--- ray/src/rt/rtrace.c 2009/12/12 19:01:00 2.57 +++ ray/src/rt/rtrace.c 2009/12/14 03:15:45 2.60 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rtrace.c,v 2.57 2009/12/12 19:01:00 greg Exp $"; +static const char RCSid[] = "$Id: rtrace.c,v 2.60 2009/12/14 03:15:45 greg Exp $"; #endif /* * rtrace.c - program and variables for individual ray tracing. @@ -63,8 +63,9 @@ static oputf_t oputo, oputd, oputv, oputV, oputl, opu static void setoutput(char *vs); extern void tranotify(OBJECT obj); static void bogusray(void); -static void rad(FVECT org, FVECT dir, double dmax); -static void irrad(FVECT org, FVECT dir); +static void raycast(RAY *r); +static void rayirrad(RAY *r); +static void rtcompute(FVECT org, FVECT dir, double dmax); static int printvals(RAY *r); static int getvec(FVECT vec, int fmt, FILE *fp); static void tabin(RAY *r); @@ -82,8 +83,10 @@ quit( /* quit program */ if (ray_pnprocs > 0) /* close children if any */ ray_pclose(0); #ifndef NON_POSIX - headclean(); /* delete header file */ - pfclean(); /* clean up persist files */ + else if (!ray_pnprocs) { + headclean(); /* delete header file */ + pfclean(); /* clean up persist files */ + } #endif exit(code); } @@ -106,7 +109,8 @@ formstr( /* return format identifier */ extern void rtrace( /* trace rays from file */ - char *fname + char *fname, + int nproc ) { unsigned long vcount = (hresolu > 1) ? (unsigned long)hresolu*vresolu @@ -126,6 +130,10 @@ rtrace( /* trace rays from file */ SET_FILE_BINARY(fp); /* set up output */ setoutput(outvals); + if (imm_irrad) + castonly = 0; + else if (castonly) + nproc = 1; /* don't bother multiprocessing */ switch (outform) { case 'a': putreal = puta; break; case 'f': putreal = putf; break; @@ -137,7 +145,10 @@ rtrace( /* trace rays from file */ default: error(CONSISTENCY, "botched output format"); } - ray_fifo_out = printvals; + if (nproc > 1) { /* start multiprocessing */ + ray_popen(nproc); + ray_fifo_out = printvals; + } if (hresolu > 0) { if (vresolu > 0) fprtresolu(hresolu, vresolu, stdout); @@ -149,7 +160,7 @@ rtrace( /* trace rays from file */ d = normalize(direc); if (d == 0.0) { /* zero ==> flush */ - if (ray_pnprocs > 1 && ray_fifo_flush() < 0) + if (nproc > 1 && ray_fifo_flush() < 0) error(USER, "lost children"); bogusray(); if (--nextflush <= 0 || !vcount) { @@ -157,13 +168,10 @@ rtrace( /* trace rays from file */ nextflush = hresolu; } } else { /* compute and print */ - if (imm_irrad) - irrad(orig, direc); - else - rad(orig, direc, lim_dist ? d : 0.0); + rtcompute(orig, direc, lim_dist ? d : 0.0); /* flush if time */ if (!--nextflush) { - if (ray_pnprocs > 1 && ray_fifo_flush() < 0) + if (nproc > 1 && ray_fifo_flush() < 0) error(USER, "lost children"); fflush(stdout); nextflush = hresolu; @@ -174,8 +182,11 @@ rtrace( /* trace rays from file */ if (vcount && !--vcount) /* check for end */ break; } - if (ray_pnprocs > 1 && ray_fifo_flush() < 0) - error(USER, "unable to complete processing"); + if (nproc > 1) { /* clean up children */ + if (ray_fifo_flush() < 0) + error(USER, "unable to complete processing"); + ray_pclose(0); + } if (fflush(stdout) < 0) error(SYSTEM, "write error"); if (vcount) @@ -290,54 +301,66 @@ bogusray(void) /* print out empty record */ static void -rad( /* compute and print ray value(s) */ - FVECT org, - FVECT dir, - double dmax +raycast( /* compute first ray intersection only */ + RAY *r ) { - VCOPY(thisray.rorg, org); - VCOPY(thisray.rdir, dir); - thisray.rmax = dmax; - if (ray_pnprocs > 1) { - if (ray_fifo_in(&thisray) < 0) - error(USER, "lost children"); - return; + if (!localhit(r, &thescene)) { + if (r->ro == &Aftplane) { /* clipped */ + r->ro = NULL; + r->rot = FHUGE; + } else + sourcehit(r); } - rayorigin(&thisray, PRIMARY, NULL, NULL); - if (castonly) { - if (!localhit(&thisray, &thescene)) { - if (thisray.ro == &Aftplane) { /* clipped */ - thisray.ro = NULL; - thisray.rot = FHUGE; - } else - sourcehit(&thisray); - } - } else - ray_trace(&thisray); - printvals(&thisray); } static void -irrad( /* compute immediate irradiance value */ +rayirrad( /* compute irradiance rather than radiance */ + RAY *r +) +{ + r->rot = 1e-5; /* pretend we hit surface */ + VSUM(r->rop, r->rorg, r->rdir, r->rot); + r->ron[0] = -r->rdir[0]; + r->ron[1] = -r->rdir[1]; + r->ron[2] = -r->rdir[2]; + r->rod = 1.0; + /* compute result */ + (*ofun[Lamb.otype].funp)(&Lamb, r); +} + + +static void +rtcompute( /* compute and print ray value(s) */ FVECT org, - FVECT dir + FVECT dir, + double dmax ) { - VSUM(thisray.rorg, org, dir, 1.1e-4); - thisray.rdir[0] = -dir[0]; - thisray.rdir[1] = -dir[1]; - thisray.rdir[2] = -dir[2]; - thisray.rmax = 0.0; + /* set up ray */ rayorigin(&thisray, PRIMARY, NULL, NULL); - /* pretend we hit surface */ - thisray.rot = 1e-5; - thisray.rod = 1.0; - VCOPY(thisray.ron, dir); - VSUM(thisray.rop, org, dir, 1e-4); - /* compute and print */ - (*ofun[Lamb.otype].funp)(&Lamb, &thisray); + if (imm_irrad) { + VSUM(thisray.rorg, org, dir, 1.1e-4); + thisray.rdir[0] = -dir[0]; + thisray.rdir[1] = -dir[1]; + thisray.rdir[2] = -dir[2]; + thisray.rmax = 0.0; + thisray.revf = rayirrad; + } else { + VCOPY(thisray.rorg, org); + VCOPY(thisray.rdir, dir); + thisray.rmax = dmax; + if (castonly) + thisray.revf = raycast; + } + if (ray_pnprocs > 1) { /* multiprocessing FIFO? */ + if (ray_fifo_in(&thisray) < 0) + error(USER, "lost children"); + return; + } + samplendx++; /* else do it ourselves */ + rayvalue(&thisray); printvals(&thisray); } @@ -383,12 +406,12 @@ getvec( /* get a vector from fp */ case 'f': /* binary float */ if (fread((char *)vf, sizeof(float), 3, fp) != 3) return(-1); - vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2]; + VCOPY(vec, vf); break; case 'd': /* binary double */ if (fread((char *)vd, sizeof(double), 3, fp) != 3) return(-1); - vec[0] = vd[0]; vec[1] = vd[1]; vec[2] = vd[2]; + VCOPY(vec, vd); break; default: error(CONSISTENCY, "botched input format");
