root/radiance/ray/src/rt/rtrace.c
Revision: 2.1
Committed: Tue Nov 12 17:09:39 1991 UTC (32 years, 7 months ago) by greg
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rtrace.c - program and variables for individual ray tracing.
9 *
10 * 6/11/86
11 */
12
13 /*
14 * Input is in the form:
15 *
16 * xorg yorg zorg xdir ydir zdir
17 *
18 * The direction need not be normalized. Output is flexible.
19 * If the direction vector is (0,0,0), then the output is flushed.
20 * All values default to ascii representation of real
21 * numbers. Binary representations can be selected
22 * with '-ff' for float or '-fd' for double. By default,
23 * radiance is computed. The '-i' or '-I' options indicate that
24 * irradiance values are desired.
25 */
26
27 #include "ray.h"
28
29 #include "octree.h"
30
31 #include "otypes.h"
32
33 int dimlist[MAXDIM]; /* sampling dimensions */
34 int ndims = 0; /* number of sampling dimensions */
35 int samplendx = 0; /* index for this sample */
36
37 int imm_irrad = 0; /* compute immediate irradiance? */
38
39 int inform = 'a'; /* input format */
40 int outform = 'a'; /* output format */
41 char *outvals = "v"; /* output specification */
42
43 int hresolu = 0; /* horizontal (scan) size */
44 int vresolu = 0; /* vertical resolution */
45
46 double dstrsrc = 0.0; /* square source distribution */
47 double shadthresh = .05; /* shadow threshold */
48 double shadcert = .5; /* shadow certainty */
49 int directrelay = 1; /* number of source relays */
50 int vspretest = 512; /* virtual source pretest density */
51 int directinvis = 0; /* sources invisible? */
52 double srcsizerat = .25; /* maximum ratio source size/dist. */
53
54 int maxdepth = 6; /* maximum recursion depth */
55 double minweight = 4e-3; /* minimum ray weight */
56
57 COLOR ambval = BLKCOLOR; /* ambient value */
58 double ambacc = 0.2; /* ambient accuracy */
59 int ambres = 32; /* ambient resolution */
60 int ambdiv = 128; /* ambient divisions */
61 int ambssamp = 0; /* ambient super-samples */
62 int ambounce = 0; /* ambient bounces */
63 char *amblist[128]; /* ambient include/exclude list */
64 int ambincl = -1; /* include == 1, exclude == 0 */
65
66 extern OBJREC Lamb; /* a Lambertian surface */
67
68 static RAY thisray; /* for our convenience */
69
70 static int oputo(), oputd(), oputv(), oputl(),
71 oputp(), oputn(), oputs(), oputw(), oputm();
72
73 static int (*ray_out[10])(), (*every_out[10])();
74 static int castonly;
75
76 static int puta(), putf(), putd();
77
78 static int (*putreal)();
79
80
81 quit(code) /* quit program */
82 int code;
83 {
84 exit(code);
85 }
86
87
88 rtrace(fname) /* trace rays from file */
89 char *fname;
90 {
91 long vcount = hresolu>1 ? hresolu*vresolu : vresolu;
92 long nextflush = hresolu;
93 FILE *fp;
94 FVECT orig, direc;
95 /* set up input */
96 if (fname == NULL)
97 fp = stdin;
98 else if ((fp = fopen(fname, "r")) == NULL) {
99 sprintf(errmsg, "cannot open input file \"%s\"", fname);
100 error(SYSTEM, errmsg);
101 }
102 /* set up output */
103 setoutput(outvals);
104 switch (outform) {
105 case 'a': putreal = puta; break;
106 case 'f': putreal = putf; break;
107 case 'd': putreal = putd; break;
108 }
109 /* process file */
110 while (getvec(orig, inform, fp) == 0 &&
111 getvec(direc, inform, fp) == 0) {
112
113 if (normalize(direc) == 0.0) { /* zero ==> flush */
114 fflush(stdout);
115 continue;
116 }
117 samplendx++;
118 /* compute and print */
119 if (imm_irrad)
120 irrad(orig, direc);
121 else
122 traceray(orig, direc);
123 /* flush if time */
124 if (--nextflush == 0) {
125 fflush(stdout);
126 nextflush = hresolu;
127 }
128 if (ferror(stdout))
129 error(SYSTEM, "write error");
130 if (--vcount == 0) /* check for end */
131 break;
132 }
133 if (vcount > 0)
134 error(USER, "read error");
135 fclose(fp);
136 }
137
138
139 setoutput(vs) /* set up output tables */
140 register char *vs;
141 {
142 extern int ourtrace(), (*trace)();
143 register int (**table)() = ray_out;
144
145 castonly = 1;
146 while (*vs)
147 switch (*vs++) {
148 case 't': /* trace */
149 *table = NULL;
150 table = every_out;
151 trace = ourtrace;
152 castonly = 0;
153 break;
154 case 'o': /* origin */
155 *table++ = oputo;
156 break;
157 case 'd': /* direction */
158 *table++ = oputd;
159 break;
160 case 'v': /* value */
161 *table++ = oputv;
162 castonly = 0;
163 break;
164 case 'l': /* length */
165 *table++ = oputl;
166 castonly = 0;
167 break;
168 case 'p': /* point */
169 *table++ = oputp;
170 break;
171 case 'n': /* normal */
172 *table++ = oputn;
173 break;
174 case 's': /* surface */
175 *table++ = oputs;
176 break;
177 case 'w': /* weight */
178 *table++ = oputw;
179 break;
180 case 'm': /* modifier */
181 *table++ = oputm;
182 break;
183 }
184 *table = NULL;
185 }
186
187
188 traceray(org, dir) /* compute and print ray value(s) */
189 FVECT org, dir;
190 {
191 register int (**tp)();
192
193 VCOPY(thisray.rorg, org);
194 VCOPY(thisray.rdir, dir);
195 rayorigin(&thisray, NULL, PRIMARY, 1.0);
196 if (castonly)
197 localhit(&thisray, &thescene) || sourcehit(&thisray);
198 else
199 rayvalue(&thisray);
200
201 if (ray_out[0] == NULL)
202 return;
203 for (tp = ray_out; *tp != NULL; tp++)
204 (**tp)(&thisray);
205 if (outform == 'a')
206 putchar('\n');
207 }
208
209
210 irrad(org, dir) /* compute immediate irradiance value */
211 FVECT org, dir;
212 {
213 register int i;
214
215 for (i = 0; i < 3; i++) {
216 thisray.rorg[i] = org[i] + dir[i];
217 thisray.rdir[i] = -dir[i];
218 }
219 rayorigin(&thisray, NULL, PRIMARY, 1.0);
220 /* pretend we hit surface */
221 thisray.rot = 1.0;
222 thisray.rod = 1.0;
223 VCOPY(thisray.ron, dir);
224 for (i = 0; i < 3; i++) /* fudge factor */
225 thisray.rop[i] = org[i] + 1e-4*dir[i];
226 /* compute and print */
227 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
228 oputv(&thisray);
229 if (outform == 'a')
230 putchar('\n');
231 }
232
233
234 getvec(vec, fmt, fp) /* get a vector from fp */
235 register FVECT vec;
236 int fmt;
237 FILE *fp;
238 {
239 extern char *fgetword();
240 extern double atof();
241 static float vf[3];
242 char buf[32];
243 register int i;
244
245 switch (fmt) {
246 case 'a': /* ascii */
247 for (i = 0; i < 3; i++) {
248 if (fgetword(buf, sizeof(buf), fp) == NULL ||
249 !isflt(buf))
250 return(-1);
251 vec[i] = atof(buf);
252 }
253 break;
254 case 'f': /* binary float */
255 if (fread((char *)vf, sizeof(float), 3, fp) != 3)
256 return(-1);
257 vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2];
258 break;
259 case 'd': /* binary double */
260 if (fread((char *)vec, sizeof(double), 3, fp) != 3)
261 return(-1);
262 break;
263 }
264 return(0);
265 }
266
267
268 static
269 ourtrace(r) /* print ray values */
270 RAY *r;
271 {
272 register int (**tp)();
273
274 if (every_out[0] == NULL)
275 return;
276 tabin(r);
277 for (tp = every_out; *tp != NULL; tp++)
278 (**tp)(r);
279 putchar('\n');
280 }
281
282
283 static
284 tabin(r) /* tab in appropriate amount */
285 RAY *r;
286 {
287 register RAY *rp;
288
289 for (rp = r->parent; rp != NULL; rp = rp->parent)
290 putchar('\t');
291 }
292
293
294 static
295 oputo(r) /* print origin */
296 register RAY *r;
297 {
298 (*putreal)(r->rorg[0]);
299 (*putreal)(r->rorg[1]);
300 (*putreal)(r->rorg[2]);
301 }
302
303
304 static
305 oputd(r) /* print direction */
306 register RAY *r;
307 {
308 (*putreal)(r->rdir[0]);
309 (*putreal)(r->rdir[1]);
310 (*putreal)(r->rdir[2]);
311 }
312
313
314 static
315 oputv(r) /* print value */
316 register RAY *r;
317 {
318 (*putreal)(colval(r->rcol,RED));
319 (*putreal)(colval(r->rcol,GRN));
320 (*putreal)(colval(r->rcol,BLU));
321 }
322
323
324 static
325 oputl(r) /* print length */
326 register RAY *r;
327 {
328 (*putreal)(r->rt);
329 }
330
331
332 static
333 oputp(r) /* print point */
334 register RAY *r;
335 {
336 if (r->rot < FHUGE) {
337 (*putreal)(r->rop[0]);
338 (*putreal)(r->rop[1]);
339 (*putreal)(r->rop[2]);
340 } else {
341 (*putreal)(0.0);
342 (*putreal)(0.0);
343 (*putreal)(0.0);
344 }
345 }
346
347
348 static
349 oputn(r) /* print normal */
350 register RAY *r;
351 {
352 if (r->rot < FHUGE) {
353 (*putreal)(r->ron[0]);
354 (*putreal)(r->ron[1]);
355 (*putreal)(r->ron[2]);
356 } else {
357 (*putreal)(0.0);
358 (*putreal)(0.0);
359 (*putreal)(0.0);
360 }
361 }
362
363
364 static
365 oputs(r) /* print name */
366 register RAY *r;
367 {
368 if (r->ro != NULL)
369 fputs(r->ro->oname, stdout);
370 else
371 putchar('*');
372 putchar('\t');
373 }
374
375
376 static
377 oputw(r) /* print weight */
378 register RAY *r;
379 {
380 (*putreal)(r->rweight);
381 }
382
383
384 static
385 oputm(r) /* print modifier */
386 register RAY *r;
387 {
388 if (r->ro != NULL)
389 fputs(objptr(r->ro->omod)->oname, stdout);
390 else
391 putchar('*');
392 putchar('\t');
393 }
394
395
396 static
397 puta(v) /* print ascii value */
398 double v;
399 {
400 printf("%e\t", v);
401 }
402
403
404 static
405 putd(v) /* print binary double */
406 double v;
407 {
408 fwrite((char *)&v, sizeof(v), 1, stdout);
409 }
410
411
412 static
413 putf(v) /* print binary float */
414 double v;
415 {
416 float f = v;
417
418 fwrite((char *)&f, sizeof(f), 1, stdout);
419 }
