root/radiance/ray/src/rt/rtrace.c
Revision: 1.8
Committed: Fri Jan 19 00:00:26 1990 UTC (35 years, 6 months ago) by greg
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rtrace.c - program and variables for individual ray tracing.
9 *
10 * 6/11/86
11 */
12
13 /*
14 * Input is in the form:
15 *
16 * xorg yorg zorg xdir ydir zdir
17 *
18 * The direction need not be normalized. Output is flexible.
19 * If the direction vector is (0,0,0), then the output is flushed.
20 * All values default to ascii representation of real
21 * numbers. Binary representations can be selected
22 * with '-ff' for float or '-fd' for double. By default,
23 * radiance is computed. The '-i' option indicates that
24 * irradiance values are desired.
25 */
26
27 #include "ray.h"
28
29 #include "otypes.h"
30
31 int inform = 'a'; /* input format */
32 int outform = 'a'; /* output format */
33 char *outvals = "v"; /* output specification */
34
35 int hresolu = 0; /* horizontal (scan) size */
36 int vresolu = 0; /* vertical resolution */
37
38 double dstrsrc = 0.0; /* square source distribution */
39 double shadthresh = .05; /* shadow threshold */
40 double shadcert = .5; /* shadow certainty */
41
42 int maxdepth = 6; /* maximum recursion depth */
43 double minweight = 4e-3; /* minimum ray weight */
44
45 COLOR ambval = BLKCOLOR; /* ambient value */
46 double ambacc = 0.2; /* ambient accuracy */
47 int ambres = 32; /* ambient resolution */
48 int ambdiv = 128; /* ambient divisions */
49 int ambssamp = 0; /* ambient super-samples */
50 int ambounce = 0; /* ambient bounces */
51 char *amblist[128]; /* ambient include/exclude list */
52 int ambincl = -1; /* include == 1, exclude == 0 */
53
54 static RAY thisray; /* for our convenience */
55
56 extern int oputo(), oputd(), oputv(), oputl(),
57 oputp(), oputn(), oputs(), oputw(), oputm();
58
59 static int (*ray_out[10])(), (*every_out[10])();
60
61 extern int puta(), putf(), putd();
62
63 static int (*putreal)();
64
65
66 quit(code) /* quit program */
67 int code;
68 {
69 exit(code);
70 }
71
72
73 rtrace(fname) /* trace rays from file */
74 char *fname;
75 {
76 long vcount = hresolu>1 ? hresolu*vresolu : vresolu;
77 long nextflush = hresolu;
78 FILE *fp;
79 FVECT orig, direc;
80 /* set up input */
81 if (fname == NULL)
82 fp = stdin;
83 else if ((fp = fopen(fname, "r")) == NULL) {
84 sprintf(errmsg, "cannot open input file \"%s\"", fname);
85 error(SYSTEM, errmsg);
86 }
87 /* set up output */
88 setoutput(outvals);
89 switch (outform) {
90 case 'a': putreal = puta; break;
91 case 'f': putreal = putf; break;
92 case 'd': putreal = putd; break;
93 }
94 /* process file */
95 while (getvec(orig, inform, fp) == 0 &&
96 getvec(direc, inform, fp) == 0) {
97
98 if (normalize(direc) == 0.0) { /* zero ==> flush */
99 fflush(stdout);
100 continue;
101 }
102 /* compute and print */
103 if (outvals[0] == 'i')
104 irrad(orig, direc);
105 else
106 radiance(orig, direc);
107 /* flush if time */
108 if (--nextflush == 0) {
109 fflush(stdout);
110 nextflush = hresolu;
111 }
112 if (ferror(stdout))
113 error(SYSTEM, "write error");
114 if (--vcount == 0) /* check for end */
115 break;
116 }
117 if (vcount > 0)
118 error(USER, "read error");
119 fclose(fp);
120 }
121
122
123 setoutput(vs) /* set up output tables */
124 register char *vs;
125 {
126 extern int ourtrace(), (*trace)();
127 register int (**table)() = ray_out;
128
129 while (*vs)
130 switch (*vs++) {
131 case 't': /* trace */
132 *table = NULL;
133 table = every_out;
134 trace = ourtrace;
135 break;
136 case 'o': /* origin */
137 *table++ = oputo;
138 break;
139 case 'd': /* direction */
140 *table++ = oputd;
141 break;
142 case 'v': /* value */
143 *table++ = oputv;
144 break;
145 case 'l': /* length */
146 *table++ = oputl;
147 break;
148 case 'p': /* point */
149 *table++ = oputp;
150 break;
151 case 'n': /* normal */
152 *table++ = oputn;
153 break;
154 case 's': /* surface */
155 *table++ = oputs;
156 break;
157 case 'w': /* weight */
158 *table++ = oputw;
159 break;
160 case 'm': /* modifier */
161 *table++ = oputm;
162 break;
163 }
164 *table = NULL;
165 }
166
167
168 radiance(org, dir) /* compute radiance value */
169 FVECT org, dir;
170 {
171 register int (**tp)();
172
173 VCOPY(thisray.rorg, org);
174 VCOPY(thisray.rdir, dir);
175 rayorigin(&thisray, NULL, PRIMARY, 1.0);
176 rayvalue(&thisray);
177
178 if (ray_out[0] == NULL)
179 return;
180 for (tp = ray_out; *tp != NULL; tp++)
181 (**tp)(&thisray);
182 if (outform == 'a')
183 putchar('\n');
184 }
185
186
187 irrad(org, dir) /* compute irradiance value */
188 FVECT org, dir;
189 {
190 static double Lambfa[5] = {PI, PI, PI, 0.0, 0.0};
191 static OBJREC Lamb = {
192 OVOID, MAT_PLASTIC, "Lambertian",
193 {0, 5, NULL, Lambfa}, NULL, -1,
194 };
195 register int i;
196
197 for (i = 0; i < 3; i++) {
198 thisray.rorg[i] = org[i] + dir[i];
199 thisray.rdir[i] = -dir[i];
200 }
201 rayorigin(&thisray, NULL, PRIMARY, 1.0);
202 /* pretend we hit surface */
203 thisray.rot = 1.0;
204 thisray.rod = 1.0;
205 VCOPY(thisray.ron, dir);
206 for (i = 0; i < 3; i++) /* fudge factor */
207 thisray.rop[i] = org[i] + 1e-4*dir[i];
208 /* compute and print */
209 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
210 oputv(&thisray);
211 if (outform == 'a')
212 putchar('\n');
213 }
214
215
216 getvec(vec, fmt, fp) /* get a vector from fp */
217 register FVECT vec;
218 int fmt;
219 FILE *fp;
220 {
221 static float vf[3];
222
223 switch (fmt) {
224 case 'a': /* ascii */
225 if (fscanf(fp, "%lf %lf %lf", vec, vec+1, vec+2) != 3)
226 return(-1);
227 break;
228 case 'f': /* binary float */
229 if (fread((char *)vf, sizeof(float), 3, fp) != 3)
230 return(-1);
231 vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2];
232 break;
233 case 'd': /* binary double */
234 if (fread((char *)vec, sizeof(double), 3, fp) != 3)
235 return(-1);
236 break;
237 }
238 return(0);
239 }
240
241
242 static
243 ourtrace(r) /* print ray values */
244 RAY *r;
245 {
246 register int (**tp)();
247
248 if (every_out[0] == NULL)
249 return;
250 tabin(r);
251 for (tp = every_out; *tp != NULL; tp++)
252 (**tp)(r);
253 putchar('\n');
254 }
255
256
257 static
258 tabin(r) /* tab in appropriate amount */
259 RAY *r;
260 {
261 register RAY *rp;
262
263 for (rp = r->parent; rp != NULL; rp = rp->parent)
264 putchar('\t');
265 }
266
267
268 static
269 oputo(r) /* print origin */
270 register RAY *r;
271 {
272 (*putreal)(r->rorg[0]);
273 (*putreal)(r->rorg[1]);
274 (*putreal)(r->rorg[2]);
275 }
276
277
278 static
279 oputd(r) /* print direction */
280 register RAY *r;
281 {
282 (*putreal)(r->rdir[0]);
283 (*putreal)(r->rdir[1]);
284 (*putreal)(r->rdir[2]);
285 }
286
287
288 static
289 oputv(r) /* print value */
290 register RAY *r;
291 {
292 (*putreal)(colval(r->rcol,RED));
293 (*putreal)(colval(r->rcol,GRN));
294 (*putreal)(colval(r->rcol,BLU));
295 }
296
297
298 static
299 oputl(r) /* print length */
300 register RAY *r;
301 {
302 if (r->rot < FHUGE)
303 (*putreal)(r->rot);
304 else
305 (*putreal)(0.0);
306 }
307
308
309 static
310 oputp(r) /* print point */
311 register RAY *r;
312 {
313 if (r->rot < FHUGE) {
314 (*putreal)(r->rop[0]);
315 (*putreal)(r->rop[1]);
316 (*putreal)(r->rop[2]);
317 } else {
318 (*putreal)(0.0);
319 (*putreal)(0.0);
320 (*putreal)(0.0);
321 }
322 }
323
324
325 static
326 oputn(r) /* print normal */
327 register RAY *r;
328 {
329 if (r->rot < FHUGE) {
330 (*putreal)(r->ron[0]);
331 (*putreal)(r->ron[1]);
332 (*putreal)(r->ron[2]);
333 } else {
334 (*putreal)(0.0);
335 (*putreal)(0.0);
336 (*putreal)(0.0);
337 }
338 }
339
340
341 static
342 oputs(r) /* print name */
343 register RAY *r;
344 {
345 if (r->ro != NULL)
346 fputs(r->ro->oname, stdout);
347 else
348 putchar('*');
349 putchar('\t');
350 }
351
352
353 static
354 oputw(r) /* print weight */
355 register RAY *r;
356 {
357 (*putreal)(r->rweight);
358 }
359
360
361 static
362 oputm(r) /* print modifier */
363 register RAY *r;
364 {
365 if (r->ro != NULL)
366 fputs(objptr(r->ro->omod)->oname, stdout);
367 else
368 putchar('*');
369 putchar('\t');
370 }
371
372
373 static
374 puta(v) /* print ascii value */
375 double v;
376 {
377 printf("%e\t", v);
378 }
379
380
381 static
382 putd(v) /* print binary double */
383 double v;
384 {
385 fwrite((char *)&v, sizeof(v), 1, stdout);
386 }
387
388
389 static
390 putf(v) /* print binary float */
391 double v;
392 {
393 float f = v;
394
395 fwrite((char *)&f, sizeof(f), 1, stdout);
396 }
