root/radiance/ray/src/rt/rtrace.c
Revision: 2.56
Committed: Fri Jul 17 06:21:29 2009 UTC (15 years, 11 months ago) by greg
Changes since 2.55: +15 -18 lines
Fixed -oo output of rtrace -I
2 static const char RCSid[] = "$Id: rtrace.c,v 2.55 2007/11/17 06:21:58 greg Exp $";
5 * rtrace.c - program and variables for individual ray tracing.
6 */
7
8 #include "copyright.h"
9
10 /*
11 * Input is in the form:
12 *
13 * xorg yorg zorg xdir ydir zdir
14 *
15 * The direction need not be normalized. Output is flexible.
16 * If the direction vector is (0,0,0), then the output is flushed.
17 * All values default to ascii representation of real
18 * numbers. Binary representations can be selected
19 * with '-ff' for float or '-fd' for double. By default,
20 * radiance is computed. The '-i' or '-I' options indicate that
21 * irradiance values are desired.
22 */
23
24 #include <time.h>
25
26 #include "platform.h"
27 #include "ray.h"
28 #include "ambient.h"
29 #include "source.h"
30 #include "otypes.h"
31 #include "resolu.h"
32 #include "random.h"
33
34 CUBE thescene; /* our scene */
35 OBJECT nsceneobjs; /* number of objects in our scene */
36
37 int dimlist[MAXDIM]; /* sampling dimensions */
38 int ndims = 0; /* number of sampling dimensions */
39 int samplendx = 0; /* index for this sample */
40
41 int imm_irrad = 0; /* compute immediate irradiance? */
42 int lim_dist = 0; /* limit distance? */
43
44 int inform = 'a'; /* input format */
45 int outform = 'a'; /* output format */
46 char *outvals = "v"; /* output specification */
47
48 int do_irrad = 0; /* compute irradiance? */
49
50 int rand_samp = 1; /* pure Monte Carlo sampling? */
51
52 void (*trace)() = NULL; /* trace call */
53
54 #ifndef MAXMODLIST
55 #define MAXMODLIST 1024 /* maximum modifiers we'll track */
56 #endif
57
58 char *tralist[MAXMODLIST]; /* list of modifers to trace (or no) */
59 int traincl = -1; /* include == 1, exclude == 0 */
60 #ifndef MAXTSET
61 #define MAXTSET 8191 /* maximum number in trace set */
62 #endif
63 OBJECT traset[MAXTSET+1]={0}; /* trace include/exclude set */
64
65 int hresolu = 0; /* horizontal (scan) size */
66 int vresolu = 0; /* vertical resolution */
67
68 double dstrsrc = 0.0; /* square source distribution */
69 double shadthresh = .03; /* shadow threshold */
70 double shadcert = .75; /* shadow certainty */
71 int directrelay = 2; /* number of source relays */
72 int vspretest = 512; /* virtual source pretest density */
73 int directvis = 1; /* sources visible? */
74 double srcsizerat = .2; /* maximum ratio source size/dist. */
75
76 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
77 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
78 double seccg = 0.; /* global scattering eccentricity */
79 double ssampdist = 0.; /* scatter sampling distance */
80
81 double specthresh = .15; /* specular sampling threshold */
82 double specjitter = 1.; /* specular sampling jitter */
83
84 int backvis = 1; /* back face visibility */
85
86 int maxdepth = -10; /* maximum recursion depth */
87 double minweight = 2e-3; /* minimum ray weight */
88
89 char *ambfile = NULL; /* ambient file name */
90 COLOR ambval = BLKCOLOR; /* ambient value */
91 int ambvwt = 0; /* initial weight for ambient value */
92 double ambacc = 0.15; /* ambient accuracy */
93 int ambres = 256; /* ambient resolution */
94 int ambdiv = 1024; /* ambient divisions */
95 int ambssamp = 512; /* ambient super-samples */
96 int ambounce = 0; /* ambient bounces */
97 char *amblist[AMBLLEN]; /* ambient include/exclude list */
98 int ambincl = -1; /* include == 1, exclude == 0 */
99
100 static int castonly = 0;
101
102 static RAY thisray; /* for our convenience */
103
104 typedef void putf_t(double v);
105 static putf_t puta, putd, putf;
106
107 typedef void oputf_t(RAY *r);
108 static oputf_t oputo, oputd, oputv, oputV, oputl, oputL, oputc, oputp,
109 oputn, oputN, oputs, oputw, oputW, oputm, oputM, oputtilde;
110
111 static void setoutput(char *vs);
112 static void tranotify(OBJECT obj);
113 static void bogusray(void);
114 static void rad(FVECT org, FVECT dir, double dmax);
115 static void irrad(FVECT org, FVECT dir);
116 static void printvals(RAY *r);
117 static int getvec(FVECT vec, int fmt, FILE *fp);
118 static void tabin(RAY *r);
119 static void ourtrace(RAY *r);
120
121 static oputf_t *ray_out[16], *every_out[16];
122 static putf_t *putreal;
123
124 void (*addobjnotify[])() = {ambnotify, tranotify, NULL};
125
126
127 void
128 quit( /* quit program */
129 int code
130 )
131 {
132 #ifndef NON_POSIX /* XXX we don't clean up elsewhere? */
133 headclean(); /* delete header file */
134 pfclean(); /* clean up persist files */
135 #endif
136 exit(code);
137 }
138
139
140 extern char *
141 formstr( /* return format identifier */
142 int f
143 )
144 {
145 switch (f) {
146 case 'a': return("ascii");
147 case 'f': return("float");
148 case 'd': return("double");
149 case 'c': return(COLRFMT);
150 }
151 return("unknown");
152 }
153
154
155 extern void
156 rtrace( /* trace rays from file */
157 char *fname
158 )
159 {
160 unsigned long vcount = (hresolu > 1) ? (unsigned long)hresolu*vresolu
161 : vresolu;
162 long nextflush = hresolu;
163 FILE *fp;
164 double d;
165 FVECT orig, direc;
166 /* set up input */
167 if (fname == NULL)
168 fp = stdin;
169 else if ((fp = fopen(fname, "r")) == NULL) {
170 sprintf(errmsg, "cannot open input file \"%s\"", fname);
171 error(SYSTEM, errmsg);
172 }
173 if (inform != 'a')
174 SET_FILE_BINARY(fp);
175 /* set up output */
176 setoutput(outvals);
177 switch (outform) {
178 case 'a': putreal = puta; break;
179 case 'f': putreal = putf; break;
180 case 'd': putreal = putd; break;
181 case 'c':
182 if (strcmp(outvals, "v"))
183 error(USER, "color format with value output only");
184 break;
185 default:
186 error(CONSISTENCY, "botched output format");
187 }
188 if (hresolu > 0) {
189 if (vresolu > 0)
190 fprtresolu(hresolu, vresolu, stdout);
191 fflush(stdout);
192 }
193 /* process file */
194 while (getvec(orig, inform, fp) == 0 &&
195 getvec(direc, inform, fp) == 0) {
196
197 d = normalize(direc);
198 if (d == 0.0) { /* zero ==> flush */
199 bogusray();
200 if (--nextflush <= 0 || !vcount) {
201 fflush(stdout);
202 nextflush = hresolu;
203 }
204 } else {
205 samplendx++;
206 /* compute and print */
207 if (imm_irrad)
208 irrad(orig, direc);
209 else
210 rad(orig, direc, lim_dist ? d : 0.0);
211 /* flush if time */
212 if (!--nextflush) {
213 fflush(stdout);
214 nextflush = hresolu;
215 }
216 }
217 if (ferror(stdout))
218 error(SYSTEM, "write error");
219 if (vcount && !--vcount) /* check for end */
220 break;
221 }
222 if (fflush(stdout) < 0)
223 error(SYSTEM, "write error");
224 if (vcount)
225 error(USER, "unexpected EOF on input");
226 if (fname != NULL)
227 fclose(fp);
228 }
229
230
231 static void
232 trace_sources(void) /* trace rays to light sources, also */
233 {
234 int sn;
235
236 for (sn = 0; sn < nsources; sn++)
237 source[sn].sflags |= SFOLLOW;
238 }
239
240
241 static void
242 setoutput( /* set up output tables */
243 char *vs
244 )
245 {
246 oputf_t **table = ray_out;
247
248 castonly = 1;
249 while (*vs)
250 switch (*vs++) {
251 case 'T': /* trace sources */
252 if (!*vs) break;
253 trace_sources();
254 /* fall through */
255 case 't': /* trace */
256 if (!*vs) break;
257 *table = NULL;
258 table = every_out;
259 trace = ourtrace;
260 castonly = 0;
261 break;
262 case 'o': /* origin */
263 *table++ = oputo;
264 break;
265 case 'd': /* direction */
266 *table++ = oputd;
267 break;
268 case 'v': /* value */
269 *table++ = oputv;
270 castonly = 0;
271 break;
272 case 'V': /* contribution */
273 *table++ = oputV;
274 if (ambounce > 0 && (ambacc > FTINY || ambssamp > 0))
275 error(WARNING,
276 "-otV accuracy depends on -aa 0 -as 0");
277 break;
278 case 'l': /* effective distance */
279 *table++ = oputl;
280 castonly = 0;
281 break;
282 case 'c': /* local coordinates */
283 *table++ = oputc;
284 break;
285 case 'L': /* single ray length */
286 *table++ = oputL;
287 break;
288 case 'p': /* point */
289 *table++ = oputp;
290 break;
291 case 'n': /* perturbed normal */
292 *table++ = oputn;
293 castonly = 0;
294 break;
295 case 'N': /* unperturbed normal */
296 *table++ = oputN;
297 break;
298 case 's': /* surface */
299 *table++ = oputs;
300 break;
301 case 'w': /* weight */
302 *table++ = oputw;
303 break;
304 case 'W': /* coefficient */
305 *table++ = oputW;
306 if (ambounce > 0 && (ambacc > FTINY || ambssamp > 0))
307 error(WARNING,
308 "-otW accuracy depends on -aa 0 -as 0");
309 break;
310 case 'm': /* modifier */
311 *table++ = oputm;
312 break;
313 case 'M': /* material */
314 *table++ = oputM;
315 break;
316 case '~': /* tilde */
317 *table++ = oputtilde;
318 break;
319 }
320 *table = NULL;
321 }
322
323
324 static void
325 bogusray(void) /* print out empty record */
326 {
327 thisray.rorg[0] = thisray.rorg[1] = thisray.rorg[2] =
328 thisray.rdir[0] = thisray.rdir[1] = thisray.rdir[2] = 0.0;
329 thisray.rmax = 0.0;
330 rayorigin(&thisray, PRIMARY, NULL, NULL);
331 printvals(&thisray);
332 }
333
334
335 static void
336 rad( /* compute and print ray value(s) */
337 FVECT org,
338 FVECT dir,
339 double dmax
340 )
341 {
342 VCOPY(thisray.rorg, org);
343 VCOPY(thisray.rdir, dir);
344 thisray.rmax = dmax;
345 rayorigin(&thisray, PRIMARY, NULL, NULL);
346 if (castonly) {
347 if (!localhit(&thisray, &thescene)) {
348 if (thisray.ro == &Aftplane) { /* clipped */
349 thisray.ro = NULL;
350 thisray.rot = FHUGE;
351 } else
352 sourcehit(&thisray);
353 }
354 } else
355 rayvalue(&thisray);
356 printvals(&thisray);
357 }
358
359
360 static void
361 irrad( /* compute immediate irradiance value */
362 FVECT org,
363 FVECT dir
364 )
365 {
366 VSUM(thisray.rorg, org, dir, 1.1e-4);
367 thisray.rdir[0] = -dir[0];
368 thisray.rdir[1] = -dir[1];
369 thisray.rdir[2] = -dir[2];
370 thisray.rmax = 0.0;
371 rayorigin(&thisray, PRIMARY, NULL, NULL);
372 /* pretend we hit surface */
373 thisray.rot = 1e-5;
374 thisray.rod = 1.0;
375 VCOPY(thisray.ron, dir);
376 VSUM(thisray.rop, org, dir, 1e-4);
377 /* compute and print */
378 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
379 printvals(&thisray);
380 }
381
382
383 static void
384 printvals( /* print requested ray values */
385 RAY *r
386 )
387 {
388 oputf_t **tp;
389
390 if (ray_out[0] == NULL)
391 return;
392 for (tp = ray_out; *tp != NULL; tp++)
393 (**tp)(r);
394 if (outform == 'a')
395 putchar('\n');
396 }
397
398
399 static int
400 getvec( /* get a vector from fp */
401 FVECT vec,
402 int fmt,
403 FILE *fp
404 )
405 {
406 static float vf[3];
407 static double vd[3];
408 char buf[32];
409 int i;
410
411 switch (fmt) {
412 case 'a': /* ascii */
413 for (i = 0; i < 3; i++) {
414 if (fgetword(buf, sizeof(buf), fp) == NULL ||
415 !isflt(buf))
416 return(-1);
417 vec[i] = atof(buf);
418 }
419 break;
420 case 'f': /* binary float */
421 if (fread((char *)vf, sizeof(float), 3, fp) != 3)
422 return(-1);
423 vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2];
424 break;
425 case 'd': /* binary double */
426 if (fread((char *)vd, sizeof(double), 3, fp) != 3)
427 return(-1);
428 vec[0] = vd[0]; vec[1] = vd[1]; vec[2] = vd[2];
429 break;
430 default:
431 error(CONSISTENCY, "botched input format");
432 }
433 return(0);
434 }
435
436
437 static void
438 tranotify( /* record new modifier */
439 OBJECT obj
440 )
441 {
442 static int hitlimit = 0;
443 OBJREC *o = objptr(obj);
444 char **tralp;
445
446 if (obj == OVOID) { /* starting over */
447 traset[0] = 0;
448 hitlimit = 0;
449 return;
450 }
451 if (hitlimit || !ismodifier(o->otype))
452 return;
453 for (tralp = tralist; *tralp != NULL; tralp++)
454 if (!strcmp(o->oname, *tralp)) {
455 if (traset[0] >= MAXTSET) {
456 error(WARNING, "too many modifiers in trace list");
457 hitlimit++;
458 return; /* should this be fatal? */
459 }
460 insertelem(traset, obj);
461 return;
462 }
463 }
464
465
466 static void
467 ourtrace( /* print ray values */
468 RAY *r
469 )
470 {
471 oputf_t **tp;
472
473 if (every_out[0] == NULL)
474 return;
475 if (r->ro == NULL) {
476 if (traincl == 1)
477 return;
478 } else if (traincl != -1 && traincl != inset(traset, r->ro->omod))
479 return;
480 tabin(r);
481 for (tp = every_out; *tp != NULL; tp++)
482 (**tp)(r);
483 if (outform == 'a')
484 putchar('\n');
485 }
486
487
488 static void
489 tabin( /* tab in appropriate amount */
490 RAY *r
491 )
492 {
493 const RAY *rp;
494
495 for (rp = r->parent; rp != NULL; rp = rp->parent)
496 putchar('\t');
497 }
498
499
500 static void
501 oputo( /* print origin */
502 RAY *r
503 )
504 {
505 (*putreal)(r->rorg[0]);
506 (*putreal)(r->rorg[1]);
507 (*putreal)(r->rorg[2]);
508 }
509
510
511 static void
512 oputd( /* print direction */
513 RAY *r
514 )
515 {
516 (*putreal)(r->rdir[0]);
517 (*putreal)(r->rdir[1]);
518 (*putreal)(r->rdir[2]);
519 }
520
521
522 static void
523 oputv( /* print value */
524 RAY *r
525 )
526 {
527 if (outform == 'c') {
528 COLR cout;
529 setcolr(cout, colval(r->rcol,RED),
530 colval(r->rcol,GRN),
531 colval(r->rcol,BLU));
532 fwrite((char *)cout, sizeof(cout), 1, stdout);
533 return;
534 }
535 (*putreal)(colval(r->rcol,RED));
536 (*putreal)(colval(r->rcol,GRN));
537 (*putreal)(colval(r->rcol,BLU));
538 }
539
540
541 static void
542 oputV( /* print value contribution */
543 RAY *r
544 )
545 {
546 double contr[3];
547
548 raycontrib(contr, r, PRIMARY);
549 multcolor(contr, r->rcol);
550 (*putreal)(contr[RED]);
551 (*putreal)(contr[GRN]);
552 (*putreal)(contr[BLU]);
553 }
554
555
556 static void
557 oputl( /* print effective distance */
558 RAY *r
559 )
560 {
561 (*putreal)(r->rt);
562 }
563
564
565 static void
566 oputL( /* print single ray length */
567 RAY *r
568 )
569 {
570 (*putreal)(r->rot);
571 }
572
573
574 static void
575 oputc( /* print local coordinates */
576 RAY *r
577 )
578 {
579 (*putreal)(r->uv[0]);
580 (*putreal)(r->uv[1]);
581 }
582
583
584 static void
585 oputp( /* print point */
586 RAY *r
587 )
588 {
589 if (r->rot < FHUGE) {
590 (*putreal)(r->rop[0]);
591 (*putreal)(r->rop[1]);
592 (*putreal)(r->rop[2]);
593 } else {
594 (*putreal)(0.0);
595 (*putreal)(0.0);
596 (*putreal)(0.0);
597 }
598 }
599
600
601 static void
602 oputN( /* print unperturbed normal */
603 RAY *r
604 )
605 {
606 if (r->rot < FHUGE) {
607 (*putreal)(r->ron[0]);
608 (*putreal)(r->ron[1]);
609 (*putreal)(r->ron[2]);
610 } else {
611 (*putreal)(0.0);
612 (*putreal)(0.0);
613 (*putreal)(0.0);
614 }
615 }
616
617
618 static void
619 oputn( /* print perturbed normal */
620 RAY *r
621 )
622 {
623 FVECT pnorm;
624
625 if (r->rot >= FHUGE) {
626 (*putreal)(0.0);
627 (*putreal)(0.0);
628 (*putreal)(0.0);
629 return;
630 }
631 raynormal(pnorm, r);
632 (*putreal)(pnorm[0]);
633 (*putreal)(pnorm[1]);
634 (*putreal)(pnorm[2]);
635 }
636
637
638 static void
639 oputs( /* print name */
640 RAY *r
641 )
642 {
643 if (r->ro != NULL)
644 fputs(r->ro->oname, stdout);
645 else
646 putchar('*');
647 putchar('\t');
648 }
649
650
651 static void
652 oputw( /* print weight */
653 RAY *r
654 )
655 {
656 (*putreal)(r->rweight);
657 }
658
659
660 static void
661 oputW( /* print coefficient */
662 RAY *r
663 )
664 {
665 double contr[3];
666
667 raycontrib(contr, r, PRIMARY);
668 (*putreal)(contr[RED]);
669 (*putreal)(contr[GRN]);
670 (*putreal)(contr[BLU]);
671 }
672
673
674 static void
675 oputm( /* print modifier */
676 RAY *r
677 )
678 {
679 if (r->ro != NULL)
680 if (r->ro->omod != OVOID)
681 fputs(objptr(r->ro->omod)->oname, stdout);
682 else
683 fputs(VOIDID, stdout);
684 else
685 putchar('*');
686 putchar('\t');
687 }
688
689
690 static void
691 oputM( /* print material */
692 RAY *r
693 )
694 {
695 OBJREC *mat;
696
697 if (r->ro != NULL) {
698 if ((mat = findmaterial(r->ro)) != NULL)
699 fputs(mat->oname, stdout);
700 else
701 fputs(VOIDID, stdout);
702 } else
703 putchar('*');
704 putchar('\t');
705 }
706
707
708 static void
709 oputtilde( /* output tilde (spacer) */
710 RAY *r
711 )
712 {
713 fputs("~\t", stdout);
714 }
715
716
717 static void
718 puta( /* print ascii value */
719 double v
720 )
721 {
722 printf("%e\t", v);
723 }
724
725
726 static void
727 putd(v) /* print binary double */
728 double v;
729 {
730 fwrite((char *)&v, sizeof(v), 1, stdout);
731 }
732
733
734 static void
735 putf(v) /* print binary float */
736 double v;
737 {
738 float f = v;
739
740 fwrite((char *)&f, sizeof(f), 1, stdout);
741 }
