root/radiance/ray/src/rt/rtrace.c
Revision: 1.15
Committed: Wed Jun 19 16:36:48 1991 UTC (34 years ago) by greg
Changes since 1.14: +1 -0 lines
added virtual sources
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rtrace.c - program and variables for individual ray tracing.
9 *
10 * 6/11/86
11 */
12
13 /*
14 * Input is in the form:
15 *
16 * xorg yorg zorg xdir ydir zdir
17 *
18 * The direction need not be normalized. Output is flexible.
19 * If the direction vector is (0,0,0), then the output is flushed.
20 * All values default to ascii representation of real
21 * numbers. Binary representations can be selected
22 * with '-ff' for float or '-fd' for double. By default,
23 * radiance is computed. The '-i' or '-I' options indicate that
24 * irradiance values are desired.
25 */
26
27 #include "ray.h"
28
29 #include "octree.h"
30
31 #include "otypes.h"
32
33 int dimlist[MAXDIM]; /* sampling dimensions */
34 int ndims = 0; /* number of sampling dimensions */
35 int samplendx = 0; /* index for this sample */
36
37 int imm_irrad = 0; /* compute immediate irradiance? */
38
39 int inform = 'a'; /* input format */
40 int outform = 'a'; /* output format */
41 char *outvals = "v"; /* output specification */
42
43 int hresolu = 0; /* horizontal (scan) size */
44 int vresolu = 0; /* vertical resolution */
45
46 double dstrsrc = 0.0; /* square source distribution */
47 double shadthresh = .05; /* shadow threshold */
48 double shadcert = .5; /* shadow certainty */
49 int directrelay = 0; /* number of source relays */
50
51 int maxdepth = 6; /* maximum recursion depth */
52 double minweight = 4e-3; /* minimum ray weight */
53
54 COLOR ambval = BLKCOLOR; /* ambient value */
55 double ambacc = 0.2; /* ambient accuracy */
56 int ambres = 32; /* ambient resolution */
57 int ambdiv = 128; /* ambient divisions */
58 int ambssamp = 0; /* ambient super-samples */
59 int ambounce = 0; /* ambient bounces */
60 char *amblist[128]; /* ambient include/exclude list */
61 int ambincl = -1; /* include == 1, exclude == 0 */
62
63 extern OBJREC Lamb; /* a Lambertian surface */
64
65 static RAY thisray; /* for our convenience */
66
67 static int oputo(), oputd(), oputv(), oputl(),
68 oputp(), oputn(), oputs(), oputw(), oputm();
69
70 static int (*ray_out[10])(), (*every_out[10])();
71 static int castonly;
72
73 static int puta(), putf(), putd();
74
75 static int (*putreal)();
76
77
78 quit(code) /* quit program */
79 int code;
80 {
81 exit(code);
82 }
83
84
85 rtrace(fname) /* trace rays from file */
86 char *fname;
87 {
88 long vcount = hresolu>1 ? hresolu*vresolu : vresolu;
89 long nextflush = hresolu;
90 FILE *fp;
91 FVECT orig, direc;
92 /* set up input */
93 if (fname == NULL)
94 fp = stdin;
95 else if ((fp = fopen(fname, "r")) == NULL) {
96 sprintf(errmsg, "cannot open input file \"%s\"", fname);
97 error(SYSTEM, errmsg);
98 }
99 /* set up output */
100 setoutput(outvals);
101 switch (outform) {
102 case 'a': putreal = puta; break;
103 case 'f': putreal = putf; break;
104 case 'd': putreal = putd; break;
105 }
106 /* process file */
107 while (getvec(orig, inform, fp) == 0 &&
108 getvec(direc, inform, fp) == 0) {
109
110 if (normalize(direc) == 0.0) { /* zero ==> flush */
111 fflush(stdout);
112 continue;
113 }
114 samplendx++;
115 /* compute and print */
116 if (imm_irrad)
117 irrad(orig, direc);
118 else
119 traceray(orig, direc);
120 /* flush if time */
121 if (--nextflush == 0) {
122 fflush(stdout);
123 nextflush = hresolu;
124 }
125 if (ferror(stdout))
126 error(SYSTEM, "write error");
127 if (--vcount == 0) /* check for end */
128 break;
129 }
130 if (vcount > 0)
131 error(USER, "read error");
132 fclose(fp);
133 }
134
135
136 setoutput(vs) /* set up output tables */
137 register char *vs;
138 {
139 extern int ourtrace(), (*trace)();
140 register int (**table)() = ray_out;
141
142 castonly = 1;
143 while (*vs)
144 switch (*vs++) {
145 case 't': /* trace */
146 *table = NULL;
147 table = every_out;
148 trace = ourtrace;
149 castonly = 0;
150 break;
151 case 'o': /* origin */
152 *table++ = oputo;
153 break;
154 case 'd': /* direction */
155 *table++ = oputd;
156 break;
157 case 'v': /* value */
158 *table++ = oputv;
159 castonly = 0;
160 break;
161 case 'l': /* length */
162 *table++ = oputl;
163 castonly = 0;
164 break;
165 case 'p': /* point */
166 *table++ = oputp;
167 break;
168 case 'n': /* normal */
169 *table++ = oputn;
170 break;
171 case 's': /* surface */
172 *table++ = oputs;
173 break;
174 case 'w': /* weight */
175 *table++ = oputw;
176 break;
177 case 'm': /* modifier */
178 *table++ = oputm;
179 break;
180 }
181 *table = NULL;
182 }
183
184
185 traceray(org, dir) /* compute and print ray value(s) */
186 FVECT org, dir;
187 {
188 register int (**tp)();
189
190 VCOPY(thisray.rorg, org);
191 VCOPY(thisray.rdir, dir);
192 rayorigin(&thisray, NULL, PRIMARY, 1.0);
193 if (castonly)
194 localhit(&thisray, &thescene) || sourcehit(&thisray);
195 else
196 rayvalue(&thisray);
197
198 if (ray_out[0] == NULL)
199 return;
200 for (tp = ray_out; *tp != NULL; tp++)
201 (**tp)(&thisray);
202 if (outform == 'a')
203 putchar('\n');
204 }
205
206
207 irrad(org, dir) /* compute immediate irradiance value */
208 FVECT org, dir;
209 {
210 register int i;
211
212 for (i = 0; i < 3; i++) {
213 thisray.rorg[i] = org[i] + dir[i];
214 thisray.rdir[i] = -dir[i];
215 }
216 rayorigin(&thisray, NULL, PRIMARY, 1.0);
217 /* pretend we hit surface */
218 thisray.rot = 1.0;
219 thisray.rod = 1.0;
220 VCOPY(thisray.ron, dir);
221 for (i = 0; i < 3; i++) /* fudge factor */
222 thisray.rop[i] = org[i] + 1e-4*dir[i];
223 /* compute and print */
224 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
225 oputv(&thisray);
226 if (outform == 'a')
227 putchar('\n');
228 }
229
230
231 getvec(vec, fmt, fp) /* get a vector from fp */
232 register FVECT vec;
233 int fmt;
234 FILE *fp;
235 {
236 static float vf[3];
237
238 switch (fmt) {
239 case 'a': /* ascii */
240 if (fscanf(fp, "%lf %lf %lf", vec, vec+1, vec+2) != 3)
241 return(-1);
242 break;
243 case 'f': /* binary float */
244 if (fread((char *)vf, sizeof(float), 3, fp) != 3)
245 return(-1);
246 vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2];
247 break;
248 case 'd': /* binary double */
249 if (fread((char *)vec, sizeof(double), 3, fp) != 3)
250 return(-1);
251 break;
252 }
253 return(0);
254 }
255
256
257 static
258 ourtrace(r) /* print ray values */
259 RAY *r;
260 {
261 register int (**tp)();
262
263 if (every_out[0] == NULL)
264 return;
265 tabin(r);
266 for (tp = every_out; *tp != NULL; tp++)
267 (**tp)(r);
268 putchar('\n');
269 }
270
271
272 static
273 tabin(r) /* tab in appropriate amount */
274 RAY *r;
275 {
276 register RAY *rp;
277
278 for (rp = r->parent; rp != NULL; rp = rp->parent)
279 putchar('\t');
280 }
281
282
283 static
284 oputo(r) /* print origin */
285 register RAY *r;
286 {
287 (*putreal)(r->rorg[0]);
288 (*putreal)(r->rorg[1]);
289 (*putreal)(r->rorg[2]);
290 }
291
292
293 static
294 oputd(r) /* print direction */
295 register RAY *r;
296 {
297 (*putreal)(r->rdir[0]);
298 (*putreal)(r->rdir[1]);
299 (*putreal)(r->rdir[2]);
300 }
301
302
303 static
304 oputv(r) /* print value */
305 register RAY *r;
306 {
307 (*putreal)(colval(r->rcol,RED));
308 (*putreal)(colval(r->rcol,GRN));
309 (*putreal)(colval(r->rcol,BLU));
310 }
311
312
313 static
314 oputl(r) /* print length */
315 register RAY *r;
316 {
317 (*putreal)(r->rt);
318 }
319
320
321 static
322 oputp(r) /* print point */
323 register RAY *r;
324 {
325 if (r->rot < FHUGE) {
326 (*putreal)(r->rop[0]);
327 (*putreal)(r->rop[1]);
328 (*putreal)(r->rop[2]);
329 } else {
330 (*putreal)(0.0);
331 (*putreal)(0.0);
332 (*putreal)(0.0);
333 }
334 }
335
336
337 static
338 oputn(r) /* print normal */
339 register RAY *r;
340 {
341 if (r->rot < FHUGE) {
342 (*putreal)(r->ron[0]);
343 (*putreal)(r->ron[1]);
344 (*putreal)(r->ron[2]);
345 } else {
346 (*putreal)(0.0);
347 (*putreal)(0.0);
348 (*putreal)(0.0);
349 }
350 }
351
352
353 static
354 oputs(r) /* print name */
355 register RAY *r;
356 {
357 if (r->ro != NULL)
358 fputs(r->ro->oname, stdout);
359 else
360 putchar('*');
361 putchar('\t');
362 }
363
364
365 static
366 oputw(r) /* print weight */
367 register RAY *r;
368 {
369 (*putreal)(r->rweight);
370 }
371
372
373 static
374 oputm(r) /* print modifier */
375 register RAY *r;
376 {
377 if (r->ro != NULL)
378 fputs(objptr(r->ro->omod)->oname, stdout);
379 else
380 putchar('*');
381 putchar('\t');
382 }
383
384
385 static
386 puta(v) /* print ascii value */
387 double v;
388 {
389 printf("%e\t", v);
390 }
391
392
393 static
394 putd(v) /* print binary double */
395 double v;
396 {
397 fwrite((char *)&v, sizeof(v), 1, stdout);
398 }
399
400
401 static
402 putf(v) /* print binary float */
403 double v;
404 {
405 float f = v;
406
407 fwrite((char *)&f, sizeof(f), 1, stdout);
408 }
