| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rtrace.c,v 2.64 2010/09/26 15:49:39 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* rtrace.c - program and variables for individual ray tracing.
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
| 11 |
* Input is in the form:
| 12 |
| 13 |
* xorg yorg zorg xdir ydir zdir
| 14 |
| 15 |
* The direction need not be normalized. Output is flexible.
| 16 |
* If the direction vector is (0,0,0), then the output is flushed.
| 17 |
* All values default to ascii representation of real
| 18 |
* numbers. Binary representations can be selected
| 19 |
* with '-ff' for float or '-fd' for double. By default,
| 20 |
* radiance is computed. The '-i' or '-I' options indicate that
| 21 |
* irradiance values are desired.
| 22 |
| 23 |
| 24 |
#include <time.h>
| 25 |
| 26 |
#include "platform.h"
| 27 |
#include "ray.h"
| 28 |
#include "ambient.h"
| 29 |
#include "source.h"
| 30 |
#include "otypes.h"
| 31 |
#include "resolu.h"
| 32 |
#include "random.h"
| 33 |
| 34 |
extern int inform; /* input format */
| 35 |
extern int outform; /* output format */
| 36 |
extern char *outvals; /* output values */
| 37 |
| 38 |
extern int imm_irrad; /* compute immediate irradiance? */
| 39 |
extern int lim_dist; /* limit distance? */
| 40 |
| 41 |
extern char *tralist[]; /* list of modifers to trace (or no) */
| 42 |
extern int traincl; /* include == 1, exclude == 0 */
| 43 |
| 44 |
extern int hresolu; /* horizontal resolution */
| 45 |
extern int vresolu; /* vertical resolution */
| 46 |
| 47 |
static int castonly = 0;
| 48 |
| 49 |
#ifndef MAXTSET
| 50 |
#define MAXTSET 8191 /* maximum number in trace set */
| 51 |
#endif
| 52 |
OBJECT traset[MAXTSET+1]={0}; /* trace include/exclude set */
| 53 |
| 54 |
static RAY thisray; /* for our convenience */
| 55 |
| 56 |
typedef void putf_t(RREAL *v, int n);
| 57 |
static putf_t puta, putd, putf;
| 58 |
| 59 |
typedef void oputf_t(RAY *r);
| 60 |
static oputf_t oputo, oputd, oputv, oputV, oputl, oputL, oputc, oputp,
| 61 |
oputn, oputN, oputs, oputw, oputW, oputm, oputM, oputtilde;
| 62 |
| 63 |
static void setoutput(char *vs);
| 64 |
extern void tranotify(OBJECT obj);
| 65 |
static void bogusray(void);
| 66 |
static void raycast(RAY *r);
| 67 |
static void rayirrad(RAY *r);
| 68 |
static void rtcompute(FVECT org, FVECT dir, double dmax);
| 69 |
static int printvals(RAY *r);
| 70 |
static int getvec(FVECT vec, int fmt, FILE *fp);
| 71 |
static void tabin(RAY *r);
| 72 |
static void ourtrace(RAY *r);
| 73 |
| 74 |
static oputf_t *ray_out[16], *every_out[16];
| 75 |
static putf_t *putreal;
| 76 |
| 77 |
| 78 |
void
| 79 |
quit( /* quit program */
| 80 |
int code
| 81 |
| 82 |
| 83 |
if (ray_pnprocs > 0) /* close children if any */
| 84 |
ray_pclose(0);
| 85 |
#ifndef NON_POSIX
| 86 |
else if (!ray_pnprocs) {
| 87 |
headclean(); /* delete header file */
| 88 |
pfclean(); /* clean up persist files */
| 89 |
| 90 |
#endif
| 91 |
exit(code);
| 92 |
| 93 |
| 94 |
| 95 |
char *
| 96 |
formstr( /* return format identifier */
| 97 |
int f
| 98 |
| 99 |
| 100 |
switch (f) {
| 101 |
case 'a': return("ascii");
| 102 |
case 'f': return("float");
| 103 |
case 'd': return("double");
| 104 |
case 'c': return(COLRFMT);
| 105 |
| 106 |
return("unknown");
| 107 |
| 108 |
| 109 |
| 110 |
extern void
| 111 |
rtrace( /* trace rays from file */
| 112 |
char *fname,
| 113 |
int nproc
| 114 |
| 115 |
| 116 |
unsigned long vcount = (hresolu > 1) ? (unsigned long)hresolu*vresolu
| 117 |
: vresolu;
| 118 |
long nextflush = (vresolu > 0) & (hresolu > 1) ? 0 : hresolu;
| 119 |
FILE *fp;
| 120 |
double d;
| 121 |
FVECT orig, direc;
| 122 |
/* set up input */
| 123 |
if (fname == NULL)
| 124 |
fp = stdin;
| 125 |
else if ((fp = fopen(fname, "r")) == NULL) {
| 126 |
sprintf(errmsg, "cannot open input file \"%s\"", fname);
| 127 |
error(SYSTEM, errmsg);
| 128 |
| 129 |
if (inform != 'a')
| 130 |
SET_FILE_BINARY(fp);
| 131 |
/* set up output */
| 132 |
setoutput(outvals);
| 133 |
if (imm_irrad)
| 134 |
castonly = 0;
| 135 |
else if (castonly)
| 136 |
nproc = 1; /* don't bother multiprocessing */
| 137 |
switch (outform) {
| 138 |
case 'a': putreal = puta; break;
| 139 |
case 'f': putreal = putf; break;
| 140 |
case 'd': putreal = putd; break;
| 141 |
case 'c':
| 142 |
if (strcmp(outvals, "v"))
| 143 |
error(USER, "color format with value output only");
| 144 |
break;
| 145 |
default:
| 146 |
error(CONSISTENCY, "botched output format");
| 147 |
| 148 |
if (nproc > 1) { /* start multiprocessing */
| 149 |
ray_popen(nproc);
| 150 |
ray_fifo_out = printvals;
| 151 |
| 152 |
if (hresolu > 0) {
| 153 |
if (vresolu > 0)
| 154 |
fprtresolu(hresolu, vresolu, stdout);
| 155 |
fflush(stdout);
| 156 |
| 157 |
/* process file */
| 158 |
while (getvec(orig, inform, fp) == 0 &&
| 159 |
getvec(direc, inform, fp) == 0) {
| 160 |
| 161 |
d = normalize(direc);
| 162 |
if (d == 0.0) { /* zero ==> flush */
| 163 |
if (--nextflush <= 0 || !vcount) {
| 164 |
if (nproc > 1 && ray_fifo_flush() < 0)
| 165 |
error(USER, "lost children");
| 166 |
bogusray();
| 167 |
fflush(stdout);
| 168 |
| 169 |
hresolu;
| 170 |
} else
| 171 |
bogusray();
| 172 |
} else { /* compute and print */
| 173 |
rtcompute(orig, direc, lim_dist ? d : 0.0);
| 174 |
/* flush if time */
| 175 |
if (!--nextflush) {
| 176 |
| 177 |
| 178 |
fflush(stdout);
| 179 |
nextflush = hresolu;
| 180 |
| 181 |
| 182 |
if (ferror(stdout))
| 183 |
error(SYSTEM, "write error");
| 184 |
if (vcount && !--vcount) /* check for end */
| 185 |
break;
| 186 |
| 187 |
if (nproc > 1) { /* clean up children */
| 188 |
if (ray_fifo_flush() < 0)
| 189 |
error(USER, "unable to complete processing");
| 190 |
ray_pclose(0);
| 191 |
| 192 |
if (fflush(stdout) < 0)
| 193 |
| 194 |
if (vcount)
| 195 |
error(USER, "unexpected EOF on input");
| 196 |
if (fname != NULL)
| 197 |
fclose(fp);
| 198 |
| 199 |
| 200 |
| 201 |
static void
| 202 |
trace_sources(void) /* trace rays to light sources, also */
| 203 |
| 204 |
int sn;
| 205 |
| 206 |
for (sn = 0; sn < nsources; sn++)
| 207 |
source[sn].sflags |= SFOLLOW;
| 208 |
| 209 |
| 210 |
| 211 |
static void
| 212 |
setoutput( /* set up output tables */
| 213 |
char *vs
| 214 |
| 215 |
| 216 |
oputf_t **table = ray_out;
| 217 |
| 218 |
castonly = 1;
| 219 |
while (*vs)
| 220 |
switch (*vs++) {
| 221 |
case 'T': /* trace sources */
| 222 |
if (!*vs) break;
| 223 |
trace_sources();
| 224 |
/* fall through */
| 225 |
case 't': /* trace */
| 226 |
if (!*vs) break;
| 227 |
*table = NULL;
| 228 |
table = every_out;
| 229 |
trace = ourtrace;
| 230 |
castonly = 0;
| 231 |
break;
| 232 |
case 'o': /* origin */
| 233 |
*table++ = oputo;
| 234 |
break;
| 235 |
case 'd': /* direction */
| 236 |
*table++ = oputd;
| 237 |
break;
| 238 |
case 'v': /* value */
| 239 |
*table++ = oputv;
| 240 |
castonly = 0;
| 241 |
break;
| 242 |
case 'V': /* contribution */
| 243 |
*table++ = oputV;
| 244 |
if (ambounce > 0 && (ambacc > FTINY || ambssamp > 0))
| 245 |
error(WARNING,
| 246 |
"-otV accuracy depends on -aa 0 -as 0");
| 247 |
break;
| 248 |
case 'l': /* effective distance */
| 249 |
*table++ = oputl;
| 250 |
castonly = 0;
| 251 |
break;
| 252 |
case 'c': /* local coordinates */
| 253 |
*table++ = oputc;
| 254 |
break;
| 255 |
case 'L': /* single ray length */
| 256 |
*table++ = oputL;
| 257 |
break;
| 258 |
case 'p': /* point */
| 259 |
*table++ = oputp;
| 260 |
break;
| 261 |
case 'n': /* perturbed normal */
| 262 |
*table++ = oputn;
| 263 |
castonly = 0;
| 264 |
break;
| 265 |
case 'N': /* unperturbed normal */
| 266 |
*table++ = oputN;
| 267 |
break;
| 268 |
case 's': /* surface */
| 269 |
*table++ = oputs;
| 270 |
break;
| 271 |
case 'w': /* weight */
| 272 |
*table++ = oputw;
| 273 |
break;
| 274 |
case 'W': /* coefficient */
| 275 |
*table++ = oputW;
| 276 |
| 277 |
error(WARNING,
| 278 |
"-otW accuracy depends on -aa 0 -as 0");
| 279 |
break;
| 280 |
case 'm': /* modifier */
| 281 |
*table++ = oputm;
| 282 |
break;
| 283 |
case 'M': /* material */
| 284 |
*table++ = oputM;
| 285 |
break;
| 286 |
case '~': /* tilde */
| 287 |
*table++ = oputtilde;
| 288 |
break;
| 289 |
| 290 |
*table = NULL;
| 291 |
| 292 |
| 293 |
| 294 |
static void
| 295 |
bogusray(void) /* print out empty record */
| 296 |
| 297 |
thisray.rorg[0] = thisray.rorg[1] = thisray.rorg[2] =
| 298 |
thisray.rdir[0] = thisray.rdir[1] = thisray.rdir[2] = 0.0;
| 299 |
thisray.rmax = 0.0;
| 300 |
rayorigin(&thisray, PRIMARY, NULL, NULL);
| 301 |
printvals(&thisray);
| 302 |
| 303 |
| 304 |
| 305 |
static void
| 306 |
raycast( /* compute first ray intersection only */
| 307 |
RAY *r
| 308 |
| 309 |
| 310 |
if (!localhit(r, &thescene)) {
| 311 |
if (r->ro == &Aftplane) { /* clipped */
| 312 |
r->ro = NULL;
| 313 |
r->rot = FHUGE;
| 314 |
} else
| 315 |
sourcehit(r);
| 316 |
| 317 |
| 318 |
| 319 |
| 320 |
static void
| 321 |
rayirrad( /* compute irradiance rather than radiance */
| 322 |
RAY *r
| 323 |
| 324 |
| 325 |
void (*old_revf)(RAY *) = r->revf;
| 326 |
| 327 |
r->rot = 1e-5; /* pretend we hit surface */
| 328 |
VSUM(r->rop, r->rorg, r->rdir, r->rot);
| 329 |
r->ron[0] = -r->rdir[0];
| 330 |
r->ron[1] = -r->rdir[1];
| 331 |
r->ron[2] = -r->rdir[2];
| 332 |
r->rod = 1.0;
| 333 |
/* compute result */
| 334 |
r->revf = raytrace;
| 335 |
(*ofun[Lamb.otype].funp)(&Lamb, r);
| 336 |
r->revf = old_revf;
| 337 |
| 338 |
| 339 |
| 340 |
static void
| 341 |
rtcompute( /* compute and print ray value(s) */
| 342 |
FVECT org,
| 343 |
FVECT dir,
| 344 |
double dmax
| 345 |
| 346 |
| 347 |
/* set up ray */
| 348 |
| 349 |
if (imm_irrad) {
| 350 |
VSUM(thisray.rorg, org, dir, 1.1e-4);
| 351 |
thisray.rdir[0] = -dir[0];
| 352 |
thisray.rdir[1] = -dir[1];
| 353 |
thisray.rdir[2] = -dir[2];
| 354 |
thisray.rmax = 0.0;
| 355 |
thisray.revf = rayirrad;
| 356 |
} else {
| 357 |
VCOPY(thisray.rorg, org);
| 358 |
VCOPY(thisray.rdir, dir);
| 359 |
thisray.rmax = dmax;
| 360 |
if (castonly)
| 361 |
thisray.revf = raycast;
| 362 |
| 363 |
if (ray_pnprocs > 1) { /* multiprocessing FIFO? */
| 364 |
if (ray_fifo_in(&thisray) < 0)
| 365 |
| 366 |
return;
| 367 |
| 368 |
samplendx++; /* else do it ourselves */
| 369 |
rayvalue(&thisray);
| 370 |
| 371 |
| 372 |
| 373 |
| 374 |
static int
| 375 |
printvals( /* print requested ray values */
| 376 |
RAY *r
| 377 |
| 378 |
| 379 |
oputf_t **tp;
| 380 |
| 381 |
if (ray_out[0] == NULL)
| 382 |
return(0);
| 383 |
for (tp = ray_out; *tp != NULL; tp++)
| 384 |
(**tp)(r);
| 385 |
if (outform == 'a')
| 386 |
putchar('\n');
| 387 |
return(1);
| 388 |
| 389 |
| 390 |
| 391 |
static int
| 392 |
getvec( /* get a vector from fp */
| 393 |
FVECT vec,
| 394 |
int fmt,
| 395 |
FILE *fp
| 396 |
| 397 |
| 398 |
static float vf[3];
| 399 |
static double vd[3];
| 400 |
char buf[32];
| 401 |
int i;
| 402 |
| 403 |
switch (fmt) {
| 404 |
case 'a': /* ascii */
| 405 |
for (i = 0; i < 3; i++) {
| 406 |
if (fgetword(buf, sizeof(buf), fp) == NULL ||
| 407 |
!isflt(buf))
| 408 |
return(-1);
| 409 |
vec[i] = atof(buf);
| 410 |
| 411 |
break;
| 412 |
case 'f': /* binary float */
| 413 |
if (fread((char *)vf, sizeof(float), 3, fp) != 3)
| 414 |
return(-1);
| 415 |
VCOPY(vec, vf);
| 416 |
break;
| 417 |
case 'd': /* binary double */
| 418 |
if (fread((char *)vd, sizeof(double), 3, fp) != 3)
| 419 |
return(-1);
| 420 |
VCOPY(vec, vd);
| 421 |
break;
| 422 |
default:
| 423 |
error(CONSISTENCY, "botched input format");
| 424 |
| 425 |
return(0);
| 426 |
| 427 |
| 428 |
| 429 |
void
| 430 |
tranotify( /* record new modifier */
| 431 |
OBJECT obj
| 432 |
| 433 |
| 434 |
static int hitlimit = 0;
| 435 |
OBJREC *o = objptr(obj);
| 436 |
char **tralp;
| 437 |
| 438 |
if (obj == OVOID) { /* starting over */
| 439 |
traset[0] = 0;
| 440 |
hitlimit = 0;
| 441 |
return;
| 442 |
| 443 |
if (hitlimit || !ismodifier(o->otype))
| 444 |
return;
| 445 |
for (tralp = tralist; *tralp != NULL; tralp++)
| 446 |
if (!strcmp(o->oname, *tralp)) {
| 447 |
if (traset[0] >= MAXTSET) {
| 448 |
error(WARNING, "too many modifiers in trace list");
| 449 |
hitlimit++;
| 450 |
return; /* should this be fatal? */
| 451 |
| 452 |
insertelem(traset, obj);
| 453 |
return;
| 454 |
| 455 |
| 456 |
| 457 |
| 458 |
static void
| 459 |
ourtrace( /* print ray values */
| 460 |
RAY *r
| 461 |
| 462 |
| 463 |
oputf_t **tp;
| 464 |
| 465 |
if (every_out[0] == NULL)
| 466 |
return;
| 467 |
if (r->ro == NULL) {
| 468 |
if (traincl == 1)
| 469 |
return;
| 470 |
} else if (traincl != -1 && traincl != inset(traset, r->ro->omod))
| 471 |
return;
| 472 |
tabin(r);
| 473 |
for (tp = every_out; *tp != NULL; tp++)
| 474 |
(**tp)(r);
| 475 |
if (outform == 'a')
| 476 |
putchar('\n');
| 477 |
| 478 |
| 479 |
| 480 |
static void
| 481 |
tabin( /* tab in appropriate amount */
| 482 |
RAY *r
| 483 |
| 484 |
| 485 |
const RAY *rp;
| 486 |
| 487 |
for (rp = r->parent; rp != NULL; rp = rp->parent)
| 488 |
putchar('\t');
| 489 |
| 490 |
| 491 |
| 492 |
static void
| 493 |
oputo( /* print origin */
| 494 |
RAY *r
| 495 |
| 496 |
| 497 |
(*putreal)(r->rorg, 3);
| 498 |
| 499 |
| 500 |
| 501 |
static void
| 502 |
oputd( /* print direction */
| 503 |
RAY *r
| 504 |
| 505 |
| 506 |
(*putreal)(r->rdir, 3);
| 507 |
| 508 |
| 509 |
| 510 |
static void
| 511 |
oputv( /* print value */
| 512 |
RAY *r
| 513 |
| 514 |
| 515 |
RREAL cval[3];
| 516 |
| 517 |
if (outform == 'c') {
| 518 |
COLR cout;
| 519 |
setcolr(cout, colval(r->rcol,RED),
| 520 |
colval(r->rcol,GRN),
| 521 |
colval(r->rcol,BLU));
| 522 |
fwrite(cout, sizeof(cout), 1, stdout);
| 523 |
return;
| 524 |
| 525 |
cval[0] = colval(r->rcol,RED);
| 526 |
cval[1] = colval(r->rcol,GRN);
| 527 |
cval[2] = colval(r->rcol,BLU);
| 528 |
(*putreal)(cval, 3);
| 529 |
| 530 |
| 531 |
| 532 |
static void
| 533 |
oputV( /* print value contribution */
| 534 |
RAY *r
| 535 |
| 536 |
| 537 |
RREAL contr[3];
| 538 |
| 539 |
raycontrib(contr, r, PRIMARY);
| 540 |
multcolor(contr, r->rcol);
| 541 |
(*putreal)(contr, 3);
| 542 |
| 543 |
| 544 |
| 545 |
static void
| 546 |
oputl( /* print effective distance */
| 547 |
RAY *r
| 548 |
| 549 |
| 550 |
(*putreal)(&r->rt, 1);
| 551 |
| 552 |
| 553 |
| 554 |
static void
| 555 |
oputL( /* print single ray length */
| 556 |
RAY *r
| 557 |
| 558 |
| 559 |
(*putreal)(&r->rot, 1);
| 560 |
| 561 |
| 562 |
| 563 |
static void
| 564 |
oputc( /* print local coordinates */
| 565 |
RAY *r
| 566 |
| 567 |
| 568 |
(*putreal)(r->uv, 2);
| 569 |
| 570 |
| 571 |
| 572 |
static RREAL vdummy[3] = {0.0, 0.0, 0.0};
| 573 |
| 574 |
| 575 |
static void
| 576 |
oputp( /* print point */
| 577 |
RAY *r
| 578 |
| 579 |
| 580 |
if (r->rot < FHUGE)
| 581 |
(*putreal)(r->rop, 3);
| 582 |
else
| 583 |
(*putreal)(vdummy, 3);
| 584 |
| 585 |
| 586 |
| 587 |
static void
| 588 |
oputN( /* print unperturbed normal */
| 589 |
RAY *r
| 590 |
| 591 |
| 592 |
if (r->rot < FHUGE)
| 593 |
(*putreal)(r->ron, 3);
| 594 |
else
| 595 |
| 596 |
| 597 |
| 598 |
| 599 |
static void
| 600 |
oputn( /* print perturbed normal */
| 601 |
RAY *r
| 602 |
| 603 |
| 604 |
FVECT pnorm;
| 605 |
| 606 |
if (r->rot >= FHUGE) {
| 607 |
| 608 |
return;
| 609 |
| 610 |
raynormal(pnorm, r);
| 611 |
(*putreal)(pnorm, 3);
| 612 |
| 613 |
| 614 |
| 615 |
static void
| 616 |
oputs( /* print name */
| 617 |
RAY *r
| 618 |
| 619 |
| 620 |
if (r->ro != NULL)
| 621 |
fputs(r->ro->oname, stdout);
| 622 |
else
| 623 |
putchar('*');
| 624 |
putchar('\t');
| 625 |
| 626 |
| 627 |
| 628 |
static void
| 629 |
oputw( /* print weight */
| 630 |
RAY *r
| 631 |
| 632 |
| 633 |
RREAL rwt = r->rweight;
| 634 |
| 635 |
(*putreal)(&rwt, 1);
| 636 |
| 637 |
| 638 |
| 639 |
static void
| 640 |
oputW( /* print coefficient */
| 641 |
RAY *r
| 642 |
| 643 |
| 644 |
RREAL contr[3];
| 645 |
| 646 |
| 647 |
| 648 |
| 649 |
| 650 |
| 651 |
static void
| 652 |
oputm( /* print modifier */
| 653 |
RAY *r
| 654 |
| 655 |
| 656 |
if (r->ro != NULL)
| 657 |
if (r->ro->omod != OVOID)
| 658 |
fputs(objptr(r->ro->omod)->oname, stdout);
| 659 |
else
| 660 |
fputs(VOIDID, stdout);
| 661 |
else
| 662 |
putchar('*');
| 663 |
putchar('\t');
| 664 |
| 665 |
| 666 |
| 667 |
static void
| 668 |
oputM( /* print material */
| 669 |
RAY *r
| 670 |
| 671 |
| 672 |
OBJREC *mat;
| 673 |
| 674 |
if (r->ro != NULL) {
| 675 |
if ((mat = findmaterial(r->ro)) != NULL)
| 676 |
fputs(mat->oname, stdout);
| 677 |
else
| 678 |
| 679 |
} else
| 680 |
putchar('*');
| 681 |
putchar('\t');
| 682 |
| 683 |
| 684 |
| 685 |
static void
| 686 |
oputtilde( /* output tilde (spacer) */
| 687 |
RAY *r
| 688 |
| 689 |
| 690 |
fputs("~\t", stdout);
| 691 |
| 692 |
| 693 |
| 694 |
static void
| 695 |
puta( /* print ascii value(s) */
| 696 |
RREAL *v, int n
| 697 |
| 698 |
| 699 |
if (n == 3) {
| 700 |
printf("%e\t%e\t%e\t", v[0], v[1], v[2]);
| 701 |
return;
| 702 |
| 703 |
while (n--)
| 704 |
printf("%e\t", *v++);
| 705 |
| 706 |
| 707 |
| 708 |
static void
| 709 |
putd(RREAL *v, int n) /* print binary double(s) */
| 710 |
| 711 |
if (sizeof(RREAL) != sizeof(double))
| 712 |
error(INTERNAL, "code error in putd()");
| 713 |
fwrite(v, sizeof(RREAL), n, stdout);
| 714 |
| 715 |
| 716 |
| 717 |
static void
| 718 |
putf(RREAL *v, int n) /* print binary float(s) */
| 719 |
| 720 |
float fa[3];
| 721 |
int i;
| 722 |
| 723 |
if (n > 3)
| 724 |
error(INTERNAL, "code error in putf()");
| 725 |
for (i = n; i--; )
| 726 |
fa[i] = v[i];
| 727 |
fwrite(fa, sizeof(float), n, stdout);
| 728 |
