root/radiance/ray/src/rt/rtrace.c
Revision: 1.16
Committed: Mon Jun 24 16:16:54 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.15: +1 -0 lines
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rtrace.c - program and variables for individual ray tracing.
9 *
10 * 6/11/86
11 */
12
13 /*
14 * Input is in the form:
15 *
16 * xorg yorg zorg xdir ydir zdir
17 *
18 * The direction need not be normalized. Output is flexible.
19 * If the direction vector is (0,0,0), then the output is flushed.
20 * All values default to ascii representation of real
21 * numbers. Binary representations can be selected
22 * with '-ff' for float or '-fd' for double. By default,
23 * radiance is computed. The '-i' or '-I' options indicate that
24 * irradiance values are desired.
25 */
26
27 #include "ray.h"
28
29 #include "octree.h"
30
31 #include "otypes.h"
32
33 int dimlist[MAXDIM]; /* sampling dimensions */
34 int ndims = 0; /* number of sampling dimensions */
35 int samplendx = 0; /* index for this sample */
36
37 int imm_irrad = 0; /* compute immediate irradiance? */
38
39 int inform = 'a'; /* input format */
40 int outform = 'a'; /* output format */
41 char *outvals = "v"; /* output specification */
42
43 int hresolu = 0; /* horizontal (scan) size */
44 int vresolu = 0; /* vertical resolution */
45
46 double dstrsrc = 0.0; /* square source distribution */
47 double shadthresh = .05; /* shadow threshold */
48 double shadcert = .5; /* shadow certainty */
49 int directrelay = 0; /* number of source relays */
50 int vspretest = 128; /* virtual source pretest density */
51
52 int maxdepth = 6; /* maximum recursion depth */
53 double minweight = 4e-3; /* minimum ray weight */
54
55 COLOR ambval = BLKCOLOR; /* ambient value */
56 double ambacc = 0.2; /* ambient accuracy */
57 int ambres = 32; /* ambient resolution */
58 int ambdiv = 128; /* ambient divisions */
59 int ambssamp = 0; /* ambient super-samples */
60 int ambounce = 0; /* ambient bounces */
61 char *amblist[128]; /* ambient include/exclude list */
62 int ambincl = -1; /* include == 1, exclude == 0 */
63
64 extern OBJREC Lamb; /* a Lambertian surface */
65
66 static RAY thisray; /* for our convenience */
67
68 static int oputo(), oputd(), oputv(), oputl(),
69 oputp(), oputn(), oputs(), oputw(), oputm();
70
71 static int (*ray_out[10])(), (*every_out[10])();
72 static int castonly;
73
74 static int puta(), putf(), putd();
75
76 static int (*putreal)();
77
78
79 quit(code) /* quit program */
80 int code;
81 {
82 exit(code);
83 }
84
85
86 rtrace(fname) /* trace rays from file */
87 char *fname;
88 {
89 long vcount = hresolu>1 ? hresolu*vresolu : vresolu;
90 long nextflush = hresolu;
91 FILE *fp;
92 FVECT orig, direc;
93 /* set up input */
94 if (fname == NULL)
95 fp = stdin;
96 else if ((fp = fopen(fname, "r")) == NULL) {
97 sprintf(errmsg, "cannot open input file \"%s\"", fname);
98 error(SYSTEM, errmsg);
99 }
100 /* set up output */
101 setoutput(outvals);
102 switch (outform) {
103 case 'a': putreal = puta; break;
104 case 'f': putreal = putf; break;
105 case 'd': putreal = putd; break;
106 }
107 /* process file */
108 while (getvec(orig, inform, fp) == 0 &&
109 getvec(direc, inform, fp) == 0) {
110
111 if (normalize(direc) == 0.0) { /* zero ==> flush */
112 fflush(stdout);
113 continue;
114 }
115 samplendx++;
116 /* compute and print */
117 if (imm_irrad)
118 irrad(orig, direc);
119 else
120 traceray(orig, direc);
121 /* flush if time */
122 if (--nextflush == 0) {
123 fflush(stdout);
124 nextflush = hresolu;
125 }
126 if (ferror(stdout))
127 error(SYSTEM, "write error");
128 if (--vcount == 0) /* check for end */
129 break;
130 }
131 if (vcount > 0)
132 error(USER, "read error");
133 fclose(fp);
134 }
135
136
137 setoutput(vs) /* set up output tables */
138 register char *vs;
139 {
140 extern int ourtrace(), (*trace)();
141 register int (**table)() = ray_out;
142
143 castonly = 1;
144 while (*vs)
145 switch (*vs++) {
146 case 't': /* trace */
147 *table = NULL;
148 table = every_out;
149 trace = ourtrace;
150 castonly = 0;
151 break;
152 case 'o': /* origin */
153 *table++ = oputo;
154 break;
155 case 'd': /* direction */
156 *table++ = oputd;
157 break;
158 case 'v': /* value */
159 *table++ = oputv;
160 castonly = 0;
161 break;
162 case 'l': /* length */
163 *table++ = oputl;
164 castonly = 0;
165 break;
166 case 'p': /* point */
167 *table++ = oputp;
168 break;
169 case 'n': /* normal */
170 *table++ = oputn;
171 break;
172 case 's': /* surface */
173 *table++ = oputs;
174 break;
175 case 'w': /* weight */
176 *table++ = oputw;
177 break;
178 case 'm': /* modifier */
179 *table++ = oputm;
180 break;
181 }
182 *table = NULL;
183 }
184
185
186 traceray(org, dir) /* compute and print ray value(s) */
187 FVECT org, dir;
188 {
189 register int (**tp)();
190
191 VCOPY(thisray.rorg, org);
192 VCOPY(thisray.rdir, dir);
193 rayorigin(&thisray, NULL, PRIMARY, 1.0);
194 if (castonly)
195 localhit(&thisray, &thescene) || sourcehit(&thisray);
196 else
197 rayvalue(&thisray);
198
199 if (ray_out[0] == NULL)
200 return;
201 for (tp = ray_out; *tp != NULL; tp++)
202 (**tp)(&thisray);
203 if (outform == 'a')
204 putchar('\n');
205 }
206
207
208 irrad(org, dir) /* compute immediate irradiance value */
209 FVECT org, dir;
210 {
211 register int i;
212
213 for (i = 0; i < 3; i++) {
214 thisray.rorg[i] = org[i] + dir[i];
215 thisray.rdir[i] = -dir[i];
216 }
217 rayorigin(&thisray, NULL, PRIMARY, 1.0);
218 /* pretend we hit surface */
219 thisray.rot = 1.0;
220 thisray.rod = 1.0;
221 VCOPY(thisray.ron, dir);
222 for (i = 0; i < 3; i++) /* fudge factor */
223 thisray.rop[i] = org[i] + 1e-4*dir[i];
224 /* compute and print */
225 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
226 oputv(&thisray);
227 if (outform == 'a')
228 putchar('\n');
229 }
230
231
232 getvec(vec, fmt, fp) /* get a vector from fp */
233 register FVECT vec;
234 int fmt;
235 FILE *fp;
236 {
237 static float vf[3];
238
239 switch (fmt) {
240 case 'a': /* ascii */
241 if (fscanf(fp, "%lf %lf %lf", vec, vec+1, vec+2) != 3)
242 return(-1);
243 break;
244 case 'f': /* binary float */
245 if (fread((char *)vf, sizeof(float), 3, fp) != 3)
246 return(-1);
247 vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2];
248 break;
249 case 'd': /* binary double */
250 if (fread((char *)vec, sizeof(double), 3, fp) != 3)
251 return(-1);
252 break;
253 }
254 return(0);
255 }
256
257
258 static
259 ourtrace(r) /* print ray values */
260 RAY *r;
261 {
262 register int (**tp)();
263
264 if (every_out[0] == NULL)
265 return;
266 tabin(r);
267 for (tp = every_out; *tp != NULL; tp++)
268 (**tp)(r);
269 putchar('\n');
270 }
271
272
273 static
274 tabin(r) /* tab in appropriate amount */
275 RAY *r;
276 {
277 register RAY *rp;
278
279 for (rp = r->parent; rp != NULL; rp = rp->parent)
280 putchar('\t');
281 }
282
283
284 static
285 oputo(r) /* print origin */
286 register RAY *r;
287 {
288 (*putreal)(r->rorg[0]);
289 (*putreal)(r->rorg[1]);
290 (*putreal)(r->rorg[2]);
291 }
292
293
294 static
295 oputd(r) /* print direction */
296 register RAY *r;
297 {
298 (*putreal)(r->rdir[0]);
299 (*putreal)(r->rdir[1]);
300 (*putreal)(r->rdir[2]);
301 }
302
303
304 static
305 oputv(r) /* print value */
306 register RAY *r;
307 {
308 (*putreal)(colval(r->rcol,RED));
309 (*putreal)(colval(r->rcol,GRN));
310 (*putreal)(colval(r->rcol,BLU));
311 }
312
313
314 static
315 oputl(r) /* print length */
316 register RAY *r;
317 {
318 (*putreal)(r->rt);
319 }
320
321
322 static
323 oputp(r) /* print point */
324 register RAY *r;
325 {
326 if (r->rot < FHUGE) {
327 (*putreal)(r->rop[0]);
328 (*putreal)(r->rop[1]);
329 (*putreal)(r->rop[2]);
330 } else {
331 (*putreal)(0.0);
332 (*putreal)(0.0);
333 (*putreal)(0.0);
334 }
335 }
336
337
338 static
339 oputn(r) /* print normal */
340 register RAY *r;
341 {
342 if (r->rot < FHUGE) {
343 (*putreal)(r->ron[0]);
344 (*putreal)(r->ron[1]);
345 (*putreal)(r->ron[2]);
346 } else {
347 (*putreal)(0.0);
348 (*putreal)(0.0);
349 (*putreal)(0.0);
350 }
351 }
352
353
354 static
355 oputs(r) /* print name */
356 register RAY *r;
357 {
358 if (r->ro != NULL)
359 fputs(r->ro->oname, stdout);
360 else
361 putchar('*');
362 putchar('\t');
363 }
364
365
366 static
367 oputw(r) /* print weight */
368 register RAY *r;
369 {
370 (*putreal)(r->rweight);
371 }
372
373
374 static
375 oputm(r) /* print modifier */
376 register RAY *r;
377 {
378 if (r->ro != NULL)
379 fputs(objptr(r->ro->omod)->oname, stdout);
380 else
381 putchar('*');
382 putchar('\t');
383 }
384
385
386 static
387 puta(v) /* print ascii value */
388 double v;
389 {
390 printf("%e\t", v);
391 }
392
393
394 static
395 putd(v) /* print binary double */
396 double v;
397 {
398 fwrite((char *)&v, sizeof(v), 1, stdout);
399 }
400
401
402 static
403 putf(v) /* print binary float */
404 double v;
405 {
406 float f = v;
407
408 fwrite((char *)&f, sizeof(f), 1, stdout);
409 }
