--- ray/src/rt/rtrace.c 2003/09/24 14:55:54 2.34 +++ ray/src/rt/rtrace.c 2005/04/14 18:04:12 2.39 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rtrace.c,v 2.34 2003/09/24 14:55:54 greg Exp $"; +static const char RCSid[] = "$Id: rtrace.c,v 2.39 2005/04/14 18:04:12 greg Exp $"; #endif /* * rtrace.c - program and variables for individual ray tracing. @@ -25,6 +25,8 @@ static const char RCSid[] = "$Id: rtrace.c,v 2.34 2003 #include "platform.h" #include "ray.h" +#include "ambient.h" +#include "source.h" #include "otypes.h" #include "resolu.h" @@ -46,8 +48,6 @@ int do_irrad = 0; /* compute irradiance? */ void (*trace)() = NULL; /* trace call */ -extern void ambnotify(), tranotify(); -void (*addobjnotify[])() = {ambnotify, tranotify, NULL}; char *tralist[128]; /* list of modifers to trace (or no) */ int traincl = -1; /* include == 1, exclude == 0 */ #define MAXTSET 511 /* maximum number in trace set */ @@ -57,8 +57,8 @@ int hresolu = 0; /* horizontal (scan) size */ int vresolu = 0; /* vertical resolution */ double dstrsrc = 0.0; /* square source distribution */ -double shadthresh = .05; /* shadow threshold */ -double shadcert = .5; /* shadow certainty */ +double shadthresh = .03; /* shadow threshold */ +double shadcert = .75; /* shadow certainty */ int directrelay = 2; /* number of source relays */ int vspretest = 512; /* virtual source pretest density */ int directvis = 1; /* sources visible? */ @@ -80,34 +80,45 @@ double minweight = 2e-3; /* minimum ray weight */ char *ambfile = NULL; /* ambient file name */ COLOR ambval = BLKCOLOR; /* ambient value */ int ambvwt = 0; /* initial weight for ambient value */ -double ambacc = 0.1; /* ambient accuracy */ +double ambacc = 0.15; /* ambient accuracy */ int ambres = 256; /* ambient resolution */ int ambdiv = 1024; /* ambient divisions */ int ambssamp = 512; /* ambient super-samples */ int ambounce = 0; /* ambient bounces */ -char *amblist[128]; /* ambient include/exclude list */ +char *amblist[AMBLLEN]; /* ambient include/exclude list */ int ambincl = -1; /* include == 1, exclude == 0 */ +static int castonly = 0; static RAY thisray; /* for our convenience */ -static void oputo(), oputd(), oputv(), oputl(), oputL(), oputc(), - oputp(), oputn(), oputN(), oputs(), oputw(), oputm(); +typedef void putf_t(double v); +static putf_t puta, putd, putf; -static void ourtrace(), tabin(); -static void (*ray_out[16])(), (*every_out[16])(); -static int castonly = 0; +typedef void oputf_t(RAY *r); +static oputf_t oputo, oputd, oputv, oputl, oputL, oputc, + oputp, oputn, oputN, oputs, oputw, oputm, oputM; -static void puta(), putf(), putd(); +static void setoutput(char *vs); +static void tranotify(OBJECT obj); +static void bogusray(void); +static void rad(FVECT org, FVECT dir, double dmax); +static void irrad(FVECT org, FVECT dir); +static void printvals(RAY *r); +static int getvec(FVECT vec, int fmt, FILE *fp); +static void tabin(RAY *r); +static void ourtrace(RAY *r); -static void (*putreal)(); +static oputf_t *ray_out[16], *every_out[16]; +static putf_t *putreal; -void bogusray(), rad(), irrad(), printvals(); +void (*addobjnotify[])() = {ambnotify, tranotify, NULL}; void -quit(code) /* quit program */ -int code; +quit( /* quit program */ + int code +) { #ifndef NON_POSIX /* XXX we don't clean up elsewhere? */ headclean(); /* delete header file */ @@ -117,9 +128,10 @@ int code; } -char * -formstr(f) /* return format identifier */ -int f; +extern char * +formstr( /* return format identifier */ + int f +) { switch (f) { case 'a': return("ascii"); @@ -131,9 +143,10 @@ int f; } -void -rtrace(fname) /* trace rays from file */ -char *fname; +extern void +rtrace( /* trace rays from file */ + char *fname +) { long vcount = hresolu>1 ? hresolu*vresolu : vresolu; long nextflush = hresolu; @@ -206,11 +219,12 @@ char *fname; } -setoutput(vs) /* set up output tables */ -register char *vs; +static void +setoutput( /* set up output tables */ + register char *vs +) { - extern void (*trace)(); - register void (**table)() = ray_out; + register oputf_t **table = ray_out; castonly = 1; while (*vs) @@ -260,13 +274,16 @@ register char *vs; case 'm': /* modifier */ *table++ = oputm; break; + case 'M': /* material */ + *table++ = oputM; + break; } *table = NULL; } -void -bogusray() /* print out empty record */ +static void +bogusray(void) /* print out empty record */ { thisray.rorg[0] = thisray.rorg[1] = thisray.rorg[2] = thisray.rdir[0] = thisray.rdir[1] = thisray.rdir[2] = 0.0; @@ -275,10 +292,12 @@ bogusray() /* print out empty record */ } -void -rad(org, dir, dmax) /* compute and print ray value(s) */ -FVECT org, dir; -double dmax; +static void +rad( /* compute and print ray value(s) */ + FVECT org, + FVECT dir, + double dmax +) { VCOPY(thisray.rorg, org); VCOPY(thisray.rdir, dir); @@ -298,9 +317,11 @@ double dmax; } -void -irrad(org, dir) /* compute immediate irradiance value */ -FVECT org, dir; +static void +irrad( /* compute immediate irradiance value */ + FVECT org, + FVECT dir +) { register int i; @@ -321,11 +342,12 @@ FVECT org, dir; } -void -printvals(r) /* print requested ray values */ -RAY *r; +static void +printvals( /* print requested ray values */ + RAY *r +) { - register void (**tp)(); + register oputf_t **tp; if (ray_out[0] == NULL) return; @@ -336,11 +358,12 @@ RAY *r; } -int -getvec(vec, fmt, fp) /* get a vector from fp */ -register FVECT vec; -int fmt; -FILE *fp; +static int +getvec( /* get a vector from fp */ + register FVECT vec, + int fmt, + FILE *fp +) { static float vf[3]; static double vd[3]; @@ -373,9 +396,10 @@ FILE *fp; } -void -tranotify(obj) /* record new modifier */ -OBJECT obj; +static void +tranotify( /* record new modifier */ + OBJECT obj +) { static int hitlimit = 0; register OBJREC *o = objptr(obj); @@ -402,10 +426,11 @@ OBJECT obj; static void -ourtrace(r) /* print ray values */ -RAY *r; +ourtrace( /* print ray values */ + RAY *r +) { - register void (**tp)(); + register oputf_t **tp; if (every_out[0] == NULL) return; @@ -422,8 +447,9 @@ RAY *r; static void -tabin(r) /* tab in appropriate amount */ -RAY *r; +tabin( /* tab in appropriate amount */ + RAY *r +) { register RAY *rp; @@ -433,8 +459,9 @@ RAY *r; static void -oputo(r) /* print origin */ -RAY *r; +oputo( /* print origin */ + RAY *r +) { (*putreal)(r->rorg[0]); (*putreal)(r->rorg[1]); @@ -443,8 +470,9 @@ RAY *r; static void -oputd(r) /* print direction */ -RAY *r; +oputd( /* print direction */ + RAY *r +) { (*putreal)(r->rdir[0]); (*putreal)(r->rdir[1]); @@ -453,8 +481,9 @@ RAY *r; static void -oputv(r) /* print value */ -RAY *r; +oputv( /* print value */ + RAY *r +) { COLR cout; @@ -472,24 +501,27 @@ RAY *r; static void -oputl(r) /* print effective distance */ -RAY *r; +oputl( /* print effective distance */ + RAY *r +) { (*putreal)(r->rt); } static void -oputL(r) /* print single ray length */ -RAY *r; +oputL( /* print single ray length */ + RAY *r +) { (*putreal)(r->rot); } static void -oputc(r) /* print local coordinates */ -RAY *r; +oputc( /* print local coordinates */ + RAY *r +) { (*putreal)(r->uv[0]); (*putreal)(r->uv[1]); @@ -497,8 +529,9 @@ RAY *r; static void -oputp(r) /* print point */ -RAY *r; +oputp( /* print point */ + RAY *r +) { if (r->rot < FHUGE) { (*putreal)(r->rop[0]); @@ -513,8 +546,9 @@ RAY *r; static void -oputN(r) /* print unperturbed normal */ -RAY *r; +oputN( /* print unperturbed normal */ + RAY *r +) { if (r->rot < FHUGE) { (*putreal)(r->ron[0]); @@ -529,8 +563,9 @@ RAY *r; static void -oputn(r) /* print perturbed normal */ -RAY *r; +oputn( /* print perturbed normal */ + RAY *r +) { FVECT pnorm; @@ -548,8 +583,9 @@ RAY *r; static void -oputs(r) /* print name */ -RAY *r; +oputs( /* print name */ + RAY *r +) { if (r->ro != NULL) fputs(r->ro->oname, stdout); @@ -560,16 +596,18 @@ RAY *r; static void -oputw(r) /* print weight */ -RAY *r; +oputw( /* print weight */ + RAY *r +) { (*putreal)(r->rweight); } static void -oputm(r) /* print modifier */ -RAY *r; +oputm( /* print modifier */ + RAY *r +) { if (r->ro != NULL) if (r->ro->omod != OVOID) @@ -583,8 +621,27 @@ RAY *r; static void -puta(v) /* print ascii value */ -double v; +oputM( /* print material */ + RAY *r +) +{ + OBJREC *mat; + + if (r->ro != NULL) { + if ((mat = findmaterial(r->ro)) != NULL) + fputs(mat->oname, stdout); + else + fputs(VOIDID, stdout); + } else + putchar('*'); + putchar('\t'); +} + + +static void +puta( /* print ascii value */ + double v +) { printf("%e\t", v); }
