root/radiance/ray/src/rt/rtrace.c
Mon Jul 20 15:54:29 2020 UTC (3 years, 9 months ago) by greg
Changes since 2.98: +4 -2 lines
Diff to previous 2.98 , to selected 2.50
fix(mkillum, rcontrib, rtrace, ranimove, rsensor): stall under macOS 10.15
due to broken flockfile() implementation -- workaround is better, anyway
Tue Jun 16 17:58:11 2020 UTC (3 years, 10 months ago) by greg
Changes since 2.97: +1 -2 lines
Diff to previous 2.97 , to selected 2.50
Backed out last change, which actually made things worse
Mon Jun 15 20:27:42 2020 UTC (3 years, 11 months ago) by greg
Changes since 2.96: +2 -2 lines
Diff to previous 2.96 , to selected 2.50
Changed so batch optimization only happens if no flush interval
Mon Jun 15 15:44:04 2020 UTC (3 years, 11 months ago) by greg
Changes since 2.95: +2 -1 lines
Diff to previous 2.95 , to selected 2.50
Optimize rtrace for throughput, especially with ambient cache
Thu May 7 17:13:08 2020 UTC (4 years ago) by greg
Changes since 2.94: +1 -2 lines
Diff to previous 2.94 , to selected 2.50
Removed superfluous declaration
Mon Apr 6 21:09:07 2020 UTC (4 years, 1 month ago) by greg
Changes since 2.93: +7 -6 lines
Diff to previous 2.93 , to selected 2.50
Fixes and improvements from last change, making ray-casting faster
Mon Apr 6 04:10:44 2020 UTC (4 years, 1 month ago) by greg
Changes since 2.92: +2 -2 lines
Diff to previous 2.92 , to selected 2.50
Made start-up much faster when only doing ray-casting
Sun Apr 5 23:01:34 2020 UTC (4 years, 1 month ago) by greg
Changes since 2.91: +23 -4 lines
Diff to previous 2.91 , to selected 2.50
Added better check to see if input is from a pipe or not
Sun Apr 5 15:47:02 2020 UTC (4 years, 1 month ago) by greg
Changes since 2.90: +40 -11 lines
Diff to previous 2.90 , to selected 2.50
Added NCOMP= to header and better checking of -o* options
Sat Apr 4 15:38:52 2020 UTC (4 years, 1 month ago) by greg
Diff to previous 2.89 , to selected 2.50
Turn off multiprocessing with -oT* and -ot* options
Fri Apr 3 17:06:16 2020 UTC (4 years, 1 month ago) by greg
Changes since 2.88: +85 -16 lines
Diff to previous 2.88 , to selected 2.50
Added input ray queue for more efficient batch processing
Thu Mar 12 17:19:18 2020 UTC (4 years, 2 months ago) by greg
Changes since 2.87: +4 -4 lines
Diff to previous 2.87 , to selected 2.50
Added precautionary testing when checking for FHUGE
Wed Mar 4 01:23:31 2020 UTC (4 years, 2 months ago) by greg
Changes since 2.86: +5 -5 lines
Diff to previous 2.86 , to selected 2.50
Undid last change, which introduced a bug!
Tue Mar 3 19:39:32 2020 UTC (4 years, 2 months ago) by greg
Changes since 2.85: +6 -6 lines
Diff to previous 2.85 , to selected 2.50
Minor simplification to last change - should not affect results
Sun Mar 1 05:38:22 2020 UTC (4 years, 2 months ago) by greg
Changes since 2.84: +4 -5 lines
Diff to previous 2.84 , to selected 2.50
Slightly improved flushing logic
Wed Aug 14 22:33:02 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.83: +1 -2 lines
Diff to previous 2.83 , to selected 2.50
Took out redundant setting
Thu Jul 25 16:59:19 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.82: +9 -3 lines
Diff to previous 2.82 , to selected 2.50
Avoid bug where -onN and -oNn output different information
Thu Jul 25 16:50:54 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.81: +4 -3 lines
Diff to previous 2.81 , to selected 2.50
Keep track of ray flips so rayreorient() can put it back as it was
Thu Jul 4 01:25:07 2019 UTC (4 years, 10 months ago) by greg
Changes since 2.80: +12 -10 lines
Diff to previous 2.80 , to selected 2.50
More warnings and correction because -oW and -oV are useless options
Thu Jul 4 01:06:35 2019 UTC (4 years, 10 months ago) by greg
Changes since 2.79: +27 -16 lines
Diff to previous 2.79 , to selected 2.50
Made -f?c RGBE output compatible with any of 'vVWrx' options and added warning
Mon May 6 16:49:38 2019 UTC (5 years ago) by greg
Changes since 2.78: +9 -5 lines
Diff to previous 2.78 , to selected 2.50
Check that number of processes does not exceed flush interval
Sat May 4 23:10:32 2019 UTC (5 years ago) by greg
Changes since 2.77: +8 -5 lines
Diff to previous 2.77 , to selected 2.50
Removed unnecessary clear + made multiple zero directions -> single flush
Sat May 4 13:48:06 2019 UTC (5 years ago) by greg
Changes since 2.76: +3 -5 lines
Diff to previous 2.76 , to selected 2.50
Made rtrace a little more robust when reporting bogus ray values
Sun Apr 7 16:39:39 2019 UTC (5 years, 1 month ago) by greg
Diff to previous 2.75 , to selected 2.50
For consistency, reflected ray distance should be inf for diffuse surface
Thu Mar 28 16:33:36 2019 UTC (5 years, 1 month ago) by greg
Changes since 2.74: +3 -3 lines
Diff to previous 2.74 , to selected 2.50
Added missing initialization for rmt and rxt
Tue Jan 8 00:16:31 2019 UTC (5 years, 4 months ago) by greg
Changes since 2.73: +4 -4 lines
Diff to previous 2.73 , to selected 2.50
Made rtrace a little more efficient under Windows if -n > 1
Tue Nov 13 19:58:33 2018 UTC (5 years, 6 months ago) by greg
Changes since 2.72: +72 -4 lines
Diff to previous 2.72 , to selected 2.50
Thu Nov 8 00:54:07 2018 UTC (5 years, 6 months ago) by greg
Changes since 2.71: +2 -1 lines
Diff to previous 2.71 , to selected 2.50
Tue Feb 13 20:27:19 2018 UTC (6 years, 3 months ago) by greg
Changes since 2.70: +3 -3 lines
Diff to previous 2.70 , to selected 2.50
Improved error message
Thu Aug 18 00:52:48 2016 UTC (7 years, 8 months ago) by greg
Changes since 2.69: +3 -3 lines
Diff to previous 2.69 , to selected 2.50
Thu Mar 3 22:38:34 2016 UTC (8 years, 2 months ago) by greg
Changes since 2.68: +8 -8 lines
Diff to previous 2.68 , to selected 2.50
Switched to more efficient i/o for small vectors
Fri Apr 11 20:27:23 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.67: +15 -2 lines
Diff to previous 2.67 , to selected 2.50
Made reading of vectors more consistent with FVFORMAT macro
Wed Jun 27 15:32:58 2012 UTC (11 years, 10 months ago) by greg
Changes since 2.66: +6 -2 lines
Diff to previous 2.66 , to selected 2.50
Added check for blocked shadow rays
Sat Jun 9 07:16:47 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.65: +2 -2 lines
Diff to previous 2.65 , to selected 2.50
Wed Apr 6 00:14:26 2011 UTC (13 years, 1 month ago) by greg
Changes since 2.64: +54 -59 lines
Diff to previous 2.64 , to selected 2.50
Improved output efficiency by reducing number of calls to fwrite()
Sun Sep 26 15:49:39 2010 UTC (13 years, 7 months ago) by greg
Changes since 2.63: +4 -3 lines
Diff to previous 2.63 , to selected 2.50
Eliminated flushing with -x >1 if -y also set to improve -n performance
Wed Dec 16 03:30:50 2009 UTC (14 years, 5 months ago) by greg
Changes since 2.62: +6 -5 lines
Diff to previous 2.62 , to selected 2.50
Bug fix for zero-direction rays with multiprocessing
Mon Dec 14 07:31:37 2009 UTC (14 years, 5 months ago) by greg
Changes since 2.61: +5 -2 lines
Diff to previous 2.61 , to selected 2.50
Precautionary change to rayirrad()
Mon Dec 14 04:49:16 2009 UTC (14 years, 5 months ago) by greg
Changes since 2.60: +2 -1 lines
Diff to previous 2.60 , to selected 2.50
Important bug fix in -I calculation
Mon Dec 14 03:15:45 2009 UTC (14 years, 5 months ago) by greg
Changes since 2.59: +7 -9 lines
Diff to previous 2.59 , to selected 2.50
Minor cosmetic change
Sun Dec 13 19:13:04 2009 UTC (14 years, 5 months ago) by greg
Changes since 2.58: +72 -50 lines
Diff to previous 2.58 , to selected 2.50
Sat Dec 12 23:08:13 2009 UTC (14 years, 5 months ago) by greg
Changes since 2.57: +10 -7 lines
Diff to previous 2.57 , to selected 2.50
Bug fixes and performance improvements to rtrace -n option
Sat Dec 12 19:01:00 2009 UTC (14 years, 5 months ago) by greg
Changes since 2.56: +40 -77 lines
Diff to previous 2.56 , to selected 2.50
Fri Jul 17 06:21:29 2009 UTC (14 years, 10 months ago) by greg
Changes since 2.55: +15 -18 lines
Diff to previous 2.55 , to selected 2.50
Fixed -oo output of rtrace -I
Sat Nov 17 06:21:58 2007 UTC (16 years, 6 months ago) by greg
Changes since 2.54: +7 -3 lines
Diff to previous 2.54 , to selected 2.50
Increased limits to number of modifiers for trace and ambient include/exclude
Wed Apr 5 14:30:38 2006 UTC (18 years, 1 month ago) by greg
Diff to previous 2.53 , to selected 2.50
Changed default in rtrace to -u+ (random sampling)
Wed Apr 5 06:22:57 2006 UTC (18 years, 1 month ago) by greg
Changes since 2.52: +2 -2 lines
Diff to previous 2.52 , to selected 2.50
Made -u+ option truly random
Wed Feb 22 17:05:36 2006 UTC (18 years, 2 months ago) by greg
Diff to previous 2.51 , to selected 2.50
Increased trace modifier limit to 8192 in rtrace
Sun Feb 5 22:22:20 2006 UTC (18 years, 3 months ago) by greg
Changes since 2.50: +24 -3 lines
Diff to previous 2.50
Added -V option to rtcontrib and -oV option to rtrace to report contributions
Revision 2.50 - (view) (download) (annotate) - [selected]
Fri Oct 7 03:45:14 2005 UTC (18 years, 7 months ago) by greg
Changes since 2.49: +3 -2 lines
Diff to previous 2.49
Added final write error check
Mon Sep 19 11:30:10 2005 UTC (18 years, 8 months ago) by schorsch
Diff to previous 2.48 , to selected 2.50
Tue Jun 21 15:06:50 2005 UTC (18 years, 10 months ago) by greg
Changes since 2.47: +5 -5 lines
Diff to previous 2.47 , to selected 2.50
Fixed bugs in black glass transmission and source weight computation
Mon Jun 13 20:07:56 2005 UTC (18 years, 11 months ago) by greg
Changes since 2.46: +4 -2 lines
Diff to previous 2.46 , to selected 2.50
Fri Jun 10 20:44:00 2005 UTC (18 years, 11 months ago) by greg
Changes since 2.45: +4 -2 lines
Diff to previous 2.45 , to selected 2.50
Fixe in rtcontrib -M option
Fri Jun 10 16:49:42 2005 UTC (18 years, 11 months ago) by greg
Changes since 2.44: +7 -6 lines
Diff to previous 2.44 , to selected 2.50
Fixed bug where rtrace would quit after 2^31 primary rays
Sun Jun 5 19:52:01 2005 UTC (18 years, 11 months ago) by greg
Diff to previous 2.43 , to selected 2.50
Thu Jun 2 04:47:27 2005 UTC (18 years, 11 months ago) by greg
Changes since 2.42: +1 -3 lines
Diff to previous 2.42 , to selected 2.50
Thu May 26 06:55:22 2005 UTC (18 years, 11 months ago) by greg
Changes since 2.41: +9 -8 lines
Diff to previous 2.41 , to selected 2.50
Wed May 25 04:44:26 2005 UTC (18 years, 11 months ago) by greg
Changes since 2.40: +19 -14 lines
Diff to previous 2.40 , to selected 2.50
Changes since 2.39: +50 -7 lines
Diff to previous 2.39 , to selected 2.50
Thu Apr 14 18:04:12 2005 UTC (19 years, 1 month ago) by greg
Changes since 2.38: +23 -2 lines
Diff to previous 2.38 , to selected 2.50
Fri Nov 5 17:36:56 2004 UTC (19 years, 6 months ago) by greg
Diff to previous 2.37 , to selected 2.50
Changes since 2.36: +112 -76 lines
Diff to previous 2.36 , to selected 2.50
Sun Mar 28 16:31:14 2004 UTC (20 years, 1 month ago) by greg
Diff to previous 2.35 , to selected 2.50
Sat Oct 4 14:39:53 2003 UTC (20 years, 7 months ago) by greg
Diff to previous 2.34 , to selected 2.50
More adjustments and corrections to default parameters
Changes since 2.33: +7 -7 lines
Diff to previous 2.33 , to selected 2.50
Changes since 2.32: +3 -2 lines
Diff to previous 2.32 , to selected 2.50
Wed Jul 16 01:32:53 2003 UTC (20 years, 10 months ago) by greg
Changes since 2.31: +3 -1 lines
Diff to previous 2.31 , to selected 2.50
Minor compile fixes
Diff to previous 2.30 , to selected 2.50
Changes since 2.29: +4 -5 lines
Diff to previous 2.29 , to selected 2.50
Fri Apr 18 17:29:22 2003 UTC (21 years, 1 month ago) by greg
Changes since 2.28: +23 -11 lines
Diff to previous 2.28 , to selected 2.50
Added rtrace -oc option to output local (u,v) coordinates
Changes since 2.27: +1 -56 lines
Diff to previous 2.27 , to selected 2.50
Changes since 2.26: +107 -36 lines
Diff to previous 2.26 , to selected 2.50
Thu Oct 30 11:01:16 1997 UTC (26 years, 6 months ago) by gregl
Diff to previous 2.25 , to selected 2.50
modified code so zero record flushing happens unless -x > 0 && -y > 0
Fri Oct 17 10:14:37 1997 UTC (26 years, 7 months ago) by gregl
Changes since 2.24: +18 -7 lines
Diff to previous 2.24 , to selected 2.50
added -ld boolean option to rtrace for limiting ray distance
Wed Jul 9 11:25:49 1997 UTC (26 years, 10 months ago) by gregl
Changes since 2.23: +26 -13 lines
Diff to previous 2.23 , to selected 2.50
Tue Jan 14 19:54:27 1997 UTC (27 years, 4 months ago) by greg
Changes since 2.22: +4 -1 lines
Diff to previous 2.22 , to selected 2.50
fixed bug in printing void materials.
Wed Apr 17 14:02:09 1996 UTC (28 years, 1 month ago) by greg
Changes since 2.21: +1 -1 lines
Diff to previous 2.21 , to selected 2.50
Wed Feb 14 15:18:12 1996 UTC (28 years, 3 months ago) by greg
Changes since 2.20: +1 -0 lines
Diff to previous 2.20 , to selected 2.50
Fri Dec 8 18:49:12 1995 UTC (28 years, 5 months ago) by greg
Changes since 2.19: +6 -1 lines
Diff to previous 2.19 , to selected 2.50
Mon Aug 21 10:29:20 1995 UTC (28 years, 9 months ago) by greg
Changes since 2.18: +4 -4 lines
Diff to previous 2.18 , to selected 2.50
increase default parameters for more accurate calculations
Wed Dec 21 09:52:00 1994 UTC (29 years, 5 months ago) by greg
Changes since 2.17: +2 -0 lines
Diff to previous 2.17 , to selected 2.50
added -bv option for back face visibility (normally on)
Tue Dec 20 20:18:34 1994 UTC (29 years, 5 months ago) by greg
Changes since 2.16: +2 -1 lines
Diff to previous 2.16 , to selected 2.50
Wed Jul 14 10:38:49 1993 UTC (30 years, 10 months ago) by greg
Changes since 2.15: +22 -20 lines
Diff to previous 2.15 , to selected 2.50
consistency improvements related to -I option
Fri Jun 18 10:14:42 1993 UTC (30 years, 11 months ago) by greg
Changes since 2.14: +31 -0 lines
Diff to previous 2.14 , to selected 2.50
added -ti, -te, -tI and -tE options to rtrace for exclude/include traces
Tue May 4 13:26:52 1993 UTC (31 years ago) by greg
Changes since 2.13: +6 -3 lines
Diff to previous 2.13 , to selected 2.50
made sure that -I option completely overrides -o option
Mon Mar 8 12:37:33 1993 UTC (31 years, 2 months ago) by greg
Diff to previous 2.12 , to selected 2.50
Fri Jan 22 09:51:20 1993 UTC (31 years, 4 months ago) by greg
Changes since 2.11: +8 -3 lines
Diff to previous 2.11 , to selected 2.50
bug fixes and improvements on stdio flushing
Wed Jan 20 15:19:51 1993 UTC (31 years, 4 months ago) by greg
Changes since 2.10: +4 -0 lines
Diff to previous 2.10 , to selected 2.50
Thu Nov 19 20:26:10 1992 UTC (31 years, 6 months ago) by greg
Diff to previous 2.9 , to selected 2.50
changed -di to ! -dv
Fri Nov 6 16:48:32 1992 UTC (31 years, 6 months ago) by greg
Changes since 2.8: +26 -3 lines
Diff to previous 2.8 , to selected 2.50
added -oN for unperturbed surface normal and made -on perturbed
Thu Oct 15 21:13:21 1992 UTC (31 years, 7 months ago) by greg
Changes since 2.7: +4 -0 lines
Diff to previous 2.7 , to selected 2.50
added setmode(fd,O_BINARY) where needed for MSDOS
Tue Jul 21 10:36:37 1992 UTC (31 years, 10 months ago) by greg
Changes since 2.6: +0 -2 lines
Diff to previous 2.6 , to selected 2.50
fixed bug introduced in last change with -h- option of rtrace
Fri Jul 10 14:56:24 1992 UTC (31 years, 10 months ago) by greg
Changes since 2.5: +38 -1 lines
Diff to previous 2.5 , to selected 2.50
added ability to print COLRFMT output of values
Thu Mar 12 09:46:19 1992 UTC (32 years, 2 months ago) by greg
Changes since 2.4: +17 -4 lines
Diff to previous 2.4 , to selected 2.50
added -oL output option for single-ray length
Thu Jan 16 12:05:20 1992 UTC (32 years, 4 months ago) by greg
Diff to previous 2.3 , to selected 2.50
changed default values and handling of specthresh
Tue Jan 14 16:16:07 1992 UTC (32 years, 4 months ago) by greg
Changes since 2.2: +3 -0 lines
Diff to previous 2.2 , to selected 2.50
added -sj and -st options and changed old -s options to -p
Thu Dec 19 14:54:53 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 2.1 , to selected 2.50
removed atof() declarations for NeXT
Tue Nov 12 17:09:39 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.20 , to selected 2.50
Mon Oct 21 12:58:10 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.19: +2 -1 lines
Diff to previous 1.19 , to selected 2.50
Mon Jul 22 13:09:58 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.18: +10 -2 lines
Diff to previous 1.18 , to selected 2.50
got rid of scanf() call
Thu Jul 18 14:43:03 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.17: +1 -0 lines
Diff to previous 1.17 , to selected 2.50
Tue Jun 25 14:06:18 1991 UTC (32 years, 10 months ago) by greg
Diff to previous 1.16 , to selected 2.50
increased defaults for -dp parameter
Mon Jun 24 16:16:54 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.15: +1 -0 lines
Diff to previous 1.15 , to selected 2.50
Wed Jun 19 16:36:48 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.14: +1 -0 lines
Diff to previous 1.14 , to selected 2.50
added virtual sources
Tue May 21 17:41:23 1991 UTC (33 years ago) by greg
Changes since 1.13: +5 -0 lines
Diff to previous 1.13 , to selected 2.50
Wed May 1 11:16:58 1991 UTC (33 years ago) by greg
Changes since 1.12: +9 -29 lines
Diff to previous 1.12 , to selected 2.50
Thu Mar 28 10:16:35 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.11: +25 -6 lines
Diff to previous 1.11 , to selected 2.50
added -oI option for irradiance after intersection
Sat Aug 18 10:34:47 1990 UTC (33 years, 9 months ago) by greg
Changes since 1.10: +11 -1 lines
Diff to previous 1.10 , to selected 2.50
added conditional ray casting to rtrace for efficiency
Tue Jun 26 09:00:15 1990 UTC (33 years, 10 months ago) by greg
Diff to previous 1.9 , to selected 2.50
Tue Mar 27 11:40:10 1990 UTC (34 years, 1 month ago) by greg
Changes since 1.8: +1 -4 lines
Diff to previous 1.8 , to selected 2.50
Fri Jan 19 00:00:26 1990 UTC (34 years, 4 months ago) by greg
Diff to previous 1.7 , to selected 2.50
Thu Jan 4 11:16:05 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.6: +6 -3 lines
Diff to previous 1.6 , to selected 2.50
added flushing for zero input direction vector
Mon Jul 10 15:21:28 1989 UTC (34 years, 10 months ago) by greg
Diff to previous 1.5 , to selected 2.50
Reduced default ambient resolution
Tue Jun 13 10:57:43 1989 UTC (34 years, 11 months ago) by greg
Diff to previous 1.4 , to selected 2.50
Wed Jun 7 21:00:59 1989 UTC (34 years, 11 months ago) by greg
Diff to previous 1.3 , to selected 2.50
Wed Jun 7 08:35:23 1989 UTC (34 years, 11 months ago) by greg
Diff to previous 1.2 , to selected 2.50
Glow type changed
Spot type eliminated
Wed Mar 15 13:47:57 1989 UTC (35 years, 2 months ago) by greg
Diff to previous 1.1 , to selected 2.50
eliminated unused variable
Thu Feb 2 10:41:37 1989 UTC (35 years, 3 months ago) by greg
Diff to selected 2.50
