root/radiance/ray/src/rt/rtrace.c
Revision: 2.27
Committed: Sat Feb 22 02:07:29 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.26: +107 -36 lines
5 * rtrace.c - program and variables for individual ray tracing.
6 */
7
8 /* ====================================================================
9 * The Radiance Software License, Version 1.0
10 *
11 * Copyright (c) 1990 - 2002 The Regents of the University of California,
12 * through Lawrence Berkeley National Laboratory. All rights reserved.
13 *
14 * Redistribution and use in source and binary forms, with or without
15 * modification, are permitted provided that the following conditions
16 * are met:
17 *
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 *
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in
23 * the documentation and/or other materials provided with the
24 * distribution.
25 *
26 * 3. The end-user documentation included with the redistribution,
27 * if any, must include the following acknowledgment:
28 * "This product includes Radiance software
29 * (http://radsite.lbl.gov/)
30 * developed by the Lawrence Berkeley National Laboratory
31 * (http://www.lbl.gov/)."
32 * Alternately, this acknowledgment may appear in the software itself,
33 * if and wherever such third-party acknowledgments normally appear.
34 *
35 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
36 * and "The Regents of the University of California" must
37 * not be used to endorse or promote products derived from this
38 * software without prior written permission. For written
39 * permission, please contact [email protected].
40 *
41 * 5. Products derived from this software may not be called "Radiance",
42 * nor may "Radiance" appear in their name, without prior written
43 * permission of Lawrence Berkeley National Laboratory.
44 *
45 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
46 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
47 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
48 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
49 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
50 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
51 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
52 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
53 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
54 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
55 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
56 * SUCH DAMAGE.
57 * ====================================================================
58 *
59 * This software consists of voluntary contributions made by many
60 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
61 * information on Lawrence Berkeley National Laboratory, please see
62 * <http://www.lbl.gov/>.
63 */
64
65 /*
66 * Input is in the form:
67 *
68 * xorg yorg zorg xdir ydir zdir
69 *
70 * The direction need not be normalized. Output is flexible.
71 * If the direction vector is (0,0,0), then the output is flushed.
72 * All values default to ascii representation of real
73 * numbers. Binary representations can be selected
74 * with '-ff' for float or '-fd' for double. By default,
75 * radiance is computed. The '-i' or '-I' options indicate that
76 * irradiance values are desired.
77 */
78
79 #include "ray.h"
80
81 #include "otypes.h"
82
83 #include "resolu.h"
84
85 CUBE thescene; /* our scene */
86 OBJECT nsceneobjs; /* number of objects in our scene */
87
88 int dimlist[MAXDIM]; /* sampling dimensions */
89 int ndims = 0; /* number of sampling dimensions */
90 int samplendx = 0; /* index for this sample */
91
92 int imm_irrad = 0; /* compute immediate irradiance? */
93 int lim_dist = 0; /* limit distance? */
94
95 int inform = 'a'; /* input format */
96 int outform = 'a'; /* output format */
97 char *outvals = "v"; /* output specification */
98
99 int do_irrad = 0; /* compute irradiance? */
100
101 void (*trace)() = NULL; /* trace call */
102
103 extern void ambnotify(), tranotify();
104 void (*addobjnotify[])() = {ambnotify, tranotify, NULL};
105 char *tralist[128]; /* list of modifers to trace (or no) */
106 int traincl = -1; /* include == 1, exclude == 0 */
107 #define MAXTSET 511 /* maximum number in trace set */
108 OBJECT traset[MAXTSET+1]={0}; /* trace include/exclude set */
109
110 int hresolu = 0; /* horizontal (scan) size */
111 int vresolu = 0; /* vertical resolution */
112
113 double dstrsrc = 0.0; /* square source distribution */
114 double shadthresh = .05; /* shadow threshold */
115 double shadcert = .5; /* shadow certainty */
116 int directrelay = 2; /* number of source relays */
117 int vspretest = 512; /* virtual source pretest density */
118 int directvis = 1; /* sources visible? */
119 double srcsizerat = .2; /* maximum ratio source size/dist. */
120
121 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
122 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
123 double seccg = 0.; /* global scattering eccentricity */
124 double ssampdist = 0.; /* scatter sampling distance */
125
126 double specthresh = .15; /* specular sampling threshold */
127 double specjitter = 1.; /* specular sampling jitter */
128
129 int backvis = 1; /* back face visibility */
130
131 int maxdepth = 6; /* maximum recursion depth */
132 double minweight = 4e-3; /* minimum ray weight */
133
134 char *ambfile = NULL; /* ambient file name */
135 COLOR ambval = BLKCOLOR; /* ambient value */
136 int ambvwt = 0; /* initial weight for ambient value */
137 double ambacc = 0.2; /* ambient accuracy */
138 int ambres = 128; /* ambient resolution */
139 int ambdiv = 512; /* ambient divisions */
140 int ambssamp = 0; /* ambient super-samples */
141 int ambounce = 0; /* ambient bounces */
142 char *amblist[128]; /* ambient include/exclude list */
143 int ambincl = -1; /* include == 1, exclude == 0 */
144
145
146 static RAY thisray; /* for our convenience */
147
148 static void oputo(), oputd(), oputv(), oputl(), oputL(),
149 oputp(), oputn(), oputN(), oputs(), oputw(), oputm();
150
151 static void ourtrace(), tabin();
152 static void (*ray_out[16])(), (*every_out[16])();
153 static int castonly = 0;
154
155 static void puta(), putf(), putd();
156
157 static void (*putreal)();
158
159 void bogusray(), rad(), irrad(), printvals();
160
161
162 void
163 quit(code) /* quit program */
164 int code;
165 {
166 #ifndef NIX
167 headclean(); /* delete header file */
168 pfclean(); /* clean up persist files */
169 #endif
170 exit(code);
171 }
172
173
174 char *
175 formstr(f) /* return format identifier */
176 int f;
177 {
178 switch (f) {
179 case 'a': return("ascii");
180 case 'f': return("float");
181 case 'd': return("double");
182 case 'c': return(COLRFMT);
183 }
184 return("unknown");
185 }
186
187
188 void
189 rtrace(fname) /* trace rays from file */
190 char *fname;
191 {
192 long vcount = hresolu>1 ? hresolu*vresolu : vresolu;
193 long nextflush = hresolu;
194 FILE *fp;
195 double d;
196 FVECT orig, direc;
197 /* set up input */
198 if (fname == NULL)
199 fp = stdin;
200 else if ((fp = fopen(fname, "r")) == NULL) {
201 sprintf(errmsg, "cannot open input file \"%s\"", fname);
202 error(SYSTEM, errmsg);
203 }
204 #ifdef MSDOS
205 if (inform != 'a')
206 setmode(fileno(fp), O_BINARY);
207 #endif
208 /* set up output */
209 setoutput(outvals);
210 switch (outform) {
211 case 'a': putreal = puta; break;
212 case 'f': putreal = putf; break;
213 case 'd': putreal = putd; break;
214 case 'c':
215 if (strcmp(outvals, "v"))
216 error(USER, "color format with value output only");
217 break;
218 default:
219 error(CONSISTENCY, "botched output format");
220 }
221 if (hresolu > 0) {
222 if (vresolu > 0)
223 fprtresolu(hresolu, vresolu, stdout);
224 fflush(stdout);
225 }
226 /* process file */
227 while (getvec(orig, inform, fp) == 0 &&
228 getvec(direc, inform, fp) == 0) {
229
230 d = normalize(direc);
231 if (d == 0.0) { /* zero ==> flush */
232 bogusray();
233 if (--nextflush <= 0 || vcount <= 0) {
234 fflush(stdout);
235 nextflush = hresolu;
236 }
237 } else {
238 samplendx++;
239 /* compute and print */
240 if (imm_irrad)
241 irrad(orig, direc);
242 else
243 rad(orig, direc, lim_dist ? d : 0.0);
244 /* flush if time */
245 if (--nextflush == 0) {
246 fflush(stdout);
247 nextflush = hresolu;
248 }
249 }
250 if (ferror(stdout))
251 error(SYSTEM, "write error");
252 if (--vcount == 0) /* check for end */
253 break;
254 }
255 fflush(stdout);
256 if (vcount > 0)
257 error(USER, "read error");
258 if (fname != NULL)
259 fclose(fp);
260 }
261
262
263 setoutput(vs) /* set up output tables */
264 register char *vs;
265 {
266 extern void (*trace)();
267 register void (**table)() = ray_out;
268
269 castonly = 1;
270 while (*vs)
271 switch (*vs++) {
272 case 't': /* trace */
273 *table = NULL;
274 table = every_out;
275 trace = ourtrace;
276 castonly = 0;
277 break;
278 case 'o': /* origin */
279 *table++ = oputo;
280 break;
281 case 'd': /* direction */
282 *table++ = oputd;
283 break;
284 case 'v': /* value */
285 *table++ = oputv;
286 castonly = 0;
287 break;
288 case 'l': /* effective distance */
289 *table++ = oputl;
290 castonly = 0;
291 break;
292 case 'L': /* single ray length */
293 *table++ = oputL;
294 break;
295 case 'p': /* point */
296 *table++ = oputp;
297 break;
298 case 'n': /* perturbed normal */
299 *table++ = oputn;
300 castonly = 0;
301 break;
302 case 'N': /* unperturbed normal */
303 *table++ = oputN;
304 break;
305 case 's': /* surface */
306 *table++ = oputs;
307 break;
308 case 'w': /* weight */
309 *table++ = oputw;
310 break;
311 case 'm': /* modifier */
312 *table++ = oputm;
313 break;
314 }
315 *table = NULL;
316 }
317
318
319 void
320 bogusray() /* print out empty record */
321 {
322 thisray.rorg[0] = thisray.rorg[1] = thisray.rorg[2] =
323 thisray.rdir[0] = thisray.rdir[1] = thisray.rdir[2] = 0.0;
324 rayorigin(&thisray, NULL, PRIMARY, 1.0);
325 printvals(&thisray);
326 }
327
328
329 void
330 rad(org, dir, dmax) /* compute and print ray value(s) */
331 FVECT org, dir;
332 double dmax;
333 {
334 VCOPY(thisray.rorg, org);
335 VCOPY(thisray.rdir, dir);
336 thisray.rmax = dmax;
337 rayorigin(&thisray, NULL, PRIMARY, 1.0);
338 if (castonly) {
339 if (!localhit(&thisray, &thescene))
340 if (thisray.ro == &Aftplane) { /* clipped */
341 thisray.ro = NULL;
342 thisray.rot = FHUGE;
343 } else
344 sourcehit(&thisray);
345 } else
346 rayvalue(&thisray);
347 printvals(&thisray);
348 }
349
350
351 void
352 irrad(org, dir) /* compute immediate irradiance value */
353 FVECT org, dir;
354 {
355 register int i;
356
357 for (i = 0; i < 3; i++) {
358 thisray.rorg[i] = org[i] + dir[i];
359 thisray.rdir[i] = -dir[i];
360 }
361 rayorigin(&thisray, NULL, PRIMARY, 1.0);
362 /* pretend we hit surface */
363 thisray.rot = 1.0-1e-4;
364 thisray.rod = 1.0;
365 VCOPY(thisray.ron, dir);
366 for (i = 0; i < 3; i++) /* fudge factor */
367 thisray.rop[i] = org[i] + 1e-4*dir[i];
368 /* compute and print */
369 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
370 printvals(&thisray);
371 }
372
373
374 void
375 printvals(r) /* print requested ray values */
376 RAY *r;
377 {
378 register void (**tp)();
379
380 if (ray_out[0] == NULL)
381 return;
382 for (tp = ray_out; *tp != NULL; tp++)
383 (**tp)(r);
384 if (outform == 'a')
385 putchar('\n');
386 }
387
388
389 int
390 getvec(vec, fmt, fp) /* get a vector from fp */
391 register FVECT vec;
392 int fmt;
393 FILE *fp;
394 {
395 static float vf[3];
396 static double vd[3];
397 char buf[32];
398 register int i;
399
400 switch (fmt) {
401 case 'a': /* ascii */
402 for (i = 0; i < 3; i++) {
403 if (fgetword(buf, sizeof(buf), fp) == NULL ||
404 !isflt(buf))
405 return(-1);
406 vec[i] = atof(buf);
407 }
408 break;
409 case 'f': /* binary float */
410 if (fread((char *)vf, sizeof(float), 3, fp) != 3)
411 return(-1);
412 vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2];
413 break;
414 case 'd': /* binary double */
415 if (fread((char *)vd, sizeof(double), 3, fp) != 3)
416 return(-1);
417 vec[0] = vd[0]; vec[1] = vd[1]; vec[2] = vd[2];
418 break;
419 default:
420 error(CONSISTENCY, "botched input format");
421 }
422 return(0);
423 }
424
425
426 void
427 tranotify(obj) /* record new modifier */
428 OBJECT obj;
429 {
430 static int hitlimit = 0;
431 register OBJREC *o = objptr(obj);
432 register char **tralp;
433
434 if (obj == OVOID) { /* starting over */
435 traset[0] = 0;
436 hitlimit = 0;
437 return;
438 }
439 if (hitlimit || !ismodifier(o->otype))
440 return;
441 for (tralp = tralist; *tralp != NULL; tralp++)
442 if (!strcmp(o->oname, *tralp)) {
443 if (traset[0] >= MAXTSET) {
444 error(WARNING, "too many modifiers in trace list");
445 hitlimit++;
446 return; /* should this be fatal? */
447 }
448 insertelem(traset, obj);
449 return;
450 }
451 }
452
453
454 static void
455 ourtrace(r) /* print ray values */
456 RAY *r;
457 {
458 register void (**tp)();
459
460 if (every_out[0] == NULL)
461 return;
462 if (r->ro == NULL) {
463 if (traincl == 1)
464 return;
465 } else if (traincl != -1 && traincl != inset(traset, r->ro->omod))
466 return;
467 tabin(r);
468 for (tp = every_out; *tp != NULL; tp++)
469 (**tp)(r);
470 putchar('\n');
471 }
472
473
474 static void
475 tabin(r) /* tab in appropriate amount */
476 RAY *r;
477 {
478 register RAY *rp;
479
480 for (rp = r->parent; rp != NULL; rp = rp->parent)
481 putchar('\t');
482 }
483
484
485 static void
486 oputo(r) /* print origin */
487 register RAY *r;
488 {
489 (*putreal)(r->rorg[0]);
490 (*putreal)(r->rorg[1]);
491 (*putreal)(r->rorg[2]);
492 }
493
494
495 static void
496 oputd(r) /* print direction */
497 register RAY *r;
498 {
499 (*putreal)(r->rdir[0]);
500 (*putreal)(r->rdir[1]);
501 (*putreal)(r->rdir[2]);
502 }
503
504
505 static void
506 oputv(r) /* print value */
507 register RAY *r;
508 {
509 COLR cout;
510
511 if (outform == 'c') {
512 setcolr(cout, colval(r->rcol,RED),
513 colval(r->rcol,GRN),
514 colval(r->rcol,BLU));
515 fwrite((char *)cout, sizeof(cout), 1, stdout);
516 return;
517 }
518 (*putreal)(colval(r->rcol,RED));
519 (*putreal)(colval(r->rcol,GRN));
520 (*putreal)(colval(r->rcol,BLU));
521 }
522
523
524 static void
525 oputl(r) /* print effective distance */
526 register RAY *r;
527 {
528 (*putreal)(r->rt);
529 }
530
531
532 static void
533 oputL(r) /* print single ray length */
534 register RAY *r;
535 {
536 (*putreal)(r->rot);
537 }
538
539
540 static void
541 oputp(r) /* print point */
542 register RAY *r;
543 {
544 if (r->rot < FHUGE) {
545 (*putreal)(r->rop[0]);
546 (*putreal)(r->rop[1]);
547 (*putreal)(r->rop[2]);
548 } else {
549 (*putreal)(0.0);
550 (*putreal)(0.0);
551 (*putreal)(0.0);
552 }
553 }
554
555
556 static void
557 oputN(r) /* print unperturbed normal */
558 register RAY *r;
559 {
560 if (r->rot < FHUGE) {
561 (*putreal)(r->ron[0]);
562 (*putreal)(r->ron[1]);
563 (*putreal)(r->ron[2]);
564 } else {
565 (*putreal)(0.0);
566 (*putreal)(0.0);
567 (*putreal)(0.0);
568 }
569 }
570
571
572 static void
573 oputn(r) /* print perturbed normal */
574 RAY *r;
575 {
576 FVECT pnorm;
577
578 if (r->rot >= FHUGE) {
579 (*putreal)(0.0);
580 (*putreal)(0.0);
581 (*putreal)(0.0);
582 return;
583 }
584 raynormal(pnorm, r);
585 (*putreal)(pnorm[0]);
586 (*putreal)(pnorm[1]);
587 (*putreal)(pnorm[2]);
588 }
589
590
591 static void
592 oputs(r) /* print name */
593 register RAY *r;
594 {
595 if (r->ro != NULL)
596 fputs(r->ro->oname, stdout);
597 else
598 putchar('*');
599 putchar('\t');
600 }
601
602
603 static void
604 oputw(r) /* print weight */
605 register RAY *r;
606 {
607 (*putreal)(r->rweight);
608 }
609
610
611 static void
612 oputm(r) /* print modifier */
613 register RAY *r;
614 {
615 if (r->ro != NULL)
616 if (r->ro->omod != OVOID)
617 fputs(objptr(r->ro->omod)->oname, stdout);
618 else
619 fputs(VOIDID, stdout);
620 else
621 putchar('*');
622 putchar('\t');
623 }
624
625
626 static void
627 puta(v) /* print ascii value */
628 double v;
629 {
630 printf("%e\t", v);
631 }
632
633
634 static void
635 putd(v) /* print binary double */
636 double v;
637 {
638 fwrite((char *)&v, sizeof(v), 1, stdout);
639 }
640
641
642 static void
643 putf(v) /* print binary float */
644 double v;
645 {
646 float f = v;
647
648 fwrite((char *)&f, sizeof(f), 1, stdout);
649 }
