root/radiance/ray/src/rt/rtrace.c
Revision: 2.36
Committed: Sun Mar 28 16:31:14 2004 UTC (21 years, 4 months ago) by greg
2 static const char RCSid[] = "$Id: rtrace.c,v 2.35 2003/10/04 14:39:53 greg Exp $";
5 * rtrace.c - program and variables for individual ray tracing.
6 */
7
8 #include "copyright.h"
9
10 /*
11 * Input is in the form:
12 *
13 * xorg yorg zorg xdir ydir zdir
14 *
15 * The direction need not be normalized. Output is flexible.
16 * If the direction vector is (0,0,0), then the output is flushed.
17 * All values default to ascii representation of real
18 * numbers. Binary representations can be selected
19 * with '-ff' for float or '-fd' for double. By default,
20 * radiance is computed. The '-i' or '-I' options indicate that
21 * irradiance values are desired.
22 */
23
24 #include <time.h>
25
26 #include "platform.h"
27 #include "ray.h"
28 #include "otypes.h"
29 #include "resolu.h"
30
31 CUBE thescene; /* our scene */
32 OBJECT nsceneobjs; /* number of objects in our scene */
33
34 int dimlist[MAXDIM]; /* sampling dimensions */
35 int ndims = 0; /* number of sampling dimensions */
36 int samplendx = 0; /* index for this sample */
37
38 int imm_irrad = 0; /* compute immediate irradiance? */
39 int lim_dist = 0; /* limit distance? */
40
41 int inform = 'a'; /* input format */
42 int outform = 'a'; /* output format */
43 char *outvals = "v"; /* output specification */
44
45 int do_irrad = 0; /* compute irradiance? */
46
47 void (*trace)() = NULL; /* trace call */
48
49 extern void ambnotify(), tranotify();
50 void (*addobjnotify[])() = {ambnotify, tranotify, NULL};
51 char *tralist[128]; /* list of modifers to trace (or no) */
52 int traincl = -1; /* include == 1, exclude == 0 */
53 #define MAXTSET 511 /* maximum number in trace set */
54 OBJECT traset[MAXTSET+1]={0}; /* trace include/exclude set */
55
56 int hresolu = 0; /* horizontal (scan) size */
57 int vresolu = 0; /* vertical resolution */
58
59 double dstrsrc = 0.0; /* square source distribution */
60 double shadthresh = .03; /* shadow threshold */
61 double shadcert = .75; /* shadow certainty */
62 int directrelay = 2; /* number of source relays */
63 int vspretest = 512; /* virtual source pretest density */
64 int directvis = 1; /* sources visible? */
65 double srcsizerat = .2; /* maximum ratio source size/dist. */
66
67 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
68 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
69 double seccg = 0.; /* global scattering eccentricity */
70 double ssampdist = 0.; /* scatter sampling distance */
71
72 double specthresh = .15; /* specular sampling threshold */
73 double specjitter = 1.; /* specular sampling jitter */
74
75 int backvis = 1; /* back face visibility */
76
77 int maxdepth = 8; /* maximum recursion depth */
78 double minweight = 2e-3; /* minimum ray weight */
79
80 char *ambfile = NULL; /* ambient file name */
81 COLOR ambval = BLKCOLOR; /* ambient value */
82 int ambvwt = 0; /* initial weight for ambient value */
83 double ambacc = 0.15; /* ambient accuracy */
84 int ambres = 256; /* ambient resolution */
85 int ambdiv = 1024; /* ambient divisions */
86 int ambssamp = 512; /* ambient super-samples */
87 int ambounce = 0; /* ambient bounces */
88 char *amblist[128]; /* ambient include/exclude list */
89 int ambincl = -1; /* include == 1, exclude == 0 */
90
91
92 static RAY thisray; /* for our convenience */
93
94 static void oputo(), oputd(), oputv(), oputl(), oputL(), oputc(),
95 oputp(), oputn(), oputN(), oputs(), oputw(), oputm();
96
97 static void ourtrace(), tabin();
98 static void (*ray_out[16])(), (*every_out[16])();
99 static int castonly = 0;
100
101 static void puta(), putf(), putd();
102
103 static void (*putreal)();
104
105 void bogusray(), rad(), irrad(), printvals();
106
107
108 void
109 quit(code) /* quit program */
110 int code;
111 {
112 #ifndef NON_POSIX /* XXX we don't clean up elsewhere? */
113 headclean(); /* delete header file */
114 pfclean(); /* clean up persist files */
115 #endif
116 exit(code);
117 }
118
119
120 char *
121 formstr(f) /* return format identifier */
122 int f;
123 {
124 switch (f) {
125 case 'a': return("ascii");
126 case 'f': return("float");
127 case 'd': return("double");
128 case 'c': return(COLRFMT);
129 }
130 return("unknown");
131 }
132
133
134 void
135 rtrace(fname) /* trace rays from file */
136 char *fname;
137 {
138 long vcount = hresolu>1 ? hresolu*vresolu : vresolu;
139 long nextflush = hresolu;
140 FILE *fp;
141 double d;
142 FVECT orig, direc;
143 /* set up input */
144 if (fname == NULL)
145 fp = stdin;
146 else if ((fp = fopen(fname, "r")) == NULL) {
147 sprintf(errmsg, "cannot open input file \"%s\"", fname);
148 error(SYSTEM, errmsg);
149 }
150 #ifdef _WIN32
151 if (inform != 'a')
152 SET_FILE_BINARY(fp);
153 #endif
154 /* set up output */
155 setoutput(outvals);
156 switch (outform) {
157 case 'a': putreal = puta; break;
158 case 'f': putreal = putf; break;
159 case 'd': putreal = putd; break;
160 case 'c':
161 if (strcmp(outvals, "v"))
162 error(USER, "color format with value output only");
163 break;
164 default:
165 error(CONSISTENCY, "botched output format");
166 }
167 if (hresolu > 0) {
168 if (vresolu > 0)
169 fprtresolu(hresolu, vresolu, stdout);
170 fflush(stdout);
171 }
172 /* process file */
173 while (getvec(orig, inform, fp) == 0 &&
174 getvec(direc, inform, fp) == 0) {
175
176 d = normalize(direc);
177 if (d == 0.0) { /* zero ==> flush */
178 bogusray();
179 if (--nextflush <= 0 || vcount <= 0) {
180 fflush(stdout);
181 nextflush = hresolu;
182 }
183 } else {
184 samplendx++;
185 /* compute and print */
186 if (imm_irrad)
187 irrad(orig, direc);
188 else
189 rad(orig, direc, lim_dist ? d : 0.0);
190 /* flush if time */
191 if (--nextflush == 0) {
192 fflush(stdout);
193 nextflush = hresolu;
194 }
195 }
196 if (ferror(stdout))
197 error(SYSTEM, "write error");
198 if (--vcount == 0) /* check for end */
199 break;
200 }
201 fflush(stdout);
202 if (vcount > 0)
203 error(USER, "read error");
204 if (fname != NULL)
205 fclose(fp);
206 }
207
208
209 setoutput(vs) /* set up output tables */
210 register char *vs;
211 {
212 extern void (*trace)();
213 register void (**table)() = ray_out;
214
215 castonly = 1;
216 while (*vs)
217 switch (*vs++) {
218 case 't': /* trace */
219 *table = NULL;
220 table = every_out;
221 trace = ourtrace;
222 castonly = 0;
223 break;
224 case 'o': /* origin */
225 *table++ = oputo;
226 break;
227 case 'd': /* direction */
228 *table++ = oputd;
229 break;
230 case 'v': /* value */
231 *table++ = oputv;
232 castonly = 0;
233 break;
234 case 'l': /* effective distance */
235 *table++ = oputl;
236 castonly = 0;
237 break;
238 case 'c': /* local coordinates */
239 *table++ = oputc;
240 break;
241 case 'L': /* single ray length */
242 *table++ = oputL;
243 break;
244 case 'p': /* point */
245 *table++ = oputp;
246 break;
247 case 'n': /* perturbed normal */
248 *table++ = oputn;
249 castonly = 0;
250 break;
251 case 'N': /* unperturbed normal */
252 *table++ = oputN;
253 break;
254 case 's': /* surface */
255 *table++ = oputs;
256 break;
257 case 'w': /* weight */
258 *table++ = oputw;
259 break;
260 case 'm': /* modifier */
261 *table++ = oputm;
262 break;
263 }
264 *table = NULL;
265 }
266
267
268 void
269 bogusray() /* print out empty record */
270 {
271 thisray.rorg[0] = thisray.rorg[1] = thisray.rorg[2] =
272 thisray.rdir[0] = thisray.rdir[1] = thisray.rdir[2] = 0.0;
273 rayorigin(&thisray, NULL, PRIMARY, 1.0);
274 printvals(&thisray);
275 }
276
277
278 void
279 rad(org, dir, dmax) /* compute and print ray value(s) */
280 FVECT org, dir;
281 double dmax;
282 {
283 VCOPY(thisray.rorg, org);
284 VCOPY(thisray.rdir, dir);
285 thisray.rmax = dmax;
286 rayorigin(&thisray, NULL, PRIMARY, 1.0);
287 if (castonly) {
288 if (!localhit(&thisray, &thescene)) {
289 if (thisray.ro == &Aftplane) { /* clipped */
290 thisray.ro = NULL;
291 thisray.rot = FHUGE;
292 } else
293 sourcehit(&thisray);
294 }
295 } else
296 rayvalue(&thisray);
297 printvals(&thisray);
298 }
299
300
301 void
302 irrad(org, dir) /* compute immediate irradiance value */
303 FVECT org, dir;
304 {
305 register int i;
306
307 for (i = 0; i < 3; i++) {
308 thisray.rorg[i] = org[i] + dir[i];
309 thisray.rdir[i] = -dir[i];
310 }
311 rayorigin(&thisray, NULL, PRIMARY, 1.0);
312 /* pretend we hit surface */
313 thisray.rot = 1.0-1e-4;
314 thisray.rod = 1.0;
315 VCOPY(thisray.ron, dir);
316 for (i = 0; i < 3; i++) /* fudge factor */
317 thisray.rop[i] = org[i] + 1e-4*dir[i];
318 /* compute and print */
319 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
320 printvals(&thisray);
321 }
322
323
324 void
325 printvals(r) /* print requested ray values */
326 RAY *r;
327 {
328 register void (**tp)();
329
330 if (ray_out[0] == NULL)
331 return;
332 for (tp = ray_out; *tp != NULL; tp++)
333 (**tp)(r);
334 if (outform == 'a')
335 putchar('\n');
336 }
337
338
339 int
340 getvec(vec, fmt, fp) /* get a vector from fp */
341 register FVECT vec;
342 int fmt;
343 FILE *fp;
344 {
345 static float vf[3];
346 static double vd[3];
347 char buf[32];
348 register int i;
349
350 switch (fmt) {
351 case 'a': /* ascii */
352 for (i = 0; i < 3; i++) {
353 if (fgetword(buf, sizeof(buf), fp) == NULL ||
354 !isflt(buf))
355 return(-1);
356 vec[i] = atof(buf);
357 }
358 break;
359 case 'f': /* binary float */
360 if (fread((char *)vf, sizeof(float), 3, fp) != 3)
361 return(-1);
362 vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2];
363 break;
364 case 'd': /* binary double */
365 if (fread((char *)vd, sizeof(double), 3, fp) != 3)
366 return(-1);
367 vec[0] = vd[0]; vec[1] = vd[1]; vec[2] = vd[2];
368 break;
369 default:
370 error(CONSISTENCY, "botched input format");
371 }
372 return(0);
373 }
374
375
376 void
377 tranotify(obj) /* record new modifier */
378 OBJECT obj;
379 {
380 static int hitlimit = 0;
381 register OBJREC *o = objptr(obj);
382 register char **tralp;
383
384 if (obj == OVOID) { /* starting over */
385 traset[0] = 0;
386 hitlimit = 0;
387 return;
388 }
389 if (hitlimit || !ismodifier(o->otype))
390 return;
391 for (tralp = tralist; *tralp != NULL; tralp++)
392 if (!strcmp(o->oname, *tralp)) {
393 if (traset[0] >= MAXTSET) {
394 error(WARNING, "too many modifiers in trace list");
395 hitlimit++;
396 return; /* should this be fatal? */
397 }
398 insertelem(traset, obj);
399 return;
400 }
401 }
402
403
404 static void
405 ourtrace(r) /* print ray values */
406 RAY *r;
407 {
408 register void (**tp)();
409
410 if (every_out[0] == NULL)
411 return;
412 if (r->ro == NULL) {
413 if (traincl == 1)
414 return;
415 } else if (traincl != -1 && traincl != inset(traset, r->ro->omod))
416 return;
417 tabin(r);
418 for (tp = every_out; *tp != NULL; tp++)
419 (**tp)(r);
420 putchar('\n');
421 }
422
423
424 static void
425 tabin(r) /* tab in appropriate amount */
426 RAY *r;
427 {
428 register RAY *rp;
429
430 for (rp = r->parent; rp != NULL; rp = rp->parent)
431 putchar('\t');
432 }
433
434
435 static void
436 oputo(r) /* print origin */
437 RAY *r;
438 {
439 (*putreal)(r->rorg[0]);
440 (*putreal)(r->rorg[1]);
441 (*putreal)(r->rorg[2]);
442 }
443
444
445 static void
446 oputd(r) /* print direction */
447 RAY *r;
448 {
449 (*putreal)(r->rdir[0]);
450 (*putreal)(r->rdir[1]);
451 (*putreal)(r->rdir[2]);
452 }
453
454
455 static void
456 oputv(r) /* print value */
457 RAY *r;
458 {
459 COLR cout;
460
461 if (outform == 'c') {
462 setcolr(cout, colval(r->rcol,RED),
463 colval(r->rcol,GRN),
464 colval(r->rcol,BLU));
465 fwrite((char *)cout, sizeof(cout), 1, stdout);
466 return;
467 }
468 (*putreal)(colval(r->rcol,RED));
469 (*putreal)(colval(r->rcol,GRN));
470 (*putreal)(colval(r->rcol,BLU));
471 }
472
473
474 static void
475 oputl(r) /* print effective distance */
476 RAY *r;
477 {
478 (*putreal)(r->rt);
479 }
480
481
482 static void
483 oputL(r) /* print single ray length */
484 RAY *r;
485 {
486 (*putreal)(r->rot);
487 }
488
489
490 static void
491 oputc(r) /* print local coordinates */
492 RAY *r;
493 {
494 (*putreal)(r->uv[0]);
495 (*putreal)(r->uv[1]);
496 }
497
498
499 static void
500 oputp(r) /* print point */
501 RAY *r;
502 {
503 if (r->rot < FHUGE) {
504 (*putreal)(r->rop[0]);
505 (*putreal)(r->rop[1]);
506 (*putreal)(r->rop[2]);
507 } else {
508 (*putreal)(0.0);
509 (*putreal)(0.0);
510 (*putreal)(0.0);
511 }
512 }
513
514
515 static void
516 oputN(r) /* print unperturbed normal */
517 RAY *r;
518 {
519 if (r->rot < FHUGE) {
520 (*putreal)(r->ron[0]);
521 (*putreal)(r->ron[1]);
522 (*putreal)(r->ron[2]);
523 } else {
524 (*putreal)(0.0);
525 (*putreal)(0.0);
526 (*putreal)(0.0);
527 }
528 }
529
530
531 static void
532 oputn(r) /* print perturbed normal */
533 RAY *r;
534 {
535 FVECT pnorm;
536
537 if (r->rot >= FHUGE) {
538 (*putreal)(0.0);
539 (*putreal)(0.0);
540 (*putreal)(0.0);
541 return;
542 }
543 raynormal(pnorm, r);
544 (*putreal)(pnorm[0]);
545 (*putreal)(pnorm[1]);
546 (*putreal)(pnorm[2]);
547 }
548
549
550 static void
551 oputs(r) /* print name */
552 RAY *r;
553 {
554 if (r->ro != NULL)
555 fputs(r->ro->oname, stdout);
556 else
557 putchar('*');
558 putchar('\t');
559 }
560
561
562 static void
563 oputw(r) /* print weight */
564 RAY *r;
565 {
566 (*putreal)(r->rweight);
567 }
568
569
570 static void
571 oputm(r) /* print modifier */
572 RAY *r;
573 {
574 if (r->ro != NULL)
575 if (r->ro->omod != OVOID)
576 fputs(objptr(r->ro->omod)->oname, stdout);
577 else
578 fputs(VOIDID, stdout);
579 else
580 putchar('*');
581 putchar('\t');
582 }
583
584
585 static void
586 puta(v) /* print ascii value */
587 double v;
588 {
589 printf("%e\t", v);
590 }
591
592
593 static void
594 putd(v) /* print binary double */
595 double v;
596 {
597 fwrite((char *)&v, sizeof(v), 1, stdout);
598 }
599
600
601 static void
602 putf(v) /* print binary float */
603 double v;
604 {
605 float f = v;
606
607 fwrite((char *)&f, sizeof(f), 1, stdout);
608 }
