1 |
/* Copyright (c) 1995 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* rtrace.c - program and variables for individual ray tracing. |
9 |
10 |
* 6/11/86 |
11 |
12 |
13 |
14 |
* Input is in the form: |
15 |
16 |
* xorg yorg zorg xdir ydir zdir |
17 |
18 |
* The direction need not be normalized. Output is flexible. |
19 |
* If the direction vector is (0,0,0), then the output is flushed. |
20 |
* All values default to ascii representation of real |
21 |
* numbers. Binary representations can be selected |
22 |
* with '-ff' for float or '-fd' for double. By default, |
23 |
* radiance is computed. The '-i' or '-I' options indicate that |
24 |
* irradiance values are desired. |
25 |
26 |
27 |
#include "ray.h" |
28 |
29 |
#include "octree.h" |
30 |
31 |
#include "otypes.h" |
32 |
33 |
#include "resolu.h" |
34 |
35 |
int dimlist[MAXDIM]; /* sampling dimensions */ |
36 |
int ndims = 0; /* number of sampling dimensions */ |
37 |
int samplendx = 0; /* index for this sample */ |
38 |
39 |
int imm_irrad = 0; /* compute immediate irradiance? */ |
40 |
41 |
int inform = 'a'; /* input format */ |
42 |
int outform = 'a'; /* output format */ |
43 |
char *outvals = "v"; /* output specification */ |
44 |
45 |
char *tralist[128]; /* list of modifers to trace (or no) */ |
46 |
int traincl = -1; /* include == 1, exclude == 0 */ |
47 |
#define MAXTSET 511 /* maximum number in trace set */ |
48 |
OBJECT traset[MAXTSET+1]={0}; /* trace include/exclude set */ |
49 |
50 |
int hresolu = 0; /* horizontal (scan) size */ |
51 |
int vresolu = 0; /* vertical resolution */ |
52 |
53 |
double dstrsrc = 0.0; /* square source distribution */ |
54 |
double shadthresh = .05; /* shadow threshold */ |
55 |
double shadcert = .5; /* shadow certainty */ |
56 |
int directrelay = 2; /* number of source relays */ |
57 |
int vspretest = 512; /* virtual source pretest density */ |
58 |
int directvis = 1; /* sources visible? */ |
59 |
double srcsizerat = .2; /* maximum ratio source size/dist. */ |
60 |
61 |
COLOR cextinction = BLKCOLOR; /* global extinction coefficient */ |
62 |
double salbedo = 0.; /* global scattering albedo */ |
63 |
double seccg = 0.; /* global scattering eccentricity */ |
64 |
double ssampdist = 0.; /* scatter sampling distance */ |
65 |
66 |
double specthresh = .15; /* specular sampling threshold */ |
67 |
double specjitter = 1.; /* specular sampling jitter */ |
68 |
69 |
int backvis = 1; /* back face visibility */ |
70 |
71 |
int maxdepth = 6; /* maximum recursion depth */ |
72 |
double minweight = 4e-3; /* minimum ray weight */ |
73 |
74 |
COLOR ambval = BLKCOLOR; /* ambient value */ |
75 |
int ambvwt = 0; /* initial weight for ambient value */ |
76 |
double ambacc = 0.2; /* ambient accuracy */ |
77 |
int ambres = 128; /* ambient resolution */ |
78 |
int ambdiv = 512; /* ambient divisions */ |
79 |
int ambssamp = 0; /* ambient super-samples */ |
80 |
int ambounce = 0; /* ambient bounces */ |
81 |
char *amblist[128]; /* ambient include/exclude list */ |
82 |
int ambincl = -1; /* include == 1, exclude == 0 */ |
83 |
84 |
extern OBJREC Lamb; /* a Lambertian surface */ |
85 |
86 |
static RAY thisray; /* for our convenience */ |
87 |
88 |
static int oputo(), oputd(), oputv(), oputl(), oputL(), |
89 |
oputp(), oputn(), oputN(), oputs(), oputw(), oputm(); |
90 |
91 |
static int ourtrace(), tabin(); |
92 |
static int (*ray_out[16])(), (*every_out[16])(); |
93 |
static int castonly = 0; |
94 |
95 |
static int puta(), putf(), putd(); |
96 |
97 |
static int (*putreal)(); |
98 |
99 |
100 |
quit(code) /* quit program */ |
101 |
int code; |
102 |
103 |
#ifndef NIX |
104 |
headclean(); /* delete header file */ |
105 |
pfclean(); /* clean up persist files */ |
106 |
#endif |
107 |
exit(code); |
108 |
109 |
110 |
111 |
char * |
112 |
formstr(f) /* return format identifier */ |
113 |
int f; |
114 |
115 |
switch (f) { |
116 |
case 'a': return("ascii"); |
117 |
case 'f': return("float"); |
118 |
case 'd': return("double"); |
119 |
case 'c': return(COLRFMT); |
120 |
121 |
return("unknown"); |
122 |
123 |
124 |
125 |
rtrace(fname) /* trace rays from file */ |
126 |
char *fname; |
127 |
128 |
long vcount = hresolu>1 ? hresolu*vresolu : vresolu; |
129 |
long nextflush = hresolu; |
130 |
FILE *fp; |
131 |
FVECT orig, direc; |
132 |
/* set up input */ |
133 |
if (fname == NULL) |
134 |
fp = stdin; |
135 |
else if ((fp = fopen(fname, "r")) == NULL) { |
136 |
sprintf(errmsg, "cannot open input file \"%s\"", fname); |
137 |
error(SYSTEM, errmsg); |
138 |
139 |
#ifdef MSDOS |
140 |
if (inform != 'a') |
141 |
setmode(fileno(fp), O_BINARY); |
142 |
#endif |
143 |
/* set up output */ |
144 |
setoutput(outvals); |
145 |
switch (outform) { |
146 |
case 'a': putreal = puta; break; |
147 |
case 'f': putreal = putf; break; |
148 |
case 'd': putreal = putd; break; |
149 |
case 'c': |
150 |
if (strcmp(outvals, "v")) |
151 |
error(USER, "color format with value output only"); |
152 |
break; |
153 |
default: |
154 |
error(CONSISTENCY, "botched output format"); |
155 |
156 |
if (hresolu > 0) { |
157 |
if (vresolu > 0) |
158 |
fprtresolu(hresolu, vresolu, stdout); |
159 |
fflush(stdout); |
160 |
161 |
/* process file */ |
162 |
while (getvec(orig, inform, fp) == 0 && |
163 |
getvec(direc, inform, fp) == 0) { |
164 |
165 |
if (normalize(direc) == 0.0) { /* zero ==> flush */ |
166 |
fflush(stdout); |
167 |
continue; |
168 |
169 |
samplendx++; |
170 |
/* compute and print */ |
171 |
if (imm_irrad) |
172 |
irrad(orig, direc); |
173 |
else |
174 |
rad(orig, direc); |
175 |
/* flush if time */ |
176 |
if (--nextflush == 0) { |
177 |
fflush(stdout); |
178 |
179 |
180 |
if (ferror(stdout)) |
181 |
error(SYSTEM, "write error"); |
182 |
if (--vcount == 0) /* check for end */ |
183 |
break; |
184 |
185 |
fflush(stdout); |
186 |
if (vcount > 0) |
187 |
error(USER, "read error"); |
188 |
if (fname != NULL) |
189 |
fclose(fp); |
190 |
191 |
192 |
193 |
setoutput(vs) /* set up output tables */ |
194 |
register char *vs; |
195 |
196 |
extern int (*trace)(); |
197 |
register int (**table)() = ray_out; |
198 |
199 |
castonly = 1; |
200 |
while (*vs) |
201 |
switch (*vs++) { |
202 |
case 't': /* trace */ |
203 |
*table = NULL; |
204 |
table = every_out; |
205 |
trace = ourtrace; |
206 |
castonly = 0; |
207 |
break; |
208 |
case 'o': /* origin */ |
209 |
*table++ = oputo; |
210 |
break; |
211 |
case 'd': /* direction */ |
212 |
*table++ = oputd; |
213 |
break; |
214 |
case 'v': /* value */ |
215 |
*table++ = oputv; |
216 |
castonly = 0; |
217 |
break; |
218 |
case 'l': /* effective distance */ |
219 |
*table++ = oputl; |
220 |
castonly = 0; |
221 |
break; |
222 |
case 'L': /* single ray length */ |
223 |
*table++ = oputL; |
224 |
break; |
225 |
case 'p': /* point */ |
226 |
*table++ = oputp; |
227 |
break; |
228 |
case 'n': /* perturbed normal */ |
229 |
*table++ = oputn; |
230 |
castonly = 0; |
231 |
break; |
232 |
case 'N': /* unperturbed normal */ |
233 |
*table++ = oputN; |
234 |
break; |
235 |
case 's': /* surface */ |
236 |
*table++ = oputs; |
237 |
break; |
238 |
case 'w': /* weight */ |
239 |
*table++ = oputw; |
240 |
break; |
241 |
case 'm': /* modifier */ |
242 |
*table++ = oputm; |
243 |
break; |
244 |
245 |
*table = NULL; |
246 |
247 |
248 |
249 |
rad(org, dir) /* compute and print ray value(s) */ |
250 |
FVECT org, dir; |
251 |
252 |
VCOPY(thisray.rorg, org); |
253 |
VCOPY(thisray.rdir, dir); |
254 |
thisray.rmax = 0.0; |
255 |
rayorigin(&thisray, NULL, PRIMARY, 1.0); |
256 |
if (castonly) |
257 |
localhit(&thisray, &thescene) || sourcehit(&thisray); |
258 |
else |
259 |
rayvalue(&thisray); |
260 |
printvals(&thisray); |
261 |
262 |
263 |
264 |
irrad(org, dir) /* compute immediate irradiance value */ |
265 |
FVECT org, dir; |
266 |
267 |
register int i; |
268 |
269 |
for (i = 0; i < 3; i++) { |
270 |
thisray.rorg[i] = org[i] + dir[i]; |
271 |
thisray.rdir[i] = -dir[i]; |
272 |
273 |
274 |
/* pretend we hit surface */ |
275 |
thisray.rot = 1.0-1e-4; |
276 |
thisray.rod = 1.0; |
277 |
VCOPY(thisray.ron, dir); |
278 |
for (i = 0; i < 3; i++) /* fudge factor */ |
279 |
thisray.rop[i] = org[i] + 1e-4*dir[i]; |
280 |
281 |
(*ofun[Lamb.otype].funp)(&Lamb, &thisray); |
282 |
283 |
284 |
285 |
286 |
printvals(r) /* print requested ray values */ |
287 |
RAY *r; |
288 |
289 |
register int (**tp)(); |
290 |
291 |
if (ray_out[0] == NULL) |
292 |
return; |
293 |
for (tp = ray_out; *tp != NULL; tp++) |
294 |
(**tp)(r); |
295 |
if (outform == 'a') |
296 |
putchar('\n'); |
297 |
298 |
299 |
300 |
getvec(vec, fmt, fp) /* get a vector from fp */ |
301 |
register FVECT vec; |
302 |
int fmt; |
303 |
FILE *fp; |
304 |
305 |
extern char *fgetword(); |
306 |
static float vf[3]; |
307 |
static double vd[3]; |
308 |
char buf[32]; |
309 |
register int i; |
310 |
311 |
switch (fmt) { |
312 |
case 'a': /* ascii */ |
313 |
314 |
if (fgetword(buf, sizeof(buf), fp) == NULL || |
315 |
!isflt(buf)) |
316 |
return(-1); |
317 |
vec[i] = atof(buf); |
318 |
319 |
break; |
320 |
case 'f': /* binary float */ |
321 |
if (fread((char *)vf, sizeof(float), 3, fp) != 3) |
322 |
return(-1); |
323 |
vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2]; |
324 |
break; |
325 |
case 'd': /* binary double */ |
326 |
if (fread((char *)vd, sizeof(double), 3, fp) != 3) |
327 |
return(-1); |
328 |
vec[0] = vd[0]; vec[1] = vd[1]; vec[2] = vd[2]; |
329 |
break; |
330 |
default: |
331 |
error(CONSISTENCY, "botched input format"); |
332 |
333 |
return(0); |
334 |
335 |
336 |
337 |
tranotify(obj) /* record new modifier */ |
338 |
OBJECT obj; |
339 |
340 |
static int hitlimit = 0; |
341 |
register OBJREC *o = objptr(obj); |
342 |
register char **tralp; |
343 |
344 |
if (hitlimit || !ismodifier(o->otype)) |
345 |
return; |
346 |
for (tralp = tralist; *tralp != NULL; tralp++) |
347 |
if (!strcmp(o->oname, *tralp)) { |
348 |
if (traset[0] >= MAXTSET) { |
349 |
error(WARNING, "too many modifiers in trace list"); |
350 |
hitlimit++; |
351 |
return; /* should this be fatal? */ |
352 |
353 |
insertelem(traset, obj); |
354 |
return; |
355 |
356 |
357 |
358 |
359 |
static |
360 |
ourtrace(r) /* print ray values */ |
361 |
RAY *r; |
362 |
363 |
364 |
365 |
if (every_out[0] == NULL) |
366 |
return; |
367 |
if (r->ro == NULL) { |
368 |
if (traincl == 1) |
369 |
return; |
370 |
} else if (traincl != -1 && traincl != inset(traset, r->ro->omod)) |
371 |
return; |
372 |
tabin(r); |
373 |
for (tp = every_out; *tp != NULL; tp++) |
374 |
(**tp)(r); |
375 |
putchar('\n'); |
376 |
377 |
378 |
379 |
static |
380 |
tabin(r) /* tab in appropriate amount */ |
381 |
RAY *r; |
382 |
383 |
register RAY *rp; |
384 |
385 |
for (rp = r->parent; rp != NULL; rp = rp->parent) |
386 |
putchar('\t'); |
387 |
388 |
389 |
390 |
static |
391 |
oputo(r) /* print origin */ |
392 |
register RAY *r; |
393 |
394 |
(*putreal)(r->rorg[0]); |
395 |
(*putreal)(r->rorg[1]); |
396 |
(*putreal)(r->rorg[2]); |
397 |
398 |
399 |
400 |
static |
401 |
oputd(r) /* print direction */ |
402 |
register RAY *r; |
403 |
404 |
(*putreal)(r->rdir[0]); |
405 |
(*putreal)(r->rdir[1]); |
406 |
(*putreal)(r->rdir[2]); |
407 |
408 |
409 |
410 |
static |
411 |
oputv(r) /* print value */ |
412 |
register RAY *r; |
413 |
414 |
COLR cout; |
415 |
416 |
if (outform == 'c') { |
417 |
setcolr(cout, colval(r->rcol,RED), |
418 |
colval(r->rcol,GRN), |
419 |
colval(r->rcol,BLU)); |
420 |
fwrite((char *)cout, sizeof(cout), 1, stdout); |
421 |
return; |
422 |
423 |
(*putreal)(colval(r->rcol,RED)); |
424 |
(*putreal)(colval(r->rcol,GRN)); |
425 |
(*putreal)(colval(r->rcol,BLU)); |
426 |
427 |
428 |
429 |
static |
430 |
oputl(r) /* print effective distance */ |
431 |
register RAY *r; |
432 |
433 |
(*putreal)(r->rt); |
434 |
435 |
436 |
437 |
static |
438 |
oputL(r) /* print single ray length */ |
439 |
register RAY *r; |
440 |
441 |
(*putreal)(r->rot); |
442 |
443 |
444 |
445 |
static |
446 |
oputp(r) /* print point */ |
447 |
register RAY *r; |
448 |
449 |
if (r->rot < FHUGE) { |
450 |
(*putreal)(r->rop[0]); |
451 |
(*putreal)(r->rop[1]); |
452 |
(*putreal)(r->rop[2]); |
453 |
} else { |
454 |
(*putreal)(0.0); |
455 |
(*putreal)(0.0); |
456 |
(*putreal)(0.0); |
457 |
458 |
459 |
460 |
461 |
static |
462 |
oputN(r) /* print unperturbed normal */ |
463 |
register RAY *r; |
464 |
465 |
466 |
(*putreal)(r->ron[0]); |
467 |
(*putreal)(r->ron[1]); |
468 |
(*putreal)(r->ron[2]); |
469 |
} else { |
470 |
(*putreal)(0.0); |
471 |
(*putreal)(0.0); |
472 |
(*putreal)(0.0); |
473 |
474 |
475 |
476 |
477 |
static |
478 |
oputn(r) /* print perturbed normal */ |
479 |
RAY *r; |
480 |
481 |
FVECT pnorm; |
482 |
483 |
if (r->rot >= FHUGE) { |
484 |
(*putreal)(0.0); |
485 |
(*putreal)(0.0); |
486 |
(*putreal)(0.0); |
487 |
return; |
488 |
489 |
raynormal(pnorm, r); |
490 |
(*putreal)(pnorm[0]); |
491 |
(*putreal)(pnorm[1]); |
492 |
(*putreal)(pnorm[2]); |
493 |
494 |
495 |
496 |
static |
497 |
oputs(r) /* print name */ |
498 |
register RAY *r; |
499 |
500 |
if (r->ro != NULL) |
501 |
fputs(r->ro->oname, stdout); |
502 |
else |
503 |
putchar('*'); |
504 |
putchar('\t'); |
505 |
506 |
507 |
508 |
static |
509 |
oputw(r) /* print weight */ |
510 |
register RAY *r; |
511 |
512 |
(*putreal)(r->rweight); |
513 |
514 |
515 |
516 |
static |
517 |
oputm(r) /* print modifier */ |
518 |
register RAY *r; |
519 |
520 |
521 |
fputs(objptr(r->ro->omod)->oname, stdout); |
522 |
else |
523 |
putchar('*'); |
524 |
putchar('\t'); |
525 |
526 |
527 |
528 |
static |
529 |
puta(v) /* print ascii value */ |
530 |
double v; |
531 |
532 |
printf("%e\t", v); |
533 |
534 |
535 |
536 |
static |
537 |
putd(v) /* print binary double */ |
538 |
double v; |
539 |
540 |
fwrite((char *)&v, sizeof(v), 1, stdout); |
541 |
542 |
543 |
544 |
static |
545 |
putf(v) /* print binary float */ |
546 |
double v; |
547 |
548 |
float f = v; |
549 |
550 |
fwrite((char *)&f, sizeof(f), 1, stdout); |
551 |
