root/radiance/ray/src/rt/rtrace.c
Revision: 2.42
Committed: Thu May 26 06:55:22 2005 UTC (20 years ago) by greg
Changes since 2.41: +9 -8 lines
2 static const char RCSid[] = "$Id: rtrace.c,v 2.41 2005/05/25 04:44:26 greg Exp $";
5 * rtrace.c - program and variables for individual ray tracing.
6 */
7
8 #include "copyright.h"
9
10 /*
11 * Input is in the form:
12 *
13 * xorg yorg zorg xdir ydir zdir
14 *
15 * The direction need not be normalized. Output is flexible.
16 * If the direction vector is (0,0,0), then the output is flushed.
17 * All values default to ascii representation of real
18 * numbers. Binary representations can be selected
19 * with '-ff' for float or '-fd' for double. By default,
20 * radiance is computed. The '-i' or '-I' options indicate that
21 * irradiance values are desired.
22 */
23
24 #include <time.h>
25
26 #include "platform.h"
27 #include "ray.h"
28 #include "ambient.h"
29 #include "source.h"
30 #include "otypes.h"
31 #include "resolu.h"
32
33 CUBE thescene; /* our scene */
34 OBJECT nsceneobjs; /* number of objects in our scene */
35
36 int dimlist[MAXDIM]; /* sampling dimensions */
37 int ndims = 0; /* number of sampling dimensions */
38 int samplendx = 0; /* index for this sample */
39
40 int imm_irrad = 0; /* compute immediate irradiance? */
41 int lim_dist = 0; /* limit distance? */
42
43 int inform = 'a'; /* input format */
44 int outform = 'a'; /* output format */
45 char *outvals = "v"; /* output specification */
46
47 int do_irrad = 0; /* compute irradiance? */
48
49 void (*trace)() = NULL; /* trace call */
50
51 char *tralist[128]; /* list of modifers to trace (or no) */
52 int traincl = -1; /* include == 1, exclude == 0 */
53 #define MAXTSET 511 /* maximum number in trace set */
54 OBJECT traset[MAXTSET+1]={0}; /* trace include/exclude set */
55
56 int hresolu = 0; /* horizontal (scan) size */
57 int vresolu = 0; /* vertical resolution */
58
59 double dstrsrc = 0.0; /* square source distribution */
60 double shadthresh = .03; /* shadow threshold */
61 double shadcert = .75; /* shadow certainty */
62 int directrelay = 2; /* number of source relays */
63 int vspretest = 512; /* virtual source pretest density */
64 int directvis = 1; /* sources visible? */
65 double srcsizerat = .2; /* maximum ratio source size/dist. */
66
67 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
68 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
69 double seccg = 0.; /* global scattering eccentricity */
70 double ssampdist = 0.; /* scatter sampling distance */
71
72 double specthresh = .15; /* specular sampling threshold */
73 double specjitter = 1.; /* specular sampling jitter */
74
75 int backvis = 1; /* back face visibility */
76
77 int maxdepth = 8; /* maximum recursion depth */
78 double minweight = 2e-3; /* minimum ray weight */
79
80 char *ambfile = NULL; /* ambient file name */
81 COLOR ambval = BLKCOLOR; /* ambient value */
82 int ambvwt = 0; /* initial weight for ambient value */
83 double ambacc = 0.15; /* ambient accuracy */
84 int ambres = 256; /* ambient resolution */
85 int ambdiv = 1024; /* ambient divisions */
86 int ambssamp = 512; /* ambient super-samples */
87 int ambounce = 0; /* ambient bounces */
88 char *amblist[AMBLLEN]; /* ambient include/exclude list */
89 int ambincl = -1; /* include == 1, exclude == 0 */
90
91 static int castonly = 0;
92
93 static RAY thisray; /* for our convenience */
94
95 typedef void putf_t(double v);
96 static putf_t puta, putd, putf;
97
98 typedef void oputf_t(RAY *r);
99 static oputf_t oputo, oputd, oputv, oputl, oputL, oputc, oputp,
100 oputn, oputN, oputs, oputw, oputW, oputm, oputM, oputtilde;
101
102 static void setoutput(char *vs);
103 static void tranotify(OBJECT obj);
104 static void bogusray(void);
105 static void rad(FVECT org, FVECT dir, double dmax);
106 static void irrad(FVECT org, FVECT dir);
107 static void printvals(RAY *r);
108 static int getvec(FVECT vec, int fmt, FILE *fp);
109 static void tabin(RAY *r);
110 static void ourtrace(RAY *r);
111
112 static oputf_t *ray_out[16], *every_out[16];
113 static putf_t *putreal;
114
115 void (*addobjnotify[])() = {ambnotify, tranotify, NULL};
116
117
118 void
119 quit( /* quit program */
120 int code
121 )
122 {
123 #ifndef NON_POSIX /* XXX we don't clean up elsewhere? */
124 headclean(); /* delete header file */
125 pfclean(); /* clean up persist files */
126 #endif
127 exit(code);
128 }
129
130
131 extern char *
132 formstr( /* return format identifier */
133 int f
134 )
135 {
136 switch (f) {
137 case 'a': return("ascii");
138 case 'f': return("float");
139 case 'd': return("double");
140 case 'c': return(COLRFMT);
141 }
142 return("unknown");
143 }
144
145
146 extern void
147 rtrace( /* trace rays from file */
148 char *fname
149 )
150 {
151 long vcount = hresolu>1 ? hresolu*vresolu : vresolu;
152 long nextflush = hresolu;
153 FILE *fp;
154 double d;
155 FVECT orig, direc;
156 /* set up input */
157 if (fname == NULL)
158 fp = stdin;
159 else if ((fp = fopen(fname, "r")) == NULL) {
160 sprintf(errmsg, "cannot open input file \"%s\"", fname);
161 error(SYSTEM, errmsg);
162 }
163 #ifdef _WIN32
164 if (inform != 'a')
165 SET_FILE_BINARY(fp);
166 #endif
167 /* set up output */
168 setoutput(outvals);
169 switch (outform) {
170 case 'a': putreal = puta; break;
171 case 'f': putreal = putf; break;
172 case 'd': putreal = putd; break;
173 case 'c':
174 if (strcmp(outvals, "v"))
175 error(USER, "color format with value output only");
176 break;
177 default:
178 error(CONSISTENCY, "botched output format");
179 }
180 if (hresolu > 0) {
181 if (vresolu > 0)
182 fprtresolu(hresolu, vresolu, stdout);
183 fflush(stdout);
184 }
185 /* process file */
186 while (getvec(orig, inform, fp) == 0 &&
187 getvec(direc, inform, fp) == 0) {
188
189 d = normalize(direc);
190 if (d == 0.0) { /* zero ==> flush */
191 bogusray();
192 if (--nextflush <= 0 || vcount <= 0) {
193 fflush(stdout);
194 nextflush = hresolu;
195 }
196 } else {
197 samplendx++;
198 /* compute and print */
199 if (imm_irrad)
200 irrad(orig, direc);
201 else
202 rad(orig, direc, lim_dist ? d : 0.0);
203 /* flush if time */
204 if (--nextflush == 0) {
205 fflush(stdout);
206 nextflush = hresolu;
207 }
208 }
209 if (ferror(stdout))
210 error(SYSTEM, "write error");
211 if (--vcount == 0) /* check for end */
212 break;
213 }
214 fflush(stdout);
215 if (vcount > 0)
216 error(USER, "unexpected EOF on input");
217 if (fname != NULL)
218 fclose(fp);
219 }
220
221
222 static void
223 trace_sources(void) /* trace rays to light sources, also */
224 {
225 int sn;
226
227 for (sn = 0; sn < nsources; sn++)
228 source[sn].sflags |= SFOLLOW;
229 }
230
231
232 static void
233 setoutput( /* set up output tables */
234 register char *vs
235 )
236 {
237 register oputf_t **table = ray_out;
238
239 castonly = 1;
240 while (*vs)
241 switch (*vs++) {
242 case 'T': /* trace sources */
243 if (!*vs) break;
244 trace_sources();
245 /* fall through */
246 case 't': /* trace */
247 if (!*vs) break;
248 *table = NULL;
249 table = every_out;
250 trace = ourtrace;
251 castonly = 0;
252 break;
253 case 'o': /* origin */
254 *table++ = oputo;
255 break;
256 case 'd': /* direction */
257 *table++ = oputd;
258 break;
259 case 'v': /* value */
260 *table++ = oputv;
261 castonly = 0;
262 break;
263 case 'l': /* effective distance */
264 *table++ = oputl;
265 castonly = 0;
266 break;
267 case 'c': /* local coordinates */
268 *table++ = oputc;
269 break;
270 case 'L': /* single ray length */
271 *table++ = oputL;
272 break;
273 case 'p': /* point */
274 *table++ = oputp;
275 break;
276 case 'n': /* perturbed normal */
277 *table++ = oputn;
278 castonly = 0;
279 break;
280 case 'N': /* unperturbed normal */
281 *table++ = oputN;
282 break;
283 case 's': /* surface */
284 *table++ = oputs;
285 break;
286 case 'w': /* weight */
287 *table++ = oputw;
288 break;
289 case 'W': /* coefficient */
290 *table++ = oputW;
291 if (ambounce > 0 && (ambacc > FTINY || ambssamp > 0))
292 error(WARNING,
293 "-otW accuracy depends on -aa 0 -as 0");
294 break;
295 case 'm': /* modifier */
296 *table++ = oputm;
297 break;
298 case 'M': /* material */
299 *table++ = oputM;
300 break;
301 case '~': /* tilde */
302 *table++ = oputtilde;
303 break;
304 }
305 *table = NULL;
306 }
307
308
309 static void
310 bogusray(void) /* print out empty record */
311 {
312 thisray.rorg[0] = thisray.rorg[1] = thisray.rorg[2] =
313 thisray.rdir[0] = thisray.rdir[1] = thisray.rdir[2] = 0.0;
314 thisray.rmax = 0.0;
315 rayorigin(&thisray, PRIMARY, NULL, NULL);
316 printvals(&thisray);
317 }
318
319
320 static void
321 rad( /* compute and print ray value(s) */
322 FVECT org,
323 FVECT dir,
324 double dmax
325 )
326 {
327 VCOPY(thisray.rorg, org);
328 VCOPY(thisray.rdir, dir);
329 thisray.rmax = dmax;
330 rayorigin(&thisray, PRIMARY, NULL, NULL);
331 if (castonly) {
332 if (!localhit(&thisray, &thescene)) {
333 if (thisray.ro == &Aftplane) { /* clipped */
334 thisray.ro = NULL;
335 thisray.rot = FHUGE;
336 } else
337 sourcehit(&thisray);
338 }
339 } else
340 rayvalue(&thisray);
341 printvals(&thisray);
342 }
343
344
345 static void
346 irrad( /* compute immediate irradiance value */
347 FVECT org,
348 FVECT dir
349 )
350 {
351 register int i;
352
353 for (i = 0; i < 3; i++) {
354 thisray.rorg[i] = org[i] + dir[i];
355 thisray.rdir[i] = -dir[i];
356 }
357 thisray.rmax = 0.0;
358 rayorigin(&thisray, PRIMARY, NULL, NULL);
359 /* pretend we hit surface */
360 thisray.rot = 1.0-1e-4;
361 thisray.rod = 1.0;
362 VCOPY(thisray.ron, dir);
363 for (i = 0; i < 3; i++) /* fudge factor */
364 thisray.rop[i] = org[i] + 1e-4*dir[i];
365 /* compute and print */
366 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
367 printvals(&thisray);
368 }
369
370
371 static void
372 printvals( /* print requested ray values */
373 RAY *r
374 )
375 {
376 register oputf_t **tp;
377
378 if (ray_out[0] == NULL)
379 return;
380 for (tp = ray_out; *tp != NULL; tp++)
381 (**tp)(r);
382 if (outform == 'a')
383 putchar('\n');
384 }
385
386
387 static int
388 getvec( /* get a vector from fp */
389 register FVECT vec,
390 int fmt,
391 FILE *fp
392 )
393 {
394 static float vf[3];
395 static double vd[3];
396 char buf[32];
397 register int i;
398
399 switch (fmt) {
400 case 'a': /* ascii */
401 for (i = 0; i < 3; i++) {
402 if (fgetword(buf, sizeof(buf), fp) == NULL ||
403 !isflt(buf))
404 return(-1);
405 vec[i] = atof(buf);
406 }
407 break;
408 case 'f': /* binary float */
409 if (fread((char *)vf, sizeof(float), 3, fp) != 3)
410 return(-1);
411 vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2];
412 break;
413 case 'd': /* binary double */
414 if (fread((char *)vd, sizeof(double), 3, fp) != 3)
415 return(-1);
416 vec[0] = vd[0]; vec[1] = vd[1]; vec[2] = vd[2];
417 break;
418 default:
419 error(CONSISTENCY, "botched input format");
420 }
421 return(0);
422 }
423
424
425 static void
426 tranotify( /* record new modifier */
427 OBJECT obj
428 )
429 {
430 static int hitlimit = 0;
431 register OBJREC *o = objptr(obj);
432 register char **tralp;
433
434 if (obj == OVOID) { /* starting over */
435 traset[0] = 0;
436 hitlimit = 0;
437 return;
438 }
439 if (hitlimit || !ismodifier(o->otype))
440 return;
441 for (tralp = tralist; *tralp != NULL; tralp++)
442 if (!strcmp(o->oname, *tralp)) {
443 if (traset[0] >= MAXTSET) {
444 error(WARNING, "too many modifiers in trace list");
445 hitlimit++;
446 return; /* should this be fatal? */
447 }
448 insertelem(traset, obj);
449 return;
450 }
451 }
452
453
454 static void
455 ourtrace( /* print ray values */
456 RAY *r
457 )
458 {
459 register oputf_t **tp;
460
461 if (every_out[0] == NULL)
462 return;
463 if (r->ro == NULL) {
464 if (traincl == 1)
465 return;
466 } else if (traincl != -1 && traincl != inset(traset, r->ro->omod))
467 return;
468 tabin(r);
469 for (tp = every_out; *tp != NULL; tp++)
470 (**tp)(r);
471 if (outform == 'a')
472 putchar('\n');
473 }
474
475
476 static void
477 tabin( /* tab in appropriate amount */
478 RAY *r
479 )
480 {
481 const RAY *rp;
482
483 for (rp = r->parent; rp != NULL; rp = rp->parent)
484 putchar('\t');
485 }
486
487
488 static void
489 oputo( /* print origin */
490 RAY *r
491 )
492 {
493 (*putreal)(r->rorg[0]);
494 (*putreal)(r->rorg[1]);
495 (*putreal)(r->rorg[2]);
496 }
497
498
499 static void
500 oputd( /* print direction */
501 RAY *r
502 )
503 {
504 (*putreal)(r->rdir[0]);
505 (*putreal)(r->rdir[1]);
506 (*putreal)(r->rdir[2]);
507 }
508
509
510 static void
511 oputv( /* print value */
512 RAY *r
513 )
514 {
515 if (outform == 'c') {
516 COLR cout;
517 setcolr(cout, colval(r->rcol,RED),
518 colval(r->rcol,GRN),
519 colval(r->rcol,BLU));
520 fwrite((char *)cout, sizeof(cout), 1, stdout);
521 return;
522 }
523 (*putreal)(colval(r->rcol,RED));
524 (*putreal)(colval(r->rcol,GRN));
525 (*putreal)(colval(r->rcol,BLU));
526 }
527
528
529 static void
530 oputl( /* print effective distance */
531 RAY *r
532 )
533 {
534 (*putreal)(r->rt);
535 }
536
537
538 static void
539 oputL( /* print single ray length */
540 RAY *r
541 )
542 {
543 (*putreal)(r->rot);
544 }
545
546
547 static void
548 oputc( /* print local coordinates */
549 RAY *r
550 )
551 {
552 (*putreal)(r->uv[0]);
553 (*putreal)(r->uv[1]);
554 }
555
556
557 static void
558 oputp( /* print point */
559 RAY *r
560 )
561 {
562 if (r->rot < FHUGE) {
563 (*putreal)(r->rop[0]);
564 (*putreal)(r->rop[1]);
565 (*putreal)(r->rop[2]);
566 } else {
567 (*putreal)(0.0);
568 (*putreal)(0.0);
569 (*putreal)(0.0);
570 }
571 }
572
573
574 static void
575 oputN( /* print unperturbed normal */
576 RAY *r
577 )
578 {
579 if (r->rot < FHUGE) {
580 (*putreal)(r->ron[0]);
581 (*putreal)(r->ron[1]);
582 (*putreal)(r->ron[2]);
583 } else {
584 (*putreal)(0.0);
585 (*putreal)(0.0);
586 (*putreal)(0.0);
587 }
588 }
589
590
591 static void
592 oputn( /* print perturbed normal */
593 RAY *r
594 )
595 {
596 FVECT pnorm;
597
598 if (r->rot >= FHUGE) {
599 (*putreal)(0.0);
600 (*putreal)(0.0);
601 (*putreal)(0.0);
602 return;
603 }
604 raynormal(pnorm, r);
605 (*putreal)(pnorm[0]);
606 (*putreal)(pnorm[1]);
607 (*putreal)(pnorm[2]);
608 }
609
610
611 static void
612 oputs( /* print name */
613 RAY *r
614 )
615 {
616 if (r->ro != NULL)
617 fputs(r->ro->oname, stdout);
618 else
619 putchar('*');
620 putchar('\t');
621 }
622
623
624 static void
625 oputw( /* print weight */
626 RAY *r
627 )
628 {
629 (*putreal)(r->rweight);
630 }
631
632
633 static void
634 oputW( /* print contribution */
635 RAY *r
636 )
637 {
638 COLOR contr;
639
640 raycontrib(contr, r, PRIMARY);
641 (*putreal)(colval(contr,RED));
642 (*putreal)(colval(contr,GRN));
643 (*putreal)(colval(contr,BLU));
644 }
645
646
647 static void
648 oputm( /* print modifier */
649 RAY *r
650 )
651 {
652 if (r->ro != NULL)
653 if (r->ro->omod != OVOID)
654 fputs(objptr(r->ro->omod)->oname, stdout);
655 else
656 fputs(VOIDID, stdout);
657 else
658 putchar('*');
659 putchar('\t');
660 }
661
662
663 static void
664 oputM( /* print material */
665 RAY *r
666 )
667 {
668 OBJREC *mat;
669
670 if (r->ro != NULL) {
671 if ((mat = findmaterial(r->ro)) != NULL)
672 fputs(mat->oname, stdout);
673 else
674 fputs(VOIDID, stdout);
675 } else
676 putchar('*');
677 putchar('\t');
678 }
679
680
681 static void
682 oputtilde( /* output tilde (spacer) */
683 RAY *r
684 )
685 {
686 fputs("~\t", stdout);
687 }
688
689
690 static void
691 puta( /* print ascii value */
692 double v
693 )
694 {
695 printf("%e\t", v);
696 }
697
698
699 static void
700 putd(v) /* print binary double */
701 double v;
702 {
703 fwrite((char *)&v, sizeof(v), 1, stdout);
704 }
705
706
707 static void
708 putf(v) /* print binary float */
709 double v;
710 {
711 float f = v;
712
713 fwrite((char *)&f, sizeof(f), 1, stdout);
714 }
