1 |
/* Copyright (c) 1994 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* rtrace.c - program and variables for individual ray tracing. |
9 |
10 |
* 6/11/86 |
11 |
12 |
13 |
14 |
* Input is in the form: |
15 |
16 |
* xorg yorg zorg xdir ydir zdir |
17 |
18 |
* The direction need not be normalized. Output is flexible. |
19 |
* If the direction vector is (0,0,0), then the output is flushed. |
20 |
* All values default to ascii representation of real |
21 |
* numbers. Binary representations can be selected |
22 |
* with '-ff' for float or '-fd' for double. By default, |
23 |
* radiance is computed. The '-i' or '-I' options indicate that |
24 |
* irradiance values are desired. |
25 |
26 |
27 |
#include "ray.h" |
28 |
29 |
#include "octree.h" |
30 |
31 |
#include "otypes.h" |
32 |
33 |
#include "resolu.h" |
34 |
35 |
int dimlist[MAXDIM]; /* sampling dimensions */ |
36 |
int ndims = 0; /* number of sampling dimensions */ |
37 |
int samplendx = 0; /* index for this sample */ |
38 |
39 |
int imm_irrad = 0; /* compute immediate irradiance? */ |
40 |
41 |
int inform = 'a'; /* input format */ |
42 |
int outform = 'a'; /* output format */ |
43 |
char *outvals = "v"; /* output specification */ |
44 |
45 |
char *tralist[128]; /* list of modifers to trace (or no) */ |
46 |
int traincl = -1; /* include == 1, exclude == 0 */ |
47 |
#define MAXTSET 511 /* maximum number in trace set */ |
48 |
OBJECT traset[MAXTSET+1]={0}; /* trace include/exclude set */ |
49 |
50 |
int hresolu = 0; /* horizontal (scan) size */ |
51 |
int vresolu = 0; /* vertical resolution */ |
52 |
53 |
double dstrsrc = 0.0; /* square source distribution */ |
54 |
double shadthresh = .05; /* shadow threshold */ |
55 |
double shadcert = .5; /* shadow certainty */ |
56 |
int directrelay = 1; /* number of source relays */ |
57 |
int vspretest = 512; /* virtual source pretest density */ |
58 |
int directvis = 1; /* sources visible? */ |
59 |
double srcsizerat = .25; /* maximum ratio source size/dist. */ |
60 |
61 |
double specthresh = .15; /* specular sampling threshold */ |
62 |
double specjitter = 1.; /* specular sampling jitter */ |
63 |
64 |
int maxdepth = 6; /* maximum recursion depth */ |
65 |
double minweight = 4e-3; /* minimum ray weight */ |
66 |
67 |
COLOR ambval = BLKCOLOR; /* ambient value */ |
68 |
double ambacc = 0.2; /* ambient accuracy */ |
69 |
int ambres = 32; /* ambient resolution */ |
70 |
int ambdiv = 128; /* ambient divisions */ |
71 |
int ambssamp = 0; /* ambient super-samples */ |
72 |
int ambounce = 0; /* ambient bounces */ |
73 |
char *amblist[128]; /* ambient include/exclude list */ |
74 |
int ambincl = -1; /* include == 1, exclude == 0 */ |
75 |
76 |
extern OBJREC Lamb; /* a Lambertian surface */ |
77 |
78 |
static RAY thisray; /* for our convenience */ |
79 |
80 |
static int oputo(), oputd(), oputv(), oputl(), oputL(), |
81 |
oputp(), oputn(), oputN(), oputs(), oputw(), oputm(); |
82 |
83 |
static int ourtrace(), tabin(); |
84 |
static int (*ray_out[16])(), (*every_out[16])(); |
85 |
static int castonly = 0; |
86 |
87 |
static int puta(), putf(), putd(); |
88 |
89 |
static int (*putreal)(); |
90 |
91 |
92 |
quit(code) /* quit program */ |
93 |
int code; |
94 |
95 |
#ifndef NIX |
96 |
headclean(); /* delete header file */ |
97 |
pfclean(); /* clean up persist files */ |
98 |
#endif |
99 |
exit(code); |
100 |
101 |
102 |
103 |
char * |
104 |
formstr(f) /* return format identifier */ |
105 |
int f; |
106 |
107 |
switch (f) { |
108 |
case 'a': return("ascii"); |
109 |
case 'f': return("float"); |
110 |
case 'd': return("double"); |
111 |
case 'c': return(COLRFMT); |
112 |
113 |
return("unknown"); |
114 |
115 |
116 |
117 |
rtrace(fname) /* trace rays from file */ |
118 |
char *fname; |
119 |
120 |
long vcount = hresolu>1 ? hresolu*vresolu : vresolu; |
121 |
long nextflush = hresolu; |
122 |
FILE *fp; |
123 |
FVECT orig, direc; |
124 |
/* set up input */ |
125 |
if (fname == NULL) |
126 |
fp = stdin; |
127 |
else if ((fp = fopen(fname, "r")) == NULL) { |
128 |
sprintf(errmsg, "cannot open input file \"%s\"", fname); |
129 |
error(SYSTEM, errmsg); |
130 |
131 |
#ifdef MSDOS |
132 |
if (inform != 'a') |
133 |
setmode(fileno(fp), O_BINARY); |
134 |
#endif |
135 |
/* set up output */ |
136 |
setoutput(outvals); |
137 |
switch (outform) { |
138 |
case 'a': putreal = puta; break; |
139 |
case 'f': putreal = putf; break; |
140 |
case 'd': putreal = putd; break; |
141 |
case 'c': |
142 |
if (strcmp(outvals, "v")) |
143 |
error(USER, "color format with value output only"); |
144 |
break; |
145 |
default: |
146 |
error(CONSISTENCY, "botched output format"); |
147 |
148 |
if (hresolu > 0) { |
149 |
if (vresolu > 0) |
150 |
fprtresolu(hresolu, vresolu, stdout); |
151 |
fflush(stdout); |
152 |
153 |
/* process file */ |
154 |
while (getvec(orig, inform, fp) == 0 && |
155 |
getvec(direc, inform, fp) == 0) { |
156 |
157 |
if (normalize(direc) == 0.0) { /* zero ==> flush */ |
158 |
fflush(stdout); |
159 |
continue; |
160 |
161 |
samplendx++; |
162 |
/* compute and print */ |
163 |
if (imm_irrad) |
164 |
irrad(orig, direc); |
165 |
else |
166 |
rad(orig, direc); |
167 |
/* flush if time */ |
168 |
if (--nextflush == 0) { |
169 |
fflush(stdout); |
170 |
171 |
172 |
if (ferror(stdout)) |
173 |
error(SYSTEM, "write error"); |
174 |
if (--vcount == 0) /* check for end */ |
175 |
break; |
176 |
177 |
fflush(stdout); |
178 |
if (vcount > 0) |
179 |
error(USER, "read error"); |
180 |
if (fname != NULL) |
181 |
fclose(fp); |
182 |
183 |
184 |
185 |
setoutput(vs) /* set up output tables */ |
186 |
register char *vs; |
187 |
188 |
extern int (*trace)(); |
189 |
register int (**table)() = ray_out; |
190 |
191 |
castonly = 1; |
192 |
while (*vs) |
193 |
switch (*vs++) { |
194 |
case 't': /* trace */ |
195 |
*table = NULL; |
196 |
table = every_out; |
197 |
trace = ourtrace; |
198 |
castonly = 0; |
199 |
break; |
200 |
case 'o': /* origin */ |
201 |
*table++ = oputo; |
202 |
break; |
203 |
case 'd': /* direction */ |
204 |
*table++ = oputd; |
205 |
break; |
206 |
case 'v': /* value */ |
207 |
*table++ = oputv; |
208 |
castonly = 0; |
209 |
break; |
210 |
case 'l': /* effective distance */ |
211 |
*table++ = oputl; |
212 |
castonly = 0; |
213 |
break; |
214 |
case 'L': /* single ray length */ |
215 |
*table++ = oputL; |
216 |
break; |
217 |
case 'p': /* point */ |
218 |
*table++ = oputp; |
219 |
break; |
220 |
case 'n': /* perturbed normal */ |
221 |
*table++ = oputn; |
222 |
castonly = 0; |
223 |
break; |
224 |
case 'N': /* unperturbed normal */ |
225 |
*table++ = oputN; |
226 |
break; |
227 |
case 's': /* surface */ |
228 |
*table++ = oputs; |
229 |
break; |
230 |
case 'w': /* weight */ |
231 |
*table++ = oputw; |
232 |
break; |
233 |
case 'm': /* modifier */ |
234 |
*table++ = oputm; |
235 |
break; |
236 |
237 |
*table = NULL; |
238 |
239 |
240 |
241 |
rad(org, dir) /* compute and print ray value(s) */ |
242 |
FVECT org, dir; |
243 |
244 |
VCOPY(thisray.rorg, org); |
245 |
VCOPY(thisray.rdir, dir); |
246 |
thisray.rmax = 0.0; |
247 |
rayorigin(&thisray, NULL, PRIMARY, 1.0); |
248 |
if (castonly) |
249 |
localhit(&thisray, &thescene) || sourcehit(&thisray); |
250 |
else |
251 |
rayvalue(&thisray); |
252 |
printvals(&thisray); |
253 |
254 |
255 |
256 |
irrad(org, dir) /* compute immediate irradiance value */ |
257 |
FVECT org, dir; |
258 |
259 |
register int i; |
260 |
261 |
for (i = 0; i < 3; i++) { |
262 |
thisray.rorg[i] = org[i] + dir[i]; |
263 |
thisray.rdir[i] = -dir[i]; |
264 |
265 |
266 |
/* pretend we hit surface */ |
267 |
thisray.rot = 1.0-1e-4; |
268 |
thisray.rod = 1.0; |
269 |
VCOPY(thisray.ron, dir); |
270 |
for (i = 0; i < 3; i++) /* fudge factor */ |
271 |
thisray.rop[i] = org[i] + 1e-4*dir[i]; |
272 |
273 |
(*ofun[Lamb.otype].funp)(&Lamb, &thisray); |
274 |
275 |
276 |
277 |
278 |
printvals(r) /* print requested ray values */ |
279 |
RAY *r; |
280 |
281 |
register int (**tp)(); |
282 |
283 |
if (ray_out[0] == NULL) |
284 |
return; |
285 |
for (tp = ray_out; *tp != NULL; tp++) |
286 |
(**tp)(r); |
287 |
if (outform == 'a') |
288 |
putchar('\n'); |
289 |
290 |
291 |
292 |
getvec(vec, fmt, fp) /* get a vector from fp */ |
293 |
register FVECT vec; |
294 |
int fmt; |
295 |
FILE *fp; |
296 |
297 |
extern char *fgetword(); |
298 |
static float vf[3]; |
299 |
static double vd[3]; |
300 |
char buf[32]; |
301 |
register int i; |
302 |
303 |
switch (fmt) { |
304 |
case 'a': /* ascii */ |
305 |
306 |
if (fgetword(buf, sizeof(buf), fp) == NULL || |
307 |
!isflt(buf)) |
308 |
return(-1); |
309 |
vec[i] = atof(buf); |
310 |
311 |
break; |
312 |
case 'f': /* binary float */ |
313 |
if (fread((char *)vf, sizeof(float), 3, fp) != 3) |
314 |
return(-1); |
315 |
vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2]; |
316 |
break; |
317 |
case 'd': /* binary double */ |
318 |
if (fread((char *)vd, sizeof(double), 3, fp) != 3) |
319 |
return(-1); |
320 |
vec[0] = vd[0]; vec[1] = vd[1]; vec[2] = vd[2]; |
321 |
break; |
322 |
default: |
323 |
error(CONSISTENCY, "botched input format"); |
324 |
325 |
return(0); |
326 |
327 |
328 |
329 |
tranotify(obj) /* record new modifier */ |
330 |
OBJECT obj; |
331 |
332 |
static int hitlimit = 0; |
333 |
register OBJREC *o = objptr(obj); |
334 |
register char **tralp; |
335 |
336 |
if (hitlimit || !ismodifier(o->otype)) |
337 |
return; |
338 |
for (tralp = tralist; *tralp != NULL; tralp++) |
339 |
if (!strcmp(o->oname, *tralp)) { |
340 |
if (traset[0] >= MAXTSET) { |
341 |
error(WARNING, "too many modifiers in trace list"); |
342 |
hitlimit++; |
343 |
return; /* should this be fatal? */ |
344 |
345 |
insertelem(traset, obj); |
346 |
return; |
347 |
348 |
349 |
350 |
351 |
static |
352 |
ourtrace(r) /* print ray values */ |
353 |
RAY *r; |
354 |
355 |
356 |
357 |
if (every_out[0] == NULL) |
358 |
return; |
359 |
if (r->ro == NULL) { |
360 |
if (traincl == 1) |
361 |
return; |
362 |
} else if (traincl != -1 && traincl != inset(traset, r->ro->omod)) |
363 |
return; |
364 |
tabin(r); |
365 |
for (tp = every_out; *tp != NULL; tp++) |
366 |
(**tp)(r); |
367 |
putchar('\n'); |
368 |
369 |
370 |
371 |
static |
372 |
tabin(r) /* tab in appropriate amount */ |
373 |
RAY *r; |
374 |
375 |
register RAY *rp; |
376 |
377 |
for (rp = r->parent; rp != NULL; rp = rp->parent) |
378 |
putchar('\t'); |
379 |
380 |
381 |
382 |
static |
383 |
oputo(r) /* print origin */ |
384 |
register RAY *r; |
385 |
386 |
(*putreal)(r->rorg[0]); |
387 |
(*putreal)(r->rorg[1]); |
388 |
(*putreal)(r->rorg[2]); |
389 |
390 |
391 |
392 |
static |
393 |
oputd(r) /* print direction */ |
394 |
register RAY *r; |
395 |
396 |
(*putreal)(r->rdir[0]); |
397 |
(*putreal)(r->rdir[1]); |
398 |
(*putreal)(r->rdir[2]); |
399 |
400 |
401 |
402 |
static |
403 |
oputv(r) /* print value */ |
404 |
register RAY *r; |
405 |
406 |
COLR cout; |
407 |
408 |
if (outform == 'c') { |
409 |
setcolr(cout, colval(r->rcol,RED), |
410 |
colval(r->rcol,GRN), |
411 |
colval(r->rcol,BLU)); |
412 |
fwrite((char *)cout, sizeof(cout), 1, stdout); |
413 |
return; |
414 |
415 |
(*putreal)(colval(r->rcol,RED)); |
416 |
(*putreal)(colval(r->rcol,GRN)); |
417 |
(*putreal)(colval(r->rcol,BLU)); |
418 |
419 |
420 |
421 |
static |
422 |
oputl(r) /* print effective distance */ |
423 |
register RAY *r; |
424 |
425 |
(*putreal)(r->rt); |
426 |
427 |
428 |
429 |
static |
430 |
oputL(r) /* print single ray length */ |
431 |
register RAY *r; |
432 |
433 |
(*putreal)(r->rot); |
434 |
435 |
436 |
437 |
static |
438 |
oputp(r) /* print point */ |
439 |
register RAY *r; |
440 |
441 |
if (r->rot < FHUGE) { |
442 |
(*putreal)(r->rop[0]); |
443 |
(*putreal)(r->rop[1]); |
444 |
(*putreal)(r->rop[2]); |
445 |
} else { |
446 |
(*putreal)(0.0); |
447 |
(*putreal)(0.0); |
448 |
(*putreal)(0.0); |
449 |
450 |
451 |
452 |
453 |
static |
454 |
oputN(r) /* print unperturbed normal */ |
455 |
register RAY *r; |
456 |
457 |
458 |
(*putreal)(r->ron[0]); |
459 |
(*putreal)(r->ron[1]); |
460 |
(*putreal)(r->ron[2]); |
461 |
} else { |
462 |
(*putreal)(0.0); |
463 |
(*putreal)(0.0); |
464 |
(*putreal)(0.0); |
465 |
466 |
467 |
468 |
469 |
static |
470 |
oputn(r) /* print perturbed normal */ |
471 |
RAY *r; |
472 |
473 |
FVECT pnorm; |
474 |
475 |
if (r->rot >= FHUGE) { |
476 |
(*putreal)(0.0); |
477 |
(*putreal)(0.0); |
478 |
(*putreal)(0.0); |
479 |
return; |
480 |
481 |
raynormal(pnorm, r); |
482 |
(*putreal)(pnorm[0]); |
483 |
(*putreal)(pnorm[1]); |
484 |
(*putreal)(pnorm[2]); |
485 |
486 |
487 |
488 |
static |
489 |
oputs(r) /* print name */ |
490 |
register RAY *r; |
491 |
492 |
if (r->ro != NULL) |
493 |
fputs(r->ro->oname, stdout); |
494 |
else |
495 |
putchar('*'); |
496 |
putchar('\t'); |
497 |
498 |
499 |
500 |
static |
501 |
oputw(r) /* print weight */ |
502 |
register RAY *r; |
503 |
504 |
(*putreal)(r->rweight); |
505 |
506 |
507 |
508 |
static |
509 |
oputm(r) /* print modifier */ |
510 |
register RAY *r; |
511 |
512 |
513 |
fputs(objptr(r->ro->omod)->oname, stdout); |
514 |
else |
515 |
putchar('*'); |
516 |
putchar('\t'); |
517 |
518 |
519 |
520 |
static |
521 |
puta(v) /* print ascii value */ |
522 |
double v; |
523 |
524 |
printf("%e\t", v); |
525 |
526 |
527 |
528 |
static |
529 |
putd(v) /* print binary double */ |
530 |
double v; |
531 |
532 |
fwrite((char *)&v, sizeof(v), 1, stdout); |
533 |
534 |
535 |
536 |
static |
537 |
putf(v) /* print binary float */ |
538 |
double v; |
539 |
540 |
float f = v; |
541 |
542 |
fwrite((char *)&f, sizeof(f), 1, stdout); |
543 |
