fix(mkillum, rcontrib, rtrace, ranimove, rsensor): stall under macOS 10.15 due to broken flockfile() implementation -- workaround is better, anyway
Backed out last change, which actually made things worse
Changed so batch optimization only happens if no flush interval
Optimize rtrace for throughput, especially with ambient cache
Removed superfluous declaration
Fixes and improvements from last change, making ray-casting faster
Made start-up much faster when only doing ray-casting
Added better check to see if input is from a pipe or not
Added NCOMP= to header and better checking of -o* options
Turn off multiprocessing with -oT* and -ot* options
Added input ray queue for more efficient batch processing
Added precautionary testing when checking for FHUGE
Undid last change, which introduced a bug!
Minor simplification to last change - should not affect results
Slightly improved flushing logic
Took out redundant setting
Avoid bug where -onN and -oNn output different information
Keep track of ray flips so rayreorient() can put it back as it was
More warnings and correction because -oW and -oV are useless options
Made -f?c RGBE output compatible with any of 'vVWrx' options and added warning
Check that number of processes does not exceed flush interval
Removed unnecessary clear + made multiple zero directions -> single flush
Made rtrace a little more robust when reporting bogus ray values
For consistency, reflected ray distance should be inf for diffuse surface
Added missing initialization for rmt and rxt
Made rtrace a little more efficient under Windows if -n > 1
Improved error message
Switched to more efficient i/o for small vectors
Made reading of vectors more consistent with FVFORMAT macro
Added check for blocked shadow rays
Improved output efficiency by reducing number of calls to fwrite()
Eliminated flushing with -x >1 if -y also set to improve -n performance
Bug fix for zero-direction rays with multiprocessing
Precautionary change to rayirrad()
Important bug fix in -I calculation
Minor cosmetic change
Bug fixes and performance improvements to rtrace -n option
Fixed -oo output of rtrace -I
Increased limits to number of modifiers for trace and ambient include/exclude
Changed default in rtrace to -u+ (random sampling)
Made -u+ option truly random
Increased trace modifier limit to 8192 in rtrace
Added -V option to rtcontrib and -oV option to rtrace to report contributions
Added final write error check
Fixed bugs in black glass transmission and source weight computation
Fixe in rtcontrib -M option
Fixed bug where rtrace would quit after 2^31 primary rays
More adjustments and corrections to default parameters
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Minor compile fixes
Added rtrace -oc option to output local (u,v) coordinates
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
modified code so zero record flushing happens unless -x > 0 && -y > 0
added -ld boolean option to rtrace for limiting ray distance
fixed bug in printing void materials.
increase default parameters for more accurate calculations
added -bv option for back face visibility (normally on)
consistency improvements related to -I option
added -ti, -te, -tI and -tE options to rtrace for exclude/include traces
made sure that -I option completely overrides -o option
bug fixes and improvements on stdio flushing
changed -di to ! -dv
added -oN for unperturbed surface normal and made -on perturbed
added setmode(fd,O_BINARY) where needed for MSDOS
fixed bug introduced in last change with -h- option of rtrace
added ability to print COLRFMT output of values
added -oL output option for single-ray length
changed default values and handling of specthresh
added -sj and -st options and changed old -s options to -p
removed atof() declarations for NeXT
got rid of scanf() call
increased defaults for -dp parameter
added virtual sources
added -oI option for irradiance after intersection
added conditional ray casting to rtrace for efficiency
added flushing for zero input direction vector
Reduced default ambient resolution
Efficient approximation to direct component with many sources Glow type changed Spot type eliminated
eliminated unused variable
