--- ray/src/rt/rtrace.c 2019/05/04 23:10:32 2.78 +++ ray/src/rt/rtrace.c 2020/07/20 15:54:29 2.99 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rtrace.c,v 2.78 2019/05/04 23:10:32 greg Exp $"; +static const char RCSid[] = "$Id: rtrace.c,v 2.99 2020/07/20 15:54:29 greg Exp $"; #endif /* * rtrace.c - program and variables for individual ray tracing. @@ -45,7 +45,7 @@ extern int traincl; /* include == 1, exclude == 0 * extern int hresolu; /* horizontal resolution */ extern int vresolu; /* vertical resolution */ -static int castonly = 0; +int castonly = 0; /* only doing ray-casting? */ #ifndef MAXTSET #define MAXTSET 8191 /* maximum number in trace set */ @@ -54,22 +54,30 @@ OBJECT traset[MAXTSET+1]={0}; /* trace include/exclud static RAY thisray; /* for our convenience */ +static FILE *inpfp = NULL; /* input stream pointer */ + +static FVECT *inp_queue = NULL; /* ray input queue if flushing */ +static int inp_qpos = 0; /* next ray to return */ +static int inp_qend = 0; /* number of rays in this work group */ + typedef void putf_t(RREAL *v, int n); -static putf_t puta, putd, putf; +static putf_t puta, putd, putf, putrgbe; typedef void oputf_t(RAY *r); static oputf_t oputo, oputd, oputv, oputV, oputl, oputL, oputc, oputp, oputr, oputR, oputx, oputX, oputn, oputN, oputs, oputw, oputW, oputm, oputM, oputtilde; -static void setoutput(char *vs); extern void tranotify(OBJECT obj); +static int is_fifo(FILE *fp); static void bogusray(void); static void raycast(RAY *r); static void rayirrad(RAY *r); static void rtcompute(FVECT org, FVECT dir, double dmax); static int printvals(RAY *r); static int getvec(FVECT vec, int fmt, FILE *fp); +static int iszerovec(const FVECT vec); +static double nextray(FVECT org, FVECT dir); static void tabin(RAY *r); static void ourtrace(RAY *r); @@ -84,8 +92,10 @@ quit( /* quit program */ { if (ray_pnprocs > 0) /* close children if any */ ray_pclose(0); + else if (ray_pnprocs < 0) + _exit(code); /* avoid flush() in child */ #ifndef NON_POSIX - else if (!ray_pnprocs) { + else { headclean(); /* delete header file */ pfclean(); /* clean up persist files */ } @@ -109,7 +119,7 @@ formstr( /* return format identifier */ } -extern void +void rtrace( /* trace rays from file */ char *fname, int nproc @@ -117,34 +127,39 @@ rtrace( /* trace rays from file */ { unsigned long vcount = (hresolu > 1) ? (unsigned long)hresolu*vresolu : (unsigned long)vresolu; - long nextflush = (vresolu > 0) & (hresolu > 1) ? 0 : hresolu; - int bogusflushed = 0; + long nextflush = (!vresolu | (hresolu <= 1)) * hresolu; + int something2flush = 0; FILE *fp; double d; FVECT orig, direc; /* set up input */ if (fname == NULL) - fp = stdin; - else if ((fp = fopen(fname, "r")) == NULL) { + inpfp = stdin; + else if ((inpfp = fopen(fname, "r")) == NULL) { sprintf(errmsg, "cannot open input file \"%s\"", fname); error(SYSTEM, errmsg); } +#ifdef getc_unlocked + flockfile(inpfp); /* avoid lock/unlock overhead */ + flockfile(stdout); +#endif if (inform != 'a') - SET_FILE_BINARY(fp); + SET_FILE_BINARY(inpfp); /* set up output */ - setoutput(outvals); - if (imm_irrad) - castonly = 0; - else if (castonly) + if (castonly || every_out[0] != NULL) nproc = 1; /* don't bother multiprocessing */ + if ((nextflush > 0) & (nproc > nextflush)) { + error(WARNING, "reducing number of processes to match flush interval"); + nproc = nextflush; + } switch (outform) { case 'a': putreal = puta; break; case 'f': putreal = putf; break; case 'd': putreal = putd; break; case 'c': - if (strcmp(outvals, "v")) - error(USER, "color format with value output only"); - break; + if (outvals[1] || !strchr("vrx", outvals[0])) + error(USER, "color format only with -ov, -or, -ox"); + putreal = putrgbe; break; default: error(CONSISTENCY, "botched output format"); } @@ -158,32 +173,27 @@ rtrace( /* trace rays from file */ else fflush(stdout); } - /* process file */ - while (getvec(orig, inform, fp) == 0 && - getvec(direc, inform, fp) == 0) { - - d = normalize(direc); - if (d == 0.0) { /* zero ==> flush */ - if ((--nextflush <= 0) | !vcount && !bogusflushed) { + /* process input rays */ + while ((d = nextray(orig, direc)) >= 0.0) { + if (d == 0.0) { /* flush request? */ + if (something2flush) { if (ray_pnprocs > 1 && ray_fifo_flush() < 0) error(USER, "child(ren) died"); bogusray(); fflush(stdout); - bogusflushed = 1; - nextflush = (vresolu > 0) & (hresolu > 1) ? 0 : - hresolu; + nextflush = (!vresolu | (hresolu <= 1)) * hresolu; + something2flush = 0; } else bogusray(); } else { /* compute and print */ rtcompute(orig, direc, lim_dist ? d : 0.0); - /* flush if time */ - if (!--nextflush) { + if (!--nextflush) { /* flush if time */ if (ray_pnprocs > 1 && ray_fifo_flush() < 0) error(USER, "child(ren) died"); fflush(stdout); nextflush = hresolu; } else - bogusflushed = 0; + something2flush = 1; } if (ferror(stdout)) error(SYSTEM, "write error"); @@ -195,12 +205,15 @@ rtrace( /* trace rays from file */ error(USER, "unable to complete processing"); ray_pclose(0); } + if (vcount) + error(WARNING, "unexpected EOF on input"); if (fflush(stdout) < 0) error(SYSTEM, "write error"); - if (vcount) - error(USER, "unexpected EOF on input"); - if (fname != NULL) - fclose(fp); + if (fname != NULL) { + fclose(inpfp); + inpfp = NULL; + } + nextray(NULL, NULL); } @@ -214,22 +227,25 @@ trace_sources(void) /* trace rays to light sources, } -static void -setoutput( /* set up output tables */ - char *vs -) +int +setrtoutput(void) /* set up output tables, return #comp */ { + char *vs = outvals; oputf_t **table = ray_out; + int ncomp = 0; - castonly = 1; - while (*vs) - switch (*vs++) { + if (!*vs) + error(USER, "empty output specification"); + + castonly = 1; /* sets castonly as side-effect */ + do + switch (*vs) { case 'T': /* trace sources */ - if (!*vs) break; + if (!vs[1]) break; trace_sources(); /* fall through */ case 't': /* trace */ - if (!*vs) break; + if (!vs[1]) break; *table = NULL; table = every_out; trace = ourtrace; @@ -237,32 +253,40 @@ setoutput( /* set up output tables */ break; case 'o': /* origin */ *table++ = oputo; + ncomp += 3; break; case 'd': /* direction */ *table++ = oputd; + ncomp += 3; break; case 'r': /* reflected contrib. */ *table++ = oputr; + ncomp += 3; castonly = 0; break; case 'R': /* reflected distance */ *table++ = oputR; + ncomp++; castonly = 0; break; case 'x': /* xmit contrib. */ *table++ = oputx; + ncomp += 3; castonly = 0; break; case 'X': /* xmit distance */ *table++ = oputX; + ncomp++; castonly = 0; break; case 'v': /* value */ *table++ = oputv; + ncomp += 3; castonly = 0; break; case 'V': /* contribution */ *table++ = oputV; + ncomp += 3; castonly = 0; if (ambounce > 0 && (ambacc > FTINY || ambssamp > 0)) error(WARNING, @@ -270,48 +294,78 @@ setoutput( /* set up output tables */ break; case 'l': /* effective distance */ *table++ = oputl; + ncomp++; castonly = 0; break; case 'c': /* local coordinates */ *table++ = oputc; + ncomp += 2; break; case 'L': /* single ray length */ *table++ = oputL; + ncomp++; break; case 'p': /* point */ *table++ = oputp; + ncomp += 3; break; case 'n': /* perturbed normal */ *table++ = oputn; + ncomp += 3; castonly = 0; break; case 'N': /* unperturbed normal */ *table++ = oputN; + ncomp += 3; break; case 's': /* surface */ *table++ = oputs; + ncomp++; break; case 'w': /* weight */ *table++ = oputw; + ncomp++; break; case 'W': /* coefficient */ *table++ = oputW; + ncomp += 3; castonly = 0; - if (ambounce > 0 && (ambacc > FTINY || ambssamp > 0)) + if (ambounce > 0 && (ambacc > FTINY) | (ambssamp > 0)) error(WARNING, "-otW accuracy depends on -aa 0 -as 0"); break; case 'm': /* modifier */ *table++ = oputm; + ncomp++; break; case 'M': /* material */ *table++ = oputM; + ncomp++; break; case '~': /* tilde */ *table++ = oputtilde; break; + default: + sprintf(errmsg, "unrecognized output option '%c'", *vs); + error(USER, errmsg); } + while (*++vs); + *table = NULL; + if (*every_out != NULL) + ncomp = 0; + /* compatibility */ + if ((do_irrad | imm_irrad) && castonly) + error(USER, "-I+ and -i+ options require some value output"); + for (table = ray_out; *table != NULL; table++) { + if ((*table == oputV) | (*table == oputW)) + error(WARNING, "-oVW options require trace mode"); + if ((do_irrad | imm_irrad) && + (*table == oputr) | (*table == oputR) | + (*table == oputx) | (*table == oputX)) + error(WARNING, "-orRxX options incompatible with -I+ and -i+"); + } + return(ncomp); } @@ -410,7 +464,24 @@ printvals( /* print requested ray values */ static int -getvec( /* get a vector from fp */ +is_fifo( /* check if file pointer connected to pipe */ + FILE *fp +) +{ +#ifdef S_ISFIFO + struct stat sbuf; + + if (fstat(fileno(fp), &sbuf) < 0) + error(SYSTEM, "fstat() failed on input stream"); + return(S_ISFIFO(sbuf.st_mode)); +#else + return (fp == stdin); /* just a guess, really */ +#endif +} + + +static int +getvec( /* get a vector from fp */ FVECT vec, int fmt, FILE *fp @@ -447,6 +518,65 @@ getvec( /* get a vector from fp */ } +static int +iszerovec(const FVECT vec) +{ + return (vec[0] == 0.0) & (vec[1] == 0.0) & (vec[2] == 0.0); +} + + +static double +nextray( /* return next ray in work group (-1.0 if EOF) */ + FVECT org, + FVECT dir +) +{ + const size_t qlength = !vresolu * hresolu; + + if ((org == NULL) | (dir == NULL)) { + if (inp_queue != NULL) /* asking to free queue */ + free(inp_queue); + inp_queue = NULL; + inp_qpos = inp_qend = 0; + return(-1.); + } + if (!inp_qend) { /* initialize FIFO queue */ + int rsiz = 6*20; /* conservative ascii ray size */ + if (inform == 'f') rsiz = 6*sizeof(float); + else if (inform == 'd') rsiz = 6*sizeof(double); + /* check against pipe limit */ + if (qlength*rsiz > 512 && is_fifo(inpfp)) + inp_queue = (FVECT *)malloc(sizeof(FVECT)*2*qlength); + inp_qend = -(inp_queue == NULL); /* flag for no queue */ + } + if (inp_qend < 0) { /* not queuing? */ + if (getvec(org, inform, inpfp) < 0 || + getvec(dir, inform, inpfp) < 0) + return(-1.); + return normalize(dir); + } + if (inp_qpos >= inp_qend) { /* need to refill input queue? */ + for (inp_qend = 0; inp_qend < qlength; inp_qend++) { + if (getvec(inp_queue[2*inp_qend], inform, inpfp) < 0 + || getvec(inp_queue[2*inp_qend+1], + inform, inpfp) < 0) + break; /* hit EOF */ + if (iszerovec(inp_queue[2*inp_qend+1])) { + ++inp_qend; /* flush request */ + break; + } + } + inp_qpos = 0; + } + if (inp_qpos >= inp_qend) /* unexpected EOF? */ + return(-1.); + VCOPY(org, inp_queue[2*inp_qpos]); + VCOPY(dir, inp_queue[2*inp_qpos+1]); + ++inp_qpos; + return normalize(dir); +} + + void tranotify( /* record new modifier */ OBJECT obj @@ -582,14 +712,6 @@ oputv( /* print value */ { RREAL cval[3]; - if (outform == 'c') { - COLR cout; - setcolr(cout, colval(r->rcol,RED), - colval(r->rcol,GRN), - colval(r->rcol,BLU)); - putbinary(cout, sizeof(cout), 1, stdout); - return; - } cval[0] = colval(r->rcol,RED); cval[1] = colval(r->rcol,GRN); cval[2] = colval(r->rcol,BLU); @@ -647,7 +769,7 @@ oputp( /* print point */ RAY *r ) { - if (r->rot < FHUGE) + if (r->rot < FHUGE*.99) (*putreal)(r->rop, 3); else (*putreal)(vdummy, 3); @@ -659,9 +781,16 @@ oputN( /* print unperturbed normal */ RAY *r ) { - if (r->rot < FHUGE) - (*putreal)(r->ron, 3); - else + if (r->rot < FHUGE*.99) { + if (r->rflips & 1) { /* undo any flippin' flips */ + FVECT unrm; + unrm[0] = -r->ron[0]; + unrm[1] = -r->ron[1]; + unrm[2] = -r->ron[2]; + (*putreal)(unrm, 3); + } else + (*putreal)(r->ron, 3); + } else (*putreal)(vdummy, 3); } @@ -673,7 +802,7 @@ oputn( /* print perturbed normal */ { FVECT pnorm; - if (r->rot >= FHUGE) { + if (r->rot >= FHUGE*.99) { (*putreal)(vdummy, 3); return; } @@ -780,7 +909,7 @@ puta( /* print ascii value(s) */ static void -putd(RREAL *v, int n) /* print binary double(s) */ +putd(RREAL *v, int n) /* output binary double(s) */ { #ifdef SMLFLT double da[3]; @@ -798,7 +927,7 @@ putd(RREAL *v, int n) /* print binary double(s) */ static void -putf(RREAL *v, int n) /* print binary float(s) */ +putf(RREAL *v, int n) /* output binary float(s) */ { #ifndef SMLFLT float fa[3]; @@ -812,4 +941,16 @@ putf(RREAL *v, int n) /* print binary float(s) */ #else putbinary(v, sizeof(RREAL), n, stdout); #endif +} + + +static void +putrgbe(RREAL *v, int n) /* output RGBE color */ +{ + COLR cout; + + if (n != 3) + error(INTERNAL, "putrgbe() not called with 3 components"); + setcolr(cout, v[0], v[1], v[2]); + putbinary(cout, sizeof(cout), 1, stdout); }
