root/radiance/ray/src/rt/rtrace.c
Revision: 2.29
Committed: Fri Apr 18 17:29:22 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.28: +23 -11 lines
Added rtrace -oc option to output local (u,v) coordinates
5 * rtrace.c - program and variables for individual ray tracing.
6 */
7
8 #include "copyright.h"
9
10 /*
11 * Input is in the form:
12 *
13 * xorg yorg zorg xdir ydir zdir
14 *
15 * The direction need not be normalized. Output is flexible.
16 * If the direction vector is (0,0,0), then the output is flushed.
17 * All values default to ascii representation of real
18 * numbers. Binary representations can be selected
19 * with '-ff' for float or '-fd' for double. By default,
20 * radiance is computed. The '-i' or '-I' options indicate that
21 * irradiance values are desired.
22 */
23
24 #include "ray.h"
25
26 #include "otypes.h"
27
28 #include "resolu.h"
29
30 CUBE thescene; /* our scene */
31 OBJECT nsceneobjs; /* number of objects in our scene */
32
33 int dimlist[MAXDIM]; /* sampling dimensions */
34 int ndims = 0; /* number of sampling dimensions */
35 int samplendx = 0; /* index for this sample */
36
37 int imm_irrad = 0; /* compute immediate irradiance? */
38 int lim_dist = 0; /* limit distance? */
39
40 int inform = 'a'; /* input format */
41 int outform = 'a'; /* output format */
42 char *outvals = "v"; /* output specification */
43
44 int do_irrad = 0; /* compute irradiance? */
45
46 void (*trace)() = NULL; /* trace call */
47
48 extern void ambnotify(), tranotify();
49 void (*addobjnotify[])() = {ambnotify, tranotify, NULL};
50 char *tralist[128]; /* list of modifers to trace (or no) */
51 int traincl = -1; /* include == 1, exclude == 0 */
52 #define MAXTSET 511 /* maximum number in trace set */
53 OBJECT traset[MAXTSET+1]={0}; /* trace include/exclude set */
54
55 int hresolu = 0; /* horizontal (scan) size */
56 int vresolu = 0; /* vertical resolution */
57
58 double dstrsrc = 0.0; /* square source distribution */
59 double shadthresh = .05; /* shadow threshold */
60 double shadcert = .5; /* shadow certainty */
61 int directrelay = 2; /* number of source relays */
62 int vspretest = 512; /* virtual source pretest density */
63 int directvis = 1; /* sources visible? */
64 double srcsizerat = .2; /* maximum ratio source size/dist. */
65
66 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
67 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
68 double seccg = 0.; /* global scattering eccentricity */
69 double ssampdist = 0.; /* scatter sampling distance */
70
71 double specthresh = .15; /* specular sampling threshold */
72 double specjitter = 1.; /* specular sampling jitter */
73
74 int backvis = 1; /* back face visibility */
75
76 int maxdepth = 6; /* maximum recursion depth */
77 double minweight = 4e-3; /* minimum ray weight */
78
79 char *ambfile = NULL; /* ambient file name */
80 COLOR ambval = BLKCOLOR; /* ambient value */
81 int ambvwt = 0; /* initial weight for ambient value */
82 double ambacc = 0.2; /* ambient accuracy */
83 int ambres = 128; /* ambient resolution */
84 int ambdiv = 512; /* ambient divisions */
85 int ambssamp = 0; /* ambient super-samples */
86 int ambounce = 0; /* ambient bounces */
87 char *amblist[128]; /* ambient include/exclude list */
88 int ambincl = -1; /* include == 1, exclude == 0 */
89
90
91 static RAY thisray; /* for our convenience */
92
93 static void oputo(), oputd(), oputv(), oputl(), oputL(), oputc(),
94 oputp(), oputn(), oputN(), oputs(), oputw(), oputm();
95
96 static void ourtrace(), tabin();
97 static void (*ray_out[16])(), (*every_out[16])();
98 static int castonly = 0;
99
100 static void puta(), putf(), putd();
101
102 static void (*putreal)();
103
104 void bogusray(), rad(), irrad(), printvals();
105
106
107 void
108 quit(code) /* quit program */
109 int code;
110 {
111 #ifndef NIX
112 headclean(); /* delete header file */
113 pfclean(); /* clean up persist files */
114 #endif
115 exit(code);
116 }
117
118
119 char *
120 formstr(f) /* return format identifier */
121 int f;
122 {
123 switch (f) {
124 case 'a': return("ascii");
125 case 'f': return("float");
126 case 'd': return("double");
127 case 'c': return(COLRFMT);
128 }
129 return("unknown");
130 }
131
132
133 void
134 rtrace(fname) /* trace rays from file */
135 char *fname;
136 {
137 long vcount = hresolu>1 ? hresolu*vresolu : vresolu;
138 long nextflush = hresolu;
139 FILE *fp;
140 double d;
141 FVECT orig, direc;
142 /* set up input */
143 if (fname == NULL)
144 fp = stdin;
145 else if ((fp = fopen(fname, "r")) == NULL) {
146 sprintf(errmsg, "cannot open input file \"%s\"", fname);
147 error(SYSTEM, errmsg);
148 }
149 #ifdef MSDOS
150 if (inform != 'a')
151 setmode(fileno(fp), O_BINARY);
152 #endif
153 /* set up output */
154 setoutput(outvals);
155 switch (outform) {
156 case 'a': putreal = puta; break;
157 case 'f': putreal = putf; break;
158 case 'd': putreal = putd; break;
159 case 'c':
160 if (strcmp(outvals, "v"))
161 error(USER, "color format with value output only");
162 break;
163 default:
164 error(CONSISTENCY, "botched output format");
165 }
166 if (hresolu > 0) {
167 if (vresolu > 0)
168 fprtresolu(hresolu, vresolu, stdout);
169 fflush(stdout);
170 }
171 /* process file */
172 while (getvec(orig, inform, fp) == 0 &&
173 getvec(direc, inform, fp) == 0) {
174
175 d = normalize(direc);
176 if (d == 0.0) { /* zero ==> flush */
177 bogusray();
178 if (--nextflush <= 0 || vcount <= 0) {
179 fflush(stdout);
180 nextflush = hresolu;
181 }
182 } else {
183 samplendx++;
184 /* compute and print */
185 if (imm_irrad)
186 irrad(orig, direc);
187 else
188 rad(orig, direc, lim_dist ? d : 0.0);
189 /* flush if time */
190 if (--nextflush == 0) {
191 fflush(stdout);
192 nextflush = hresolu;
193 }
194 }
195 if (ferror(stdout))
196 error(SYSTEM, "write error");
197 if (--vcount == 0) /* check for end */
198 break;
199 }
200 fflush(stdout);
201 if (vcount > 0)
202 error(USER, "read error");
203 if (fname != NULL)
204 fclose(fp);
205 }
206
207
208 setoutput(vs) /* set up output tables */
209 register char *vs;
210 {
211 extern void (*trace)();
212 register void (**table)() = ray_out;
213
214 castonly = 1;
215 while (*vs)
216 switch (*vs++) {
217 case 't': /* trace */
218 *table = NULL;
219 table = every_out;
220 trace = ourtrace;
221 castonly = 0;
222 break;
223 case 'o': /* origin */
224 *table++ = oputo;
225 break;
226 case 'd': /* direction */
227 *table++ = oputd;
228 break;
229 case 'v': /* value */
230 *table++ = oputv;
231 castonly = 0;
232 break;
233 case 'l': /* effective distance */
234 *table++ = oputl;
235 castonly = 0;
236 break;
237 case 'c': /* local coordinates */
238 *table++ = oputc;
239 break;
240 case 'L': /* single ray length */
241 *table++ = oputL;
242 break;
243 case 'p': /* point */
244 *table++ = oputp;
245 break;
246 case 'n': /* perturbed normal */
247 *table++ = oputn;
248 castonly = 0;
249 break;
250 case 'N': /* unperturbed normal */
251 *table++ = oputN;
252 break;
253 case 's': /* surface */
254 *table++ = oputs;
255 break;
256 case 'w': /* weight */
257 *table++ = oputw;
258 break;
259 case 'm': /* modifier */
260 *table++ = oputm;
261 break;
262 }
263 *table = NULL;
264 }
265
266
267 void
268 bogusray() /* print out empty record */
269 {
270 thisray.rorg[0] = thisray.rorg[1] = thisray.rorg[2] =
271 thisray.rdir[0] = thisray.rdir[1] = thisray.rdir[2] = 0.0;
272 rayorigin(&thisray, NULL, PRIMARY, 1.0);
273 printvals(&thisray);
274 }
275
276
277 void
278 rad(org, dir, dmax) /* compute and print ray value(s) */
279 FVECT org, dir;
280 double dmax;
281 {
282 VCOPY(thisray.rorg, org);
283 VCOPY(thisray.rdir, dir);
284 thisray.rmax = dmax;
285 rayorigin(&thisray, NULL, PRIMARY, 1.0);
286 if (castonly) {
287 if (!localhit(&thisray, &thescene))
288 if (thisray.ro == &Aftplane) { /* clipped */
289 thisray.ro = NULL;
290 thisray.rot = FHUGE;
291 } else
292 sourcehit(&thisray);
293 } else
294 rayvalue(&thisray);
295 printvals(&thisray);
296 }
297
298
299 void
300 irrad(org, dir) /* compute immediate irradiance value */
301 FVECT org, dir;
302 {
303 register int i;
304
305 for (i = 0; i < 3; i++) {
306 thisray.rorg[i] = org[i] + dir[i];
307 thisray.rdir[i] = -dir[i];
308 }
309 rayorigin(&thisray, NULL, PRIMARY, 1.0);
310 /* pretend we hit surface */
311 thisray.rot = 1.0-1e-4;
312 thisray.rod = 1.0;
313 VCOPY(thisray.ron, dir);
314 for (i = 0; i < 3; i++) /* fudge factor */
315 thisray.rop[i] = org[i] + 1e-4*dir[i];
316 /* compute and print */
317 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
318 printvals(&thisray);
319 }
320
321
322 void
323 printvals(r) /* print requested ray values */
324 RAY *r;
325 {
326 register void (**tp)();
327
328 if (ray_out[0] == NULL)
329 return;
330 for (tp = ray_out; *tp != NULL; tp++)
331 (**tp)(r);
332 if (outform == 'a')
333 putchar('\n');
334 }
335
336
337 int
338 getvec(vec, fmt, fp) /* get a vector from fp */
339 register FVECT vec;
340 int fmt;
341 FILE *fp;
342 {
343 static float vf[3];
344 static double vd[3];
345 char buf[32];
346 register int i;
347
348 switch (fmt) {
349 case 'a': /* ascii */
350 for (i = 0; i < 3; i++) {
351 if (fgetword(buf, sizeof(buf), fp) == NULL ||
352 !isflt(buf))
353 return(-1);
354 vec[i] = atof(buf);
355 }
356 break;
357 case 'f': /* binary float */
358 if (fread((char *)vf, sizeof(float), 3, fp) != 3)
359 return(-1);
360 vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2];
361 break;
362 case 'd': /* binary double */
363 if (fread((char *)vd, sizeof(double), 3, fp) != 3)
364 return(-1);
365 vec[0] = vd[0]; vec[1] = vd[1]; vec[2] = vd[2];
366 break;
367 default:
368 error(CONSISTENCY, "botched input format");
369 }
370 return(0);
371 }
372
373
374 void
375 tranotify(obj) /* record new modifier */
376 OBJECT obj;
377 {
378 static int hitlimit = 0;
379 register OBJREC *o = objptr(obj);
380 register char **tralp;
381
382 if (obj == OVOID) { /* starting over */
383 traset[0] = 0;
384 hitlimit = 0;
385 return;
386 }
387 if (hitlimit || !ismodifier(o->otype))
388 return;
389 for (tralp = tralist; *tralp != NULL; tralp++)
390 if (!strcmp(o->oname, *tralp)) {
391 if (traset[0] >= MAXTSET) {
392 error(WARNING, "too many modifiers in trace list");
393 hitlimit++;
394 return; /* should this be fatal? */
395 }
396 insertelem(traset, obj);
397 return;
398 }
399 }
400
401
402 static void
403 ourtrace(r) /* print ray values */
404 RAY *r;
405 {
406 register void (**tp)();
407
408 if (every_out[0] == NULL)
409 return;
410 if (r->ro == NULL) {
411 if (traincl == 1)
412 return;
413 } else if (traincl != -1 && traincl != inset(traset, r->ro->omod))
414 return;
415 tabin(r);
416 for (tp = every_out; *tp != NULL; tp++)
417 (**tp)(r);
418 putchar('\n');
419 }
420
421
422 static void
423 tabin(r) /* tab in appropriate amount */
424 RAY *r;
425 {
426 register RAY *rp;
427
428 for (rp = r->parent; rp != NULL; rp = rp->parent)
429 putchar('\t');
430 }
431
432
433 static void
434 oputo(r) /* print origin */
435 RAY *r;
436 {
437 (*putreal)(r->rorg[0]);
438 (*putreal)(r->rorg[1]);
439 (*putreal)(r->rorg[2]);
440 }
441
442
443 static void
444 oputd(r) /* print direction */
445 RAY *r;
446 {
447 (*putreal)(r->rdir[0]);
448 (*putreal)(r->rdir[1]);
449 (*putreal)(r->rdir[2]);
450 }
451
452
453 static void
454 oputv(r) /* print value */
455 RAY *r;
456 {
457 COLR cout;
458
459 if (outform == 'c') {
460 setcolr(cout, colval(r->rcol,RED),
461 colval(r->rcol,GRN),
462 colval(r->rcol,BLU));
463 fwrite((char *)cout, sizeof(cout), 1, stdout);
464 return;
465 }
466 (*putreal)(colval(r->rcol,RED));
467 (*putreal)(colval(r->rcol,GRN));
468 (*putreal)(colval(r->rcol,BLU));
469 }
470
471
472 static void
473 oputl(r) /* print effective distance */
474 RAY *r;
475 {
476 (*putreal)(r->rt);
477 }
478
479
480 static void
481 oputL(r) /* print single ray length */
482 RAY *r;
483 {
484 (*putreal)(r->rot);
485 }
486
487
488 static void
489 oputc(r) /* print local coordinates */
490 RAY *r;
491 {
492 (*putreal)(r->uv[0]);
493 (*putreal)(r->uv[1]);
494 }
495
496
497 static void
498 oputp(r) /* print point */
499 RAY *r;
500 {
501 if (r->rot < FHUGE) {
502 (*putreal)(r->rop[0]);
503 (*putreal)(r->rop[1]);
504 (*putreal)(r->rop[2]);
505 } else {
506 (*putreal)(0.0);
507 (*putreal)(0.0);
508 (*putreal)(0.0);
509 }
510 }
511
512
513 static void
514 oputN(r) /* print unperturbed normal */
515 RAY *r;
516 {
517 if (r->rot < FHUGE) {
518 (*putreal)(r->ron[0]);
519 (*putreal)(r->ron[1]);
520 (*putreal)(r->ron[2]);
521 } else {
522 (*putreal)(0.0);
523 (*putreal)(0.0);
524 (*putreal)(0.0);
525 }
526 }
527
528
529 static void
530 oputn(r) /* print perturbed normal */
531 RAY *r;
532 {
533 FVECT pnorm;
534
535 if (r->rot >= FHUGE) {
536 (*putreal)(0.0);
537 (*putreal)(0.0);
538 (*putreal)(0.0);
539 return;
540 }
541 raynormal(pnorm, r);
542 (*putreal)(pnorm[0]);
543 (*putreal)(pnorm[1]);
544 (*putreal)(pnorm[2]);
545 }
546
547
548 static void
549 oputs(r) /* print name */
550 RAY *r;
551 {
552 if (r->ro != NULL)
553 fputs(r->ro->oname, stdout);
554 else
555 putchar('*');
556 putchar('\t');
557 }
558
559
560 static void
561 oputw(r) /* print weight */
562 RAY *r;
563 {
564 (*putreal)(r->rweight);
565 }
566
567
568 static void
569 oputm(r) /* print modifier */
570 RAY *r;
571 {
572 if (r->ro != NULL)
573 if (r->ro->omod != OVOID)
574 fputs(objptr(r->ro->omod)->oname, stdout);
575 else
576 fputs(VOIDID, stdout);
577 else
578 putchar('*');
579 putchar('\t');
580 }
581
582
583 static void
584 puta(v) /* print ascii value */
585 double v;
586 {
587 printf("%e\t", v);
588 }
589
590
591 static void
592 putd(v) /* print binary double */
593 double v;
594 {
595 fwrite((char *)&v, sizeof(v), 1, stdout);
596 }
597
598
599 static void
600 putf(v) /* print binary float */
601 double v;
602 {
603 float f = v;
604
605 fwrite((char *)&f, sizeof(f), 1, stdout);
606 }
