root/radiance/ray/src/rt/rtrace.c
Revision: 2.8
Committed: Thu Oct 15 21:13:21 1992 UTC (32 years, 6 months ago) by greg
Changes since 2.7: +4 -0 lines
added setmode(fd,O_BINARY) where needed for MSDOS
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rtrace.c - program and variables for individual ray tracing.
9 *
10 * 6/11/86
11 */
12
13 /*
14 * Input is in the form:
15 *
16 * xorg yorg zorg xdir ydir zdir
17 *
18 * The direction need not be normalized. Output is flexible.
19 * If the direction vector is (0,0,0), then the output is flushed.
20 * All values default to ascii representation of real
21 * numbers. Binary representations can be selected
22 * with '-ff' for float or '-fd' for double. By default,
23 * radiance is computed. The '-i' or '-I' options indicate that
24 * irradiance values are desired.
25 */
26
27 #include "ray.h"
28
29 #include "octree.h"
30
31 #include "otypes.h"
32
33 #include "resolu.h"
34
35 int dimlist[MAXDIM]; /* sampling dimensions */
36 int ndims = 0; /* number of sampling dimensions */
37 int samplendx = 0; /* index for this sample */
38
39 int imm_irrad = 0; /* compute immediate irradiance? */
40
41 int inform = 'a'; /* input format */
42 int outform = 'a'; /* output format */
43 char *outvals = "v"; /* output specification */
44
45 int hresolu = 0; /* horizontal (scan) size */
46 int vresolu = 0; /* vertical resolution */
47
48 double dstrsrc = 0.0; /* square source distribution */
49 double shadthresh = .05; /* shadow threshold */
50 double shadcert = .5; /* shadow certainty */
51 int directrelay = 1; /* number of source relays */
52 int vspretest = 512; /* virtual source pretest density */
53 int directinvis = 0; /* sources invisible? */
54 double srcsizerat = .25; /* maximum ratio source size/dist. */
55
56 double specthresh = .15; /* specular sampling threshold */
57 double specjitter = 1.; /* specular sampling jitter */
58
59 int maxdepth = 6; /* maximum recursion depth */
60 double minweight = 4e-3; /* minimum ray weight */
61
62 COLOR ambval = BLKCOLOR; /* ambient value */
63 double ambacc = 0.2; /* ambient accuracy */
64 int ambres = 32; /* ambient resolution */
65 int ambdiv = 128; /* ambient divisions */
66 int ambssamp = 0; /* ambient super-samples */
67 int ambounce = 0; /* ambient bounces */
68 char *amblist[128]; /* ambient include/exclude list */
69 int ambincl = -1; /* include == 1, exclude == 0 */
70
71 extern OBJREC Lamb; /* a Lambertian surface */
72
73 static RAY thisray; /* for our convenience */
74
75 static int oputo(), oputd(), oputv(), oputl(), oputL(),
76 oputp(), oputn(), oputs(), oputw(), oputm();
77
78 static int (*ray_out[10])(), (*every_out[10])();
79 static int castonly;
80
81 static int puta(), putf(), putd();
82
83 static int (*putreal)();
84
85
86 quit(code) /* quit program */
87 int code;
88 {
89 exit(code);
90 }
91
92
93 char *
94 formstr(f) /* return format identifier */
95 int f;
96 {
97 switch (f) {
98 case 'a': return("ascii");
99 case 'f': return("float");
100 case 'd': return("double");
101 case 'c': return(COLRFMT);
102 }
103 return("unknown");
104 }
105
106
107 rtrace(fname) /* trace rays from file */
108 char *fname;
109 {
110 long vcount = hresolu>1 ? hresolu*vresolu : vresolu;
111 long nextflush = hresolu;
112 FILE *fp;
113 FVECT orig, direc;
114 /* set up input */
115 if (fname == NULL)
116 fp = stdin;
117 else if ((fp = fopen(fname, "r")) == NULL) {
118 sprintf(errmsg, "cannot open input file \"%s\"", fname);
119 error(SYSTEM, errmsg);
120 }
121 #ifdef MSDOS
122 if (inform != 'a')
123 setmode(fileno(fp), O_BINARY);
124 #endif
125 /* set up output */
126 setoutput(outvals);
127 switch (outform) {
128 case 'a': putreal = puta; break;
129 case 'f': putreal = putf; break;
130 case 'd': putreal = putd; break;
131 case 'c':
132 if (strcmp(outvals, "v"))
133 error(USER, "color format with value output only");
134 break;
135 default:
136 error(CONSISTENCY, "botched output format");
137 }
138 if (hresolu > 0 && vresolu > 0)
139 fprtresolu(hresolu, vresolu, stdout);
140 /* process file */
141 while (getvec(orig, inform, fp) == 0 &&
142 getvec(direc, inform, fp) == 0) {
143
144 if (normalize(direc) == 0.0) { /* zero ==> flush */
145 fflush(stdout);
146 continue;
147 }
148 samplendx++;
149 /* compute and print */
150 if (imm_irrad)
151 irrad(orig, direc);
152 else
153 traceray(orig, direc);
154 /* flush if time */
155 if (--nextflush == 0) {
156 fflush(stdout);
157 nextflush = hresolu;
158 }
159 if (ferror(stdout))
160 error(SYSTEM, "write error");
161 if (--vcount == 0) /* check for end */
162 break;
163 }
164 if (vcount > 0)
165 error(USER, "read error");
166 fclose(fp);
167 }
168
169
170 setoutput(vs) /* set up output tables */
171 register char *vs;
172 {
173 extern int ourtrace(), (*trace)();
174 register int (**table)() = ray_out;
175
176 castonly = 1;
177 while (*vs)
178 switch (*vs++) {
179 case 't': /* trace */
180 *table = NULL;
181 table = every_out;
182 trace = ourtrace;
183 castonly = 0;
184 break;
185 case 'o': /* origin */
186 *table++ = oputo;
187 break;
188 case 'd': /* direction */
189 *table++ = oputd;
190 break;
191 case 'v': /* value */
192 *table++ = oputv;
193 castonly = 0;
194 break;
195 case 'l': /* effective distance */
196 *table++ = oputl;
197 castonly = 0;
198 break;
199 case 'L': /* single ray length */
200 *table++ = oputL;
201 break;
202 case 'p': /* point */
203 *table++ = oputp;
204 break;
205 case 'n': /* normal */
206 *table++ = oputn;
207 break;
208 case 's': /* surface */
209 *table++ = oputs;
210 break;
211 case 'w': /* weight */
212 *table++ = oputw;
213 break;
214 case 'm': /* modifier */
215 *table++ = oputm;
216 break;
217 }
218 *table = NULL;
219 }
220
221
222 traceray(org, dir) /* compute and print ray value(s) */
223 FVECT org, dir;
224 {
225 register int (**tp)();
226
227 VCOPY(thisray.rorg, org);
228 VCOPY(thisray.rdir, dir);
229 rayorigin(&thisray, NULL, PRIMARY, 1.0);
230 if (castonly)
231 localhit(&thisray, &thescene) || sourcehit(&thisray);
232 else
233 rayvalue(&thisray);
234
235 if (ray_out[0] == NULL)
236 return;
237 for (tp = ray_out; *tp != NULL; tp++)
238 (**tp)(&thisray);
239 if (outform == 'a')
240 putchar('\n');
241 }
242
243
244 irrad(org, dir) /* compute immediate irradiance value */
245 FVECT org, dir;
246 {
247 register int i;
248
249 for (i = 0; i < 3; i++) {
250 thisray.rorg[i] = org[i] + dir[i];
251 thisray.rdir[i] = -dir[i];
252 }
253 rayorigin(&thisray, NULL, PRIMARY, 1.0);
254 /* pretend we hit surface */
255 thisray.rot = 1.0;
256 thisray.rod = 1.0;
257 VCOPY(thisray.ron, dir);
258 for (i = 0; i < 3; i++) /* fudge factor */
259 thisray.rop[i] = org[i] + 1e-4*dir[i];
260 /* compute and print */
261 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
262 oputv(&thisray);
263 if (outform == 'a')
264 putchar('\n');
265 }
266
267
268 getvec(vec, fmt, fp) /* get a vector from fp */
269 register FVECT vec;
270 int fmt;
271 FILE *fp;
272 {
273 extern char *fgetword();
274 static float vf[3];
275 static double vd[3];
276 char buf[32];
277 register int i;
278
279 switch (fmt) {
280 case 'a': /* ascii */
281 for (i = 0; i < 3; i++) {
282 if (fgetword(buf, sizeof(buf), fp) == NULL ||
283 !isflt(buf))
284 return(-1);
285 vec[i] = atof(buf);
286 }
287 break;
288 case 'f': /* binary float */
289 if (fread((char *)vf, sizeof(float), 3, fp) != 3)
290 return(-1);
291 vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2];
292 break;
293 case 'd': /* binary double */
294 if (fread((char *)vd, sizeof(double), 3, fp) != 3)
295 return(-1);
296 vec[0] = vd[0]; vec[1] = vd[1]; vec[2] = vd[2];
297 break;
298 default:
299 error(CONSISTENCY, "botched input format");
300 }
301 return(0);
302 }
303
304
305 static
306 ourtrace(r) /* print ray values */
307 RAY *r;
308 {
309 register int (**tp)();
310
311 if (every_out[0] == NULL)
312 return;
313 tabin(r);
314 for (tp = every_out; *tp != NULL; tp++)
315 (**tp)(r);
316 putchar('\n');
317 }
318
319
320 static
321 tabin(r) /* tab in appropriate amount */
322 RAY *r;
323 {
324 register RAY *rp;
325
326 for (rp = r->parent; rp != NULL; rp = rp->parent)
327 putchar('\t');
328 }
329
330
331 static
332 oputo(r) /* print origin */
333 register RAY *r;
334 {
335 (*putreal)(r->rorg[0]);
336 (*putreal)(r->rorg[1]);
337 (*putreal)(r->rorg[2]);
338 }
339
340
341 static
342 oputd(r) /* print direction */
343 register RAY *r;
344 {
345 (*putreal)(r->rdir[0]);
346 (*putreal)(r->rdir[1]);
347 (*putreal)(r->rdir[2]);
348 }
349
350
351 static
352 oputv(r) /* print value */
353 register RAY *r;
354 {
355 COLR cout;
356
357 if (outform == 'c') {
358 setcolr(cout, colval(r->rcol,RED),
359 colval(r->rcol,GRN),
360 colval(r->rcol,BLU));
361 fwrite((char *)cout, sizeof(cout), 1, stdout);
362 return;
363 }
364 (*putreal)(colval(r->rcol,RED));
365 (*putreal)(colval(r->rcol,GRN));
366 (*putreal)(colval(r->rcol,BLU));
367 }
368
369
370 static
371 oputl(r) /* print effective distance */
372 register RAY *r;
373 {
374 (*putreal)(r->rt);
375 }
376
377
378 static
379 oputL(r) /* print single ray length */
380 register RAY *r;
381 {
382 (*putreal)(r->rot);
383 }
384
385
386 static
387 oputp(r) /* print point */
388 register RAY *r;
389 {
390 if (r->rot < FHUGE) {
391 (*putreal)(r->rop[0]);
392 (*putreal)(r->rop[1]);
393 (*putreal)(r->rop[2]);
394 } else {
395 (*putreal)(0.0);
396 (*putreal)(0.0);
397 (*putreal)(0.0);
398 }
399 }
400
401
402 static
403 oputn(r) /* print normal */
404 register RAY *r;
405 {
406 if (r->rot < FHUGE) {
407 (*putreal)(r->ron[0]);
408 (*putreal)(r->ron[1]);
409 (*putreal)(r->ron[2]);
410 } else {
411 (*putreal)(0.0);
412 (*putreal)(0.0);
413 (*putreal)(0.0);
414 }
415 }
416
417
418 static
419 oputs(r) /* print name */
420 register RAY *r;
421 {
422 if (r->ro != NULL)
423 fputs(r->ro->oname, stdout);
424 else
425 putchar('*');
426 putchar('\t');
427 }
428
429
430 static
431 oputw(r) /* print weight */
432 register RAY *r;
433 {
434 (*putreal)(r->rweight);
435 }
436
437
438 static
439 oputm(r) /* print modifier */
440 register RAY *r;
441 {
442 if (r->ro != NULL)
443 fputs(objptr(r->ro->omod)->oname, stdout);
444 else
445 putchar('*');
446 putchar('\t');
447 }
448
449
450 static
451 puta(v) /* print ascii value */
452 double v;
453 {
454 printf("%e\t", v);
455 }
456
457
458 static
459 putd(v) /* print binary double */
460 double v;
461 {
462 fwrite((char *)&v, sizeof(v), 1, stdout);
463 }
464
465
466 static
467 putf(v) /* print binary float */
468 double v;
469 {
470 float f = v;
471
472 fwrite((char *)&f, sizeof(f), 1, stdout);
473 }
