal)(r->rdir[0]);
342 (*putreal)(r->rdir[1]);
343 (*putreal)(r->rdir[2]);
344 }
345
346
347 static
348 oputv(r) /* print value */
349 register RAY *r;
350 {
351 COLR cout;
352
353 if (outform == 'c') {
354 setcolr(cout, colval(r->rcol,RED),
355 colval(r->rcol,GRN),
356 colval(r->rcol,BLU));
357 fwrite((char *)cout, sizeof(cout), 1, stdout);
358 return;
359 }
360 (*putreal)(colval(r->rcol,RED));
361 (*putreal)(colval(r->rcol,GRN));
362 (*putreal)(colval(r->rcol,BLU));
363 }
364
365
366 static
367 oputl(r) /* print effective distance */
368 register RAY *r;
369 {
370 (*putreal)(r->rt);
371 }
372
373
374 static
375 oputL(r) /* print single ray length */
376 register RAY *r;
377 {
378 (*putreal)(r->rot);
379 }
380
381
382 static
383 oputp(r) /* print point */
384 register RAY *r;
385 {
386 if (r->rot < FHUGE) {
387 (*putreal)(r->rop[0]);
388 (*putreal)(r->rop[1]);
389 (*putreal)(r->rop[2]);
390 } else {
391 (*putreal)(0.0);
392 (*putreal)(0.0);
393 (*putreal)(0.0);
394 }
395 }
396
397
398 static
399 oputn(r) /* print normal */
400 register RAY *r;
401 {
402 if (r->rot < FHUGE) {
403 (*putreal)(r->ron[0]);
404 (*putreal)(r->ron[1]);
405 (*putreal)(r->ron[2]);
406 } else {
407 (*putreal)(0.0);
408 (*putreal)(0.0);
409 (*putreal)(0.0);
410 }
411 }
412
413
414 static
415 oputs(r) /* print name */
416 register RAY *r;
417 {
418 if (r->ro != NULL)
419 fputs(r->ro->oname, stdout);
420 else
421 putchar('*');
422 putchar('\t');
423 }
424
425
426 static
427 oputw(r) /* print weight */
428 register RAY *r;
429 {
430 (*putreal)(r->rweight);
431 }
432
433
434 static
435 oputm(r) /* print modifier */
436 register RAY *r;
437 {
438 if (r->ro != NULL)
439 fputs(objptr(r->ro->omod)->oname, stdout);
440 else
441 putchar('*');
442 putchar('\t');
443 }
444
445
446 static
447 puta(v) /* print ascii value */
448 double v;
449 {
450 printf("%e\t", v);
451 }
452
453
454 static
455 putd(v) /* print binary double */
456 double v;
457 {
458 fwrite((char *)&v, sizeof(v), 1, stdout);
459 }
460
461
462 static
463 putf(v) /* print binary float */
464 double v;
465 {
466 float f = v;
467
468 fwrite((char *)&f, sizeof(f), 1, stdout);
469 }
