root/radiance/ray/src/rt/rtrace.c
Revision: 1.4
Committed: Wed Jun 7 21:00:59 1989 UTC (35 years ago) by greg
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rtrace.c - program and variables for individual ray tracing.
9 *
10 * 6/11/86
11 */
12
13 /*
14 * Input is in the form:
15 *
16 * xorg yorg zorg xdir ydir zdir
17 *
18 * The direction need not be normalized. Output is flexible.
19 * All values default to ascii representation of real
20 * numbers. Binary representations can be selected
21 * with '-ff' for float or '-fd' for double. By default,
22 * radiance is computed. The '-i' option indicates that
23 * irradiance values are desired.
24 */
25
26 #include "ray.h"
27
28 #include "otypes.h"
29
30 int inform = 'a'; /* input format */
31 int outform = 'a'; /* output format */
32 char *outvals = "v"; /* output specification */
33
34 int hresolu = 0; /* horizontal (scan) size */
35 int vresolu = 0; /* vertical resolution */
36
37 double dstrsrc = 0.0; /* square source distribution */
38 double shadthresh = .05; /* shadow threshold */
39
40 int maxdepth = 6; /* maximum recursion depth */
41 double minweight = 4e-3; /* minimum ray weight */
42
43 COLOR ambval = BLKCOLOR; /* ambient value */
44 double ambacc = 0.2; /* ambient accuracy */
45 int ambres = 128; /* ambient resolution */
46 int ambdiv = 128; /* ambient divisions */
47 int ambssamp = 0; /* ambient super-samples */
48 int ambounce = 0; /* ambient bounces */
49 char *amblist[128]; /* ambient include/exclude list */
50 int ambincl = -1; /* include == 1, exclude == 0 */
51
52 static RAY thisray; /* for our convenience */
53
54 extern int oputo(), oputd(), oputv(), oputl(),
55 oputp(), oputn(), oputs(), oputw(), oputm();
56
57 static int (*ray_out[10])(), (*every_out[10])();
58
59 extern int puta(), putf(), putd();
60
61 static int (*putreal)();
62
63
64 quit(code) /* quit program */
65 int code;
66 {
67 exit(code);
68 }
69
70
71 rtrace(fname) /* trace rays from file */
72 char *fname;
73 {
74 long vcount = hresolu>1 ? hresolu*vresolu : vresolu;
75 long nextflush = hresolu;
76 FILE *fp;
77 FVECT orig, direc;
78 /* set up input */
79 if (fname == NULL)
80 fp = stdin;
81 else if ((fp = fopen(fname, "r")) == NULL) {
82 sprintf(errmsg, "cannot open input file \"%s\"", fname);
83 error(SYSTEM, errmsg);
84 }
85 /* set up output */
86 setoutput(outvals);
87 switch (outform) {
88 case 'a': putreal = puta; break;
89 case 'f': putreal = putf; break;
90 case 'd': putreal = putd; break;
91 }
92 /* process file */
93 while (getvec(orig, inform, fp) == 0 &&
94 getvec(direc, inform, fp) == 0) {
95
96 if (normalize(direc) == 0.0)
97 error(USER, "zero direction vector");
98 /* compute and print */
99 if (outvals[0] == 'i')
100 irrad(orig, direc);
101 else
102 radiance(orig, direc);
103 /* flush if requested */
104 if (--nextflush == 0) {
105 fflush(stdout);
106 nextflush = hresolu;
107 }
108 if (ferror(stdout))
109 error(SYSTEM, "write error");
110 if (--vcount == 0) /* check for end */
111 break;
112 }
113 if (vcount > 0)
114 error(USER, "read error");
115 fclose(fp);
116 }
117
118
119 setoutput(vs) /* set up output tables */
120 register char *vs;
121 {
122 extern int ourtrace(), (*trace)();
123 register int (**table)() = ray_out;
124
125 while (*vs)
126 switch (*vs++) {
127 case 't': /* trace */
128 *table = NULL;
129 table = every_out;
130 trace = ourtrace;
131 break;
132 case 'o': /* origin */
133 *table++ = oputo;
134 break;
135 case 'd': /* direction */
136 *table++ = oputd;
137 break;
138 case 'v': /* value */
139 *table++ = oputv;
140 break;
141 case 'l': /* length */
142 *table++ = oputl;
143 break;
144 case 'p': /* point */
145 *table++ = oputp;
146 break;
147 case 'n': /* normal */
148 *table++ = oputn;
149 break;
150 case 's': /* surface */
151 *table++ = oputs;
152 break;
153 case 'w': /* weight */
154 *table++ = oputw;
155 break;
156 case 'm': /* modifier */
157 *table++ = oputm;
158 break;
159 }
160 *table = NULL;
161 }
162
163
164 radiance(org, dir) /* compute radiance value */
165 FVECT org, dir;
166 {
167 register int (**tp)();
168
169 VCOPY(thisray.rorg, org);
170 VCOPY(thisray.rdir, dir);
171 rayorigin(&thisray, NULL, PRIMARY, 1.0);
172 rayvalue(&thisray);
173
174 if (ray_out[0] == NULL)
175 return;
176 for (tp = ray_out; *tp != NULL; tp++)
177 (**tp)(&thisray);
178 if (outform == 'a')
179 putchar('\n');
180 }
181
182
183 irrad(org, dir) /* compute irradiance value */
184 FVECT org, dir;
185 {
186 static double Lambfa[5] = {PI, PI, PI, 0.0, 0.0};
187 static OBJREC Lamb = {
188 OVOID, MAT_PLASTIC, "Lambertian",
189 {0, 5, NULL, Lambfa}, NULL, -1,
190 };
191 register int i;
192
193 for (i = 0; i < 3; i++) {
194 thisray.rorg[i] = org[i] + dir[i];
195 thisray.rdir[i] = -dir[i];
196 }
197 rayorigin(&thisray, NULL, PRIMARY, 1.0);
198 /* pretend we hit surface */
199 thisray.rot = 1.0;
200 thisray.rod = 1.0;
201 VCOPY(thisray.ron, dir);
202 for (i = 0; i < 3; i++) /* fudge factor */
203 thisray.rop[i] = org[i] + 1e-4*dir[i];
204 /* compute and print */
205 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
206 oputv(&thisray);
207 if (outform == 'a')
208 putchar('\n');
209 }
210
211
212 getvec(vec, fmt, fp) /* get a vector from fp */
213 register FVECT vec;
214 int fmt;
215 FILE *fp;
216 {
217 static float vf[3];
218
219 switch (fmt) {
220 case 'a': /* ascii */
221 if (fscanf(fp, "%lf %lf %lf", vec, vec+1, vec+2) != 3)
222 return(-1);
223 break;
224 case 'f': /* binary float */
225 if (fread(vf, sizeof(float), 3, fp) != 3)
226 return(-1);
227 vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2];
228 break;
229 case 'd': /* binary double */
230 if (fread(vec, sizeof(double), 3, fp) != 3)
231 return(-1);
232 break;
233 }
234 return(0);
235 }
236
237
238 static
239 ourtrace(r) /* print ray values */
240 RAY *r;
241 {
242 register int (**tp)();
243
244 if (every_out[0] == NULL)
245 return;
246 tabin(r);
247 for (tp = every_out; *tp != NULL; tp++)
248 (**tp)(r);
249 putchar('\n');
250 }
251
252
253 static
254 tabin(r) /* tab in appropriate amount */
255 RAY *r;
256 {
257 register RAY *rp;
258
259 for (rp = r->parent; rp != NULL; rp = rp->parent)
260 putchar('\t');
261 }
262
263
264 static
265 oputo(r) /* print origin */
266 register RAY *r;
267 {
268 (*putreal)(r->rorg[0]);
269 (*putreal)(r->rorg[1]);
270 (*putreal)(r->rorg[2]);
271 }
272
273
274 static
275 oputd(r) /* print direction */
276 register RAY *r;
277 {
278 (*putreal)(r->rdir[0]);
279 (*putreal)(r->rdir[1]);
280 (*putreal)(r->rdir[2]);
281 }
282
283
284 static
285 oputv(r) /* print value */
286 register RAY *r;
287 {
288 (*putreal)(colval(r->rcol,RED));
289 (*putreal)(colval(r->rcol,GRN));
290 (*putreal)(colval(r->rcol,BLU));
291 }
292
293
294 static
295 oputl(r) /* print length */
296 register RAY *r;
297 {
298 if (r->rot < FHUGE)
299 (*putreal)(r->rot);
300 else
301 (*putreal)(0.0);
302 }
303
304
305 static
306 oputp(r) /* print point */
307 register RAY *r;
308 {
309 if (r->rot < FHUGE) {
310 (*putreal)(r->rop[0]);
311 (*putreal)(r->rop[1]);
312 (*putreal)(r->rop[2]);
313 } else {
314 (*putreal)(0.0);
315 (*putreal)(0.0);
316 (*putreal)(0.0);
317 }
318 }
319
320
321 static
322 oputn(r) /* print normal */
323 register RAY *r;
324 {
325 if (r->rot < FHUGE) {
326 (*putreal)(r->ron[0]);
327 (*putreal)(r->ron[1]);
328 (*putreal)(r->ron[2]);
329 } else {
330 (*putreal)(0.0);
331 (*putreal)(0.0);
332 (*putreal)(0.0);
333 }
334 }
335
336
337 static
338 oputs(r) /* print name */
339 register RAY *r;
340 {
341 if (r->ro != NULL)
342 fputs(r->ro->oname, stdout);
343 else
344 putchar('*');
345 putchar('\t');
346 }
347
348
349 static
350 oputw(r) /* print weight */
351 register RAY *r;
352 {
353 (*putreal)(r->rweight);
354 }
355
356
357 static
358 oputm(r) /* print modifier */
359 register RAY *r;
360 {
361 if (r->ro != NULL)
362 fputs(objptr(r->ro->omod)->oname, stdout);
363 else
364 putchar('*');
365 putchar('\t');
366 }
367
368
369 static
370 puta(v) /* print ascii value */
371 double v;
372 {
373 printf("%e\t", v);
374 }
375
376
377 static
378 putd(v) /* print binary double */
379 double v;
380 {
381 fwrite(&v, sizeof(v), 1, stdout);
382 }
383
384
385 static
386 putf(v) /* print binary float */
387 double v;
388 {
389 float f = v;
390
391 fwrite(&f, sizeof(f), 1, stdout);
392 }
