root/radiance/ray/src/rt/rtrace.c
Revision: 2.104
Committed: Sat Apr 30 15:13:42 2022 UTC (3 years, 1 month ago) by greg
Changes since 2.103: +6 -4 lines
fix(rtrace): Restored original silence during virtual source pretests
2 static const char RCSid[] = "$Id: rtrace.c,v 2.103 2022/04/24 15:40:33 greg Exp $";
5 * rtrace.c - program and variables for individual ray tracing.
6 */
7
8 #include "copyright.h"
9
10 /*
11 * Input is in the form:
12 *
13 * xorg yorg zorg xdir ydir zdir
14 *
15 * The direction need not be normalized. Output is flexible.
16 * If the direction vector is (0,0,0), then the output is flushed.
17 * All values default to ascii representation of real
18 * numbers. Binary representations can be selected
19 * with '-ff' for float or '-fd' for double. By default,
20 * radiance is computed. The '-i' or '-I' options indicate that
21 * irradiance values are desired.
22 */
23
24 #include <time.h>
25
26 #include "platform.h"
27 #include "ray.h"
28 #include "ambient.h"
29 #include "source.h"
30 #include "otypes.h"
31 #include "otspecial.h"
32 #include "resolu.h"
33 #include "random.h"
34
35 extern int inform; /* input format */
36 extern int outform; /* output format */
37 extern char *outvals; /* output values */
38
39 extern int imm_irrad; /* compute immediate irradiance? */
40 extern int lim_dist; /* limit distance? */
41
42 extern char *tralist[]; /* list of modifers to trace (or no) */
43 extern int traincl; /* include == 1, exclude == 0 */
44
45 extern int hresolu; /* horizontal resolution */
46 extern int vresolu; /* vertical resolution */
47
48 int castonly = 0; /* only doing ray-casting? */
49
50 #ifndef MAXTSET
51 #define MAXTSET 8191 /* maximum number in trace set */
52 #endif
53 OBJECT traset[MAXTSET+1]={0}; /* trace include/exclude set */
54
55 static int Tflag = 0; /* source tracing enabled? */
56
57 static RAY thisray; /* for our convenience */
58
59 static FILE *inpfp = NULL; /* input stream pointer */
60
61 static FVECT *inp_queue = NULL; /* ray input queue if flushing */
62 static int inp_qpos = 0; /* next ray to return */
63 static int inp_qend = 0; /* number of rays in this work group */
64
65 typedef void putf_t(RREAL *v, int n);
66 static putf_t puta, putd, putf, putrgbe;
67
68 typedef void oputf_t(RAY *r);
69 static oputf_t oputo, oputd, oputv, oputV, oputl, oputL, oputc, oputp,
70 oputr, oputR, oputx, oputX, oputn, oputN, oputs,
71 oputw, oputW, oputm, oputM, oputtilde;
72
73 extern void tranotify(OBJECT obj);
74 static int is_fifo(FILE *fp);
75 static void bogusray(void);
76 static void raycast(RAY *r);
77 static void rayirrad(RAY *r);
78 static void rtcompute(FVECT org, FVECT dir, double dmax);
79 static int printvals(RAY *r);
80 static int getvec(FVECT vec, int fmt, FILE *fp);
81 static int iszerovec(const FVECT vec);
82 static double nextray(FVECT org, FVECT dir);
83 static void tabin(RAY *r);
84 static void ourtrace(RAY *r);
85
86 static oputf_t *ray_out[32], *every_out[32];
87 static putf_t *putreal;
88
89
90 void
91 quit( /* quit program */
92 int code
93 )
94 {
95 if (ray_pnprocs > 0) /* close children if any */
96 ray_pclose(0);
97 else if (ray_pnprocs < 0)
98 _exit(code); /* avoid flush() in child */
99 #ifndef NON_POSIX
100 else {
101 headclean(); /* delete header file */
102 pfclean(); /* clean up persist files */
103 }
104 #endif
105 exit(code);
106 }
107
108
109 char *
110 formstr( /* return format identifier */
111 int f
112 )
113 {
114 switch (f) {
115 case 'a': return("ascii");
116 case 'f': return("float");
117 case 'd': return("double");
118 case 'c': return(COLRFMT);
119 }
120 return("unknown");
121 }
122
123
124 static void
125 trace_sources(void) /* trace rays to light sources, also */
126 {
127 int sn;
128
129 for (sn = 0; sn < nsources; sn++)
130 source[sn].sflags |= SFOLLOW;
131 }
132
133
134 void
135 rtrace( /* trace rays from file */
136 char *fname,
137 int nproc
138 )
139 {
140 unsigned long vcount = (hresolu > 1) ? (unsigned long)hresolu*vresolu
141 : (unsigned long)vresolu;
142 long nextflush = (!vresolu | (hresolu <= 1)) * hresolu;
143 int something2flush = 0;
144 FILE *fp;
145 double d;
146 FVECT orig, direc;
147 /* set up input */
148 if (fname == NULL)
149 inpfp = stdin;
150 else if ((inpfp = fopen(fname, "r")) == NULL) {
151 sprintf(errmsg, "cannot open input file \"%s\"", fname);
152 error(SYSTEM, errmsg);
153 }
154 #ifdef getc_unlocked
155 flockfile(inpfp); /* avoid lock/unlock overhead */
156 flockfile(stdout);
157 #endif
158 if (inform != 'a')
159 SET_FILE_BINARY(inpfp);
160 /* set up output */
161 if (castonly || every_out[0] != NULL)
162 nproc = 1; /* don't bother multiprocessing */
163 if (every_out[0] != NULL) {
164 trace = ourtrace; /* enable full tree tracing */
165 if (Tflag) /* light sources, too? */
166 trace_sources();
167 }
168 if ((nextflush > 0) & (nproc > nextflush)) {
169 error(WARNING, "reducing number of processes to match flush interval");
170 nproc = nextflush;
171 }
172 if (nproc > 1) { /* start multiprocessing */
173 ray_popen(nproc);
174 ray_fifo_out = printvals;
175 }
176 if (hresolu > 0) {
177 if (vresolu > 0)
178 fprtresolu(hresolu, vresolu, stdout);
179 else
180 fflush(stdout);
181 }
182 /* process input rays */
183 while ((d = nextray(orig, direc)) >= 0.0) {
184 if (d == 0.0) { /* flush request? */
185 if (something2flush) {
186 if (ray_pnprocs > 1 && ray_fifo_flush() < 0)
187 error(USER, "child(ren) died");
188 bogusray();
189 fflush(stdout);
190 nextflush = (!vresolu | (hresolu <= 1)) * hresolu;
191 something2flush = 0;
192 } else
193 bogusray();
194 } else { /* compute and print */
195 rtcompute(orig, direc, lim_dist ? d : 0.0);
196 if (!--nextflush) { /* flush if time */
197 if (ray_pnprocs > 1 && ray_fifo_flush() < 0)
198 error(USER, "child(ren) died");
199 fflush(stdout);
200 nextflush = hresolu;
201 } else
202 something2flush = 1;
203 }
204 if (ferror(stdout))
205 error(SYSTEM, "write error");
206 if (vcount && !--vcount) /* check for end */
207 break;
208 }
209 if (ray_pnprocs > 1) { /* clean up children */
210 if (ray_fifo_flush() < 0)
211 error(USER, "unable to complete processing");
212 ray_pclose(0);
213 }
214 if (vcount)
215 error(WARNING, "unexpected EOF on input");
216 if (fflush(stdout) < 0)
217 error(SYSTEM, "write error");
218 if (fname != NULL) {
219 fclose(inpfp);
220 inpfp = NULL;
221 }
222 nextray(NULL, NULL);
223 }
224
225
226 int
227 setrtoutput(void) /* set up output tables, return #comp */
228 {
229 char *vs = outvals;
230 oputf_t **table = ray_out;
231 int ncomp = 0;
232
233 if (!*vs)
234 error(USER, "empty output specification");
235
236 switch (outform) { /* make sure (*putreal)() calls someone! */
237 case 'a': putreal = puta; break;
238 case 'f': putreal = putf; break;
239 case 'd': putreal = putd; break;
240 case 'c':
241 if (outvals[1] || !strchr("vrx", outvals[0]))
242 error(USER, "color format only with -ov, -or, -ox");
243 putreal = putrgbe; break;
244 default:
245 error(CONSISTENCY, "botched output format");
246 }
247 castonly = 1; /* sets castonly as side-effect */
248 do
249 switch (*vs) {
250 case 'T': /* trace sources */
251 Tflag++;
252 /* fall through */
253 case 't': /* trace */
254 if (!vs[1]) break;
255 *table = NULL;
256 table = every_out;
257 castonly = 0;
258 break;
259 case 'o': /* origin */
260 *table++ = oputo;
261 ncomp += 3;
262 break;
263 case 'd': /* direction */
264 *table++ = oputd;
265 ncomp += 3;
266 break;
267 case 'r': /* reflected contrib. */
268 *table++ = oputr;
269 ncomp += 3;
270 castonly = 0;
271 break;
272 case 'R': /* reflected distance */
273 *table++ = oputR;
274 ncomp++;
275 castonly = 0;
276 break;
277 case 'x': /* xmit contrib. */
278 *table++ = oputx;
279 ncomp += 3;
280 castonly = 0;
281 break;
282 case 'X': /* xmit distance */
283 *table++ = oputX;
284 ncomp++;
285 castonly = 0;
286 break;
287 case 'v': /* value */
288 *table++ = oputv;
289 ncomp += 3;
290 castonly = 0;
291 break;
292 case 'V': /* contribution */
293 *table++ = oputV;
294 ncomp += 3;
295 castonly = 0;
296 if (ambounce > 0 && (ambacc > FTINY || ambssamp > 0))
297 error(WARNING,
298 "-otV accuracy depends on -aa 0 -as 0");
299 break;
300 case 'l': /* effective distance */
301 *table++ = oputl;
302 ncomp++;
303 castonly = 0;
304 break;
305 case 'c': /* local coordinates */
306 *table++ = oputc;
307 ncomp += 2;
308 break;
309 case 'L': /* single ray length */
310 *table++ = oputL;
311 ncomp++;
312 break;
313 case 'p': /* point */
314 *table++ = oputp;
315 ncomp += 3;
316 break;
317 case 'n': /* perturbed normal */
318 *table++ = oputn;
319 ncomp += 3;
320 castonly = 0;
321 break;
322 case 'N': /* unperturbed normal */
323 *table++ = oputN;
324 ncomp += 3;
325 break;
326 case 's': /* surface */
327 *table++ = oputs;
328 ncomp++;
329 break;
330 case 'w': /* weight */
331 *table++ = oputw;
332 ncomp++;
333 break;
334 case 'W': /* coefficient */
335 *table++ = oputW;
336 ncomp += 3;
337 castonly = 0;
338 if (ambounce > 0 && (ambacc > FTINY) | (ambssamp > 0))
339 error(WARNING,
340 "-otW accuracy depends on -aa 0 -as 0");
341 break;
342 case 'm': /* modifier */
343 *table++ = oputm;
344 ncomp++;
345 break;
346 case 'M': /* material */
347 *table++ = oputM;
348 ncomp++;
349 break;
350 case '~': /* tilde */
351 *table++ = oputtilde;
352 break;
353 default:
354 sprintf(errmsg, "unrecognized output option '%c'", *vs);
355 error(USER, errmsg);
356 }
357 while (*++vs);
358
359 *table = NULL;
360 if (*every_out != NULL)
361 ncomp = 0;
362 /* compatibility */
363 if ((do_irrad | imm_irrad) && castonly)
364 error(USER, "-I+ and -i+ options require some value output");
365 for (table = ray_out; *table != NULL; table++) {
366 if ((*table == oputV) | (*table == oputW))
367 error(WARNING, "-oVW options require trace mode");
368 if ((do_irrad | imm_irrad) &&
369 (*table == oputr) | (*table == oputR) |
370 (*table == oputx) | (*table == oputX))
371 error(WARNING, "-orRxX options incompatible with -I+ and -i+");
372 }
373 return(ncomp);
374 }
375
376
377 static void
378 bogusray(void) /* print out empty record */
379 {
380 rayorigin(&thisray, PRIMARY, NULL, NULL);
381 printvals(&thisray);
382 }
383
384
385 static void
386 raycast( /* compute first ray intersection only */
387 RAY *r
388 )
389 {
390 if (!localhit(r, &thescene)) {
391 if (r->ro == &Aftplane) { /* clipped */
392 r->ro = NULL;
393 r->rot = FHUGE;
394 } else
395 sourcehit(r);
396 }
397 }
398
399
400 static void
401 rayirrad( /* compute irradiance rather than radiance */
402 RAY *r
403 )
404 {
405 void (*old_revf)(RAY *) = r->revf;
406 /* pretend we hit surface */
407 r->rxt = r->rot = 1e-5;
408 VSUM(r->rop, r->rorg, r->rdir, r->rot);
409 r->ron[0] = -r->rdir[0];
410 r->ron[1] = -r->rdir[1];
411 r->ron[2] = -r->rdir[2];
412 r->rod = 1.0;
413 /* compute result */
414 r->revf = raytrace;
415 (*ofun[Lamb.otype].funp)(&Lamb, r);
416 r->revf = old_revf;
417 }
418
419
420 static void
421 rtcompute( /* compute and print ray value(s) */
422 FVECT org,
423 FVECT dir,
424 double dmax
425 )
426 {
427 /* set up ray */
428 if (imm_irrad) {
429 VSUM(thisray.rorg, org, dir, 1.1e-4);
430 thisray.rdir[0] = -dir[0];
431 thisray.rdir[1] = -dir[1];
432 thisray.rdir[2] = -dir[2];
433 thisray.rmax = 0.0;
434 } else {
435 VCOPY(thisray.rorg, org);
436 VCOPY(thisray.rdir, dir);
437 thisray.rmax = dmax;
438 }
439 rayorigin(&thisray, PRIMARY, NULL, NULL);
440 if (imm_irrad)
441 thisray.revf = rayirrad;
442 else if (castonly)
443 thisray.revf = raycast;
444 if (ray_pnprocs > 1) { /* multiprocessing FIFO? */
445 if (ray_fifo_in(&thisray) < 0)
446 error(USER, "lost children");
447 return;
448 }
449 samplendx++; /* else do it ourselves */
450 rayvalue(&thisray);
451 printvals(&thisray);
452 }
453
454
455 static int
456 printvals( /* print requested ray values */
457 RAY *r
458 )
459 {
460 oputf_t **tp;
461
462 if (ray_out[0] == NULL)
463 return(0);
464 for (tp = ray_out; *tp != NULL; tp++)
465 (**tp)(r);
466 if (outform == 'a')
467 putchar('\n');
468 return(1);
469 }
470
471
472 static int
473 is_fifo( /* check if file pointer connected to pipe */
474 FILE *fp
475 )
476 {
477 #ifdef S_ISFIFO
478 struct stat sbuf;
479
480 if (fstat(fileno(fp), &sbuf) < 0)
481 error(SYSTEM, "fstat() failed on input stream");
482 return(S_ISFIFO(sbuf.st_mode));
483 #else
484 return (fp == stdin); /* just a guess, really */
485 #endif
486 }
487
488
489 static int
490 getvec( /* get a vector from fp */
491 FVECT vec,
492 int fmt,
493 FILE *fp
494 )
495 {
496 static float vf[3];
497 static double vd[3];
498 char buf[32];
499 int i;
500
501 switch (fmt) {
502 case 'a': /* ascii */
503 for (i = 0; i < 3; i++) {
504 if (fgetword(buf, sizeof(buf), fp) == NULL ||
505 !isflt(buf))
506 return(-1);
507 vec[i] = atof(buf);
508 }
509 break;
510 case 'f': /* binary float */
511 if (getbinary(vf, sizeof(float), 3, fp) != 3)
512 return(-1);
513 VCOPY(vec, vf);
514 break;
515 case 'd': /* binary double */
516 if (getbinary(vd, sizeof(double), 3, fp) != 3)
517 return(-1);
518 VCOPY(vec, vd);
519 break;
520 default:
521 error(CONSISTENCY, "botched input format");
522 }
523 return(0);
524 }
525
526
527 static int
528 iszerovec(const FVECT vec)
529 {
530 return (vec[0] == 0.0) & (vec[1] == 0.0) & (vec[2] == 0.0);
531 }
532
533
534 static double
535 nextray( /* return next ray in work group (-1.0 if EOF) */
536 FVECT org,
537 FVECT dir
538 )
539 {
540 const size_t qlength = !vresolu * hresolu;
541
542 if ((org == NULL) | (dir == NULL)) {
543 if (inp_queue != NULL) /* asking to free queue */
544 free(inp_queue);
545 inp_queue = NULL;
546 inp_qpos = inp_qend = 0;
547 return(-1.);
548 }
549 if (!inp_qend) { /* initialize FIFO queue */
550 int rsiz = 6*20; /* conservative ascii ray size */
551 if (inform == 'f') rsiz = 6*sizeof(float);
552 else if (inform == 'd') rsiz = 6*sizeof(double);
553 /* check against pipe limit */
554 if (qlength*rsiz > 512 && is_fifo(inpfp))
555 inp_queue = (FVECT *)malloc(sizeof(FVECT)*2*qlength);
556 inp_qend = -(inp_queue == NULL); /* flag for no queue */
557 }
558 if (inp_qend < 0) { /* not queuing? */
559 if (getvec(org, inform, inpfp) < 0 ||
560 getvec(dir, inform, inpfp) < 0)
561 return(-1.);
562 return normalize(dir);
563 }
564 if (inp_qpos >= inp_qend) { /* need to refill input queue? */
565 for (inp_qend = 0; inp_qend < qlength; inp_qend++) {
566 if (getvec(inp_queue[2*inp_qend], inform, inpfp) < 0
567 || getvec(inp_queue[2*inp_qend+1],
568 inform, inpfp) < 0)
569 break; /* hit EOF */
570 if (iszerovec(inp_queue[2*inp_qend+1])) {
571 ++inp_qend; /* flush request */
572 break;
573 }
574 }
575 inp_qpos = 0;
576 }
577 if (inp_qpos >= inp_qend) /* unexpected EOF? */
578 return(-1.);
579 VCOPY(org, inp_queue[2*inp_qpos]);
580 VCOPY(dir, inp_queue[2*inp_qpos+1]);
581 ++inp_qpos;
582 return normalize(dir);
583 }
584
585
586 void
587 tranotify( /* record new modifier */
588 OBJECT obj
589 )
590 {
591 static int hitlimit = 0;
592 OBJREC *o = objptr(obj);
593 char **tralp;
594
595 if (obj == OVOID) { /* starting over */
596 traset[0] = 0;
597 hitlimit = 0;
598 return;
599 }
600 if (hitlimit || !ismodifier(o->otype))
601 return;
602 for (tralp = tralist; *tralp != NULL; tralp++)
603 if (!strcmp(o->oname, *tralp)) {
604 if (traset[0] >= MAXTSET) {
605 error(WARNING, "too many modifiers in trace list");
606 hitlimit++;
607 return; /* should this be fatal? */
608 }
609 insertelem(traset, obj);
610 return;
611 }
612 }
613
614
615 static void
616 ourtrace( /* print ray values */
617 RAY *r
618 )
619 {
620 oputf_t **tp;
621
622 if (every_out[0] == NULL)
623 return;
624 if (r->ro == NULL) {
625 if (traincl == 1)
626 return;
627 } else if (traincl != -1 && traincl != inset(traset, r->ro->omod))
628 return;
629 tabin(r);
630 for (tp = every_out; *tp != NULL; tp++)
631 (**tp)(r);
632 if (outform == 'a')
633 putchar('\n');
634 }
635
636
637 static void
638 tabin( /* tab in appropriate amount */
639 RAY *r
640 )
641 {
642 const RAY *rp;
643
644 for (rp = r->parent; rp != NULL; rp = rp->parent)
645 putchar('\t');
646 }
647
648
649 static void
650 oputo( /* print origin */
651 RAY *r
652 )
653 {
654 (*putreal)(r->rorg, 3);
655 }
656
657
658 static void
659 oputd( /* print direction */
660 RAY *r
661 )
662 {
663 (*putreal)(r->rdir, 3);
664 }
665
666
667 static void
668 oputr( /* print mirrored contribution */
669 RAY *r
670 )
671 {
672 RREAL cval[3];
673
674 cval[0] = colval(r->mcol,RED);
675 cval[1] = colval(r->mcol,GRN);
676 cval[2] = colval(r->mcol,BLU);
677 (*putreal)(cval, 3);
678 }
679
680
681
682 static void
683 oputR( /* print mirrored distance */
684 RAY *r
685 )
686 {
687 (*putreal)(&r->rmt, 1);
688 }
689
690
691 static void
692 oputx( /* print unmirrored contribution */
693 RAY *r
694 )
695 {
696 RREAL cval[3];
697
698 cval[0] = colval(r->rcol,RED) - colval(r->mcol,RED);
699 cval[1] = colval(r->rcol,GRN) - colval(r->mcol,GRN);
700 cval[2] = colval(r->rcol,BLU) - colval(r->mcol,BLU);
701 (*putreal)(cval, 3);
702 }
703
704
705 static void
706 oputX( /* print unmirrored distance */
707 RAY *r
708 )
709 {
710 (*putreal)(&r->rxt, 1);
711 }
712
713
714 static void
715 oputv( /* print value */
716 RAY *r
717 )
718 {
719 RREAL cval[3];
720
721 cval[0] = colval(r->rcol,RED);
722 cval[1] = colval(r->rcol,GRN);
723 cval[2] = colval(r->rcol,BLU);
724 (*putreal)(cval, 3);
725 }
726
727
728 static void
729 oputV( /* print value contribution */
730 RAY *r
731 )
732 {
733 RREAL contr[3];
734
735 raycontrib(contr, r, PRIMARY);
736 multcolor(contr, r->rcol);
737 (*putreal)(contr, 3);
738 }
739
740
741 static void
742 oputl( /* print effective distance */
743 RAY *r
744 )
745 {
746 RREAL d = raydistance(r);
747
748 (*putreal)(&d, 1);
749 }
750
751
752 static void
753 oputL( /* print single ray length */
754 RAY *r
755 )
756 {
757 (*putreal)(&r->rot, 1);
758 }
759
760
761 static void
762 oputc( /* print local coordinates */
763 RAY *r
764 )
765 {
766 (*putreal)(r->uv, 2);
767 }
768
769
770 static RREAL vdummy[3] = {0.0, 0.0, 0.0};
771
772
773 static void
774 oputp( /* print intersection point */
775 RAY *r
776 )
777 {
778 (*putreal)(r->rop, 3); /* set to ray origin if distant or no hit */
779 }
780
781
782 static void
783 oputN( /* print unperturbed normal */
784 RAY *r
785 )
786 {
787 if (r->ro == NULL) { /* zero vector if clipped or no hit */
788 (*putreal)(vdummy, 3);
789 return;
790 }
791 if (r->rflips & 1) { /* undo any flippin' flips */
792 FVECT unrm;
793 unrm[0] = -r->ron[0];
794 unrm[1] = -r->ron[1];
795 unrm[2] = -r->ron[2];
796 (*putreal)(unrm, 3);
797 } else
798 (*putreal)(r->ron, 3);
799 }
800
801
802 static void
803 oputn( /* print perturbed normal */
804 RAY *r
805 )
806 {
807 FVECT pnorm;
808
809 if (r->ro == NULL) { /* clipped or no hit */
810 (*putreal)(vdummy, 3);
811 return;
812 }
813 raynormal(pnorm, r);
814 (*putreal)(pnorm, 3);
815 }
816
817
818 static void
819 oputs( /* print name */
820 RAY *r
821 )
822 {
823 if (r->ro != NULL)
824 fputs(r->ro->oname, stdout);
825 else
826 putchar('*');
827 putchar('\t');
828 }
829
830
831 static void
832 oputw( /* print weight */
833 RAY *r
834 )
835 {
836 RREAL rwt = r->rweight;
837
838 (*putreal)(&rwt, 1);
839 }
840
841
842 static void
843 oputW( /* print coefficient */
844 RAY *r
845 )
846 {
847 RREAL contr[3];
848 /* shadow ray not on source? */
849 if (r->rsrc >= 0 && source[r->rsrc].so != r->ro)
850 setcolor(contr, 0.0, 0.0, 0.0);
851 else
852 raycontrib(contr, r, PRIMARY);
853
854 (*putreal)(contr, 3);
855 }
856
857
858 static void
859 oputm( /* print modifier */
860 RAY *r
861 )
862 {
863 if (r->ro != NULL)
864 if (r->ro->omod != OVOID)
865 fputs(objptr(r->ro->omod)->oname, stdout);
866 else
867 fputs(VOIDID, stdout);
868 else
869 putchar('*');
870 putchar('\t');
871 }
872
873
874 static void
875 oputM( /* print material */
876 RAY *r
877 )
878 {
879 OBJREC *mat;
880
881 if (r->ro != NULL) {
882 if ((mat = findmaterial(r->ro)) != NULL)
883 fputs(mat->oname, stdout);
884 else
885 fputs(VOIDID, stdout);
886 } else
887 putchar('*');
888 putchar('\t');
889 }
890
891
892 static void
893 oputtilde( /* output tilde (spacer) */
894 RAY *r
895 )
896 {
897 fputs("~\t", stdout);
898 }
899
900
901 static void
902 puta( /* print ascii value(s) */
903 RREAL *v, int n
904 )
905 {
906 if (n == 3) {
907 printf("%e\t%e\t%e\t", v[0], v[1], v[2]);
908 return;
909 }
910 while (n--)
911 printf("%e\t", *v++);
912 }
913
914
915 static void
916 putd(RREAL *v, int n) /* output binary double(s) */
917 {
918 #ifdef SMLFLT
919 double da[3];
920 int i;
921
922 if (n > 3)
923 error(INTERNAL, "code error in putd()");
924 for (i = n; i--; )
925 da[i] = v[i];
926 putbinary(da, sizeof(double), n, stdout);
927 #else
928 putbinary(v, sizeof(RREAL), n, stdout);
929 #endif
930 }
931
932
933 static void
934 putf(RREAL *v, int n) /* output binary float(s) */
935 {
936 #ifndef SMLFLT
937 float fa[3];
938 int i;
939
940 if (n > 3)
941 error(INTERNAL, "code error in putf()");
942 for (i = n; i--; )
943 fa[i] = v[i];
944 putbinary(fa, sizeof(float), n, stdout);
945 #else
946 putbinary(v, sizeof(RREAL), n, stdout);
947 #endif
948 }
949
950
951 static void
952 putrgbe(RREAL *v, int n) /* output RGBE color */
953 {
954 COLR cout;
955
956 if (n != 3)
957 error(INTERNAL, "putrgbe() not called with 3 components");
958 setcolr(cout, v[0], v[1], v[2]);
959 putbinary(cout, sizeof(cout), 1, stdout);
960 }
