--- ray/src/rt/rtrace.c 2009/12/14 03:15:45 2.60 +++ ray/src/rt/rtrace.c 2020/06/15 15:44:04 2.96 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rtrace.c,v 2.60 2009/12/14 03:15:45 greg Exp $"; +static const char RCSid[] = "$Id: rtrace.c,v 2.96 2020/06/15 15:44:04 greg Exp $"; #endif /* * rtrace.c - program and variables for individual ray tracing. @@ -28,6 +28,7 @@ static const char RCSid[] = "$Id: rtrace.c,v 2.60 2009 #include "ambient.h" #include "source.h" #include "otypes.h" +#include "otspecial.h" #include "resolu.h" #include "random.h" @@ -44,7 +45,7 @@ extern int traincl; /* include == 1, exclude == 0 * extern int hresolu; /* horizontal resolution */ extern int vresolu; /* vertical resolution */ -static int castonly = 0; +int castonly = 0; /* only doing ray-casting? */ #ifndef MAXTSET #define MAXTSET 8191 /* maximum number in trace set */ @@ -53,25 +54,34 @@ OBJECT traset[MAXTSET+1]={0}; /* trace include/exclud static RAY thisray; /* for our convenience */ -typedef void putf_t(double v); -static putf_t puta, putd, putf; +static FILE *inpfp = NULL; /* input stream pointer */ +static FVECT *inp_queue = NULL; /* ray input queue if flushing */ +static int inp_qpos = 0; /* next ray to return */ +static int inp_qend = 0; /* number of rays in this work group */ + +typedef void putf_t(RREAL *v, int n); +static putf_t puta, putd, putf, putrgbe; + typedef void oputf_t(RAY *r); static oputf_t oputo, oputd, oputv, oputV, oputl, oputL, oputc, oputp, - oputn, oputN, oputs, oputw, oputW, oputm, oputM, oputtilde; + oputr, oputR, oputx, oputX, oputn, oputN, oputs, + oputw, oputW, oputm, oputM, oputtilde; -static void setoutput(char *vs); extern void tranotify(OBJECT obj); +static int is_fifo(FILE *fp); static void bogusray(void); static void raycast(RAY *r); static void rayirrad(RAY *r); static void rtcompute(FVECT org, FVECT dir, double dmax); static int printvals(RAY *r); static int getvec(FVECT vec, int fmt, FILE *fp); +static int iszerovec(const FVECT vec); +static double nextray(FVECT org, FVECT dir); static void tabin(RAY *r); static void ourtrace(RAY *r); -static oputf_t *ray_out[16], *every_out[16]; +static oputf_t *ray_out[32], *every_out[32]; static putf_t *putreal; @@ -107,92 +117,102 @@ formstr( /* return format identifier */ } -extern void +void rtrace( /* trace rays from file */ char *fname, int nproc ) { unsigned long vcount = (hresolu > 1) ? (unsigned long)hresolu*vresolu - : vresolu; - long nextflush = hresolu; + : (unsigned long)vresolu; + long nextflush = (!vresolu | (hresolu <= 1)) * hresolu; + int something2flush = 0; FILE *fp; double d; FVECT orig, direc; /* set up input */ if (fname == NULL) - fp = stdin; - else if ((fp = fopen(fname, "r")) == NULL) { + inpfp = stdin; + else if ((inpfp = fopen(fname, "r")) == NULL) { sprintf(errmsg, "cannot open input file \"%s\"", fname); error(SYSTEM, errmsg); } +#ifdef getc_unlocked + flockfile(inpfp); /* avoid lock/unlock overhead */ + flockfile(stdout); +#endif if (inform != 'a') - SET_FILE_BINARY(fp); + SET_FILE_BINARY(inpfp); /* set up output */ - setoutput(outvals); - if (imm_irrad) - castonly = 0; - else if (castonly) + if (castonly || every_out[0] != NULL) nproc = 1; /* don't bother multiprocessing */ + if ((nextflush > 0) & (nproc > nextflush)) { + error(WARNING, "reducing number of processes to match flush interval"); + nproc = nextflush; + } switch (outform) { case 'a': putreal = puta; break; case 'f': putreal = putf; break; case 'd': putreal = putd; break; case 'c': - if (strcmp(outvals, "v")) - error(USER, "color format with value output only"); - break; + if (outvals[1] || !strchr("vrx", outvals[0])) + error(USER, "color format only with -ov, -or, -ox"); + putreal = putrgbe; break; default: error(CONSISTENCY, "botched output format"); } if (nproc > 1) { /* start multiprocessing */ ray_popen(nproc); ray_fifo_out = printvals; + ray_pnbatch = 1; /* optimize for throughput */ } if (hresolu > 0) { if (vresolu > 0) fprtresolu(hresolu, vresolu, stdout); - fflush(stdout); + else + fflush(stdout); } - /* process file */ - while (getvec(orig, inform, fp) == 0 && - getvec(direc, inform, fp) == 0) { - - d = normalize(direc); - if (d == 0.0) { /* zero ==> flush */ - if (nproc > 1 && ray_fifo_flush() < 0) - error(USER, "lost children"); - bogusray(); - if (--nextflush <= 0 || !vcount) { + /* process input rays */ + while ((d = nextray(orig, direc)) >= 0.0) { + if (d == 0.0) { /* flush request? */ + if (something2flush) { + if (ray_pnprocs > 1 && ray_fifo_flush() < 0) + error(USER, "child(ren) died"); + bogusray(); fflush(stdout); - nextflush = hresolu; - } + nextflush = (!vresolu | (hresolu <= 1)) * hresolu; + something2flush = 0; + } else + bogusray(); } else { /* compute and print */ rtcompute(orig, direc, lim_dist ? d : 0.0); - /* flush if time */ - if (!--nextflush) { - if (nproc > 1 && ray_fifo_flush() < 0) - error(USER, "lost children"); + if (!--nextflush) { /* flush if time */ + if (ray_pnprocs > 1 && ray_fifo_flush() < 0) + error(USER, "child(ren) died"); fflush(stdout); nextflush = hresolu; - } + } else + something2flush = 1; } if (ferror(stdout)) error(SYSTEM, "write error"); if (vcount && !--vcount) /* check for end */ break; } - if (nproc > 1) { /* clean up children */ + if (ray_pnprocs > 1) { /* clean up children */ if (ray_fifo_flush() < 0) error(USER, "unable to complete processing"); ray_pclose(0); } + if (vcount) + error(WARNING, "unexpected EOF on input"); if (fflush(stdout) < 0) error(SYSTEM, "write error"); - if (vcount) - error(USER, "unexpected EOF on input"); - if (fname != NULL) - fclose(fp); + if (fname != NULL) { + fclose(inpfp); + inpfp = NULL; + } + nextray(NULL, NULL); } @@ -206,22 +226,25 @@ trace_sources(void) /* trace rays to light sources, } -static void -setoutput( /* set up output tables */ - char *vs -) +int +setrtoutput(void) /* set up output tables, return #comp */ { + char *vs = outvals; oputf_t **table = ray_out; + int ncomp = 0; - castonly = 1; - while (*vs) - switch (*vs++) { + if (!*vs) + error(USER, "empty output specification"); + + castonly = 1; /* sets castonly as side-effect */ + do + switch (*vs) { case 'T': /* trace sources */ - if (!*vs) break; + if (!vs[1]) break; trace_sources(); /* fall through */ case 't': /* trace */ - if (!*vs) break; + if (!vs[1]) break; *table = NULL; table = every_out; trace = ourtrace; @@ -229,72 +252,125 @@ setoutput( /* set up output tables */ break; case 'o': /* origin */ *table++ = oputo; + ncomp += 3; break; case 'd': /* direction */ *table++ = oputd; + ncomp += 3; break; + case 'r': /* reflected contrib. */ + *table++ = oputr; + ncomp += 3; + castonly = 0; + break; + case 'R': /* reflected distance */ + *table++ = oputR; + ncomp++; + castonly = 0; + break; + case 'x': /* xmit contrib. */ + *table++ = oputx; + ncomp += 3; + castonly = 0; + break; + case 'X': /* xmit distance */ + *table++ = oputX; + ncomp++; + castonly = 0; + break; case 'v': /* value */ *table++ = oputv; + ncomp += 3; castonly = 0; break; case 'V': /* contribution */ *table++ = oputV; + ncomp += 3; + castonly = 0; if (ambounce > 0 && (ambacc > FTINY || ambssamp > 0)) error(WARNING, "-otV accuracy depends on -aa 0 -as 0"); break; case 'l': /* effective distance */ *table++ = oputl; + ncomp++; castonly = 0; break; case 'c': /* local coordinates */ *table++ = oputc; + ncomp += 2; break; case 'L': /* single ray length */ *table++ = oputL; + ncomp++; break; case 'p': /* point */ *table++ = oputp; + ncomp += 3; break; case 'n': /* perturbed normal */ *table++ = oputn; + ncomp += 3; castonly = 0; break; case 'N': /* unperturbed normal */ *table++ = oputN; + ncomp += 3; break; case 's': /* surface */ *table++ = oputs; + ncomp++; break; case 'w': /* weight */ *table++ = oputw; + ncomp++; break; case 'W': /* coefficient */ *table++ = oputW; - if (ambounce > 0 && (ambacc > FTINY || ambssamp > 0)) + ncomp += 3; + castonly = 0; + if (ambounce > 0 && (ambacc > FTINY) | (ambssamp > 0)) error(WARNING, "-otW accuracy depends on -aa 0 -as 0"); break; case 'm': /* modifier */ *table++ = oputm; + ncomp++; break; case 'M': /* material */ *table++ = oputM; + ncomp++; break; case '~': /* tilde */ *table++ = oputtilde; break; + default: + sprintf(errmsg, "unrecognized output option '%c'", *vs); + error(USER, errmsg); } + while (*++vs); + *table = NULL; + if (*every_out != NULL) + ncomp = 0; + /* compatibility */ + if ((do_irrad | imm_irrad) && castonly) + error(USER, "-I+ and -i+ options require some value output"); + for (table = ray_out; *table != NULL; table++) { + if ((*table == oputV) | (*table == oputW)) + error(WARNING, "-oVW options require trace mode"); + if ((do_irrad | imm_irrad) && + (*table == oputr) | (*table == oputR) | + (*table == oputx) | (*table == oputX)) + error(WARNING, "-orRxX options incompatible with -I+ and -i+"); + } + return(ncomp); } static void bogusray(void) /* print out empty record */ { - thisray.rorg[0] = thisray.rorg[1] = thisray.rorg[2] = - thisray.rdir[0] = thisray.rdir[1] = thisray.rdir[2] = 0.0; - thisray.rmax = 0.0; rayorigin(&thisray, PRIMARY, NULL, NULL); printvals(&thisray); } @@ -320,14 +396,18 @@ rayirrad( /* compute irradiance rather than radiance RAY *r ) { - r->rot = 1e-5; /* pretend we hit surface */ + void (*old_revf)(RAY *) = r->revf; + /* pretend we hit surface */ + r->rxt = r->rot = 1e-5; VSUM(r->rop, r->rorg, r->rdir, r->rot); r->ron[0] = -r->rdir[0]; r->ron[1] = -r->rdir[1]; r->ron[2] = -r->rdir[2]; r->rod = 1.0; /* compute result */ + r->revf = raytrace; (*ofun[Lamb.otype].funp)(&Lamb, r); + r->revf = old_revf; } @@ -383,7 +463,24 @@ printvals( /* print requested ray values */ static int -getvec( /* get a vector from fp */ +is_fifo( /* check if file pointer connected to pipe */ + FILE *fp +) +{ +#ifdef S_ISFIFO + struct stat sbuf; + + if (fstat(fileno(fp), &sbuf) < 0) + error(SYSTEM, "fstat() failed on input stream"); + return(S_ISFIFO(sbuf.st_mode)); +#else + return (fp == stdin); /* just a guess, really */ +#endif +} + + +static int +getvec( /* get a vector from fp */ FVECT vec, int fmt, FILE *fp @@ -404,12 +501,12 @@ getvec( /* get a vector from fp */ } break; case 'f': /* binary float */ - if (fread((char *)vf, sizeof(float), 3, fp) != 3) + if (getbinary(vf, sizeof(float), 3, fp) != 3) return(-1); VCOPY(vec, vf); break; case 'd': /* binary double */ - if (fread((char *)vd, sizeof(double), 3, fp) != 3) + if (getbinary(vd, sizeof(double), 3, fp) != 3) return(-1); VCOPY(vec, vd); break; @@ -420,6 +517,65 @@ getvec( /* get a vector from fp */ } +static int +iszerovec(const FVECT vec) +{ + return (vec[0] == 0.0) & (vec[1] == 0.0) & (vec[2] == 0.0); +} + + +static double +nextray( /* return next ray in work group (-1.0 if EOF) */ + FVECT org, + FVECT dir +) +{ + const size_t qlength = !vresolu * hresolu; + + if ((org == NULL) | (dir == NULL)) { + if (inp_queue != NULL) /* asking to free queue */ + free(inp_queue); + inp_queue = NULL; + inp_qpos = inp_qend = 0; + return(-1.); + } + if (!inp_qend) { /* initialize FIFO queue */ + int rsiz = 6*20; /* conservative ascii ray size */ + if (inform == 'f') rsiz = 6*sizeof(float); + else if (inform == 'd') rsiz = 6*sizeof(double); + /* check against pipe limit */ + if (qlength*rsiz > 512 && is_fifo(inpfp)) + inp_queue = (FVECT *)malloc(sizeof(FVECT)*2*qlength); + inp_qend = -(inp_queue == NULL); /* flag for no queue */ + } + if (inp_qend < 0) { /* not queuing? */ + if (getvec(org, inform, inpfp) < 0 || + getvec(dir, inform, inpfp) < 0) + return(-1.); + return normalize(dir); + } + if (inp_qpos >= inp_qend) { /* need to refill input queue? */ + for (inp_qend = 0; inp_qend < qlength; inp_qend++) { + if (getvec(inp_queue[2*inp_qend], inform, inpfp) < 0 + || getvec(inp_queue[2*inp_qend+1], + inform, inpfp) < 0) + break; /* hit EOF */ + if (iszerovec(inp_queue[2*inp_qend+1])) { + ++inp_qend; /* flush request */ + break; + } + } + inp_qpos = 0; + } + if (inp_qpos >= inp_qend) /* unexpected EOF? */ + return(-1.); + VCOPY(org, inp_queue[2*inp_qpos]); + VCOPY(dir, inp_queue[2*inp_qpos+1]); + ++inp_qpos; + return normalize(dir); +} + + void tranotify( /* record new modifier */ OBJECT obj @@ -488,9 +644,7 @@ oputo( /* print origin */ RAY *r ) { - (*putreal)(r->rorg[0]); - (*putreal)(r->rorg[1]); - (*putreal)(r->rorg[2]); + (*putreal)(r->rorg, 3); } @@ -499,28 +653,68 @@ oputd( /* print direction */ RAY *r ) { - (*putreal)(r->rdir[0]); - (*putreal)(r->rdir[1]); - (*putreal)(r->rdir[2]); + (*putreal)(r->rdir, 3); } static void +oputr( /* print mirrored contribution */ + RAY *r +) +{ + RREAL cval[3]; + + cval[0] = colval(r->mcol,RED); + cval[1] = colval(r->mcol,GRN); + cval[2] = colval(r->mcol,BLU); + (*putreal)(cval, 3); +} + + + +static void +oputR( /* print mirrored distance */ + RAY *r +) +{ + (*putreal)(&r->rmt, 1); +} + + +static void +oputx( /* print unmirrored contribution */ + RAY *r +) +{ + RREAL cval[3]; + + cval[0] = colval(r->rcol,RED) - colval(r->mcol,RED); + cval[1] = colval(r->rcol,GRN) - colval(r->mcol,GRN); + cval[2] = colval(r->rcol,BLU) - colval(r->mcol,BLU); + (*putreal)(cval, 3); +} + + +static void +oputX( /* print unmirrored distance */ + RAY *r +) +{ + (*putreal)(&r->rxt, 1); +} + + +static void oputv( /* print value */ RAY *r ) { - if (outform == 'c') { - COLR cout; - setcolr(cout, colval(r->rcol,RED), - colval(r->rcol,GRN), - colval(r->rcol,BLU)); - fwrite((char *)cout, sizeof(cout), 1, stdout); - return; - } - (*putreal)(colval(r->rcol,RED)); - (*putreal)(colval(r->rcol,GRN)); - (*putreal)(colval(r->rcol,BLU)); + RREAL cval[3]; + + cval[0] = colval(r->rcol,RED); + cval[1] = colval(r->rcol,GRN); + cval[2] = colval(r->rcol,BLU); + (*putreal)(cval, 3); } @@ -529,13 +723,11 @@ oputV( /* print value contribution */ RAY *r ) { - double contr[3]; + RREAL contr[3]; raycontrib(contr, r, PRIMARY); multcolor(contr, r->rcol); - (*putreal)(contr[RED]); - (*putreal)(contr[GRN]); - (*putreal)(contr[BLU]); + (*putreal)(contr, 3); } @@ -544,7 +736,9 @@ oputl( /* print effective distance */ RAY *r ) { - (*putreal)(r->rt); + RREAL d = raydistance(r); + + (*putreal)(&d, 1); } @@ -553,7 +747,7 @@ oputL( /* print single ray length */ RAY *r ) { - (*putreal)(r->rot); + (*putreal)(&r->rot, 1); } @@ -562,25 +756,22 @@ oputc( /* print local coordinates */ RAY *r ) { - (*putreal)(r->uv[0]); - (*putreal)(r->uv[1]); + (*putreal)(r->uv, 2); } +static RREAL vdummy[3] = {0.0, 0.0, 0.0}; + + static void oputp( /* print point */ RAY *r ) { - if (r->rot < FHUGE) { - (*putreal)(r->rop[0]); - (*putreal)(r->rop[1]); - (*putreal)(r->rop[2]); - } else { - (*putreal)(0.0); - (*putreal)(0.0); - (*putreal)(0.0); - } + if (r->rot < FHUGE*.99) + (*putreal)(r->rop, 3); + else + (*putreal)(vdummy, 3); } @@ -589,15 +780,17 @@ oputN( /* print unperturbed normal */ RAY *r ) { - if (r->rot < FHUGE) { - (*putreal)(r->ron[0]); - (*putreal)(r->ron[1]); - (*putreal)(r->ron[2]); - } else { - (*putreal)(0.0); - (*putreal)(0.0); - (*putreal)(0.0); - } + if (r->rot < FHUGE*.99) { + if (r->rflips & 1) { /* undo any flippin' flips */ + FVECT unrm; + unrm[0] = -r->ron[0]; + unrm[1] = -r->ron[1]; + unrm[2] = -r->ron[2]; + (*putreal)(unrm, 3); + } else + (*putreal)(r->ron, 3); + } else + (*putreal)(vdummy, 3); } @@ -608,16 +801,12 @@ oputn( /* print perturbed normal */ { FVECT pnorm; - if (r->rot >= FHUGE) { - (*putreal)(0.0); - (*putreal)(0.0); - (*putreal)(0.0); + if (r->rot >= FHUGE*.99) { + (*putreal)(vdummy, 3); return; } raynormal(pnorm, r); - (*putreal)(pnorm[0]); - (*putreal)(pnorm[1]); - (*putreal)(pnorm[2]); + (*putreal)(pnorm, 3); } @@ -639,7 +828,9 @@ oputw( /* print weight */ RAY *r ) { - (*putreal)(r->rweight); + RREAL rwt = r->rweight; + + (*putreal)(&rwt, 1); } @@ -648,12 +839,14 @@ oputW( /* print coefficient */ RAY *r ) { - double contr[3]; + RREAL contr[3]; + /* shadow ray not on source? */ + if (r->rsrc >= 0 && source[r->rsrc].so != r->ro) + setcolor(contr, 0.0, 0.0, 0.0); + else + raycontrib(contr, r, PRIMARY); - raycontrib(contr, r, PRIMARY); - (*putreal)(contr[RED]); - (*putreal)(contr[GRN]); - (*putreal)(contr[BLU]); + (*putreal)(contr, 3); } @@ -701,27 +894,62 @@ oputtilde( /* output tilde (spacer) */ static void -puta( /* print ascii value */ - double v +puta( /* print ascii value(s) */ + RREAL *v, int n ) { - printf("%e\t", v); + if (n == 3) { + printf("%e\t%e\t%e\t", v[0], v[1], v[2]); + return; + } + while (n--) + printf("%e\t", *v++); } static void -putd(v) /* print binary double */ -double v; +putd(RREAL *v, int n) /* output binary double(s) */ { - fwrite((char *)&v, sizeof(v), 1, stdout); +#ifdef SMLFLT + double da[3]; + int i; + + if (n > 3) + error(INTERNAL, "code error in putd()"); + for (i = n; i--; ) + da[i] = v[i]; + putbinary(da, sizeof(double), n, stdout); +#else + putbinary(v, sizeof(RREAL), n, stdout); +#endif } static void -putf(v) /* print binary float */ -double v; +putf(RREAL *v, int n) /* output binary float(s) */ { - float f = v; +#ifndef SMLFLT + float fa[3]; + int i; - fwrite((char *)&f, sizeof(f), 1, stdout); + if (n > 3) + error(INTERNAL, "code error in putf()"); + for (i = n; i--; ) + fa[i] = v[i]; + putbinary(fa, sizeof(float), n, stdout); +#else + putbinary(v, sizeof(RREAL), n, stdout); +#endif +} + + +static void +putrgbe(RREAL *v, int n) /* output RGBE color */ +{ + COLR cout; + + if (n != 3) + error(INTERNAL, "putrgbe() not called with 3 components"); + setcolr(cout, v[0], v[1], v[2]); + putbinary(cout, sizeof(cout), 1, stdout); }
