root/radiance/ray/src/rt/rtrace.c
Revision: 2.38
Committed: Fri Nov 5 17:36:56 2004 UTC (20 years, 6 months ago) by greg
2 static const char RCSid[] = "$Id: rtrace.c,v 2.37 2004/03/30 16:13:01 schorsch Exp $";
5 * rtrace.c - program and variables for individual ray tracing.
6 */
7
8 #include "copyright.h"
9
10 /*
11 * Input is in the form:
12 *
13 * xorg yorg zorg xdir ydir zdir
14 *
15 * The direction need not be normalized. Output is flexible.
16 * If the direction vector is (0,0,0), then the output is flushed.
17 * All values default to ascii representation of real
18 * numbers. Binary representations can be selected
19 * with '-ff' for float or '-fd' for double. By default,
20 * radiance is computed. The '-i' or '-I' options indicate that
21 * irradiance values are desired.
22 */
23
24 #include <time.h>
25
26 #include "platform.h"
27 #include "ray.h"
28 #include "ambient.h"
29 #include "source.h"
30 #include "otypes.h"
31 #include "resolu.h"
32
33 CUBE thescene; /* our scene */
34 OBJECT nsceneobjs; /* number of objects in our scene */
35
36 int dimlist[MAXDIM]; /* sampling dimensions */
37 int ndims = 0; /* number of sampling dimensions */
38 int samplendx = 0; /* index for this sample */
39
40 int imm_irrad = 0; /* compute immediate irradiance? */
41 int lim_dist = 0; /* limit distance? */
42
43 int inform = 'a'; /* input format */
44 int outform = 'a'; /* output format */
45 char *outvals = "v"; /* output specification */
46
47 int do_irrad = 0; /* compute irradiance? */
48
49 void (*trace)() = NULL; /* trace call */
50
51 char *tralist[128]; /* list of modifers to trace (or no) */
52 int traincl = -1; /* include == 1, exclude == 0 */
53 #define MAXTSET 511 /* maximum number in trace set */
54 OBJECT traset[MAXTSET+1]={0}; /* trace include/exclude set */
55
56 int hresolu = 0; /* horizontal (scan) size */
57 int vresolu = 0; /* vertical resolution */
58
59 double dstrsrc = 0.0; /* square source distribution */
60 double shadthresh = .03; /* shadow threshold */
61 double shadcert = .75; /* shadow certainty */
62 int directrelay = 2; /* number of source relays */
63 int vspretest = 512; /* virtual source pretest density */
64 int directvis = 1; /* sources visible? */
65 double srcsizerat = .2; /* maximum ratio source size/dist. */
66
67 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
68 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
69 double seccg = 0.; /* global scattering eccentricity */
70 double ssampdist = 0.; /* scatter sampling distance */
71
72 double specthresh = .15; /* specular sampling threshold */
73 double specjitter = 1.; /* specular sampling jitter */
74
75 int backvis = 1; /* back face visibility */
76
77 int maxdepth = 8; /* maximum recursion depth */
78 double minweight = 2e-3; /* minimum ray weight */
79
80 char *ambfile = NULL; /* ambient file name */
81 COLOR ambval = BLKCOLOR; /* ambient value */
82 int ambvwt = 0; /* initial weight for ambient value */
83 double ambacc = 0.15; /* ambient accuracy */
84 int ambres = 256; /* ambient resolution */
85 int ambdiv = 1024; /* ambient divisions */
86 int ambssamp = 512; /* ambient super-samples */
87 int ambounce = 0; /* ambient bounces */
88 char *amblist[AMBLLEN]; /* ambient include/exclude list */
89 int ambincl = -1; /* include == 1, exclude == 0 */
90
91 static int castonly = 0;
92
93 static RAY thisray; /* for our convenience */
94
95 typedef void putf_t(double v);
96 static putf_t puta, putd, putf;
97
98 typedef void oputf_t(RAY *r);
99 static oputf_t oputo, oputd, oputv, oputl, oputL, oputc,
100 oputp, oputn, oputN, oputs, oputw, oputm;
101
102 static void setoutput(char *vs);
103 static void tranotify(OBJECT obj);
104 static void bogusray(void);
105 static void rad(FVECT org, FVECT dir, double dmax);
106 static void irrad(FVECT org, FVECT dir);
107 static void printvals(RAY *r);
108 static int getvec(FVECT vec, int fmt, FILE *fp);
109 static void tabin(RAY *r);
110 static void ourtrace(RAY *r);
111
112 static oputf_t *ray_out[16], *every_out[16];
113 static putf_t *putreal;
114
115 void (*addobjnotify[])() = {ambnotify, tranotify, NULL};
116
117
118 void
119 quit( /* quit program */
120 int code
121 )
122 {
123 #ifndef NON_POSIX /* XXX we don't clean up elsewhere? */
124 headclean(); /* delete header file */
125 pfclean(); /* clean up persist files */
126 #endif
127 exit(code);
128 }
129
130
131 extern char *
132 formstr( /* return format identifier */
133 int f
134 )
135 {
136 switch (f) {
137 case 'a': return("ascii");
138 case 'f': return("float");
139 case 'd': return("double");
140 case 'c': return(COLRFMT);
141 }
142 return("unknown");
143 }
144
145
146 extern void
147 rtrace( /* trace rays from file */
148 char *fname
149 )
150 {
151 long vcount = hresolu>1 ? hresolu*vresolu : vresolu;
152 long nextflush = hresolu;
153 FILE *fp;
154 double d;
155 FVECT orig, direc;
156 /* set up input */
157 if (fname == NULL)
158 fp = stdin;
159 else if ((fp = fopen(fname, "r")) == NULL) {
160 sprintf(errmsg, "cannot open input file \"%s\"", fname);
161 error(SYSTEM, errmsg);
162 }
163 #ifdef _WIN32
164 if (inform != 'a')
165 SET_FILE_BINARY(fp);
166 #endif
167 /* set up output */
168 setoutput(outvals);
169 switch (outform) {
170 case 'a': putreal = puta; break;
171 case 'f': putreal = putf; break;
172 case 'd': putreal = putd; break;
173 case 'c':
174 if (strcmp(outvals, "v"))
175 error(USER, "color format with value output only");
176 break;
177 default:
178 error(CONSISTENCY, "botched output format");
179 }
180 if (hresolu > 0) {
181 if (vresolu > 0)
182 fprtresolu(hresolu, vresolu, stdout);
183 fflush(stdout);
184 }
185 /* process file */
186 while (getvec(orig, inform, fp) == 0 &&
187 getvec(direc, inform, fp) == 0) {
188
189 d = normalize(direc);
190 if (d == 0.0) { /* zero ==> flush */
191 bogusray();
192 if (--nextflush <= 0 || vcount <= 0) {
193 fflush(stdout);
194 nextflush = hresolu;
195 }
196 } else {
197 samplendx++;
198 /* compute and print */
199 if (imm_irrad)
200 irrad(orig, direc);
201 else
202 rad(orig, direc, lim_dist ? d : 0.0);
203 /* flush if time */
204 if (--nextflush == 0) {
205 fflush(stdout);
206 nextflush = hresolu;
207 }
208 }
209 if (ferror(stdout))
210 error(SYSTEM, "write error");
211 if (--vcount == 0) /* check for end */
212 break;
213 }
214 fflush(stdout);
215 if (vcount > 0)
216 error(USER, "read error");
217 if (fname != NULL)
218 fclose(fp);
219 }
220
221
222 static void
223 setoutput( /* set up output tables */
224 register char *vs
225 )
226 {
227 register oputf_t **table = ray_out;
228
229 castonly = 1;
230 while (*vs)
231 switch (*vs++) {
232 case 't': /* trace */
233 *table = NULL;
234 table = every_out;
235 trace = ourtrace;
236 castonly = 0;
237 break;
238 case 'o': /* origin */
239 *table++ = oputo;
240 break;
241 case 'd': /* direction */
242 *table++ = oputd;
243 break;
244 case 'v': /* value */
245 *table++ = oputv;
246 castonly = 0;
247 break;
248 case 'l': /* effective distance */
249 *table++ = oputl;
250 castonly = 0;
251 break;
252 case 'c': /* local coordinates */
253 *table++ = oputc;
254 break;
255 case 'L': /* single ray length */
256 *table++ = oputL;
257 break;
258 case 'p': /* point */
259 *table++ = oputp;
260 break;
261 case 'n': /* perturbed normal */
262 *table++ = oputn;
263 castonly = 0;
264 break;
265 case 'N': /* unperturbed normal */
266 *table++ = oputN;
267 break;
268 case 's': /* surface */
269 *table++ = oputs;
270 break;
271 case 'w': /* weight */
272 *table++ = oputw;
273 break;
274 case 'm': /* modifier */
275 *table++ = oputm;
276 break;
277 }
278 *table = NULL;
279 }
280
281
282 static void
283 bogusray(void) /* print out empty record */
284 {
285 thisray.rorg[0] = thisray.rorg[1] = thisray.rorg[2] =
286 thisray.rdir[0] = thisray.rdir[1] = thisray.rdir[2] = 0.0;
287 rayorigin(&thisray, NULL, PRIMARY, 1.0);
288 printvals(&thisray);
289 }
290
291
292 static void
293 rad( /* compute and print ray value(s) */
294 FVECT org,
295 FVECT dir,
296 double dmax
297 )
298 {
299 VCOPY(thisray.rorg, org);
300 VCOPY(thisray.rdir, dir);
301 thisray.rmax = dmax;
302 rayorigin(&thisray, NULL, PRIMARY, 1.0);
303 if (castonly) {
304 if (!localhit(&thisray, &thescene)) {
305 if (thisray.ro == &Aftplane) { /* clipped */
306 thisray.ro = NULL;
307 thisray.rot = FHUGE;
308 } else
309 sourcehit(&thisray);
310 }
311 } else
312 rayvalue(&thisray);
313 printvals(&thisray);
314 }
315
316
317 static void
318 irrad( /* compute immediate irradiance value */
319 FVECT org,
320 FVECT dir
321 )
322 {
323 register int i;
324
325 for (i = 0; i < 3; i++) {
326 thisray.rorg[i] = org[i] + dir[i];
327 thisray.rdir[i] = -dir[i];
328 }
329 rayorigin(&thisray, NULL, PRIMARY, 1.0);
330 /* pretend we hit surface */
331 thisray.rot = 1.0-1e-4;
332 thisray.rod = 1.0;
333 VCOPY(thisray.ron, dir);
334 for (i = 0; i < 3; i++) /* fudge factor */
335 thisray.rop[i] = org[i] + 1e-4*dir[i];
336 /* compute and print */
337 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
338 printvals(&thisray);
339 }
340
341
342 static void
343 printvals( /* print requested ray values */
344 RAY *r
345 )
346 {
347 register oputf_t **tp;
348
349 if (ray_out[0] == NULL)
350 return;
351 for (tp = ray_out; *tp != NULL; tp++)
352 (**tp)(r);
353 if (outform == 'a')
354 putchar('\n');
355 }
356
357
358 static int
359 getvec( /* get a vector from fp */
360 register FVECT vec,
361 int fmt,
362 FILE *fp
363 )
364 {
365 static float vf[3];
366 static double vd[3];
367 char buf[32];
368 register int i;
369
370 switch (fmt) {
371 case 'a': /* ascii */
372 for (i = 0; i < 3; i++) {
373 if (fgetword(buf, sizeof(buf), fp) == NULL ||
374 !isflt(buf))
375 return(-1);
376 vec[i] = atof(buf);
377 }
378 break;
379 case 'f': /* binary float */
380 if (fread((char *)vf, sizeof(float), 3, fp) != 3)
381 return(-1);
382 vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2];
383 break;
384 case 'd': /* binary double */
385 if (fread((char *)vd, sizeof(double), 3, fp) != 3)
386 return(-1);
387 vec[0] = vd[0]; vec[1] = vd[1]; vec[2] = vd[2];
388 break;
389 default:
390 error(CONSISTENCY, "botched input format");
391 }
392 return(0);
393 }
394
395
396 static void
397 tranotify( /* record new modifier */
398 OBJECT obj
399 )
400 {
401 static int hitlimit = 0;
402 register OBJREC *o = objptr(obj);
403 register char **tralp;
404
405 if (obj == OVOID) { /* starting over */
406 traset[0] = 0;
407 hitlimit = 0;
408 return;
409 }
410 if (hitlimit || !ismodifier(o->otype))
411 return;
412 for (tralp = tralist; *tralp != NULL; tralp++)
413 if (!strcmp(o->oname, *tralp)) {
414 if (traset[0] >= MAXTSET) {
415 error(WARNING, "too many modifiers in trace list");
416 hitlimit++;
417 return; /* should this be fatal? */
418 }
419 insertelem(traset, obj);
420 return;
421 }
422 }
423
424
425 static void
426 ourtrace( /* print ray values */
427 RAY *r
428 )
429 {
430 register oputf_t **tp;
431
432 if (every_out[0] == NULL)
433 return;
434 if (r->ro == NULL) {
435 if (traincl == 1)
436 return;
437 } else if (traincl != -1 && traincl != inset(traset, r->ro->omod))
438 return;
439 tabin(r);
440 for (tp = every_out; *tp != NULL; tp++)
441 (**tp)(r);
442 putchar('\n');
443 }
444
445
446 static void
447 tabin( /* tab in appropriate amount */
448 RAY *r
449 )
450 {
451 register RAY *rp;
452
453 for (rp = r->parent; rp != NULL; rp = rp->parent)
454 putchar('\t');
455 }
456
457
458 static void
459 oputo( /* print origin */
460 RAY *r
461 )
462 {
463 (*putreal)(r->rorg[0]);
464 (*putreal)(r->rorg[1]);
465 (*putreal)(r->rorg[2]);
466 }
467
468
469 static void
470 oputd( /* print direction */
471 RAY *r
472 )
473 {
474 (*putreal)(r->rdir[0]);
475 (*putreal)(r->rdir[1]);
476 (*putreal)(r->rdir[2]);
477 }
478
479
480 static void
481 oputv( /* print value */
482 RAY *r
483 )
484 {
485 COLR cout;
486
487 if (outform == 'c') {
488 setcolr(cout, colval(r->rcol,RED),
489 colval(r->rcol,GRN),
490 colval(r->rcol,BLU));
491 fwrite((char *)cout, sizeof(cout), 1, stdout);
492 return;
493 }
494 (*putreal)(colval(r->rcol,RED));
495 (*putreal)(colval(r->rcol,GRN));
496 (*putreal)(colval(r->rcol,BLU));
497 }
498
499
500 static void
501 oputl( /* print effective distance */
502 RAY *r
503 )
504 {
505 (*putreal)(r->rt);
506 }
507
508
509 static void
510 oputL( /* print single ray length */
511 RAY *r
512 )
513 {
514 (*putreal)(r->rot);
515 }
516
517
518 static void
519 oputc( /* print local coordinates */
520 RAY *r
521 )
522 {
523 (*putreal)(r->uv[0]);
524 (*putreal)(r->uv[1]);
525 }
526
527
528 static void
529 oputp( /* print point */
530 RAY *r
531 )
532 {
533 if (r->rot < FHUGE) {
534 (*putreal)(r->rop[0]);
535 (*putreal)(r->rop[1]);
536 (*putreal)(r->rop[2]);
537 } else {
538 (*putreal)(0.0);
539 (*putreal)(0.0);
540 (*putreal)(0.0);
541 }
542 }
543
544
545 static void
546 oputN( /* print unperturbed normal */
547 RAY *r
548 )
549 {
550 if (r->rot < FHUGE) {
551 (*putreal)(r->ron[0]);
552 (*putreal)(r->ron[1]);
553 (*putreal)(r->ron[2]);
554 } else {
555 (*putreal)(0.0);
556 (*putreal)(0.0);
557 (*putreal)(0.0);
558 }
559 }
560
561
562 static void
563 oputn( /* print perturbed normal */
564 RAY *r
565 )
566 {
567 FVECT pnorm;
568
569 if (r->rot >= FHUGE) {
570 (*putreal)(0.0);
571 (*putreal)(0.0);
572 (*putreal)(0.0);
573 return;
574 }
575 raynormal(pnorm, r);
576 (*putreal)(pnorm[0]);
577 (*putreal)(pnorm[1]);
578 (*putreal)(pnorm[2]);
579 }
580
581
582 static void
583 oputs( /* print name */
584 RAY *r
585 )
586 {
587 if (r->ro != NULL)
588 fputs(r->ro->oname, stdout);
589 else
590 putchar('*');
591 putchar('\t');
592 }
593
594
595 static void
596 oputw( /* print weight */
597 RAY *r
598 )
599 {
600 (*putreal)(r->rweight);
601 }
602
603
604 static void
605 oputm( /* print modifier */
606 RAY *r
607 )
608 {
609 if (r->ro != NULL)
610 if (r->ro->omod != OVOID)
611 fputs(objptr(r->ro->omod)->oname, stdout);
612 else
613 fputs(VOIDID, stdout);
614 else
615 putchar('*');
616 putchar('\t');
617 }
618
619
620 static void
621 puta( /* print ascii value */
622 double v
623 )
624 {
625 printf("%e\t", v);
626 }
627
628
629 static void
630 putd(v) /* print binary double */
631 double v;
632 {
633 fwrite((char *)&v, sizeof(v), 1, stdout);
634 }
635
636
637 static void
638 putf(v) /* print binary float */
639 double v;
640 {
641 float f = v;
642
643 fwrite((char *)&f, sizeof(f), 1, stdout);
644 }
