root/radiance/ray/src/rt/rtrace.c
Revision: 2.30
Committed: Thu Jun 5 19:29:34 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 2.29: +4 -5 lines
2 static const char RCSid[] = "$Id: rtrace.c,v 2.29 2003/04/18 17:29:22 greg Exp $";
5 * rtrace.c - program and variables for individual ray tracing.
6 */
7
8 #include "copyright.h"
9
10 /*
11 * Input is in the form:
12 *
13 * xorg yorg zorg xdir ydir zdir
14 *
15 * The direction need not be normalized. Output is flexible.
16 * If the direction vector is (0,0,0), then the output is flushed.
17 * All values default to ascii representation of real
18 * numbers. Binary representations can be selected
19 * with '-ff' for float or '-fd' for double. By default,
20 * radiance is computed. The '-i' or '-I' options indicate that
21 * irradiance values are desired.
22 */
23
24 #include "platform.h"
25 #include "ray.h"
26 #include "otypes.h"
27 #include "resolu.h"
28
29 CUBE thescene; /* our scene */
30 OBJECT nsceneobjs; /* number of objects in our scene */
31
32 int dimlist[MAXDIM]; /* sampling dimensions */
33 int ndims = 0; /* number of sampling dimensions */
34 int samplendx = 0; /* index for this sample */
35
36 int imm_irrad = 0; /* compute immediate irradiance? */
37 int lim_dist = 0; /* limit distance? */
38
39 int inform = 'a'; /* input format */
40 int outform = 'a'; /* output format */
41 char *outvals = "v"; /* output specification */
42
43 int do_irrad = 0; /* compute irradiance? */
44
45 void (*trace)() = NULL; /* trace call */
46
47 extern void ambnotify(), tranotify();
48 void (*addobjnotify[])() = {ambnotify, tranotify, NULL};
49 char *tralist[128]; /* list of modifers to trace (or no) */
50 int traincl = -1; /* include == 1, exclude == 0 */
51 #define MAXTSET 511 /* maximum number in trace set */
52 OBJECT traset[MAXTSET+1]={0}; /* trace include/exclude set */
53
54 int hresolu = 0; /* horizontal (scan) size */
55 int vresolu = 0; /* vertical resolution */
56
57 double dstrsrc = 0.0; /* square source distribution */
58 double shadthresh = .05; /* shadow threshold */
59 double shadcert = .5; /* shadow certainty */
60 int directrelay = 2; /* number of source relays */
61 int vspretest = 512; /* virtual source pretest density */
62 int directvis = 1; /* sources visible? */
63 double srcsizerat = .2; /* maximum ratio source size/dist. */
64
65 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
66 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
67 double seccg = 0.; /* global scattering eccentricity */
68 double ssampdist = 0.; /* scatter sampling distance */
69
70 double specthresh = .15; /* specular sampling threshold */
71 double specjitter = 1.; /* specular sampling jitter */
72
73 int backvis = 1; /* back face visibility */
74
75 int maxdepth = 6; /* maximum recursion depth */
76 double minweight = 4e-3; /* minimum ray weight */
77
78 char *ambfile = NULL; /* ambient file name */
79 COLOR ambval = BLKCOLOR; /* ambient value */
80 int ambvwt = 0; /* initial weight for ambient value */
81 double ambacc = 0.2; /* ambient accuracy */
82 int ambres = 128; /* ambient resolution */
83 int ambdiv = 512; /* ambient divisions */
84 int ambssamp = 0; /* ambient super-samples */
85 int ambounce = 0; /* ambient bounces */
86 char *amblist[128]; /* ambient include/exclude list */
87 int ambincl = -1; /* include == 1, exclude == 0 */
88
89
90 static RAY thisray; /* for our convenience */
91
92 static void oputo(), oputd(), oputv(), oputl(), oputL(), oputc(),
93 oputp(), oputn(), oputN(), oputs(), oputw(), oputm();
94
95 static void ourtrace(), tabin();
96 static void (*ray_out[16])(), (*every_out[16])();
97 static int castonly = 0;
98
99 static void puta(), putf(), putd();
100
101 static void (*putreal)();
102
103 void bogusray(), rad(), irrad(), printvals();
104
105
106 void
107 quit(code) /* quit program */
108 int code;
109 {
110 #ifndef NIX
111 headclean(); /* delete header file */
112 pfclean(); /* clean up persist files */
113 #endif
114 exit(code);
115 }
116
117
118 char *
119 formstr(f) /* return format identifier */
120 int f;
121 {
122 switch (f) {
123 case 'a': return("ascii");
124 case 'f': return("float");
125 case 'd': return("double");
126 case 'c': return(COLRFMT);
127 }
128 return("unknown");
129 }
130
131
132 void
133 rtrace(fname) /* trace rays from file */
134 char *fname;
135 {
136 long vcount = hresolu>1 ? hresolu*vresolu : vresolu;
137 long nextflush = hresolu;
138 FILE *fp;
139 double d;
140 FVECT orig, direc;
141 /* set up input */
142 if (fname == NULL)
143 fp = stdin;
144 else if ((fp = fopen(fname, "r")) == NULL) {
145 sprintf(errmsg, "cannot open input file \"%s\"", fname);
146 error(SYSTEM, errmsg);
147 }
148 #ifdef _WIN32
149 if (inform != 'a')
150 SET_FILE_BINARY(fp);
151 #endif
152 /* set up output */
153 setoutput(outvals);
154 switch (outform) {
155 case 'a': putreal = puta; break;
156 case 'f': putreal = putf; break;
157 case 'd': putreal = putd; break;
158 case 'c':
159 if (strcmp(outvals, "v"))
160 error(USER, "color format with value output only");
161 break;
162 default:
163 error(CONSISTENCY, "botched output format");
164 }
165 if (hresolu > 0) {
166 if (vresolu > 0)
167 fprtresolu(hresolu, vresolu, stdout);
168 fflush(stdout);
169 }
170 /* process file */
171 while (getvec(orig, inform, fp) == 0 &&
172 getvec(direc, inform, fp) == 0) {
173
174 d = normalize(direc);
175 if (d == 0.0) { /* zero ==> flush */
176 bogusray();
177 if (--nextflush <= 0 || vcount <= 0) {
178 fflush(stdout);
179 nextflush = hresolu;
180 }
181 } else {
182 samplendx++;
183 /* compute and print */
184 if (imm_irrad)
185 irrad(orig, direc);
186 else
187 rad(orig, direc, lim_dist ? d : 0.0);
188 /* flush if time */
189 if (--nextflush == 0) {
190 fflush(stdout);
191 nextflush = hresolu;
192 }
193 }
194 if (ferror(stdout))
195 error(SYSTEM, "write error");
196 if (--vcount == 0) /* check for end */
197 break;
198 }
199 fflush(stdout);
200 if (vcount > 0)
201 error(USER, "read error");
202 if (fname != NULL)
203 fclose(fp);
204 }
205
206
207 setoutput(vs) /* set up output tables */
208 register char *vs;
209 {
210 extern void (*trace)();
211 register void (**table)() = ray_out;
212
213 castonly = 1;
214 while (*vs)
215 switch (*vs++) {
216 case 't': /* trace */
217 *table = NULL;
218 table = every_out;
219 trace = ourtrace;
220 castonly = 0;
221 break;
222 case 'o': /* origin */
223 *table++ = oputo;
224 break;
225 case 'd': /* direction */
226 *table++ = oputd;
227 break;
228 case 'v': /* value */
229 *table++ = oputv;
230 castonly = 0;
231 break;
232 case 'l': /* effective distance */
233 *table++ = oputl;
234 castonly = 0;
235 break;
236 case 'c': /* local coordinates */
237 *table++ = oputc;
238 break;
239 case 'L': /* single ray length */
240 *table++ = oputL;
241 break;
242 case 'p': /* point */
243 *table++ = oputp;
244 break;
245 case 'n': /* perturbed normal */
246 *table++ = oputn;
247 castonly = 0;
248 break;
249 case 'N': /* unperturbed normal */
250 *table++ = oputN;
251 break;
252 case 's': /* surface */
253 *table++ = oputs;
254 break;
255 case 'w': /* weight */
256 *table++ = oputw;
257 break;
258 case 'm': /* modifier */
259 *table++ = oputm;
260 break;
261 }
262 *table = NULL;
263 }
264
265
266 void
267 bogusray() /* print out empty record */
268 {
269 thisray.rorg[0] = thisray.rorg[1] = thisray.rorg[2] =
270 thisray.rdir[0] = thisray.rdir[1] = thisray.rdir[2] = 0.0;
271 rayorigin(&thisray, NULL, PRIMARY, 1.0);
272 printvals(&thisray);
273 }
274
275
276 void
277 rad(org, dir, dmax) /* compute and print ray value(s) */
278 FVECT org, dir;
279 double dmax;
280 {
281 VCOPY(thisray.rorg, org);
282 VCOPY(thisray.rdir, dir);
283 thisray.rmax = dmax;
284 rayorigin(&thisray, NULL, PRIMARY, 1.0);
285 if (castonly) {
286 if (!localhit(&thisray, &thescene))
287 if (thisray.ro == &Aftplane) { /* clipped */
288 thisray.ro = NULL;
289 thisray.rot = FHUGE;
290 } else
291 sourcehit(&thisray);
292 } else
293 rayvalue(&thisray);
294 printvals(&thisray);
295 }
296
297
298 void
299 irrad(org, dir) /* compute immediate irradiance value */
300 FVECT org, dir;
301 {
302 register int i;
303
304 for (i = 0; i < 3; i++) {
305 thisray.rorg[i] = org[i] + dir[i];
306 thisray.rdir[i] = -dir[i];
307 }
308 rayorigin(&thisray, NULL, PRIMARY, 1.0);
309 /* pretend we hit surface */
310 thisray.rot = 1.0-1e-4;
311 thisray.rod = 1.0;
312 VCOPY(thisray.ron, dir);
313 for (i = 0; i < 3; i++) /* fudge factor */
314 thisray.rop[i] = org[i] + 1e-4*dir[i];
315 /* compute and print */
316 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
317 printvals(&thisray);
318 }
319
320
321 void
322 printvals(r) /* print requested ray values */
323 RAY *r;
324 {
325 register void (**tp)();
326
327 if (ray_out[0] == NULL)
328 return;
329 for (tp = ray_out; *tp != NULL; tp++)
330 (**tp)(r);
331 if (outform == 'a')
332 putchar('\n');
333 }
334
335
336 int
337 getvec(vec, fmt, fp) /* get a vector from fp */
338 register FVECT vec;
339 int fmt;
340 FILE *fp;
341 {
342 static float vf[3];
343 static double vd[3];
344 char buf[32];
345 register int i;
346
347 switch (fmt) {
348 case 'a': /* ascii */
349 for (i = 0; i < 3; i++) {
350 if (fgetword(buf, sizeof(buf), fp) == NULL ||
351 !isflt(buf))
352 return(-1);
353 vec[i] = atof(buf);
354 }
355 break;
356 case 'f': /* binary float */
357 if (fread((char *)vf, sizeof(float), 3, fp) != 3)
358 return(-1);
359 vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2];
360 break;
361 case 'd': /* binary double */
362 if (fread((char *)vd, sizeof(double), 3, fp) != 3)
363 return(-1);
364 vec[0] = vd[0]; vec[1] = vd[1]; vec[2] = vd[2];
365 break;
366 default:
367 error(CONSISTENCY, "botched input format");
368 }
369 return(0);
370 }
371
372
373 void
374 tranotify(obj) /* record new modifier */
375 OBJECT obj;
376 {
377 static int hitlimit = 0;
378 register OBJREC *o = objptr(obj);
379 register char **tralp;
380
381 if (obj == OVOID) { /* starting over */
382 traset[0] = 0;
383 hitlimit = 0;
384 return;
385 }
386 if (hitlimit || !ismodifier(o->otype))
387 return;
388 for (tralp = tralist; *tralp != NULL; tralp++)
389 if (!strcmp(o->oname, *tralp)) {
390 if (traset[0] >= MAXTSET) {
391 error(WARNING, "too many modifiers in trace list");
392 hitlimit++;
393 return; /* should this be fatal? */
394 }
395 insertelem(traset, obj);
396 return;
397 }
398 }
399
400
401 static void
402 ourtrace(r) /* print ray values */
403 RAY *r;
404 {
405 register void (**tp)();
406
407 if (every_out[0] == NULL)
408 return;
409 if (r->ro == NULL) {
410 if (traincl == 1)
411 return;
412 } else if (traincl != -1 && traincl != inset(traset, r->ro->omod))
413 return;
414 tabin(r);
415 for (tp = every_out; *tp != NULL; tp++)
416 (**tp)(r);
417 putchar('\n');
418 }
419
420
421 static void
422 tabin(r) /* tab in appropriate amount */
423 RAY *r;
424 {
425 register RAY *rp;
426
427 for (rp = r->parent; rp != NULL; rp = rp->parent)
428 putchar('\t');
429 }
430
431
432 static void
433 oputo(r) /* print origin */
434 RAY *r;
435 {
436 (*putreal)(r->rorg[0]);
437 (*putreal)(r->rorg[1]);
438 (*putreal)(r->rorg[2]);
439 }
440
441
442 static void
443 oputd(r) /* print direction */
444 RAY *r;
445 {
446 (*putreal)(r->rdir[0]);
447 (*putreal)(r->rdir[1]);
448 (*putreal)(r->rdir[2]);
449 }
450
451
452 static void
453 oputv(r) /* print value */
454 RAY *r;
455 {
456 COLR cout;
457
458 if (outform == 'c') {
459 setcolr(cout, colval(r->rcol,RED),
460 colval(r->rcol,GRN),
461 colval(r->rcol,BLU));
462 fwrite((char *)cout, sizeof(cout), 1, stdout);
463 return;
464 }
465 (*putreal)(colval(r->rcol,RED));
466 (*putreal)(colval(r->rcol,GRN));
467 (*putreal)(colval(r->rcol,BLU));
468 }
469
470
471 static void
472 oputl(r) /* print effective distance */
473 RAY *r;
474 {
475 (*putreal)(r->rt);
476 }
477
478
479 static void
480 oputL(r) /* print single ray length */
481 RAY *r;
482 {
483 (*putreal)(r->rot);
484 }
485
486
487 static void
488 oputc(r) /* print local coordinates */
489 RAY *r;
490 {
491 (*putreal)(r->uv[0]);
492 (*putreal)(r->uv[1]);
493 }
494
495
496 static void
497 oputp(r) /* print point */
498 RAY *r;
499 {
500 if (r->rot < FHUGE) {
501 (*putreal)(r->rop[0]);
502 (*putreal)(r->rop[1]);
503 (*putreal)(r->rop[2]);
504 } else {
505 (*putreal)(0.0);
506 (*putreal)(0.0);
507 (*putreal)(0.0);
508 }
509 }
510
511
512 static void
513 oputN(r) /* print unperturbed normal */
514 RAY *r;
515 {
516 if (r->rot < FHUGE) {
517 (*putreal)(r->ron[0]);
518 (*putreal)(r->ron[1]);
519 (*putreal)(r->ron[2]);
520 } else {
521 (*putreal)(0.0);
522 (*putreal)(0.0);
523 (*putreal)(0.0);
524 }
525 }
526
527
528 static void
529 oputn(r) /* print perturbed normal */
530 RAY *r;
531 {
532 FVECT pnorm;
533
534 if (r->rot >= FHUGE) {
535 (*putreal)(0.0);
536 (*putreal)(0.0);
537 (*putreal)(0.0);
538 return;
539 }
540 raynormal(pnorm, r);
541 (*putreal)(pnorm[0]);
542 (*putreal)(pnorm[1]);
543 (*putreal)(pnorm[2]);
544 }
545
546
547 static void
548 oputs(r) /* print name */
549 RAY *r;
550 {
551 if (r->ro != NULL)
552 fputs(r->ro->oname, stdout);
553 else
554 putchar('*');
555 putchar('\t');
556 }
557
558
559 static void
560 oputw(r) /* print weight */
561 RAY *r;
562 {
563 (*putreal)(r->rweight);
564 }
565
566
567 static void
568 oputm(r) /* print modifier */
569 RAY *r;
570 {
571 if (r->ro != NULL)
572 if (r->ro->omod != OVOID)
573 fputs(objptr(r->ro->omod)->oname, stdout);
574 else
575 fputs(VOIDID, stdout);
576 else
577 putchar('*');
578 putchar('\t');
579 }
580
581
582 static void
583 puta(v) /* print ascii value */
584 double v;
585 {
586 printf("%e\t", v);
587 }
588
589
590 static void
591 putd(v) /* print binary double */
592 double v;
593 {
594 fwrite((char *)&v, sizeof(v), 1, stdout);
595 }
596
597
598 static void
599 putf(v) /* print binary float */
600 double v;
601 {
602 float f = v;
603
604 fwrite((char *)&f, sizeof(f), 1, stdout);
605 }
